How to: banana pi BPI-M3 install BPI-WiringPi
#2
How do i use the hardware PWM correctly? I already figured out that i have to use wiringPi Pin 7. I executed the following code:
gpio mode 7 pwm
gpio pwm-ms
gpio pwmr 128
gpio pwmc 6
gpio pwm 7 120
But i get the following error:
val pwmWrite 0 <= X <= 1024 Or you can set new range by yourself by pwmSetRange(range
The same error occured when i coded the same with the C library:
#include <wiringPi.h>
int main ()
  if (wiringPiSetup() == -1)
    return 1;
  pwmSetMode(PWM_MODE_MS);
  pinMode(7, PWM_OUTPUT);
  pwmSetRange(128);
  pwmSetClock(6);
  pwmWrite(7,120);
  return 0 ;
But i got the same error. I think there is still a bug. Please confirm or give any suggestions, what i’m doing wrong.
#3
Does anybody have an idea?
#4
Maybe the vendor you got hardware and software from? Think positive and stay calm! Maybe they need just another 2 months to ignore your question but then maybe they’re in the mood to look into. But I would suspect they give a shit as usual.
BTW: Do you have something below /sys/devices/platform/sunxi_pwm available? If not why do you expect that PWM should work?
#5
How to force m3 to allow exporting gpio? example: echo 7 > /sys/class/gpio/export -su: echo: write error: Invalid argument
(Daniel) #6
Hi, i Followed the instruction but become an error. Can anybody help me?
(BPI_Justin) #7
HI: please reference the document and provider error messages.
https://bananapi.gitbooks.io/bpi-m3/content/bpi-m3_wiringpi.html.
(Daniel) #8
Error message is in the Picture of my last post
(BPI_Justin) #9
you can run “gpio readall” commnad?
(Daniel) #10
Yes, i can run the command. But become an error Message
Unable to determine Hardware version. I see: Hardware : sun8i
(BPI_Justin) #11
HI: Please reference it
(Daniel) #12
This not help me, I followed the instructions above but output the same error message .
[quote]
root@bananapi:~# Welcome to Ubuntu 15.10 (GNU/Linux 3.4.39-BPI-M3-Kernel armv7l)
 * Documentation:  https://help.ubuntu.com/
0 packages can be updated.
0 updates are security updates.
New release '16.04 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
root@bananapi:~/BPI-WiringPi/m3_test# gpio readall
Unable to determine hardware version. I see: Hardware   : sun8i
 - expecting BCM2708 or BCM2709. Please report this to projects@drogon.net
[/quote]
If you are unable to help me, say it and let other try to help.
Regards
(GrzegorzK) #13
First you must remove WiringPi: sudo apt-get remove wiringpi .
Then compile new Bpi-wiringpi.
(Daniel) #14
Thanks, It works.
Best regards
(TheGame) #15
Hello, I NEED to run WiringPi as normal user since I will be implementing it with ROS. I followed that guide:
but I can’t find anywhere the gpio files that should be under /sys/class/gpio, where are them?
(Osa Kozak) #16
Hi, I tried to install BPI-WiringPi on BananaPi M3 with Raspian Jessie Mate… But i have build failed Error…
root@OsaServer:~# sudo apt-get remove wiringpi
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'wiringpi' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
root@OsaServer:~#
root@OsaServer:/home/pi# git clone https://github.com/BPI-SINOVOIP/BPI-WiringPi.git -b BPI_M3
Cloning into 'BPI-WiringPi'...
remote: Counting objects: 306, done.
remote: Total 306 (delta 0), reused 0 (delta 0), pack-reused 306
Receiving objects: 100% (306/306), 548.28 KiB | 480.00 KiB/s, done.
Resolving deltas: 100% (168/168), done.
Checking connectivity... done.
