How to configure BPi-R2 as one-armed "router on a stick"
I’ve been trying to configure the BPi-R2 as a one-armed router (of a fashion), and have hit some problems I don’t understand. I’m conversant enough with Linux networking, including software bridging with the old brctl tool, but it’s my first experience with DSA and the ip-bridge utility, and I’ve probably made a mistake.
I wonder if the below approach of adding a wan VLAN interface to the br-lan bridge is the right way to do it and I’m just missing some detail, or if I should switch to the (unfamiliar) bridge vlan tool in a completely different approach, or what. Ideas?
Facility network environment: We have a router (MikroTik PoE running RouterOS) with all active ports configured as “hybrid” trunk ports, i.e. untagged traffic is VLAN 1, and tagged VLANs 100-103. A couple of WiFi APs (Ubiquiti AC running OpenWRT) broadcast several ESSIDs, each bridged to one of the VLANs 100-103.
Goal configuration: The goal is to set up the BPi-R2 in a lab as a router. It will have a PXE boot environment on the br-lan bridge for provisioning machines. The wan interface forwards Internet traffic through the MikroTik, as you’d expect. Also, the wan interface should forward VLAN 103 traffic between the BPi’s br-lan bridge and the rest of the network to provide access to lab machines via the lab ESSID from other parts of the facility.
Current config (failing): The wan port is connected to one of the hybrid trunk ports on the Mikrotik, untagged, carrying masqueraded traffic from the br-lan bridge to the Internet. The VLAN 103 traffic goes over the wan.103 port, which is slaved to the br-lan bridge together with the four lan0-lan3 ports. This configuration partly works: hosts wired to the lan0-lan3 ports can access the Internet and hosts on the lab ESSID can, too. The BPi-R2 can ping both groups of hosts. However, the two groups of hosts cannot talk with each other.
OS and kernel: I actually started this experiment with Debian Buster with @frank-w’s 5.4 kernel, and when I hit the wall, switched over to OpenWRT (built from master branch, kernel 5.4.101), and seeing the exact same problem.
Output of `ip`, `bridge`, etc. utilities
root@OpenWrt:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1504 qdisc fq_codel state UP qlen 1000
    link/ether aa:b6:32:5c:a2:33 brd ff:ff:ff:ff:ff:ff
3: wan@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
4: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
5: lan1@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
6: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
7: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
11: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
12: wan.103@wan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP qlen 1000
root@OpenWrt:~# ip addr
    inet6 ::1/128 scope host
    inet6 fe80::a8b6:32ff:fe5c:a233/64 scope link
    inet 10.88.0.222/24 brd 10.88.0.255 scope global wan
    inet6 2605:a601:ab40:4000:a8b6:32ff:fe5c:a233/64 scope global dynamic noprefixroute
       valid_lft 14274sec preferred_lft 14274sec
    inet 10.64.0.1/24 brd 10.64.0.255 scope global br-lan
    inet6 fd9b:4875:7d7::1/60 scope global noprefixroute
root@OpenWrt:~# bridge link
4: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 master br-lan state disabled priority 32 cost 100
5: lan1@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br-lan state forwarding priority 32 cost 4
6: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 master br-lan state disabled priority 32 cost 100
7: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 master br-lan state disabled priority 32 cost 4
12: wan.103@wan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br-lan state forwarding priority 32 cost 4
root@OpenWrt:~# brctl show
bridge name     bridge id               STP enabled     interfaces
br-lan          7fff.aab6325ca233       yes             lan0
                                                        lan1
                                                        lan2
                                                        lan3
                                                        wan.103
root@OpenWrt:~# bridge vlan
port    vlan ids
lan0     1 PVID Egress Untagged
lan1     1 PVID Egress Untagged
lan2     1 PVID Egress Untagged
lan3     1 PVID Egress Untagged
br-lan   1 PVID Egress Untagged
wan.103  1 PVID Egress Untagged
I got the one-armed “router on a stick” configuration working perfectly. Instructions for doing it manually and doing it with Debian/Ubuntu’s /etc/network/interfaces follow.
