M3 sound driver and module?
I will add sound to module file to Debian 8
What is the model of sound card?. I will play mp3 from headfone.
we test it now ,once ready ,will update all source code to github ,and let you konw
This is a lie as usual.
All the source code you got from the chip manufacturer is already on Github: https://github.com/BPI-SINOVOIP/BPI-M3-bsp/tree/master/linux-sunxi/sound
The sound chip used is inside the AXP818. If sound isn’t working the only reason is that you as the manufacturer have no clue at all about software issues and are only interested in selling hardware.
android is working fine ,and linux image ,we need fixed some issue and test it .
Hi, I have a BPI 1 or 2, I’m not sure which it is, it was a gift, so I did not order it. It does not have on-board WIFI, but it does have a SATA connection. Anyway, I am asking here if you could include SSH with the Android image, as I am a Blind user, and it is impossible to access Android to put TalkBack onto it unless I use SSH through my network. TalkBack is the screenreader for Android, and without that, it is like the sighted trying to use a computer without a screen. Thanks. Glenn
I use Debian headless
June 2016 - What makes the Sound? I put my USB-Behringer-UCA222 and search Audio… && … nope…
I found AXP818 Datesheet https://www.google.at/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiFqOablsTNAhVHcRQKHY0NCpEQFggbMAA&url=https%3A%2F%2Flinux-sunxi.org%2Fimages%2F7%2F73%2FAXP818_datasheet_Revision1.0.pdf&usg=AFQjCNGjT2Z4jg6rQZA_vyHoP_2zQZ6nlg&bvm=bv.125596728,d.d24
Gran chips , tarjeta de sonido hermosa :yum: :rolling_eyes:
Veeery long URL and… this pdf is…confidential !! :zipper_mouth: :rolling_eyes: :skull_crossbones: :scream: :sunglasses: Probably because there is no Audio im BPi-M3 ? :scream:
@sinovoip Great
It really works(ed), depends on some alsamixer settings:
(However, in their Ubuntu image Jan '17 based on Raspberry Ubuntu Mate no devices are detected. Kernel sound module seems missing…)