root@OsaServer:/home/pi# cd BPI-WiringPi
root@OsaServer:/home/pi/BPI-WiringPi# chmod +x ./build
root@OsaServer:/home/pi/BPI-WiringPi# sudo ./build
./build: 4: ./build: [[: not found
wiringPi Build script
WiringPi Library
[UnInstall]
[Compile] wiringPi.c
[Compile] wiringSerial.c
[Compile] wiringShift.c
[Compile] piHiPri.c
[Compile] piThread.c
[Compile] wiringPiSPI.c
[Compile] wiringPiI2C.c
[Compile] softPwm.c
wiringPi.c:666:3: warning: excess elements in array initializer
   -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, // ... 63
wiringPi.c:666:3: warning: (near initialization for ‘pinTobcm_BP’)
wiringPi.c:756:3: warning: excess elements in array initializer
   {-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,},//PN
wiringPi.c:756:3: warning: (near initialization for ‘BP_PIN_MASK’)
wiringPi.c: In function ‘sunxi_gpio_unexports’:
wiringPi.c:798:13: warning: assignment makes integer from pointer without a cast
     if ((fd = fopen ("/sys/class/gpio/unexport", "w")) == NULL)
wiringPi.c:798:56: warning: comparison between pointer and integer
wiringPi.c:807:14: warning: passing argument 1 of ‘fprintf’ makes pointer from integer without a cast
     fprintf (fd, "%d\n", pin) ;
In file included from wiringPi.c:55:0:
/usr/include/stdio.h:356:12: note: expected ‘struct FILE * __restrict__’ but argument is of type ‘int’
 extern int fprintf (FILE *__restrict __stream,
wiringPi.c:808:13: warning: passing argument 1 of ‘fclose’ makes pointer from integer without a cast
     fclose (fd) ;
/usr/include/stdio.h:237:12: note: expected ‘struct FILE *’ but argument is of type ‘int’
 extern int fclose (FILE *__stream);
[Compile] softTone.c
[Compile] mcp23008.c
[Compile] mcp23016.c
[Compile] mcp23017.c
wiringPi.c: At top level:
wiringPi.c:719:12: warning: ‘physToGpioR3’ defined but not used [-Wunused-variable]
 static int physToGpioR3 [64] =//head num map to BCMpin
[Compile] mcp23s08.c
[Compile] mcp23s17.c
[Compile] sr595.c
[Compile] pcf8574.c
[Compile] pcf8591.c
[Compile] mcp3002.c
[Compile] mcp3004.c
[Compile] mcp4802.c
[Compile] mcp3422.c
[Compile] max31855.c
[Compile] max5322.c
[Compile] sn3218.c
[Compile] drcSerial.c
[Compile] wpiExtensions.c
[Link (Dynamic)]
[Install Headers]
[Install Dynamic Lib]
WiringPi Devices Library
[UnInstall]
[Compile] ds1302.c
[Compile] maxdetect.c
[Compile] piNes.c
[Compile] gertboard.c
[Compile] piFace.c
[Compile] lcd128x64.c
[Compile] lcd.c
[Compile] piGlow.c
[Link (Dynamic)]
[Install Headers]
GPIO Utility
[Compile] gpio.c
[Compile] readall.c
[Compile] pins.c
gpio.c: In function ‘doExports’:
gpio.c:428:5: warning: implicit declaration of function ‘sunxi_gpio_exports’ [-Wimplicit-function-declaration]
     sunxi_gpio_exports();
gpio.c:420:20: warning: unused variable ‘pin’ [-Wunused-variable]
   int i, l, first, pin;
gpio.c: In function ‘doUnexportall’:
gpio.c:757:5: warning: implicit declaration of function ‘sunxi_gpio_unexports’ [-Wimplicit-function-declaration]
     sunxi_gpio_unexports();
gpio.c: At top level:
gpio.c:877:13: warning: ‘doPadDrive’ defined but not used [-Wunused-function]
 static void doPadDrive (int argc, char *argv [])
gpio.c:965:13: warning: ‘doGbw’ defined but not used [-Wunused-function]
 static void doGbw (int argc, char *argv [])
gpio.c:1007:13: warning: ‘doGbr’ defined but not used [-Wunused-function]
 static void doGbr (int argc, char *argv [])
[Link]
/usr/bin/ld: gpio.o: undefined reference to symbol 'exit@@GLIBC_2.4'
//lib/arm-linux-gnueabihf/libc.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
Makefile:51: recipe for target 'gpio' failed
make: *** [gpio] Error 1
Make Failed… Please check the messages and fix any problems. If you’re still stuck, then please email all the output and as many details as you can to projects@drogon.net
(Sean) #17
@BPI_Justin I have a similar problem as @Osa_Kozak
However i am using: Ubuntu 16.04 mate… Release Date: 2017-07-20
When i follow your tutorial explicitly i get the following error:
pi@bpi-iot-ros-ai:~$ cd BPI-WiringPi
pi@bpi-iot-ros-ai:~/BPI-WiringPi$ chmod +x ./build
pi@bpi-iot-ros-ai:~/BPI-WiringPi$ sudo ./build
[sudo] password for pi:
WiringPi Library
[UnInstall]
make: Nothing to be done for 'all'.
[Install Headers]
[UnInstall]
[Install Headers]
GPIO Utility
[Link]
/usr/bin/ld: gpio.o: undefined reference to symbol '__printf_chk@@GLIBC_2.4'
Make Failed...
Please check the messages and fix any problems. If you're still stuck,
  projects@drogon.net
However when i change: git clone https://github.com/BPI-SINOVOIP/BPI-WiringPi.git -b BPI_M3
To: git clone https://github.com/BPI-SINOVOIP/BPI-WiringPi2.git
It installs ok. but there is no test file in the M3_test folder
What is wrong with the: git clone https://github.com/BPI-SINOVOIP/BPI-WiringPi.git -b BPI_M3 ???
Compiling project: linking fails on Ubuntu 16.04, LimeSuite
(bpi team) #18
newest wiringpi:
(fred) #19
Your new version lead to the same message error describe by @Shadow3561
  • expecting BCM2708, BCM2709, BCM2709. If this is a genuine Raspberry Pi then please report this to projects@drogon.net. If this is not a Raspberry Pi then you are on your own as wiringpi is designed to support the Raspberry Pi ONLY
So, conclusion, even if you provide something from another developer (who seems to be not happy of that)… can you please give the correct patch to implement the gpio.
Thank you
(The Gunzmo) #20
WiringPi broke my kernel but WiringPi2 worked without any problems thanks @sinovoip great work!
(Matheus Rodrigues) #21
O meu está acontecendo o mesmo
