Magia, debian or ubuntu?
Is there a “.deb” for the newer main-kernels ?
All newer kernels from main branches ha a deb on releases-page…but 4.14 has most features
First, for others user, 2 remarks
I had a error in my fstab… /dev was written /deb :frowning: Now, its good with the auto mount.
Now, my dhcp is in wan. In the beginning of /etc/network/interfaces, I have put :
auto eth1
iface eth1 inet manual
  pre-up ip link set $IFACE up
auto wan
allow-hotplug wan
  iface wan inet dhcp
  pre-up ip link set $IFACE address 32:D1:55:7D:03:39 up
Now my problems or questions
I have a problem with your wifi.sh :
root@bpi-r2:/var/log# sh /etc/init.d/wifi.sh
/etc/init.d/wifi.sh: 19: /etc/init.d/wifi.sh: [[: not found
/etc/init.d/wifi.sh: 44: /etc/init.d/wifi.sh: [[: not found
Error, wifi device no created, /dev/wmtWifi
Device "ap0" does not exist.
/etc/init.d/wifi.sh: 61: /etc/init.d/wifi.sh: [[: not found
Done, all good, ready to lauch hostapd
And I can’t have the ap0 with the kernel 4.14.79-bpi-r2-main :
root@bpi-r2:~# wmt_loader
init combo device
Opened combo device
get device id : 30243
set device id : 30243
Message from syslogd@bpi-r2 at Nov 14 08:06:07 ...
 kernel:[  511.249768] Internal error: Oops: 17 [#1] SMP ARM
 kernel:[  511.339170] Process wmt_loader (pid: 680, stack limit = 0xdda42218)
 kernel:[  511.345392] Stack: (0xdda43e08 to 0xdda44000)
 kernel:[  511.349720] 3e00:                   c017ff1c c05b2aa0 dda43e34 dda43e20 c05b2aac c048cd98
 kernel:[  511.357845] 3e20: c117b0b4 00000000 dda43e4c dda43e38 c05f54b4 c05b2a84 c1276f44 c12774c8
 kernel:[  511.365970] 3e40: dda43e74 dda43e50 c05d60a0 c05f5438 ffffffff c1276f44 dda43eac c1276f44
 kernel:[  511.374095] 3e60: c12774c8 0be00000 dda43eac dda43e78 c05f221c c05d607c c0d8b090 dda43e88
 kernel:[  511.382220] 3e80: c017ff1c c117b158 00007623 00007623 00000003 00007623 dda42000 00000036
 kernel:[  511.390344] 3ea0: dda43ed4 dda43eb0 c05f9664 c05f1fdc 80047704 00007623 dda43edc c117b154
 kernel:[  511.398469] 3ec0: 00007623 00007623 dda43eec dda43ed8 c05f94b4 c05f95f8 c117b154 80047704
 kernel:[  511.406594] 3ee0: dda43f0c dda43ef0 c05f890c c05f94a4 00007623 defd6510 ddd683c0 00000003
 kernel:[  511.414719] 3f00: dda43f7c dda43f10 c02b1bcc c05f87c8 dda43f74 c029e8ac c0abe4dc 00000017
 kernel:[  511.422844] 3f20: ddcf1780 00000000 dd39e450 00000002 ddcf1788 00000004 dda43f74 dda43f48
 kernel:[  511.430969] 3f40: c029e968 c02e647c 00000000 00000000 ddcf1780 ddd683c0 00000003 ddd683c0
 kernel:[  511.439093] 3f60: 80047704 00007623 dda42000 00000036 dda43fa4 dda43f80 c02b248c c02b1b28
 kernel:[  511.447217] 3f80: bedf8c78 00000000 00000000 00000036 c0108ec4 dda42000 00000000 dda43fa8
 kernel:[  511.455342] 3fa0: c0108cc0 c02b2454 bedf8c78 00000000 00000003 80047704 00007623 00000000
 kernel:[  511.463467] 3fc0: bedf8c78 00000000 00000000 00000036 00000000 00000000 b6f5b000 00000000
 kernel:[  511.471591] 3fe0: 00011010 bedf8c3c 000085b3 b6ed4716 20080030 00000003 00000000 00000000
 kernel:[  511.567057] Code: e3530c01 0a00000a e3520c02 0a000013 (e5922000)
Segmentation fault
I see cat /boot/_uEnv.txt, why bananapi/bpi-m64/ ? In the bpi-r2 there is only bananapi/bpi-r2/linux with the kernel
root@bpi-r2:~# cat /boot/_uEnv.txt
console=tty0 console=ttyS0,115200n8 no_console_suspend board=bpi-m64
#fdt_filename=bananapi/bpi-m64/linux/a64-2GB.dtb
fdt_filename=bananapi/bpi-m64/linux/a64-2GB-sd.dtb
kernel_filename=bananapi/bpi-m64/linux/Image
initrd_filename=bananapi/bpi-m64/linux/initrd.img
ethaddr=36:c9:e3:f1:b8:05
optargs=disp.screen0_output_mode=720p60
root=/dev/mmcblk0p2
init=/sbin/init
Have you copied all for wifu (also conf and firmware)?
