Missing NICs eth2-eth4?
my network support 1Gbps/Full. it is funny the main NIC is 1G but not the lan NIC whic are detected in 10/Full and 100/Full.
# ethtool eth0
Settings for eth0:
	Supported ports: [ TP MII ]
	Supported link modes:   1000baseT/Half 1000baseT/Full
	Advertised link modes:  1000baseT/Half 1000baseT/Full
	Link partner advertised link modes:  1000baseT/Full
	Link partner advertised pause frame use: Symmetric
	Link partner advertised auto-negotiation: No
	Speed: 1000Mb/s
	Duplex: Full
	Port: MII
	PHYAD: 0
	Transceiver: internal
	Auto-negotiation: on
	Link detected: yes
lan0
# # ethtool lan0
Settings for lan0:
	Supported ports: [ TP AUI BNC MII FIBRE ]
	Supported link modes:   10baseT/Half 10baseT/Full
	                        100baseT/Half 100baseT/Full
	                        1000baseT/Full
	Advertised link modes:  10baseT/Half 10baseT/Full
	                        1000baseT/Full
	Advertised pause frame use: No
	Link partner advertised link modes:  10baseT/Half
	Link partner advertised pause frame use: No
	Speed: 10Mb/s
	Duplex: Half
	Port: MII
	PHYAD: 1
	Supports Wake-on: d
	Wake-on: d
	Link detected: yes
lan3
# ethtool lan3
Settings for lan3:
	                        1000baseT/Full
	                        1000baseT/Full
	Link partner advertised link modes:  10baseT/Half 10baseT/Full
	Speed: 100Mb/s
	Duplex: Full
	Port: MII
	PHYAD: 4
	Supports Wake-on: d
	Wake-on: d
	Link detected: yes
eth0 (=cpu-port) is afaik fixed to 1GBs in dts(i)
lan0-4 have variable bandwidth (Auto-Neg/OS-Setting), you see in your ethtool, that 1G is also supported:
                        1000baseT/Full
                        1000baseT/Full
i don’t known why a fallback speed is used, on my switch 1G is used on lan0
as you see
your switch on the other end supports only 10/100Mbit (handled over auto-neg) :wink: or maybe cable, etc…
OK will check might be on my side. The good news with your kernel i can see all 5 NICs, so thanks.
it’s not my work…the dsa-support was working before in 4.14…
ok excuse my limited knowledge… whats the link to your 4.14 kernel from github and how exactly do you copy over the old kernel?
first things first i guess where is your github link and ill try to google the how to
You’ll find all info in my wiki
Installation: https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:kernel#compiled_414x
I mainly use build.sh to copy kernel to sdcard because i can define name of binary in boot and this makes backup of existing kernel.
If you want to use different names you have to make sure that your new kernel gets loaded by set kernel var to name of your Kernel-binary. If you use my last uboot there are multiple kernel-vars and you can define own menu-entries (needs reload bootmenu before they appear).
Github-link is also on this page
Forgive my poor knowledge, the port isolation works for PHY to switch lines and thus all lan-ports are considered to carry information on NIC eth0. If this is true, does the CPU differentiate which lan port is sending the information and how does it do that?
PS- I wish to implement OVS on R2 but the port isolation does not work to parse and redirect traffic from each of the lan ports
Frank,
         I have your buster build and have all of the Ethernet interfaces working out of the box. The wireless connection I can't seem to get it working at all. It isn't represented when doing the "ip a" command. How do I get the wireless up and operational?
Thanks again for all your help!
-Brian-
You have to create ap0-device with wmt-tools. See my wiki or any of the wifi-threads
https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:wlan#internal
Basicly you need wmt-tools (you’ll find binaries in src-folder - without ext):
config and maybe my wifi.sh
there is a package in my wiki, github releases and my gdrive containing neceasary files
