BPI-Webduino:bit Basic functional testing
Banana pi BPI-webduino:bit function demo
BPI-Webduino:bit
Development environment:Atom+PlatformIO(Visual Studio Code+PlatformIO)
Need to install ESP32 platform and WS2812 driver library
PIO_platforms
PIO_llibraries
Code
		//BIT NEW
//BPI - BIT test code
#include <Arduino.h>
#include <NeoPixelBus.h>
#include "WiFi.h"
#define LEDC_CHANNEL_0 0
#define LEDC_TIMER_13_BIT 13
#define LEDC_BASE_FREQ 4500
const char *ssid = "SSID";
const char *password = "PASSWD";
const uint16_t PixelCount = 25;
const uint8_t PixelPin = 4;
#define colorSaturation 64
#define delay_ms 500
#define bout 3
NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin);
RgbColor red(colorSaturation, 0, 0);
RgbColor green(0, colorSaturation, 0);
RgbColor blue(0, 0, colorSaturation);
RgbColor white(colorSaturation);
RgbColor black(0);
HslColor hslRed(red);
HslColor hslGreen(green);
HslColor hslBlue(blue);
HslColor hslWhite(white);
HslColor hslBlack(black);
#define LUM0 36 //ADC1_CH0
#define LUM1 39 //ADC1_CH3
#define Temp 34 //ADC2_CH7
#define Buzzer 25
#define BottomA 35
#define BottomB 27
int LUM_Value0 = 0;
int LUM_Value1 = 0;
int Temp_value = 0;
int adTestFreq = 0;
int wifiTestFreq = 0;
int ledTestFreq = 0;
int BuzzerTestFreq = 0;
int brightness = 0;
int fadeAmount = 5;
void ledcAnalogWrite(uint8_t channel, uint32_t value)
	// calculate duty, 8191 from 2 ^ 13 - 1 (2 ^ LEDC_TIMER_13_BIT - 1)
	//value_MAX = 255
	uint32_t duty = (8191 / 255) * value;
	// write duty to LEDC
	ledcWrite(channel, duty);
void setup()
	Serial.begin(115200); //Serial Port Config 115200-8-N-1
	while (!Serial)
		; // wait for serial attach
	Serial.println();
	Serial.println("Initializing...");
	Serial.flush();
	// this resets all the neopixels to an off state
	strip.Begin();
	strip.Show();
	Serial.println();
	Serial.println("BPI-BIT Function Test Demo");
	Serial.println("Running...");
	Serial.println();
	ledcSetup(LEDC_CHANNEL_0, LEDC_BASE_FREQ, LEDC_TIMER_13_BIT);
	ledcAttachPin(Buzzer, LEDC_CHANNEL_0);
void loop()
	 ***Board:BPI-Webduino:BIT                                  ***
	 ***Function:LED(WS2812) Test                               ***
	Serial.println();
	Serial.println("LED test!!!");
	Serial.println();
	for (ledTestFreq = 0; ledTestFreq < bout; ledTestFreq++)
		int i;
		delay(delay_ms);
		Serial.println("Colors R");
		for (i = 0; i <= PixelCount - 1; i++)
			strip.SetPixelColor(i, hslRed);
			strip.Show();
		delay(delay_ms);
		Serial.println("Colors B");
			strip.SetPixelColor(i, hslBlue);
			strip.Show();
		delay(delay_ms);
		Serial.println("Colors G");
			strip.SetPixelColor(i, hslGreen);
			strip.Show();
		delay(delay_ms);
		Serial.println("Colors W");
			strip.SetPixelColor(i, hslWhite);
			strip.Show();
		delay(delay_ms);
		Serial.println("Turn Off");
			strip.SetPixelColor(i, hslBlack);
			strip.Show();
		Serial.println();
	Serial.println("--Over--");
	 ***Function:ADC Test                                       ***
	Serial.println();
	Serial.println("ADC test!!!");
	Serial.println();
	for (adTestFreq = 0; adTestFreq < bout; adTestFreq++)
		// turn the LED on (HIGH is the voltage level)
		LUM_Value0 = analogRead(LUM0);
