Issue with lan0
Good afternoon,
I try to replace my R1 by a R2
I use armbian with kernel 4.19.1-mt7623
I have configure interface
link/ether aa:f0:f0:7a:4b:08 brd ff:ff:ff:ff:ff:ff
3: wan@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
4: lan0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 02:19:04:d6:b8:3d brd ff:ff:ff:ff:ff:ff
inet 192.168.101.254/24 brd 192.168.101.255 scope global lan0
5: lan1@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 02:19:04:e7:c9:4e brd ff:ff:ff:ff:ff:ff
inet 192.168.97.254/24 brd 192.168.97.255 scope global lan1
6: lan2@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 02:19:04:f8:d0:5f brd ff:ff:ff:ff:ff:ff
inet 192.168.19.254/24 brd 192.168.19.255 scope global lan2
7: lan3@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 02:19:04:09:e1:60 brd ff:ff:ff:ff:ff:ff
inet 192.168.57.2/24 brd 192.168.57.255 scope global lan3
I have a laptop connect to lan1, I have acces to laptop connect to: lan2 lan3
It’s possible for a laptop connect to lan0 to get an IP by DHCP server on R2.
But not possible for a latpop on lan0 to connect to R2 or communicated to a laptop on lan1 or lan2, or lan3.
I have delete all iptables rules.
I don’t know if it’s an hardware issue or configuration.
Do you have any suggestion for solved my issue.
Thank you for your help
It will be interesring if your client gets an ip on lan0 in lan0-ip-subnet. If not look if your dhcp listens on lan0
client on lan0 get an IP from lan0-ip-subnet, and dhcp listens on lan0.
After new test,
a dhcp client connect on lan0 don’t receive an IP.
Mar  5 11:00:50 srvprotect2 dhcpd[1075]: DHCPDISCOVER from 6c:62:6d:c8:f0:50 via lan0
Mar  5 11:00:50 srvprotect2 dhcpd[1075]: DHCPOFFER on 192.168.101.49 to 6c:62:6d:c8:f0:50 via lan0
Mar  5 11:00:59 srvprotect2 dhcpd[1075]: DHCPDISCOVER from 6c:62:6d:c8:f0:50 via lan0
Mar  5 11:00:59 srvprotect2 dhcpd[1075]: DHCPOFFER on 192.168.101.49 to 6c:62:6d:c8:f0:50 via lan0
I don’t understand this issue.
Because on BPI R1 is functionnal.
When I configure lan2 with same parameters that lan0 and lan0 with same parameters that lan2.
I have issue on lan2.
Maybe on a armbian file lan0 do a specific config ?
Can you try to configure static ip on client connected to lan0 in same subnet and try to access r2 (lan0,lanx by routing)
I have make this test and I don’t have access to R2.
Information about armbian
http://ix.io/1CEs
Have you tried putting eth0 and lan0 to down and then eth0 to up and then lan0 to up?
Maybe eth0 is not full up when putting lan0 to up…lan1+ gets a link-up message in dmesg but not lan0
No, I try with theses commands ?
ip link set eth0 down
ip link set lan0 down
ip link set eth0 up
ip link set lan0 up
Right (wait a bit between eth0 up and lan0 up), imho armbian uses a strange trick (configure dhcp on eth0) to get eth0 up on boot
I have trying, same issue.
Not possible to connect to R2 from a laptop on lan0
Not possible to ping a laptop on lan0
You can try another image like my debian to test for config-issue
I download it and I try.
But I have always issue with WAN interface : state LOWERLAYERDOWN
For test I use debian image and add kernel 4.19 ?
you have set eth1 also up…like it’s done in default /etc/network/interfaces…do not remove eth0/eth1 block
Hello,
I have try with your image, now it’s ok.
I have a message when I add IPTABLE rules
libkmod: ERROR ../libkmod/libkmod-config.c:635 kmod_config_parse: /etc/modprobe.d/mtk_pmic_keys.conf line 1: ignoring bad line starting with '“blacklist'
Thank you for your help.
hi,
this line is for users who have soldered their power-switch (to boot r2 on powersupply). i wonder about this error (especially the second quote)…can you look in this file and remove quotes if there is any present? it should only contain this:
blacklist mtk_pmic_keys
Hello,
Thank you issue is solved.
I have replace my R1 by my R2.
Thank you yet.
