How to compile armbian with desktop for banana pi m2+ zero?
thanks all information.
I try get help on armbian forum , and i receive this informations : https://forum.armbian.com/topic/6867-h2-banana-pi-zero/
If possible , i need help on ths task .
Sorry, Carlos, can’t help with armbian, but I am using Ubuntu MATE image from this website:
Overall, works pretty good.
Only thing I miss is ethernet support, but WiFi works well.
Mark
Sorry , in my case i need , one distribution compiled , to meet my needs .
thanks
It is already compiled, just download image file and install to a storage card.
I need more than just a ready image, I need to be able to create my own image, with updates that I use. I need information, drivers, kernel compatible, uboot compatible end more.
I use as router openwrt, for this use and more I have options is not standard on this imagem.
Thanks you try help
@sinovoip @sinovoip1 , is possible share information to create image armbian ?
In my case , i need recompile after news patchs security , is one example i need compile armbian .
I think I found the right process :slight_smile:
Procedure : https://docs.armbian.com/Developer-Guide_Build-Preparation/#using-our-automated-build-system
File to enter version of my card: https://github.com/armbian/build/blob/master/config/boards/bananapim2zero.csc
I will inform the result
More things @sinovoip
https://linux-sunxi.org/Sinovoip_Banana_Pi_M2_Zero
http://wiki.friendlyarm.com/wiki/index.php/Mainline_U-boot_and_Linux
I need more info and procedures …
i found this article , is very nice : https://diyprojects.io/how-to-build-armbian-orangepi-bananapi-cubieboard/#.WtIanZch1Zg and BPI-M2+ new image:How to build armbian for bpi-m2+
But a need too information for kernel 4.+ …
