[BPI-R64] OpenWRT kernel 5.4.40 running from eMMC
Both mt7622 and mt7615 are loaded correctly and run smoothly on my board.
   11.570554] kmodloader: done loading kernel modules from /etc/modules.d/*
[   11.687303] mt7615e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a
[   11.687303]
[   11.687306] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[   11.687306]
[   11.963927] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
[   12.098384] mt7615e 0000:01:00.0: N9 Firmware Version: 2.0, Build Time: 20200131181812
[   12.126014] mt7615e 0000:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20190121161307
MT7622 onboard WiFi actually shares the same firmware download procedure with BT. However, the driver currently lacks of mechanism to sync both components that cross the subsystem. Try to disable btif node in dts to keep them mutually exclusive for the moment. Will fix it in spare time.
More specifically, you may need to apply this patch to get BT work. https://patchwork.kernel.org/patch/11504383/
And just for clarification, you are using Openwrt Image generated with steps from first post?
Hi. Yes, I followed the steps exactly as enumerated in post #1. Thus after the build, I am copying the files build_dir/target-aarch64_cortex-a53_musl/linux-mediatek_mt7622/{bpi_bananapi-r64-kernel.bin,image-mt7622-bananapi-bpi-r64.dtb,root.ext4} to r64-boot on the SDcard and mounting the SDcard as /media/sdb1 on R64 and running update.sh to flash to eMMC.
From @niebieski20 and @Ryder.Lee responses, it is not clear if mt7622 is not releasing the semaphore or if BTIF is causing the problem.
In either case, I would like to try to disable both: mt67622-onboard-wifi and btif and enable only the mt7615. How do I do that? I guess I need to edit one or both: mt7622-bananapi-bpi-r64.dts or mt7622.dtsi files.
To respond to earlier messages: my experience is the same as @svintuss as far as the patch semaphore timedout is concerned. Actually, I sometimes get a kernel crash from the mt7615 driver too – but I don’t want to distract this thread. Here is my bootlog (note: there are some extra messages showing from additional dev_info() messages I added into the driver code)
Bootlog where patch semaphore timedout error occurs:
[    0.000000] Linux version 5.4.40 (mikamble@AUS-LX-MIKAMBLE) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r13225-bc0288b768)) #0 SMP Wed May 13 09:16:43 2020
[    0.000000] Machine model: Bananapi BPI-R64
[    0.000000] On node 0 totalpages: 262096
[    0.000000]   DMA32 zone: 4096 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 262096 pages, LIFO batch:63
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 20 pages/cpu s43608 r8192 d30120 u81920
[    0.000000] pcpu-alloc: s43608 r8192 d30120 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258000
[    0.000000] Kernel command line: board=bpi-r64 console=ttyS0,115200n1 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rootwait service=linux debug=7 initcall_debug=0 androidboot.hardware=mt7622 swiotlb=512
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] Memory: 1018404K/1048384K available (6590K kernel code, 432K rwdata, 1896K rodata, 448K init, 285K bss, 29980K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: 	CONFIG_RCU_FANOUT set to non-default value of 32.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[    0.000000] random: get_random_bytes called from start_kernel+0x2d4/0x42c with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[    0.000003] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[    0.000161] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=50000)
[    0.000168] pid_max: default: 32768 minimum: 301
[    0.000254] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.000265] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.001142] ASID allocator initialised with 65536 entries
[    0.001191] rcu: Hierarchical SRCU implementation.
[    0.001447] smp: Bringing up secondary CPUs ...
[    0.001764] Detected VIPT I-cache on CPU1
[    0.001800] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.001853] smp: Brought up 1 node, 2 CPUs
[    0.001859] SMP: Total of 2 processors activated.
[    0.001863] CPU features: detected: 32-bit EL0 Support
[    0.001867] CPU features: detected: CRC32 instructions
[    0.001968] CPU: All CPU(s) started at EL2
[    0.001978] alternatives: patching kernel code
[    0.005113] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.005125] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.005216] pinctrl core: initialized pinctrl subsystem
[    0.005640] NET: Registered protocol family 16
[    0.005924] DMA: preallocated 256 KiB pool for atomic allocations
[    0.016850] GPIO line 499 (asm_sel) hogged as output/high
[    0.029482] SCSI subsystem initialized
[    0.029639] libata version 3.00 loaded.