My intuition that the new ip-bridge utility is the way forward was correct. The old brctl utility is apparently obsolete, and can’t configure a VLAN-aware bridge. Because of this and no direct support for veth virtual network interfaces, the Debian config relies heavily on inelegant pre-up/post-up commands.
This configuration could also be done on OpenWRT, but will require installing the ip-bridge and (IIRC) ip-full packages, and I believe can’t be done in LuCI.
On OSs with systemd-networkd, this configuration is supported natively, which is more elegant, but may be unfamiliar to many and may not be nicely integrated into user-friendly configuration interfaces. (I’d be interested to hear otherwise.)
Command line procedure
Here’s the manual procedure to set up the one-armed router. The ip and bridge utilities must be installed.
`bash` commands for manual configuration
# Create the "internal" network bridge; must be down if already exists
ip link add name br_int type bridge
ip link set dev br_int down
# Set vlans:  br_int and lan0-lan3 all on VLAN 103, untagged
ip link set dev br_int type bridge vlan_filtering 1
for i in 0 1 2 3; do
    bridge vlan del dev lan${i} vid 1
    bridge vlan add dev lan${i} vid 103 pvid untagged
done
bridge vlan del dev br_int vid 1 self
bridge vlan add dev br_int vid 103 pvid untagged self
# Bring up the bridge interface
ip set dev br_int up
# At this point, start the DHCP server; hosts should be able to
# communicate on local network
# Add wan interface to bridge and set VLANs: 103 tagged (PVID 1 set by default)
ip link set dev wan master br_int
bridge vlan add dev wan vid 103
# Add "external" network VLAN interface to bridge and configure
ip link add link br_int name br_ext type vlan id 1
bridge vlan add dev br_int vid 1 self
# Now configure external IP and default route or run dhclient.  Done!
Using /etc/network/interfaces:
In OpenWRT I couldn’t quickly figure out how to make settings persist, or make built .ipks available, or recognize the SATA disk, and needed to rebuild the kernel with CONFIG_VETH, and lots of other things were missing to even get to where I could start getting Docker Engine to work, and on top of that, OpenWRT is still using these obsolete tools, so I punted. The Docker network appliance would’ve been pretty cool, though.
Switching back to Debian, the following /etc/network/interfaces file configures the same network. Debian also seems to use the obsolete brctl tool and needs hackery to add the full configuration, but it was easy, even if ugly.
`/etc/network/interfaces` file on Debian/Ubuntu
auto eth0
iface eth0 inet manual
  pre-up ip link set $IFACE up
auto wan
iface wan inet manual
auto lan0
iface lan0 inet manual
auto lan1
iface lan1 inet manual
auto lan2
iface lan2 inet manual
auto lan3
iface lan3 inet manual
auto br_int
iface br_int inet static
    # Create bridge interface
    pre-up ip link add name br_int type bridge
    # Enable VLAN filtering on bridge
    pre-up ip link set dev br_int type bridge vlan_filtering 1
    # Set VLANs:  PVID 103; untagged 1
    pre-up bridge vlan add dev $IFACE vid 103 pvid untagged self
    pre-up bridge vlan del dev $IFACE vid 1 self
    pre-up bridge vlan add dev $IFACE vid 1 self
    address 10.64.0.1
    netmask 255.255.255.0
    bridge_ports lan0 lan1 lan2 lan3 wan
    bridge_stp yes
    bridge_maxwait 0
    # Configure port VLANs
    post-up bridge vlan add dev wan vid 103
    post-up bridge vlan del dev lan0 vid 1
    post-up bridge vlan add dev lan0 vid 103 pvid untagged
    post-up bridge vlan del dev lan1 vid 1
    post-up bridge vlan add dev lan1 vid 103 pvid untagged
    post-up bridge vlan del dev lan2 vid 1
    post-up bridge vlan add dev lan2 vid 103 pvid untagged
    post-up bridge vlan del dev lan3 vid 1
    post-up bridge vlan add dev lan3 vid 103 pvid untagged
iface br_int inet6 static
    # fd = private; 22:c8b4:d740 = random global id; 0064 = subnet id; addr 1
    address fd22:c8b4:d740:0064::1
    netmask 64
    dad-attempts 0
auto br_ext
iface br_ext inet dhcp
    pre-up ip link add link br_int name br_ext type vlan id 1
    vlan-raw-device br_int
Results
This configuration satisfies the OP “goal configuration” perfectly.
