How to use IR with lirc on BPI-M1,BPI-M1+
BPI-M1/M1+ support IR interface on board. you can use it as remote control.
How to use IR interface
test on bananian image:
1,install lirc
apt-get install lirc
apt-get install evtest
2,edit /etc/lirc/hardware.conf as below:
nano /etc/lirc/hardware.conf
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS="--uinput"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="UNCONFIGURED"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/input/event0"
MODULES="sunxi-ir"
ctrl+O save and ctrl+x exit.
3,test lirc
service lirc start
4 test remote-control unit
evtest
choose “0” must xunxi-ir
please note:value 0 value 1
press is:1,unpress is:0