[    0.029778] usbcore: registered new interface driver usbfs
[    0.029804] usbcore: registered new interface driver hub
[    0.029831] usbcore: registered new device driver usb
[    0.030599] Bluetooth: Core ver 2.22
[    0.030636] NET: Registered protocol family 31
[    0.030640] Bluetooth: HCI device and connection manager initialized
[    0.030648] Bluetooth: HCI socket layer initialized
[    0.030654] Bluetooth: L2CAP socket layer initialized
[    0.030664] Bluetooth: SCO socket layer initialized
[    0.031119] clocksource: Switched to clocksource arch_sys_counter
[    0.031597] thermal_sys: Registered thermal governor 'fair_share'
[    0.031600] thermal_sys: Registered thermal governor 'bang_bang'
[    0.031604] thermal_sys: Registered thermal governor 'step_wise'
[    0.031608] thermal_sys: Registered thermal governor 'user_space'
[    0.031611] thermal_sys: Registered thermal governor 'power_allocator'
[    0.031869] NET: Registered protocol family 2
[    0.032168] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.032185] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.032237] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.032343] TCP: Hash tables configured (established 8192 bind 8192)
[    0.032431] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.032456] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.032547] NET: Registered protocol family 1
[    0.032565] PCI: CLS 0 bytes, default 64
[    0.033420] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.036789] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.036799] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.049942] mtk-tphy 1a0c4000.usb-phy: failed to get ref_clk(id-1)
[    0.053106] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[    0.067102] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.067772] printk: console [ttyS0] disabled
[    0.088136] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 118, base_baud = 1562500) is a ST16650V2
[    0.629684] printk: console [ttyS0] enabled
[    0.654530] 11004000.serial: ttyS1 at MMIO 0x11004000 (irq = 119, base_baud = 1562500) is a ST16650V2
[    0.664206] 1100c000.serial: ttyS2 at MMIO 0x1100c000 (irq = 125, base_baud = 17499995) is a MediaTek BTIF
[    0.673943] serial serial0: tty port ttyS2 registered
[    0.679199] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.686695] libphy: Fixed MDIO Bus: probed
[    0.714135] libphy: mdio: probed
[    0.717400] mtk_soc_eth 1b100000.ethernet: generated random MAC address 8a:cc:95:2c:91:d5
[    0.725845] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffffc011480000, irq 134
[    0.735000] mtk_soc_eth 1b100000.ethernet: generated random MAC address 36:b3:8d:b5:6d:e3
[    0.743378] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffffc011480000, irq 134
[    0.752590] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.759114] ehci-pci: EHCI PCI platform driver
[    0.763584] ehci-platform: EHCI generic platform driver
[    0.768916] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.775111] ohci-platform: OHCI generic platform driver
[    0.780875] usbcore: registered new interface driver usb-storage
[    0.787255] rtc_mt7622 10212800.rtc: registered as rtc0
[    0.793141] Driver for 1-wire Dallas network protocol.
[    0.798486] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[    0.807665] mtk-wdt 10212000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    0.815496] Bluetooth: HCI UART driver ver 2.3
[    0.819935] Bluetooth: HCI UART protocol H4 registered
[    0.825067] Bluetooth: HCI UART protocol BCSP registered
[    0.830426] Bluetooth: HCI UART protocol Broadcom registered
[    0.836095] Bluetooth: HCI UART protocol QCA registered
[    0.867482] mtk-msdc 11240000.mmc: Got CD GPIO
[    0.897596] NET: Registered protocol family 10
[    0.902660] Segment Routing with IPv6
[    0.906371] NET: Registered protocol family 17
[    0.910834] 8021q: 802.1Q VLAN Support v1.8
[    0.925734] mtk-pcie 1a140000.pcie: host bridge /pcie@1a140000 ranges:
[    0.932284] mtk-pcie 1a140000.pcie: Parsing ranges property...
