Mount root file system on USB drive on M3
Hello,
I could not change the boot parameters on any of the 3 Linux images provided … For Debian and Rasbian i cannot even find the boot parameters… the boot partition is empty.
Anyonw managed to move the root file system on a HDD on the M3 ?
thanks, Vlad.
HI vlad, Did you succeed running debian, raspbian or ubuntu on BPI M3 without error? I read on this forums that sinovoip all OS (excep android) provided are corrupted and i tried it. Only android are running smoothly. Still waiting for their final release.
Since my M3 seems to arrive today I just tried it again with the Ubuntu 15.04 image: They didn’t exchange the file on Google Drive so still corrupted:
macbookpro-tk:~ tk$ unzip -l /Users/tk/Downloads/BPI-M3_ubuntu_15.04_hdmi.img.zip
Archive:  /Users/tk/Downloads/BPI-M3_ubuntu_15.04_hdmi.img.zip
warning [/Users/tk/Downloads/BPI-M3_ubuntu_15.04_hdmi.img.zip]:  76 extra bytes at beginning or within zipfile
  (attempting to process anyway)
error [/Users/tk/Downloads/BPI-M3_ubuntu_15.04_hdmi.img.zip]:  reported length of central directory is
  -76 bytes too long (Atari STZip zipfile?  J.H.Holm ZIPSPLIT 1.1
  zipfile?).  Compensating...
  Length     Date   Time    Name
4294967295  09-24-15 07:22   BPI-M3_ubuntu_15.04_hdmi.img
4294967295                   1 file
note:  didn't find end-of-central-dir signature at end of central dir.
It’s unbelievable that this is all done by a ‘company’ and not a bunch of first graders…
Very disappointed, SinoVoip company build this forum & continuing sell BPI-M3 but they not response to all clients complaints, All OS are broken please fix these problem.
I could deploy all 3 inages. I used 7zip on windows to extract and win32imager to write the image.
But as i said the image runs but impossible to change parameters on kernel. Also is quite dirty a lot of remainings from m1 and m2
I don’t think so, AFAIK @projectbananapi built this forum that is currently called official.
You extracted corrupted ZIP files to create disk images you use now. Not the best approach :smile:
Since they have no clue about software at all they simply used the BSP they got from Allwinner. Then they did nothing a few months. Now they ship the devices and now they start to realise that somethings’s wrong, eg.
And so on. You can’t expect that the OS images are working :joy:
So be prepared to use an Ubuntu installation, clone the BSP with their most recent fixes and compile BSP/kernel yourself. That’s also the only way to alter hardware initialisation by adjusting sys_config.fex files here: https://github.com/BPI-SINOVOIP/BPI-M3-bsp/tree/master/sunxi-pack/chips/sun8iw6p1/configs
They refrain from using a more recent u-boot version that would make use of script.bin so you really have to setup a build environment to change such trivial stuff like display initialisation. You should be able to adjust kernel parameters by using uEnv.txt, at least these kernel parameters are set correctly:
I have searched a lot on the Internet how to mount the root file system on the USB drive, but, found no result, but macbook pro won’t turn on helped me a lot in this regarding that provided the entire guidance on this.
