Hdmi in uboot and linux
(Alex R.) #81
I’ve never used it, but I’ve found:https://www.kernel.org/doc/html/v4.11/admin-guide/dynamic-debug-howto.html CONFIG_DYNAMIC_DEBUG should activate dev-dbg.
(Alex R.) #82
Yes, debug=7 is enabled. I didn’t found anything suspicious, but I’ll upload uart output next time when l boot 4.14
No, problem is only on 4.14
(Frank W.) #83
mhm, but i reboot my 4.14 many times…so something added after seems to prevent it
(Alex R.) #84
This problem defenetly appeared after hdmi patches was ported. It probably also affects wifi/bt.
(Frank W.) #85
Wifi has newer version of watchdog (drivers/watchdog/mtk_wdt.c)…maybe this conflicts?
Try to use the original from 4.14,compile without wifi-driver and try to reboot
(Alex R.) #86
Try to use predefined templates a top of the page. There are most of resolutions in these templates.
(Frank W.) #87
mhm…option is already set in defconfig…will try again with debug=7 and drm.debug=0x7
grep 'CONFIG_DYNAMIC_DEBUG' arch/arm/configs/*fwu_defconfig
CONFIG_DYNAMIC_DEBUG=y
(Frank W.) #88
800x600@60Hz => HSYNC of 37.88kHz
1024x768@60Hz=> HSYNC of 48.36kHz
same values used by rpi in my screens above…but it seems that these are not used by fbdev/drm-driver on r2
found messages in debugfs…but placeholder are not filled:
drivers/gpu/drm/mediatek/mtk_hdmi.c:1382 [mediatek_drm_hdmi]mtk_hdmi_bridge_mode_set =_ "hsync_start:%d,hsync_end:%d, htotal:%d"
log with dmesg and debug-fs-messages for drm: 4.16-hdmi-1024x768@60_debug.txt (75,7 KB)
(Alex R.) #89
So looks like approximately value of hsync can be calculated as: vsync * vert-res * 1.05
(Frank W.) #90
after adding #define DEBUG in mtk_hdmi.c:
[13:28] root@bpi-r2:~# dmesg |grep -i sync
[    2.959897] mediatek-drm-hdmi 14015000.hdmi: hsync_start:1048,hsync_end:1184, htotal:1344
[    2.959909] mediatek-drm-hdmi 14015000.hdmi: vsync_start:771, vsync_end:777, vtotal:806
still 1024x768@60…full dmesg: 4.16-hdmi-1024x768@60_debug.txt (74,6 KB)
i have created branch 4.16-hdmi+wlan for testing if the reboot-issue also occour in 4.16 => reboot works here…so it should be nothing wifi-driver-related
Searching testing people for hdmi + wifi in Kernel 4.16
(Alex R.) #91
What is your actual hsync frequency when using 1024x768@60? Lines 406 and 488 looks suspicious (sorry, can’t insert, I’m writing from smartphone)
(Frank W.) #92
it seems 67.5kHz, but i don’t know if that info is from uboot…becuase my screen goes off and does not go on after that (check signal cable)…maybe vga-adapter blocks incorect signal
405: [    3.022383] [drm:drm_calc_timestamping_constants] crtc 34: hwmode: htotal 1344, vtotal 806, vdisplay 768
406: [    3.022392] [drm:drm_calc_timestamping_constants] crtc 34: clock 65000 kHz framedur 16665600 linedur 20676
487: [    9.335294] [drm:drm_calc_timestamping_constants] crtc 34: hwmode: htotal 1344, vtotal 806, vdisplay 768
488: [    9.335304] [drm:drm_calc_timestamping_constants] crtc 34: clock 65000 kHz framedur 16665600 linedur 20676
489: [    9.335331] [drm:drm_vblank_enable] enabling vblank on crtc 0, ret: 0
btw. xserver also does not work here (see process running but screen stays in standby)… @Ryder.Lee
edit: after killing x-server, i got the fb-console…and also can start xserver again…
(Alex R.) #93
Is there anything useful in dmesg?
BTW, have you tried to run same video config on 4.4 bsp kernel?
