How to use BPI-4G LTE module with BPI-R2
(Prakash) #61
Just curious to know if this 4G module is compatible with Raspberry pi board?.
(ZB) #62
probably not, but if you add driver to the code, possibly yes.
(Prakash) #63
Hi. I am using Ubuntu 16.04 image and run the quectel program with 4G module. I am getting the following which I could not understand why the wwan0 disappear when we call dhclient,
> root@bpi-iot-ros-ai:~/quectel-CM# ./quectel-CM &
> [1] 15185
> [05-02_18:34:11:572] WCDMA&LTE_QConnectManager_Linux&Android_V1.1.34
> [05-02_18:34:11:572] ./quectel-CM profile[1] = (null)/(null)/(null)/0, pincode = (null)
> [05-02_18:34:11:573] Find /sys/bus/usb/devices/1-1 idVendor=2c7c idProduct=0125
> [05-02_18:34:11:573] Find /sys/bus/usb/devices/1-1:1.4/net/wwan0
> [05-02_18:34:11:573] Find usbnet_adapter = wwan0
> [05-02_18:34:11:573] Find /sys/bus/usb/devices/1-1:1.4/usbmisc/cdc-wdm0
> [05-02_18:34:11:573] Find qmichannel = /dev/cdc-wdm0
> root@bpi-iot-ros-ai:~/quectel-CM# [05-02_18:34:11:713] cdc_wdm_fd = 7
> [05-02_18:34:11:813] Get clientWDS = 19
> [05-02_18:34:11:845] Get clientDMS = 1
> [05-02_18:34:11:877] Get clientNAS = 3
> [05-02_18:34:11:910] Get clientUIM = 1
> [05-02_18:34:11:941] Get clientWDA = 1
> [05-02_18:34:11:973] requestBaseBandVersion EC25EFAR02A08M4G
> [05-02_18:34:12:070] requestGetSIMStatus SIMStatus: SIM_READY
> [05-02_18:34:12:101] requestGetProfile[1] www///0
> [05-02_18:34:12:136] requestRegistrationState2 MCC: 404, MNC: 84, PS: Attached, DataCap: LTE
> [05-02_18:34:12:165] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
> [05-02_18:34:12:230] requestRegistrationState2 MCC: 404, MNC: 84, PS: Attached, DataCap: LTE
> [05-02_18:34:12:293] requestSetupDataCall WdsConnectionIPv4Handle: 0x879a1100
> [05-02_18:34:12:357] requestQueryDataCall IPv4ConnectionStatus: CONNECTED
> [05-02_18:34:12:390] ifconfig wwan0 up
> [05-02_18:34:12:400] busybox udhcpc -f -n -q -t 5 -i wwan0
> [05-02_18:34:12:406] udhcpc (v1.22.1) started
> [05-02_18:34:12:474] Sending discover...
> [05-02_18:34:12:614] Sending select for 10.66.46.245...
> [05-02_18:34:12:744] Lease of 10.66.46.245 obtained, lease time 7200
> root@bpi-iot-ros-ai:~/quectel-CM# dhclient wwan0
> root@bpi-iot-ros-ai:~/quectel-CM# [05-02_18:34:24:204] QmiWwanThread poll err/hup/inval
> [05-02_18:34:24:204] poll fd = 7, events = 0x0018
> [05-02_18:34:24:204] QmiWwanThread exit
> [05-02_18:34:24:204] ifconfig wwan0 down
> wwan0: ERROR while getting interface flags: No such device
> [05-02_18:34:24:235] main exit
Any kind of help is appreciated. TIA.
(ZB) #64
Hello,it looks strange, when you use dhcp to get IP, but /quectel-CM exit, let me have a look.
(ZB) #65
Hello,Could you please show these logs?
  1. Do this command to check device:ls /dev/ttyUSB*
  2. After you execute ./quectel-CM &,and after you dhclient wwan0,if wwan0 is down,please check device again:ls /dev/ttyUSB*
  3. if /dev/ttyUSB* is exist, please do minicom -D /dev/ttyUSB2, and do these commands to check 4g module statue:
  • at+csq
  • at+ccid
  • at+cgreg?
(Prakash) #66
Hi. Check my reply.
  1. ls /dev/ttyUSB*
    ls: cannot access ‘/dev/ttyUSB*’: No such file or directory
  2. quectel-cm quit, because of no wwan0 device and gives same result for “ls /dev/ttyUSB*”.
  3. Not able to do since there was no wwan0.
(ZB) #67
so your image don’t recognise the 4g module? you don’t have /dev/ttyUSB*?
(Prakash) #68
@Jackzeng No. The module initially mounted on the ttyUSB0-3 and automatically unmounted only after I call quectel-cm & dhclient wwan0. My dmesg message is as follows,
> [   83.279885] i2c /dev entries driver
[   86.865460] xhci-mtk 1a1c0000.usb: xHCI host not responding to stop endpoint command.
[   86.865602] xhci-mtk 1a1c0000.usb: Assuming host is dying, halting host.