[    0.938121] mtk-pcie 1a140000.pcie:   MEM 0x20000000..0x2fffffff -> 0x20000000
[    0.945537] mtk-pcie mtk_pcie_startup_port_v2. training timeout set to 1000. portbase=10b05000
[    0.969575] mtk-pcie mtk_pcie_startup_port_v2. training timeout set to 1000. portbase=10b0d000
[    0.996729] mtk-msdc 11230000.mmc: phase: [map:1fffffff] [maxlen:29] [final:9]
[    1.013332] mmc0: new HS200 MMC card at address 0001
[    1.019455] mmcblk0: mmc0:0001 008G30 7.28 GiB
[    1.024877] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
[    1.031700] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
[    1.037679] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB, chardev (250:0)
[    1.046212]  mmcblk0: p1 p2
[    1.978215] mtk-pcie mtk_pcie_startup_port_v2. poll timeout. err=-110
[    1.978223] mtk-pcie 1a140000.pcie: Port1 link down
[    1.989639] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
[    1.995823] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.001306] pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
[    2.008178] pci_bus 0000:00: scanning bus
[    2.012214] pci 0000:00:00.0: [14c3:3258] type 01 class 0x060400
[    2.018257] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x1ffffffff 64bit pref]
[    2.026871] pci_bus 0000:00: fixups for bus
[    2.031057] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[    2.037754] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.045764] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[    2.052549] pci_bus 0000:01: scanning bus
[    2.056683] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280
[    2.062915] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
[    2.070624] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:00.0 (capable of 4.000 Gb/s with 5 GT/s x1 link)
[    2.085605] pci_bus 0000:01: fixups for bus
[    2.089787] pci_bus 0000:01: bus scan returning with max=01
[    2.095357] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.101971] pci_bus 0000:00: bus scan returning with max=01
[    2.107553] pci 0000:00:00.0: BAR 0: no space for [mem size 0x200000000 64bit pref]
[    2.115205] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x200000000 64bit pref]
[    2.123205] pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff]
[    2.129992] pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x200fffff 64bit]
[    2.137380] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.142347] pci 0000:00:00.0:   bridge window [mem 0x20000000-0x200fffff]
[    2.149329] mtk_hsdma 1b007000.dma-controller: Using 3 as missing dma-requests property
[    2.157513] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[    2.723148] mt753x gsw@0: LAN/WAN VLAN setting=wllll
[    2.728577] mt753x gsw@0: Switch is MediaTek MT7531BE rev 0
[    7.380242] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[    7.385477] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[    7.394521] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000210010
[    7.403594] xhci-mtk 1a0c0000.usb: irq 130, io mem 0x1a0c0000
[    7.409725] hub 1-0:1.0: USB hub found
[    7.413490] hub 1-0:1.0: 2 ports detected
[    7.417711] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[    7.422940] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[    7.430337] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[    7.436632] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.444940] hub 2-0:1.0: USB hub found
[    7.448701] hub 2-0:1.0: 1 port detected
[    7.452968] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01T00:12:31 UTC (946685551)
[    7.463919] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    7.471229] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    7.483042] EXT4-fs (mmcblk0p2): recovery complete
[    7.488892] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    7.497022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    7.504000] Freeing unused kernel memory: 448K
[    7.515150] Run /sbin/init as init process
[    7.580557] init: Console is alive
[    7.584058] init: - watchdog -
[    7.622985] random: fast init done
[    7.721046] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    7.734997] ehci-fsl: Freescale EHCI Host controller driver
[    7.744960] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    7.760863] init: - preinit -
[    7.842281] mtk_soc_eth 1b100000.ethernet: PPE started
[    7.847473] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[    7.855791] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
4
[   10.859270] mount_root: mounting /dev/root
[   10.864988] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   10.870489] mount_root: loading kmods from internal overlay
[   10.884545] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[   10.892162] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[   10.966567] urandom-seed: Seeding with /etc/urandom.seed
[   10.984526] procd: Change state 0 -> 1
[   10.988329] procd: - early -
[   10.991225] procd: Watchdog handover: fd=3
[   10.995334] procd: - watchdog -
[   10.998487] procd: Ping
[   11.000958] procd: Opened watchdog with timeout 30s
