Mt7615 wifi driver testing
R2 VHT80
interface=wlp1s0
driver=nl80211
ssid=126test
hw_mode=a
channel=36
ieee80211n=1
ieee80211ac=1
require_ht=1
require_vht=1
vht_capab=[SHORT-GI-80][RXLDPC]
ht_capab=[HT40+][SHORT-GI-20][SHORT-GI-40][LDPC]
vht_oper_chwidth=1
vht_oper_centr_freq_seg0_idx=42
country_code=US
%E6%93%B7%E5%8F%96
minstrel rate control rc_stat image
20190303 update
vht80 2*nss
%E6%93%B7%E5%8F%96
IxChariot test:
Bidirectional: image001
RX: image002
TX (need to fix drop issue): image003
I’ve posted the v1 to mainline. The driver fully supports AP, station and monitor mode. https://patchwork.kernel.org/project/linux-mediatek/list/?series=97035 https://patchwork.kernel.org/project/linux-mediatek/list/?series=97041
The host driver has been applied to mainline.
Also add support for mtd eeprom parsing - https://patchwork.kernel.org/patch/10947385/
i test that driver, and when encryption is enabled, the speed drops almost 10 times
Thanks. will fix it.
Ryder Lee posted a fix: https://patchwork.kernel.org/patch/10970253/
Maybe you need part 1/2 too
MT7615 module have support BPI-R2, BPI-R64, and We have tested the parametric performance of module 7615 in the laboratory.To achieve the optimal
BPI-R64+MT7615 test wifi function with openwrt
http://wiki.banana-pi.org/BPI-R64_%2B_MT7615_function_test
I have been successful in using the SD card version of the img file to boot into a working system. I would like to use the EMMC.img version and have the router boot and function out of emmc. Can you guide me how to flash the EMMC.img version? I tried using the following options in u-boot menu:
    1. System Load Linux Kernel then write to Flash via TFTP and
  • b. System Load flashimage then write to Flash via TFTP.
The TFTP transfer was successful, but got errors.
In case of “System Load Linux Kernel”, I got
Bytes transferred = 20191432 (13418c8 hex)
get filesize 0x13418c8
[do_filesize_check] partition_size: 0x1e00000 , filesize: 0x13418c8
[do_read_image_blks] Image format error,neither FIT image nor old image.
Bad Magic Number.
mmc0 is current device
mmc0 operation
dev_num = 0
MMC write: dev # 0, block # 4096, count 98304 ... 98304 blocks write: OK
mmc0 operation
dev_num = 0
MMC read: dev # 0, block # 4096, count 1 ... 1 blocks read: OK
Bad Magic Number.
mmc0 operation
dev_num = 0
MMC read: dev # 0, block # 4096, count 0 ... 0 blocks read: OK
bootm flag=0, states=70f
Wrong Image Format for bootm command
ERROR: can't get kernel image!
In case of “Load flashimage”, I got
[do_filesize_check] partition_size: 0x1400000 , filesize: 0x13418c8
mmc0 operation
dev_num = 0
MMC write: dev # 0, block # 0, count 40960 ... 40960 blocks write: OK
dev_num = 0
Writing to MMC(0)... offset=1310720
size=4096
mmc->write_bl_len=512
done
invaild env!!!
Thanks