[   86.866204] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[   86.866390] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[   86.866547] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[   86.866697] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[   86.867029] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[   86.867181] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[   86.867331] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[   86.867487] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[   86.867836] qmi_wwan 1-1:1.4: Tx URB error: -22
[   86.868564] qmi_wwan 1-1:1.4: Tx URB error: -22
[   86.869260] qmi_wwan 1-1:1.4: Tx URB error: -22
[   86.869882] xhci-mtk 1a1c0000.usb: HC died; cleaning up
[   86.869979] qmi_wwan 1-1:1.4: Tx URB error: -22
[   86.870710] usb 1-1: USB disconnect, device number 2
[   86.879981] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[   86.880438] option 1-1:1.0: device disconnected
[   86.888800] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[   86.888892] option 1-1:1.1: device disconnected
[   86.891991] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[   86.892081] option 1-1:1.2: device disconnected
[   86.896328] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[   86.896414] option 1-1:1.3: device disconnected
[   86.896735] qmi_wwan 1-1:1.4 wwan0: unregister 'qmi_wwan' usb-1a1c0000.usb-1, WWAN/QMI device
[   86.946338] Alignment trap: not handling instruction e8503f00 at [<b6ac0ca4>]
[   86.946379] Unhandled fault: alignment exception (0x001) at 0x65676173
[   86.946387] pgd = db280000
[   86.946393] [65676173] *pgd=00000000
TIA.
(Prakash) #69
It is even automatically disconnected shortly after I reinserted the 4G module. Check my updated dmesg log.
> [ 1878.359005] usb 3-1: new high-speed USB device number 2 using xhci-mtk
[ 1878.539129] option 3-1:1.0: GSM modem (1-port) converter detected
[ 1878.540371] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 1878.541375] option 3-1:1.1: GSM modem (1-port) converter detected
[ 1878.542313] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 1878.542811] option 3-1:1.2: GSM modem (1-port) converter detected
[ 1878.543910] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 1878.544392] option 3-1:1.3: GSM modem (1-port) converter detected
[ 1878.545542] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 1878.549750] qmi_wwan 3-1:1.4: cdc-wdm0: USB WDM device
[ 1878.549777] qmi_wwan 3-1:1.4: Quectel EC25 work on RawIP mode
[ 1878.551531] qmi_wwan 3-1:1.4 wwan0: register 'qmi_wwan' at usb-1a240000.usb-1, WWAN/QMI device, a2:47:39:3d:2d:11
[ 1897.628386] xhci-mtk 1a240000.usb: xHCI host not responding to stop endpoint command.
[ 1897.628528] xhci-mtk 1a240000.usb: Assuming host is dying, halting host.
[ 1897.629144] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.629327] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.629481] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.629633] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.629915] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.630071] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.630222] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.630373] option1 ttyUSB1: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.630648] qmi_wwan 3-1:1.4: Tx URB error: -22
[ 1897.630766] option1 ttyUSB2: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.630923] option1 ttyUSB2: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.631076] option1 ttyUSB2: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.631226] option1 ttyUSB2: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.631522] option1 ttyUSB3: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.631696] option1 ttyUSB3: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.631852] option1 ttyUSB3: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.632003] option1 ttyUSB3: usb_wwan_indat_callback: resubmit read urb failed. (-22)
[ 1897.632228] xhci-mtk 1a240000.usb: HC died; cleaning up
[ 1897.633014] usb 3-1: USB disconnect, device number 2
[ 1897.639833] qmi_wwan 3-1:1.4: Tx URB error: -19
[ 1897.640603] qmi_wwan 3-1:1.4: Tx URB error: -19
[ 1897.641248] qmi_wwan 3-1:1.4: Tx URB error: -19
[ 1897.643776] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 1897.644315] option 3-1:1.0: device disconnected
[ 1897.650978] qmi_wwan 3-1:1.4: Tx URB error: -19
[ 1897.651593] option1 ttyUSB3: usb_wwan_open: submit int urb failed: -19
[ 1897.651615] option1 ttyUSB3: usb_wwan_open: submit read urb 0 failed: -19
[ 1897.651624] option1 ttyUSB3: usb_wwan_open: submit read urb 1 failed: -19
[ 1897.651633] option1 ttyUSB3: usb_wwan_open: submit read urb 2 failed: -19
[ 1897.651641] option1 ttyUSB3: usb_wwan_open: submit read urb 3 failed: -19
[ 1897.652715] option1 ttyUSB2: usb_wwan_open: submit int urb failed: -19
[ 1897.652731] option1 ttyUSB2: usb_wwan_open: submit read urb 0 failed: -19
[ 1897.652739] option1 ttyUSB2: usb_wwan_open: submit read urb 1 failed: -19
[ 1897.652747] option1 ttyUSB2: usb_wwan_open: submit read urb 2 failed: -19
[ 1897.652756] option1 ttyUSB2: usb_wwan_open: submit read urb 3 failed: -19
[ 1897.654660] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 1897.654713] option 3-1:1.1: device disconnected
[ 1897.655549] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 1897.655588] option 3-1:1.2: device disconnected
[ 1897.656388] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 1897.656436] option 3-1:1.3: device disconnected
[ 1897.656693] qmi_wwan 3-1:1.4 wwan0: unregister 'qmi_wwan' usb-1a240000.usb-1, WWAN/QMI device
