Nebkas : Control LED by CPU temperature
Hi folks!
Today I wrote a simple script for showing the CPU temperature by using the green LED
0-39° = LED OFF 40-49°C = LED heartbeat over 50°C = LED on
You need the “lm-sensors” package(apt-get install lm-sensors)
greetz
Nebkas
 #!/bin/zsh
 while
 do
 temp=$( sensors | grep temp | cut -c16-17 )
 clear
 if [ $temp -le 39 ]
 then
     echo -e "Aktuelle Temperatur: " "\e[32m$temp" "\e[0m°C"
         echo none > /sys/class/leds/green\:ph24\:led1/trigger
 elif [ $temp -le 49 ]
 then
     echo "Aktuelle Temperatur: " "\e[33m$temp" "\e[0m°C"
         echo heartbeat > /sys/class/leds/green\:ph24\:led1/trigger
 else
     echo "Aktuelle Temperatur: " "\e[31m$temp" "\e[0m°C"
         echo default-on > /sys/class/leds/green\:ph24\:led1/trigger
 fi
 sleep 1
 done
link: http://www.lemaker.org/thread-22441-1-1.html
