Mellanox connectX-3 via pcie
I want to test connectX-3 in infiniband type. Got src from frankie repo from github, made menuconfig, added support in kernel and compile. Copied new image to SD, but it does not work… Connectied via minipcie -> pcie x16 expander. lspci and lshw showed only pci controller. Modules for connectX-3 modprobed success. Any help?
I tested 2 expander-cables (pcie-only) and they don’t work…don’t know why. Tested with mt7612 which works when directly inserted into pcie-slot,but not with expander-cable
I am interested, expander is other type and working, or other board works with pcie better?
IIRC M4 has M.2 PCIEx port while R2 has miniPCIEx - so expanders are different for sure.
Upd. Beware of this findings:
May be bacause some pins for pcie and usb 3.0…
https://bananapi.gitbooks.io/banana-pi-bpi-r2-open-source-smart-router/content/bpi-r2-usb-30-interface.html
https://bananapi.gitbooks.io/banana-pi-bpi-r2-open-source-smart-router/content/bpi-r2-pcie-interface.html
