Help for testing 4.19 on R2
(Frank W.) #1
i’ve merged 4.19-main and hdmi+gmac into 4.19-testing for having 1 4.19-kernel with all features currently working in 4.19.
  • poweroff
  • internal wifi
  • hdmi+fbdev (needs video=1920x1080 in cmdline or any other resolution)
  • second gmac (wan connected to eth1 like in 4.14)
have uploaded binary-package here
https://drive.google.com/open?id=1MY8owoBdyv060u0QcE0GVC1YEtIPgu5E
hope there will some people for testing
hdmi works with the following resolutions:
  • 1280x1024 (hdmi2dvi) xserver+fbdev
  • 1080p xserver+fbdev
2nd gmac:
root@bpi-r2:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group defau0
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP g0
    link/ether 86:0d:62:b7:de:c7 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::840d:62ff:feb7:dec7/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP g0
    link/ether 92:df:b5:57:69:99 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::90df:b5ff:fe57:6999/64 scope link
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
5: wan@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP 0
    inet 192.168.0.42/24 brd 192.168.0.255 scope global wan
6: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state 0
    inet 192.168.4.10/24 brd 192.168.4.255 scope global lan0
7: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master0
8: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master0
9: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state 0
10: br0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN 0
    inet 192.168.1.1/24 brd 192.168.1.255 scope global br0
11: lan3.60@lan3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue st0
    inet 192.168.60.10/24 brd 192.168.60.255 scope global lan3.60
ping over wan (eth1):
--- 192.168.0.10 ping statistics ---
1026 packets transmitted, 1026 received, 0% packet loss, time 1066036ms
rtt min/avg/max/mdev = 0.339/0.426/0.560/0.040 ms
ping over lan0 (eth0):
1634 packets transmitted, 1634 received, 0% packet loss, time 1698243ms
rtt min/avg/max/mdev = 0.336/0.428/0.798/0.035 ms
wifi-ap (connection from my cellphone, did ssh to r2 wifi-interface):
ap0: Event ASSOC (0) received
ap0: STA b4:9d:xx:xx:22:e9 IEEE 802.11: associated
STA did not include WPS/RSN/WPA IE in (Re)AssocReq
  New STA
ap_sta_add: register ap_handle_timer timeout for b4:9d:xx:xx:22:e9 (300 seconds
- ap_max_inactivity)
nl80211: Set STA flags - ifname=ap0 addr=b4:9d:xx:xx:22:e9 total_flags=0x0 flags
_or=0x0 flags_and=0xfffffff1 authorized=0
ap0: AP-STA-CONNECTED b4:9d:xx:xx:22:e9
ap0: STA b4:9d:xx:xx:22:e9 RADIUS: starting accounting session 5BFAC73E-00000000
IEEE 802.1X: Ignore STA - 802.1X not enabled or forced for WPS
hostapd_new_assoc_sta: reschedule ap_handle_timer timeout for b4:9d:xx:xx:22:e9
(300 seconds - ap_max_inactivity)
nl80211: Event message available
nl80211: Drv Event 20 (NL80211_CMD_DEL_STATION) received for ap0
nl80211: Delete station b4:9d:xx:xx:22:e9
ap0: Event DISASSOC (1) received
ap0: STA b4:9d:xx:xx:22:e9 IEEE 802.11: disassociated
ap0: AP-STA-DISCONNECTED b4:9d:xx:xx:22:e9
nl80211: sta_remove -> DEL_STATION ap0 b4:9d:xx:xx:22:e9 --> 0 (Success)
ap_free_sta: cancel ap_handle_timer for b4:9d:xx:xx:22:e9
regards Frank
(Alex R.) #2
I’ve installed new kernel. HDMI/Wi-Fi/USB/SATA - Everything is ok. I see both eth0 and eth1 devices but can’t test in right now (wifi-onsy setup).
I’ve also modified udev rules to set different MACs on eth0 and eth1.
ACTION=="add", SUBSYSTEM=="net", KERNELS=="eth0", RUN+="/bin/ip link set dev %k address ae:fc:de:ad:be:ee"
ACTION=="add", SUBSYSTEM=="net", KERNELS=="eth1", RUN+="/bin/ip link set dev %k address ae:fc:de:ad:be:ef"
1b100000.ethernet eth0
didnt worked for me so i left only eth0/1.
(Alex R.) #3
I’ve testet wan/lan. Looks Ok for me. Also I’ve found that udev rulres doesn’t affect on wan/lan intercaces mac addresses. Tese interfaces have the macs that generates random on boot.
My example:
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether ae:fc:de:ad:be:ef brd ff:ff:ff:ff:ff:ff
    inet6 fe80::acfc:deff:fead:beef/64 scope link
5: wan@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether ba:0d:31:83:39:fe brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.2/24 brd 192.168.1.255 scope global wan
    inet6 fe80::b80d:31ff:fe83:39fe/64 scope link
and
[ 4.766387] mtk_soc_eth 1b100000.ethernet: generated random MAC address ba:0d:31:83:39:fe
(Frank W.) #4
lan/wan gets (random) mac from cpu-port. Imho your udev is later…why it works for eth i don’t know.i guess it is because interface needs to be down for mac-setting.
I set mac via network/interfaces…preup
(Frank W.) #5
had forgotten change to mdio-device in testing-branch…updated now…currently uploading
