[BPI-R2] Control On-board LEDs
blinking can be disabled by echo 0 > /sys/class/leds/bpi-r2:isink:green/brightness
frequency can changes, you can try
echo 100 > /sys/class/leds/bpi-r2:isink:green/delay_on
echo 100 > /sys/class/leds/bpi-r2:isink:green/delay_off
and
echo 1000 > /sys/class/leds/bpi-r2:isink:green/delay_on
and compare what diffrences between the two set of commands
It seems hardware characteristics. i have checked the hardware value written by the driver, it indeed to writing the same value to their leds registers but thereā€™s brightness differences
:stuck_out_tongue: then the led is off :wink: i want a steady-on
with 100/1000 i see no differenceā€¦tried with 10/1000 ā€¦there is a difference
echo 1 > /sys/class/leds/bpi-r2:isink:green/brightness
it is steady on on my setup ā€¦
[11:45] root@bpi-r2:~# L=/sys/class/leds/bpi-r2\:isink
[12:05] root@bpi-r2:~# echo 0 > $L:green/brightness                 #goes off
[12:05] root@bpi-r2:~# echo 1 > $L:green/brightness                 #starts blinking
weird. it is different with my test.
echo 0 (to cancel blinking), and then echo 1 , i can get a always steady on
how about the other two leds ?
driver should use the same programming to those leds
the other 2 (red/blue) go on (1) and off (0), no blinking
timing with delay-nodes ist strange anywayā€¦hard to describe
i see no difference between red,blue and green: https://github.com/frank-w/BPI-R2-4.14/blob/b80a9345899842733507fe40decec0ab7f0ba3cd/arch/arm/boot/dts/mt7623n-bananapi-bpi-r2.dts#L72
btw. i have HW rev 1.1 (if it matters), running debian 8 on my test-system with kernel 4.14.34
LEDs in /sys/class/leds/bpi-r2:pio (next to gpio40-header) are also strange:
  • red cannot be set
  • blue and green are swapped
  • 0/1 is swapped (1 turnes off, 0 turns on)
it looks like gpio problem
it can be solved by change properties such as label and low or high-active in gpio leds nodes in dts. Could you help to try which one is good setting?
where are the pio-leds defined? i lokked in bananapi.dts and mt7623.dtsiā€¦found only the isink leds
how about the blinking of green isink-led? any idea? which HW-revision/kernel do you use?
compatible string is gpio-led, see
https://elixir.bootlin.com/linux/v4.17-rc1/source/arch/arm/boot/dts/mt7623n-bananapi-bpi-r2.dts#L87
it looks like board issue, I am using v1.1 with v4.16 rc5 and code is almost same between 4.14 you used and 4.16.
ok, found it, thank youā€¦in dts the are defined as high-activeā€¦in shematics they look low-active (led between vcc and gpio)ā€¦thats the first problemā€¦to bad that in shematics the colors are not describedā€¦so we can only swap green&blue but have no clue whats up with red
fixed green and blue: https://github.com/frank-w/BPI-R2-4.14/commit/5da2e20c279ae77f13ea92d11f2e4c8c17ab0ce2 working now as expected and do not light the entire time (only red is always on).
in shematics the leds are named
led0=239 (r)
led1=241 (b)
led2=240 (g)
as you see by reading gpio-order you get r-g-b, with led-numbers you get r-b-gā€¦seems like thats the reason for swapped green/blue
xbgmsharp tested also the green-led-behaviour: green light is only blinking
On my board, the resistors R303 and R239-R240 are not populated, so the red LED can not be controlled. It is used only as a power indicator.
then i need to disable blinking of green isink led
@frank-w I clonned your git repo for kernel 4.14-main, configure it to have built in SATA and RAID support and then compile it using your build.sh script: build.sh build and then build.sh pack. I got an archive bpi-r2_4.14.34_main.tar.gz which I extract to SDCard to root. Now, when I try to boot from this kernel, it hangs on ā€œStarting kernelā€¦ā€. How can I debug what is wrong?
Part    Start Sector    Num Sectors     UUID            Type
  1     204800          524288          03ecee97-01     0c
  2     729088          14211072        03ecee97-02     83
mmc0 is available
reading bananapi/bpi-r2/linux/uEnv.txt
811 bytes read in 5 ms (158.2 KiB/s)
Loaded environment from uEnv.txt
Banana Pi bpi-r2 chip: mt7623n Service: linux
reading bananapi/bpi-r2/linux/uImage
8895605 bytes read in 544 ms (15.6 MiB/s)
reading bananapi/berryboot.img
** Unable to read file bananapi/berryboot.img **
bootm flag=0, states=70f
## Booting kernel from Legacy Image at 84000000 ...
   Image Name:   Linux Kernel 4.14.34-main
   Data Size:    8895541 Bytes = 8.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
Starting kernel ...
in 4.14 the needed commands are:
  • ./build.sh importconfig
  • ./build.sh config to add raid-support
  • ./build.sh
The tar contains folders bpi-boot for uImage and bpi-root for modulesā€¦extract with same folders to the right partition
For debug you can use this Steps (done that for dma-debug):
To enable the earlyprintk :
-> make menuconfig -> kernel hacking -> early printk
options used to have the debugs on the serial port :
root=/dev/mmcblk0p2 rootfstype=ext4 rootwait console=ttyS0,115200 earlycon=uart8250,mmio32,0x11004000 earlyprintk=serial,ttyS0,115200 debug=7 loglevel=7 initcall_debug=1 ignore_loglevel=1 bootopts=vmalloc=496M
As I found a little free time Iā€™m back to this task :slight_smile: After enabling debug I have: https://pastebin.com/BXXqwGMn So, I think I have not enabled some important options in kernel config, right?
@frank-w ./build.sh importconfig will be working only the system running from BPI-R2 motherboards, right? Iā€™m compile this kernel on Virtual machine with Ubuntu 16.04 so, importconfig will be works on x86_64 arch too?
It maybe important: I use BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz
bpi-bootsel BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz /dev/mmcblk1boot0
build.sh from my repo works also with crosscompileā€¦i also compile on x86_64.
You can look in my defconfig and compare with yours
Preloader has nothing to do with kernelā€¦you do not need to change it
Try using an existing image and only replace uImage on boot-part and add modules folder to rootā€¦just to verify your kernel works
As for your log it seems pinctl-driver (mt2701) is missing
could not find pctldev for node /pinctrl@10005000/pcie_pin_default,
Iā€™m update my local kernel source to 4.14.39 from your git repo. Run
and then
./build.sh config
to add RAID support. After that I compile the kernel using
./build.sh build
and then copy kernel image and modules to correct path on SDCard. When I have:
options for debug in uEnv.txt the boot process hangs on
[    4.289399] initcall exar_pci_driver_init+0x0/0x30 returned 0 after 30 usecs
[    4.296439] calling  mtk8250_platform_driver_init+0x0/0x28 @ 1
[    4.322980] 11004000.serial: ttyS0 at MMIO 0x11004000 (irq = 197, base_baud = 1625000) is a ST16650V2
If Iā€™m back to default options in uEnv.txt file BPI finish booting and I can logon to OS but HDMI not works :confused:
In kernel 4.14.39 - it is possible to have old network interface name eth0 and eth1 instead wan@eth0 lanX@eth0 etc.?
