I’ve finally done with it! I’ve ported fbdev from 4.4 kernel, and looks like it works.
I need some time to check and describe it.
Bad news - the sd-card slot on my R2 has been broken - it can’t hold sdcard anymore (You can see “waiting for root” on video ). It has contact only while i’m pushing to card. I probably can bot from EMMC, but i steel need sd to install image.
So i’m out of buissnes for some time.
And we steel need more tests. As for me - both Xorg and framebuffer work!
can you share your ported fbdev and xserver-config?
I’ve created the pull request on github, check it please. (it’s a bit draft, so if @Ryder.Lee or someone qualified will can to audit it, that would be great! As I’m not a driver developer
I didn’t made any scpecial chandes to Xorg config. It’s default.
And also CONFIG_DRM_FBDEV_EMULATION=y should be activated
the pull-request from Alex: https://github.com/frank-w/BPI-R2-4.14/pull/23/files
@Ryder.Lee can you take a look on it? if you say it’s right i merge it to hdmi-branch so i can also test it…my hdmi-cable should arrive today (needed a longer one)
@DeadMeat imho you can add CONFIG_DRM_FBDEV_EMULATION=y to fwu_defconfig in your branch and the pullrequest should be updated…
Done. The pull request has been updated.
Looks good to me. You can take this through your tree.
have included it into 4.16-hdmi branch. @DeadMeat have you additional settings in uEnv.txt to get console-output over hdmi like i mentioned above?
ok, you used the default uEnv.txt from ubuntu-image…
is card recognized on host-pc? what says badblocks?
Absolutely.
The card is OK, it’s a mechanical problem - ‘click&hold’ mechanism seems to be broken, so card slot can’t hold the card.
oh, thats very bad
does the card hold inside or is it thrown out a bit?
can you send me the uEnv.txt, so that i can compare with my own?
## uEnv.txt
bpi=bananapi
board=bpi-r2
chip=mt7623n
service=linux
kernel=uImage
kaddr=0x84000000
rdaddr=0x86000000
#root=/dev/ram
root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
console=earlyprintk console=tty1 fbcon=map:0 console=ttyS0,115200
bootopts=vmalloc=496M debug=7 initcall_debug=0
abootargs=setenv bootargs board=${board} console=${console} root=${root} service=${service} ${bootopts}
ahello=echo Banana Pi ${board} chip: $chip Service: $service
aboot=if fatload $device $partition $rdaddr ${bpi}/berryboot.img; then bootm $kaddr $rdaddr ; else bootm $kaddr; fi
aload_kernel=fatload $device $partition $kaddr ${bpi}/${board}/${service}/${kernel}
uenvcmd=run ahello abootargs aload_kernel aboot
## END
you have the related settings set (in my uEnv missing):
Probably it’s OS image related.
The card drops on any inaccurate movement.
got my cable, and i see fb-console-output (have not yet xserver installed)…
only issue i have is that screen is not centered (login-prompt not visible), now i search a configuration option to fix this…most instructions are for grub
[16:50] root@bpi-r2:~# cat /sys/class/graphics/fb0/modes
U:1920x1080p-0
[16:51] root@bpi-r2:~# fbset -fb /dev/fb0 -g 1920 1080 1920 1080 16
ioctl FBIOPUT_VSCREENINFO: Invalid argument
[16:53] root@bpi-r2:~# echo U:1920x1080p-0 > /sys/class/graphics/fb0/mode
still no change
installed xserver-xorg and xinit
[16:57] root@bpi-r2:~# less /var/log/Xorg.0.log |grep EE
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 931.136] (EE) AIGLX: reverting to software rendering
[ 931.137] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so faile)
[ 931.137] (EE) GLX: could not load software renderer
[ 931.729] (EE) Server terminated successfully (0). Closing log file.
after installing libgl1-mesa-dri
[17:02] root@bpi-r2:~# less /var/log/Xorg.0.log |grep EE
[ 1319.003] (EE) AIGLX: reverting to software rendering
[ 1319.495] (EE) Server terminated successfully (0). Closing log file.
playing around with disp-options in uenv.txt from here [how to]the final solution of compulsive modification of HDMI output resolution, but also no success
it’s a long time ago i have configured last time a x-server manually
my servers are headless, maybe only a vncserver, which have not to be configured, clients are all ubuntu
logs showing no real error as far as i see
Xorg.0.log (21,0 KB) dmesg.log (85,0 KB)
after installing lxde i got a graphical interface, still not correctly aligned, but a step further. Problem before is fixed (i guess missing displaymanager)
additionally i had to install “policykit-1”
the alignment-problem is also fixed by realigning-function of the TV…nothing to do on bpi-r2
Hello, Frank
As i know driver supports only 32bit color depth, so u probably should try
fbset -fb /dev/fb0 -g 1920 1080 1920 1080 32
If I get you right, You’ve finnaly solved your aligment problem by TV-settings? So now You have both framebuffer and Xserver?
Right,both working…but it will be nice to set the resolution of console (make font larger).
I need to know how to set Resolution (hdmi mode) in uboot (if cec fails). I will try out vga and dvi-adapters next days.
