I need docker service. After applying docker service in openwrt master branch. Rootfs and recovery will be larger. Now openwrt MediaTek mt7622 bananapi_ Bpi-r64-sdcard.img.gz is about 117mb
I modified target / Linux / MediaTek / image / mt7622.mk as follows
diff --git a/target/linux/mediatek/image/mt7622.mk b/target/linux/mediatek/image/mt7622.mk
index 6077e623ff..e0f37f9f49 100644
--- a/target/linux/mediatek/image/mt7622.mk
+++ b/target/linux/mediatek/image/mt7622.mk
@@ -45,13 +45,13 @@ define Build/mt7622-gpt
-t 0xef -N fip -r -p 2M@2M \
-t 0x83 -N ubootenv -r -p 1M@4M \
- -N recovery -r -p 32M@6M \
+ -N recovery -r -p 64M@6M \
$(if $(findstring sdmmc,$1), \
- -N install -r -p 7M@38M \
- -t 0x2e -N production -p 211M@45M \
+ -N install -r -p 7M@70M \
+ -t 0x2e -N production -p 422M@77M \
$(if $(findstring emmc,$1), \
- -t 0x2e -N production -p 980M@40M \
+ -t 0x2e -N production -p 980M@72M \
cat [email protected] >> $@
rm [email protected]
@@ -87,12 +87,12 @@ define Device/bananapi_bpi-r64
pad-to 512k | bl2 sdmmc-2ddr |\
pad-to 2048k | bl31-uboot bananapi_bpi-r64-sdmmc |\
pad-to 6144k | append-image-stage initramfs-recovery.itb |\
- pad-to 38912k | mt7622-gpt emmc |\
- pad-to 39424k | bl2 emmc-2ddr |\
- pad-to 40960k | bl31-uboot bananapi_bpi-r64-emmc |\
- pad-to 43008k | bl2 snand-2ddr |\
- pad-to 43520k | bl31-uboot bananapi_bpi-r64-snand |\
- pad-to 46080k | append-image squashfs-sysupgrade.itb | gzip
+ pad-to 71680k | mt7622-gpt emmc |\
+ pad-to 72192k | bl2 emmc-2ddr |\
+ pad-to 72704k | bl31-uboot bananapi_bpi-r64-emmc |\
+ pad-to 75264k | bl2 snand-2ddr |\
+ pad-to 75776k | bl31-uboot bananapi_bpi-r64-snand |\
+ pad-to 78848k | append-image squashfs-sysupgrade.itb | gzip
KERNEL := kernel-bin | gzip
KERNEL_INITRAMFS := kernel-bin | lzma | fit lzma $$(DTS_DIR)/$$(DEVICE_DTS).dtb with-initrd | pad-to 128k
IMAGE/sysupgrade.itb := append-kernel | fit gzip $$(DTS_DIR)/$$(DEVICE_DTS).dtb external-static-with-rootfs | append-metadata
CRC 32 error after booting rootfs
switch to partitions #0, OK
mmc1 is current device
MMC read: dev # 1, block # 157696, count 8 ... 8 blocks read: OK
MMC read: dev # 1, block # 157696, count 135624 ... 135624 blocks read: OK
## Loading kernel from FIT Image at 4007ff28 ...
Using 'config-mt7622-bananapi-bpi-r64-pcie1' configuration
Description: ARM64 OpenWrt Linux-5.10.35
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x40080f28
Data Size: 5288381 Bytes = 5 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x44000000
Entry Point: 0x44000000
Hash algo: crc32
Hash value: eed74fd6
Hash algo: sha1
Hash value: ada2c8f3727ee90fed9cb7e6a960b43159c9ccd7
## Loading fdt from FIT Image at 4007ff28 ...
Trying 'fdt-1' fdt subimage
Description: ARM64 OpenWrt bananapi_bpi-r64 device tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x4058cf28
Data Size: 31796 Bytes = 31.1 KiB
Load Address: 0x43ff83cc
Hash algo: crc32
Hash value: 5f04dd9c
Hash algo: sha1
Hash value: b6b5aa7f9adb7cdfb82e98a1366b88e5e6a182c0
Loading fdt from 0x4058cf28 to 0x43ff83cc
Trying 'fdt-mt7622-bananapi-bpi-r64-pcie1' fdt subimage
Description: ARM64 OpenWrt bananapi_bpi-r64 device tree overlay mt7622-bananapi-bpi-r64-pcie1
Data Start: 0x40594f28
Data Size: 408 Bytes = 408 Bytes
Load Address: 0x43ff8234
Hash algo: crc32
Hash value: 7a017eca
Hash algo: sha1
Hash value: 1c9ab4777c11f5fedb5674c69e7e4c456960fe8a
Loading fdt from 0x40594f28 to 0x43ff8234
Booting using the fdt blob at 0x43ff83cc
## Loading loadables from FIT Image at 4007ff28 ...
Trying 'rootfs-1' loadables subimage
Description: ARM64 OpenWrt bananapi_bpi-r64 rootfs
Type: Filesystem Image
Data Start: 0x40596f28
Data Size: 64102400 Bytes = 61.1 MiB
Hash algo: crc32
Hash value: 84e7f94d
Hash algo: sha1
Hash value: ea2152c599600dd392ec96af9140463c94c48fc1
Verifying Hash Integrity ... crc32 error!
Bad hash value for 'hash@1' hash node in 'rootfs-1' image node
Bad Data Hash
Loadable(s) is corrupt or invalid
MMC read: dev # 1, block # 12288, count 8 ... 8 blocks read: OK
MMC read: dev # 1, block # 12288, count 93044 ... 93044 blocks read: OK
There are also “reserved-memory/FDT_ERR_EXISTS” errors
MMC read: dev # 1, block # 157696, count 122864 ... 122864 blocks read: OK
Type: Kernel Image
Data Size: 5288263 Bytes = 5 MiB
OS: Linux
Hash algo: crc32
Hash value: 8ae05828
Hash algo: sha1
Hash value: 754874c0096326cb2a5b21bdce7c062390e4251f
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
Data Size: 57569280 Bytes = 54.9 MiB
Hash algo: crc32
Hash value: cc899a00
Hash algo: sha1
Hash value: 0c9f4e6c926aa7cad91b829fc843ee7e090f8d93
Uncompressing Kernel Image
Loading Device Tree to 000000007f7f0000, end 000000007f7fac2f ... OK
Add 'reserved-memory' node failed: FDT_ERR_EXISTS
Starting kernel ...
how to solve this problem… thk!