Now, both wired clients (on the BPi-R2’s LAN ports) and wireless clients (bridged in over VLAN 103 on the BPi-R2’s WAN port) can get DHCP addresses from the BPi-R2 and can talk to each other on the “internal” network. They can also all connect to the Internet with traffic masqueraded over the BPi-R2’s WAN port (untagged VLAN 1).
Diagnostic shell commands showing bridge and VLAN configuration
root@bpi-r2:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether a2:2a:4d:2a:d4:7e brd ff:ff:ff:ff:ff:ff
3: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
4: wan@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br_int state UP mode DEFAULT group default qlen 1000
5: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br_int state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
6: lan1@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br_int state UP mode DEFAULT group default qlen 1000
7: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br_int state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
8: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br_int state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
9: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether 00:08:22:2a:c1:fb brd ff:ff:ff:ff:ff:ff
10: br_int: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
11: br_ext@br_int: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
12: br-7ac2e4ace930: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default
    link/ether 02:42:58:f1:46:2a brd ff:ff:ff:ff:ff:ff
13: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
    link/ether 02:42:1f:f4:b4:70 brd ff:ff:ff:ff:ff:ff
15: veth6d93e8e@if14: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-7ac2e4ace930 state UP mode DEFAULT group default
    link/ether 3a:14:e8:48:4a:61 brd ff:ff:ff:ff:ff:ff link-netnsid 0
root@bpi-r2:~# bridge link
4: wan state UP @eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br_int state forwarding priority 32 cost 4
5: lan0 state LOWERLAYERDOWN @eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 master br_int state disabled priority 32 cost 100
6: lan1 state UP @eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br_int state forwarding priority 32 cost 4
7: lan2 state LOWERLAYERDOWN @eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 master br_int state disabled priority 32 cost 100
8: lan3 state LOWERLAYERDOWN @eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 master br_int state disabled priority 32 cost 100
15: veth6d93e8e state UP @(null): <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br-7ac2e4ace930 state forwarding priority 32 cost 2
root@bpi-r2:~# bridge vlan
port    vlan ids
wan      1 PVID Egress Untagged
         103
lan0     103 PVID Egress Untagged
lan1     103 PVID Egress Untagged
lan2     103 PVID Egress Untagged
lan3     103 PVID Egress Untagged
br_int   1
br-7ac2e4ace930  1 PVID Egress Untagged
docker0  1 PVID Egress Untagged
veth6d93e8e      1 PVID Egress Untagged
So all is working now? What was the mistake? For ugly interfaces-file you can create a script containing commands for br_int and call this in pre-up/post-up (passing mode and iface as param)…maybe use it for other interfaces
Afaik debian uses pre-up/post-up hooks /etc/network/ip-*.d/bridge,which is a link to script which calls brctl. Maybe newer network-daemon (systemd-networkd, netplan) support bridge command natively,but then you need ro configure full network with this
Did you see the complete instructions I posted for both manual and /etc/network/interfaces, plus debug commands? I hid them in expandable sections in order to keep the post tidy, but maybe that’s not helpful if folks who might benefit won’t notice them.
I saw them,but i wanted to know if it now works…
Oh, yes, works perfectly! I’ll edit to make that more clear. Thanks, and I’m happy for further suggestions to make this more useful.
Only the one i posted above to move code (params interface and state) to a script to have only 2 lines per interface in interfaces file. And this is then also portable to other network daemons