		LUM_Value1 = analogRead(LUM1);
		Temp_value = analogRead(Temp);
		Serial.println();
		Serial.println("----LUM&Temp Test(AD Test)----");
		//LUM0--ADC1_CH0-Pin:IO36
		Serial.print("LUM0:");
		Serial.print(LUM_Value0);
		Serial.println();
		//LUM1--ADC1_CH3-Pin:IO39
		Serial.print("LUM1:");
		Serial.print(LUM_Value1);
		Serial.println();
		//Temp--ADC2_CH7-Pin:IO27
		Serial.print("TEMP:");
		Serial.print(Temp_value);
		Serial.println();
		delay(delay_ms);
		Serial.println();
	 ***Function:Wi-Fi Test                                     ***
	Serial.println();
	Serial.println("Wi-Fi test!!!");
	Serial.println();
	// //Wi-Fi connect
	// Serial.print("Connecting to ");
	// Serial.println(ssid);
	// WiFi.begin(ssid, password);
	// while (WiFi.status() != WL_CONNECTED)
	//     delay(500);
	//     Serial.print(".");
	// Serial.println("WiFi connected");
	// Serial.println("IP address: ");
	// Serial.println(WiFi.localIP());
	// Serial.println("Setup done");
	// Serial.println("");
	// WiFi.disconnect();
	for (wifiTestFreq = 0; wifiTestFreq < 1; wifiTestFreq++)
		Serial.println("scan start");
		// WiFi.scanNetworks will return the number of networks found
		int n = WiFi.scanNetworks();
		Serial.println("scan done");
		if (n == 0)
			Serial.println("no networks found");
		else
			Serial.print(n);
			Serial.println(" networks found");
			for (int j = 0; j < n; ++j)
				// Print SSID and RSSI for each network found
				Serial.print(j + 1);
				Serial.print(": ");
				Serial.print(WiFi.SSID(j));
				Serial.print(" (");
				Serial.print(WiFi.RSSI(j));
				Serial.print(")");
				Serial.println((WiFi.encryptionType(j) == WIFI_AUTH_OPEN) ? " " : "*");
				delay(10);
		Serial.println("");
		// Wait a bit before scanning again
		delay(2000);
	 ***Function:Buzzer Test                                    ***
	Serial.println();
	Serial.println("Buzzer Test!!!");
	Serial.println();
	Serial.println("Buzzer is fading");
	for (BuzzerTestFreq = 0; BuzzerTestFreq < bout; BuzzerTestFreq++)
		for (brightness = 0; brightness < 255; brightness++)
			Serial.print(".");
			// set the brightness on LEDC channel 0
			ledcAnalogWrite(LEDC_CHANNEL_0, brightness);
			// change the brightness for next time through the loop:
			brightness = brightness + fadeAmount;
			// reverse the direction of the fading at the ends of the fade:
			if (brightness <= 0 || brightness >= 255)
				fadeAmount = -fadeAmount;
			// wait for 30 milliseconds to see the dimming effect
			delay(30);
		Serial.println();
		ledcAnalogWrite(LEDC_CHANNEL_0, 0);
	Serial.println("---------Test Over !!!---------");
  • 1 After compiling pass, connect BIT board to the computer, download into BIT board. The program will run automatically, WS2812 Programmable Full Color LED Test Loop Three Times (Display Color Order: Red, Blue, Green, White, Black) ADC sampled three times (channel: ADC1_CH0(LUM0)/ADC1_CH3(LUM1)/ADC1_CH6(TEMP)) Wi-Fi scan once (scan available Wi-Fi signal and signal strength) Buzzer test three times (cycle test three times with duty cycle gradient)
  • 2Test results return View method:
Serial port 115200-8-N-1 settings like, will show the results of each step of the test