Looks like official image…these contain kernels for all their boards
I think that’s I have do all. But here, I have not my bpi-r2. I can nothing try.
Do you know this : https://www.armbian.com/bananapi-r2/ It’s a debian to ?
I have seen that there is work on armbian…imho it’s a modified debian. But i’m staying on basic debian.
If wmt-config is not on place driver crashes. In wifi_patching i had fixed this,but also moved init to automatic which actually does npt work
The question is : What I need ?
I nead a version with apache, mysql, ssh for a server.
I nead a version with a firewall, a DHCP server, a hostapd server
I like have a screen for work on my network config
Basicly on ubuntu and debian you can install all including router-specific and xserver. Here you need a kernel with hdmi-support like my 4.14.
Openwrt/lede are only router-os not designes for a Workstation-usage. Here imho you can’t install xserver.
Armbian i don’t know of it supports hdmi,but at least with kernel 4.19,i expect not because i’m still working on hdmi-suppprt for 4.19.
The .deb found here https://github.com/frank-w/BPI-R2-4.14/releases/tag/CI-BUILD-20181105194538-7d3facdb15cd support the HDMI ? I don’t need the X server. Only a terminal and This kernel have HDMI. I try but :
  1. It doesn’t work with my old TV, I use a old VGA wirh adaptator The TV say 1080p. I have write it in /boot/_uEnv.txt
    optargs=disp.screen0_output_mode=1080p
Nothing…
  1. My 2 keybord don’y work. Whenn I press azer, /var/log/debug have :
     root@bpi-r2:~# tail -f /var/log/debug Nov 14 18:24:15 bpi-r2 kernel: [  469.968370] evbug: Event. Dev: input2, Type: 4, Code: 4, Value: 458772
     Nov 14 18:24:15 bpi-r2 kernel: [  469.975026] evbug: Event. Dev: input2, Type: 1, Code: 16, Value: 1
     Nov 14 18:24:15 bpi-r2 kernel: [  469.975030] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
     Nov 14 18:24:15 bpi-r2 kernel: [  470.048345] evbug: Event. Dev: input2, Type: 4, Code: 4, Value: 458772
     Nov 14 18:24:15 bpi-r2 kernel: [  470.054984] evbug: Event. Dev: input2, Type: 1, Code: 16, Value: 0
     Nov 14 18:24:15 bpi-r2 kernel: [  470.061260] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
     Nov 14 18:24:15 bpi-r2 kernel: [  470.256343] evbug: Event. Dev: input2, Type: 4, Code: 4, Value: 458778
     Nov 14 18:24:15 bpi-r2 kernel: [  470.262990] evbug: Event. Dev: input2, Type: 1, Code: 17, Value: 1
     Nov 14 18:24:15 bpi-r2 kernel: [  470.262994] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
     Nov 14 18:24:15 bpi-r2 kernel: [  470.352335] evbug: Event. Dev: input2, Type: 4, Code: 4, Value: 458778
     Nov 14 18:24:15 bpi-r2 kernel: [  470.358973] evbug: Event. Dev: input2, Type: 1, Code: 17, Value: 0
     Nov 14 18:24:15 bpi-r2 kernel: [  470.365249] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
     Nov 14 18:24:16 bpi-r2 kernel: [  470.584349] evbug: Event. Dev: input2, Type: 4, Code: 4, Value: 458760
     Nov 14 18:24:16 bpi-r2 kernel: [  470.590994] evbug: Event. Dev: input2, Type: 1, Code: 18, Value: 1
     Nov 14 18:24:16 bpi-r2 kernel: [  470.590998] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
     Nov 14 18:24:16 bpi-r2 kernel: [  470.688335] evbug: Event. Dev: input2, Type: 4, Code: 4, Value: 458760
     Nov 14 18:24:16 bpi-r2 kernel: [  470.694975] evbug: Event. Dev: input2, Type: 1, Code: 18, Value: 0
     Nov 14 18:24:16 bpi-r2 kernel: [  470.701252] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
     Nov 14 18:24:16 bpi-r2 kernel: [  470.880338] evbug: Event. Dev: input2, Type: 4, Code: 4, Value: 458773
     Nov 14 18:24:16 bpi-r2 kernel: [  470.886985] evbug: Event. Dev: input2, Type: 1, Code: 19, Value: 1
     Nov 14 18:24:16 bpi-r2 kernel: [  470.886988] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
     Nov 14 18:24:16 bpi-r2 kernel: [  470.968334] evbug: Event. Dev: input2, Type: 4, Code: 4, Value: 458773
     Nov 14 18:24:16 bpi-r2 kernel: [  470.974972] evbug: Event. Dev: input2, Type: 1, Code: 19, Value: 0
     Nov 14 18:24:16 bpi-r2 kernel: [  470.981249] evbug: Event. Dev: input2, Type: 0, Code: 0, Value: 0
I wait for a new SD-Card and I test it.
