M3 WDT (watchdog timer)
Hello everyone, I wanted to know how well supported is the watchdog timer on the M3 ? I haven’t seen the module compile by default and since I do not have a x86 system, compiling the kernel is often challenging.
do you mean android???
android have WDT support.
Sorry I forgot to flag this properly, I am developing on linux, specifically on gentoo.
HI: you need re-build M3 kernel. CONFIG_WATCHDOG=m
Thank you,
So there is a hardware WDT in the chip itself ?
you can try it…
Step 1: sudo modprobe sunxi_wdt
Step 2: sudo apt-get install watchdog sudo service watchdog start
CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y CONFIG_WATCHDOG_NOWAYOUT=y CONFIG_SUNXI_WDT=m
What is the reason not to have enabled by default I guess? Preferably in the Linux OS want.
how to use WDT in Android?I use BPI-M2U
