Gertbot with a Banana Pi?
HI, I’m planning on doing a project with two stepper motors and found the Gertbot when I was looking for a controller that can support stronger stepper motors. I still have two Banana Pis laying around and so I wanted to ask if it works with those as well or if I should get a Raspberry Pi to run it. If I should get a Raspberry Pi, which one would you suggest? Please help. Thanks! I didn’t find the right solution from the Internet. References: https://lb.raspberrypi.org/forums/viewtopic.php?t=195551&p=1223652
Business Whiteboard Animation
both raspberry pi ,and banana pi all can do this , just choose by youself.:slight_smile:
