Magia, debian or ubuntu?
why now sdb and why #5? sdx1 is BPI-BOOT and sdx2 is BPI_ROOT if you add a sdx3 as data this is enough…have done it too
how do you created the partition and what does “does not work” mean?
sdb5 because mga make a extented partition. I have remove this partition and do sdb3, I have remove sdb3. My sd card don’t work… I make a new SD card.
i know no mageia-image for bpi-r2
try debian/ubuntu and create the data-partition with fdisk directly without touching partition 1 and 2…only add and it will not affect the system itself
Now, I try debian.
I have do a ping 192.168.1.10 1 time. But the ssh don’t work. I have try so many modifiy /etc/network/interfaces. Now I made
dd bs=1M if=deb_stretch_4.14.13_SD.img of=/dev/sdc   status=progress conv=fsync;sync
for have a new debian…
I don’t understand what is lna0, lan1, lan2, lan3 and eth0. Is not the same config als ubuntu.
if you look on ethernet-ports of r2, you see from left to right the interfaces (from left to right) wan,lan0,lan1,lan2,lan3
eth0 is connection from soc to switch and have no ip-config…only bring up…see my interfaces already in the image
I can’t do ssh with the debian. I do a ping, but no ssh :
  • 64 bytes from 192.168.1.10: icmp_seq=67 ttl=64 time=0.401 ms
  • 64 bytes from 192.168.1.10: icmp_seq=68 ttl=64 time=0.409 ms
  • 64 bytes from 192.168.1.10: icmp_seq=69 ttl=64 time=0.388 ms
  • ^C
  • — 192.168.1.10 ping statistics —
  • 69 packets transmitted, 29 received, +32 errors, 57% packet loss, time 69615ms
  • rtt min/avg/max/mdev = 0.281/106.340/2048.563/411.829 ms, pipe 4
  • [root@localhost pi]# ssh 192.168.1.10 -p22
  • ssh: connect to host 192.168.1.10 port 22: Connection refused
Is ssh-server running?
How can I it know ? It’s the BPI-R2 with debian and I have nothing for testing it if I can’t ssh do. The BPI-R2 have no HDMI output.
In /lib/systemd/system there is ssh.service. In /var/log I have nothing.
I see you have packet loss…check connection and try different cable
My image loads ssh…maybe you can’t login as root (permitrootlogin-setting),but you should get a user/pw-prompt
The packet lost are before the first ping is good. After this fisrt good ping all the ping are good. The ssh error say that’s it’s not a user problem.
You use deb_stretch_4.14.13_SD.img right? Have to try…i thought ssh was started
I have “deb_stretch_4.14.13_SD.img”.
I have try with different cable. Il think that’s I have a probleme with ethernet-ports. The ping don’t work with lan0. Il try all the internet port I try now the lan0 :it’s good. When it works, I always did this manipulation before. But, I never had a problem with ubuntu.
The “cp2102” is for open a console in the BPI-R2. It can help me for debugin ?
Right you can see whats going on,login as root and work on r2 directly without ssh
It’s named serial console or debug-uart
https://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:debug-uart
I just ordered the cp2102 to aliexpress. For a network connection, I have just done different tests. I just have to wait a long time. And after, it’s good.
  • 64 bytes from 192.168.1.10: icmp_seq=436 ttl=64 time=0.383 ms
  • ^C
  • 436 packets transmitted, 436 received, 0% packet loss, time 445479ms
  • rtt min/avg/max/mdev = 0.271/0.359/0.488/0.046 m
I miss the ssh.
as i said, i have to test it,
but before i write the image again to my card, i update kernels, uboot and system
I don’t have a ubuntu, but I can have a debian at my work. With mageia, I don’t have the same name for paquet or file. Have debian the same name as ubuntu ?
try disable mountpoints in /etc/fstab for emmc…seems that i had not deactivated them…bootprocess hangs there
# <file system>         <dir>           <type>  <options>               <dump> $
/dev/mmcblk0p2          /               ext4    errors=remount-ro       0      $
/dev/mmcblk0p1          /boot           vfat    defaults                0      $
#/dev/mmcblk1p2         /mnt/emmc/root          ext4    errors=remount-ro      $
#/dev/mmcblk1p1         /mnt/emmc/boot          vfat    defaults               $
what do you mean with “same name”?
Mageia have only gcc-arm-linux-gnu, mageia have not gcc-arm-linux-gnueabihf.
disable mountpoints in /etc/fstab for emmc is a good idea… I can ping faster :
 64 bytes from 192.168.1.10: icmp_seq=17 ttl=64 time=0.824 ms
before it was arround the “icmp_seq=100”…
And the ssh is good !
now the question is : Can I install the driver for the HDMI output ?
Thank’s !
You need a kernel with hdmi…
actual versions of 4.14 do have hdmi-support
There is only root user…
And the 4.18 kernel ?