1: you need to use /boot/bananapi/bpi-r2/linux/uEnv.txt, option should be
video=1920x1080
in your bootargs
  1. regarding evbug-messages try to remove module (should be module in your kernel):
    modprobe -r evbug
to make it permanent create/add /etc/modprobe.d/evbug.conf
blacklist evbug
and reboot
Now, I have xfce4 and iceWM in my BPI_R2 :sunny: with your debian. But, tty1 I can’t have a french keybord. It’s no easy for my login…
I have try :
dpkg-reconfigure console-data
dpkg-reconfigure locales
There is not loadkeys
reboot works als halt
I don’t know why, but if I don’t do Ctrl-D, the boot is stoping.
You have console on screen connected via hdmi?
Try
sudo dpkg-reconfigure keyboard-configuration
You are still on 4.14.79? Reboot works maybe anything prevents your system to reboot…again logs will be helpful
I have a console on screen connected via hdmi. And I have xfce via hdmi. I have do :
My keyboard remains in qwerty with the console on screen connected via hdmi.
Xserver does not use console keymap and have to be set separately
Try
setxkbmap fr
Maybe with sudo
I don’t nead sudo because I work directly as root. With the X server, I don’t have problem, my keybord is in azerty.
I don’t understand why the boot ask my the root password for maintenance. I do Ctrl-D and after is good. I see only :
root@bpi-r2:~# dmesg | grep urandom
[    7.770219] random: systemd: uninitialized urandom read (16 bytes read)
[    7.788304] random: systemd: uninitialized urandom read (16 bytes read)
[    7.944583] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[  117.527589] random: 7 urandom warning(s) missed due to ratelimiting
root@bpi-r2:~# dmesg | grep fail
[    4.575917] mdio_bus fixed-0: lookup for GPIO reset failed
[    4.673641] mdio_bus mdio-bus: lookup for GPIO reset failed
[    5.128215] mtk-msdc 11240000.mmc: lookup for GPIO wp failed
[    5.238003] mtk-msdc 11230000.mmc: lookup for GPIO wp failed
[    6.128755] mdio_bus dsa-0.0: lookup for GPIO reset failed
I think that now I do a new card with your debian. I don’t remeber what I have do for my 2 problem :
  1. can not boot with no Ctrl-D
  2. wmt_loader don’t work
I have try the armbian :
  1. No HDMI
  2. dd use all the sd-card
here we need full dmesg
Just call my wifi.sh with bash or without sh…imho it lies in /root so do only ~/wifi.sh
I have a new install of your debian.
I can’t have a french keybord in tty. I have ask a question here : https://www.developpez.net/forums/d1913621/systemes/linux/distributions/debian/clavier-francais-console-tty/#post10600277
I have other problem with the old screen (new my sohn use the new with his computer in mageia 6). When I boot, I don’t have screen. But I can make a ssh. I have do a reboot and I have see the message in the screen while the reboot. Nothing after… No Ctrl-Alt-F1 .With a ssh, I do
systemctl restart lightdm
And lightdm work and I can do Ctrl-Alt-F1 to go in tty1 (in qwerty :cold_sweat: )
For the keybord, I install kbd :
apt-get install kbd
And after a reboot, I have automatically the french keybord.
all problems fixed? did not understand your xserver-issue…note that hdmi-driver does not support a bunch of resolutions. try to set video to 1080x1920 in your uenv.txt (have to be appended to bootargs) and connect a screen which supports this resolution (a TV) to test if it’s a resolution-issue.
kernel 4.14 uses hdmi v1 which works best with 1080p, 4.19-rc1 supports hdmiv5 too, but 4.19 final has again problems with hdmi…it’s annoying me too ;(
I don’t understand my xserver-issue. I have not try the WiFi with this new sc-card.
Now, I am preparing an exam subject for my students.
