I’m just playing with my BananaPi R2 board that I just got. I followed the directions on this page: http://wiki.banana-pi.org/Getting_Started_with_R2#OpenWrt_On_SD_.26_Emmc_Steps
My build system is Ubuntu 19.04. I had to patch some of the build tools to accomodate glibc 2.28 but I got it to build.
However, when I try to start the AP http://wiki.banana-pi.org/Getting_Started_with_R2#WiFi_and_Ap_mode_on_R2_Openwrt
I get an error when hostapd starts. My complete log is this:
root@LEDE:/# ./setup.sh
+ sleep 3
+ wmt_loader
init combo devic[ 87.915270] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 666)
e
[ 87.923521] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[ 87.930966] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[ 87.939638] set current consys chipid (0x7623)
[ 87.945427] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [ 87.954018] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[ 87.993234] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 88.000600] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6620.defAnt, mt6620_ant_m3.cfg, -1)
[ 88.008732] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 88.016082] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6628.defAnt, mt6628_ant_m1.cfg, -1)
[ 88.024192] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[ 88.031543] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6630.defAnt, mt6630_ant_m1.cfg, -1)
[ 88.040901] [WMT-CONSYS-HW][E]mtk_wmt_probe(122):Wmt Cannot find pinctrl default!
[ 88.049059] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[ 88.055818] [BT-MOD-INIT][I]do_bluetooth_drv_init:CONFIG_MTK_COMBO_BT is not defined
[ 88.063496] [WCN-MOD-INIT][E]do_connectivity_driver_init(57):do common driver init failed, ret:-1
[ 88.072310] [GPS-MOD-INIT][I]do_gps_drv_init:CONFIG_MTK_COMBO_GPS is not defined
[ 88.079659] [WCN-MOD-INIT][E]do_connectivity_driver_init(62):do common driver init failed, ret:-1
[ 88.088470] [FM-MOD-INIT][I]do_fm_drv_init:start to do fm module init
[ 88.094868] [FM-MOD-INIT][I]do_fm_drv_init:finish fm module init
[ 88.100821] [WLAN-MOD-INIT][I]do_wlan_drv_init:start to do wlan module init 0x7623
[ 88.108745] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 153) installed.
[ 88.116278] [WLAN-MOD-INIT][I]do_wlan_drv_init:WMT-WIFI char dev init, ret:0
[ 88.124139] [WLAN-MOD-INIT][I]do_wlan_drv_init:WLAN-GEN2 driver init, ret:0
[ 88.131073] [WLAN-MOD-INIT][I]do_wlan_drv_init:finish wlan module init
do module init: [ 88.137745] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 666)
30243
failed to init module
+ sleep 5
+ stp_uart_launc[ 90.893410] [WMT-DEV][W]WMT_unlocked_ioctl:chipid = 0x7623
her -p /etc/firm[ 90.899742] [WMT-LIB][W]wmt_lib_set_hif:new hifType: 2, fm:2
ware
open devic[ 90.906795] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
e node succeed.([ 90.914948] [WMT-DEV][W]WMT_unlocked_ioctl:unknown cmd (-2147180516)
Node:/dev/stpwmt[ 90.922680] vcn18: mode operation not allowed
, fd:3)
chip id is 0x7623
chi[ 90.929806] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(292):Read CONSYS chipId(0xfffff093)Id:0x7623, setting to property((null))
chiId:0x7623
run SOC chip flow
create pwr on thread ok
[ 91.035344] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 91.042687] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6620.defAnt, mt6620_ant_m3.cfg, -1)
[ 91.050949] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 91.058373] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6628.defAnt, mt6628_ant_m1.cfg, -1)
[ 91.066557] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[ 91.073893] [WMT-CONF][W]wmt_conf_parse:parse fail (mt6630.defAnt, mt6630_ant_m1.cfg, -1)
[ 91.083907] [WMT-IC][W]mtk_wcn_soc_ver_check:0x7623: read hw_ver (hw version) (0x8a00)
[ 91.092413] [WMT-IC][W]mtk_wcn_soc_ver_check:0x7623: read fw_ver (rom version) (0x8a00)
[ 91.100432] [WMT-IC][W]mtk_wcn_soc_ver_check:0x7623: ic info: SOC_CONSYS.E1 (0x8a00/0x8a00, WMTHWVER:0, patch_ext:_e1)
enter power on connsys flowpatch name pre-fix:ROMv2_lm_patch
fwVersion:0x8a00
/etc/firmware/ROMv2_lm_patch_1_0_hdr.bin
fw Ver in patch: 0x8a00
read patch info:0x22,0x00,0x06,0x00
gpatchnum = [2]
gdwonseq = [2]
/etc/firmware/ROMv2_lm_patch_1_1_hdr.bin
read patch info:0x21,0x00,0x0e,0xf0
gdwonseq = [1]
cmd(srh_patch) resp(ok)
[ 91.258959] [WMT-IC][W]mtk_wcn_soc_patch_dwn:wmt_core: patch dwn:0 frag(51, 268) ok
[ 91.385938] [WMT-IC][W]mtk_wcn_soc_patch_dwn:wmt_core: patch dwn:0 frag(114, 52) ok
[ 91.721213] [WMT-IC][W]mtk_wcn_soc_sw_init:co-clock disabled.
[ 91.727739] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
[ 91.735193] [WMT-CORE][W]wmt_core_dump_func_state:[AF FUNC ON]status(b:0 f:0 g:0 w:0 lpbk:2 coredump:0 wmt:2 stp:0)
[ 91.745665] [WMT-EXP][W]mtk_wcn_wmt_func_ctrl:OPID(3) type(9) ok
+ sleep 5
[ 95.894449] [MTK-WIFI] WIFI_open: WIFI_open: major 153 minor 0 (pid 674)
+ [ 95.901967] [MTK-WIFI] WIFI_write: WIFI_write A
[ 95.901967]
echo A
[ 95.944893] [WMT-FUNC][W]wmt_func_wifi_on:WMT-FUNC: wmt wlan func on before wlan probe
[ 95.980196] kalFirmwareImageMapping firmware size 225840
[ 97.156087] [MTK-WIFI] register_set_p2p_mode_handler: (pid 670) register set p2p mode handler c0276f3c
[ 97.165431] [WMT-FUNC][W]wmt_func_wifi_on:WMT-FUNC: wmt call wlan probe ok
[ 97.172272] [WMT-CORE][W]wmt_core_dump_func_state:[AF FUNC ON]status(b:0 f:0 g:0 w:2 lpbk:2 coredump:0 wmt:2 stp:0)
[ 97.182840] [WMT-EXP][W]mtk_wcn_wmt_func_ctrl:OPID(3) type(3) ok
[ 97.188895] [MTK-WIFI] WIFI_write: WMT turn on WIFI success!
[ 97.195829] [MTK-WIFI] WIFI_write: Set wlan mode 0 --> 1
[ 97.201137] [MTK-WIFI] WIFI_close: WIFI_close: major 153 minor 0 (pid 674)
+ hostapd -d hostapd.conf
Configuration file: hostapd.conf
Line 4: invalid/unknown driver 'nl80211'
1 errors found in configuration file 'hostapd.conf'
Failed to set up interface with hostapd.conf
Failed to initialize interface
Any ideas on what I need to do to get AP mode to work?
