Build custom image
Hi everyone,
Exist any member in this forum that can explain me how can I build my own custom Debian (or any Linux distribution) distribution for the BPI-M3? I tried a lot of kind of things but I never get an image who works. I need a lite and clean Linux, only with a few of packages that I need.
Months ago I was using a lite debian image who I downloaded from this forum but with the new BPI-M3 it is not recognize the new eMMC. I used bpi-tools to update but didn’t work, it breaks with kernel panic error.
Thank you.
Hello, Here are the steps for making an image:
http://wiki.banana-pi.org/Getting_Started_with_M3#Make_your_own_image
for emmc, you could find solution here :slight_smile:
I use how to update image to support new emmc as an example.
http://wiki.banana-pi.org/Getting_Started_with_M3#Update_your_image
Not sure about new eMMC, don’t have it, try: https://dl.armbian.com/bananapim3/
If it works, with this:
https://github.com/armbian/build with EXPERT=“yes” you get access to unofficially supported configurations.
you can build your custom image.
Hi Jackzeng,
Thank you but I couldn’t make a simple image, I’m try it with bsp but never works. Yes, to update image to support new emmc works fine but it doesn’t exist a simple image to download, therefore I’m trying to make one.
Hi igorpec,
Thank you, I tested this Armbian image but doesn’t work fine to me, I have problems with the network, the emmc and the realtime privileges (and other things that I don’t use it). I’ll work on them with the unofficially configurations.
Surely there are problems and shortcomings but this is the best what exists with a modern kernel. I didn’t notice network problems and my eMMC works. I am not familiar with stock Allwinner BSP kernel state and compilation for this board. K3.4.y is too old to waste time with.
At least we have a stable and supported build environment to start with.
Which you have share about build coustom image a good one I share a link where I want to start up online website is it good for my website. https://www.webtoolsoffers.com/