(Frank W.) #94
Have not looked in it and did not tried with 4.4…but i can reproduce it…after reboot monitor-standby,also after starting x-server, after killing this the first time monitor goes on and virtualconsole is visible
I will make a log later…currently out of home
(Frank W.) #95
i don’t know why it works before multiple time also with reboot after killing xserver…i have tried it again and now it does not work anymore with 4.16 :frowning:
but i have tried with 4.4, and have same behaviour…
i have no DEBUG-Flag in 4.4, but this errors came up after killing xserver the first time:
[   65.763056] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x300000 pa=0x0 larb=0 port=0
[   65.763167] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x301000 pa=0x0 larb=0 port=0
[   65.763212] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x304000 pa=0x0 larb=0 port=0
[   65.763308] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x300000 pa=0x0 larb=0 port=0
[   65.764035] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x301000 pa=0x0 larb=0 port=0
[   65.764065] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x302000 pa=0x0 larb=0 port=0
[   65.764094] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x304000 pa=0x0 larb=0 port=0
[   65.764123] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x305000 pa=0x0 larb=0 port=0
[   65.764153] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x307000 pa=0x0 larb=0 port=0
[   65.764182] mtk-iommu 10205000.mmsys_iommu: fault type=0x5 iova=0x308000 pa=0x0 larb=0 port=0
(Frank W.) #96
@DeadMeat hdmi is working in 4.14? for kernelcrash in wifi-driver did you reset mtk_wdt.c? Maybe this causes watchdog-crash…looks like same crash as here: R2 internal Wifi/BT (MT6625L) - Kernel 4.14.x/4.16
(Alex R.) #97
Hi, Frank, As for me there are no problems with hdmi in 4.14 - it’s works same way as in 4.16.
No progress with mtk_wdt.c/wifi/broken reboot for today. :frowning:
(Frank W.) #98
I see your last commit…you’ve removed wifi-driver as i suggested…
Which image do you use as base for testing? Are the wmt-tools available? I ask because you have no changes in files used by wifi-driver. Have you same crash with default main-kernel on same system?
i created 4.14-hdmi also in my repo and merged your commits into it for testing…
(Alex R.) #99
I’m using 2018-03-29-ubuntu-16.04-mate-desktop-bpi-r2-sd-emmc
I’m not shure
pi@bpi-iot-ros-ai:~$ aptitude search wmt
p   wmtemp        - WM dock applet displaying lm_sensors temperature values
p   wmtime        - Window Maker dockapp that displays the time and date
p   wmtop        - dockapp that displays 3 top memory or CPU using processes
p   wmtv        - Dockable video4linux TV player for WindowMaker
Only on hdmi-patched 4.14.
(Frank W.) #100
wmt-tools are not available via apt…these are compiled additionally but in latest official images they should be in /usr/bin (wmt_loader, wmt_loopback, stp_uart_launcher).
i have included wifi-driver in my build…will try it…it will crash if i try to enable wifi-driver, same procedure does not crash with 4.14-main (.44), so it’s a change with the hdmi-driver, hdmi itself works at least with 1080p, nice work… now we have to look why wifi crash => wifi-thread
it seems that you removed the wifi-related dts(i)-nodes…bpi-r2.dts.diff (2,4 KB) mt7623.dtsi.diff (3,5 KB) => fixed in my repo ( https://github.com/frank-w/BPI-R2-4.14/tree/4.14-hdmi ) by applying these 2 patches with -R
have you simply copied dts/dtsi from 4.16 to 4.14?
reverted dts(i) to 4.14-main, removed hdmi-related nodes and readded them from 4.16…works so far. here the full log (including bootloader+ wifi-init): 4.14-hdmi wlan.txt (115,7 KB)
also cleaned defconfig…only thing to do is fix warnings:
drivers/gpu/drm/mediatek/mtk_drm_drv.c:172:15: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
  .main_path = mt2701_mtk_ddp_main,
drivers/gpu/drm/mediatek/mtk_drm_drv.c:174:14: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
  .ext_path = mt2701_mtk_ddp_ext,
drivers/gpu/drm/mediatek/mtk_drm_drv.c:180:15: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
  .main_path = mt8173_mtk_ddp_main,
In file included from ./include/linux/cdev.h:8:0,
                 from ./include/drm/drmP.h:36,
                 from drivers/gpu/drm/mediatek/mtk_dpi.c:14:
drivers/gpu/drm/mediatek/mtk_dpi.c: In function 'mtk_dpi_probe':
./include/linux/device.h:1346:36: warning: 'bridge_node' may be used uninitialized in this function [-Wmaybe-uninitialized]
 #define dev_info(dev, fmt, arg...) _dev_info(dev, fmt, ##arg)
drivers/gpu/drm/mediatek/mtk_dpi.c:731:27: note: 'bridge_node' was declared here
  struct device_node *ep, *bridge_node;
In file included from drivers/gpu/drm/mediatek/mtk_drm_fbdev.c:14:0:
drivers/gpu/drm/mediatek/mtk_drm_fbdev.c: In function 'mtk_fbdev_probe':
./include/drm/drmP.h:175:2: warning: 'err' may be used uninitialized in this function [-Wmaybe-uninitialized]
  drm_dev_printk(dev, KERN_ERR, DRM_UT_NONE, __func__, " *ERROR*",\
drivers/gpu/drm/mediatek/mtk_drm_fbdev.c:61:6: note: 'err' was declared here
  int err;
fixed the warnings in my repo…