[   11.012721] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/mem/full","SUBSYSTEM":"mem","SYNTH_UUID":"0","MAJOR":"1","MINOR":"7","DEVNAME":"full","DEVMODE":"0666","SEQNUM":"612"}}
[   11.029345] procd: Command: makedev
[   11.032910] procd:  /dev/full
[   11.036226] procd:  0666
[   11.038817] procd: Message:
[   11.041701] procd:  ACTION=add
[   11.044804] procd:  DEVPATH=/devices/virtual/mem/full
[   11.049918] procd:  SUBSYSTEM=mem
[   11.053266] procd:  SYNTH_UUID=0
[   11.056538] procd:  MAJOR=1
[   11.059363] procd:  MINOR=7
[   11.062192] procd:  DEVNAME=full
[   11.065492] procd:  DEVMODE=0666
[   11.068792] procd:  SEQNUM=612
[   11.072011] procd: Finished udevtrigger
[   11.075948] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/mem/null","SUBSYSTEM":"mem","SYNTH_UUID":"0","MAJOR":"1","MINOR":"3","DEVNAME":"null","DEVMODE":"0666","SEQNUM":"613"}}
[   11.092345] procd: Command: makedev
[   11.095873] procd:  /dev/null
[   11.098847] procd:  0666
[   11.101400] procd: Message:
[   11.104210] procd:  ACTION=add
[   11.107276] procd:  DEVPATH=/devices/virtual/mem/null
[   11.112339] procd:  SUBSYSTEM=mem
[   11.115666] procd:  SYNTH_UUID=0
[   11.118898] procd:  MAJOR=1
[   11.121704] procd:  MINOR=3
[   11.124510] procd:  DEVNAME=null
[   11.127748] procd:  DEVMODE=0666
[   11.130982] procd:  SEQNUM=613
[   11.134087] procd: Finished hotplug exec instance, pid=741
[   11.139789] procd: Launched hotplug exec instance, pid=769
[   11.145415] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/cpu_dma_latency","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"63","DEVNAME":"cpu_dma_latency","SEQNUM":"614"}}
[   11.162736] procd: Command: makedev
[   11.166254] procd:  /dev/cpu_dma_latency
[   11.170192] procd:  0600
[   11.172740] procd: Message:
[   11.175547] procd:  ACTION=add
[   11.178607] procd:  DEVPATH=/devices/virtual/misc/cpu_dma_latency
[   11.184711] procd:  SUBSYSTEM=misc
[   11.188124] procd:  SYNTH_UUID=0
[   11.191364] procd:  MAJOR=10
[   11.194251] procd:  MINOR=63
[   11.197143] procd:  DEVNAME=cpu_dma_latency
[   11.201337] procd:  SEQNUM=614
[   11.204503] procd: Finished hotplug exec instance, pid=769
[   11.210046] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/vhci","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"137","DEVNAME":"vhci","SEQNUM":"615"}}
[   11.225402] procd: Command: makedev
[   11.228903] procd:  /dev/vhci
[   11.231883] procd:  0600
[   11.234421] procd: Message:
[   11.237227] procd:  ACTION=add
[   11.240293] procd:  DEVPATH=/devices/virtual/misc/vhci
[   11.245442] procd:  SUBSYSTEM=misc
[   11.248855] procd:  SYNTH_UUID=0
[   11.252093] procd:  MAJOR=10
[   11.254980] procd:  MINOR=137
[   11.257958] procd:  DEVNAME=vhci
[   11.261197] procd:  SEQNUM=615
[   11.264341] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/10212000.watchdog/misc/watchdog","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"130","DEVNAME":"watchdog","SEQNUM":"616"}}
[   11.282040] procd: Command: makedev
[   11.285546] procd:  /dev/watchdog
[   11.288886] procd:  0600
[   11.291431] procd: Message:
[   11.294231] procd:  ACTION=add
[   11.297298] procd:  DEVPATH=/devices/platform/10212000.watchdog/misc/watchdog
[   11.304444] procd:  SUBSYSTEM=misc
[   11.307858] procd:  SYNTH_UUID=0
[   11.311092] procd:  MAJOR=10
[   11.313984] procd:  MINOR=130
[   11.316963] procd:  DEVNAME=watchdog
[   11.320550] procd:  SEQNUM=616
[   11.323697] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/ptmx","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"5","MINOR":"2","DEVNAME":"ptmx","DEVMODE":"0666","SEQNUM":"617"}}
[   11.340058] procd: Command: makedev
[   11.343558] procd:  /dev/ptmx
[   11.346531] procd:  0666
[   11.349075] procd: Message:
[   11.351880] procd:  ACTION=add
[   11.354940] procd:  DEVPATH=/devices/virtual/tty/ptmx
[   11.360003] procd:  SUBSYSTEM=tty
[   11.363329] procd:  SYNTH_UUID=0
[   11.366563] procd:  MAJOR=5
[   11.369369] procd:  MINOR=2
[   11.372173] procd:  DEVNAME=ptmx
[   11.375412] procd:  DEVMODE=0666
[   11.378645] procd:  SEQNUM=617
[   11.381751] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/console","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"5","MINOR":"1","DEVNAME":"console","SEQNUM":"618"}}
[   11.397190] procd: Command: makedev
[   11.400695] procd:  /dev/console
[   11.403944] procd:  0600
[   11.406482] procd: Message:
[   11.409288] procd:  ACTION=add
[   11.412354] procd:  DEVPATH=/devices/virtual/tty/console
[   11.417677] procd:  SUBSYSTEM=tty
[   11.421003] procd:  SYNTH_UUID=0
[   11.424242] procd:  MAJOR=5
[   11.427042] procd:  MINOR=1
[   11.429848] procd:  DEVNAME=console
[   11.433347] procd:  SEQNUM=618
[   11.436487] procd: Command: exec
[   11.439728] procd:  /sbin/hotplug-call
[   11.443487] procd:  tty
[   11.445938] procd: Message:
[   11.448744] procd:  ACTION=add
[   11.451809] procd:  DEVPATH=/devices/virtual/tty/console
[   11.457131] procd:  SUBSYSTEM=tty
[   11.460456] procd:  SYNTH_UUID=0
[   11.463695] procd:  MAJOR=5
[   11.466494] procd:  MINOR=1
[   11.469299] procd:  DEVNAME=console
[   11.472799] procd:  SEQNUM=618
[   11.476067] procd: Launched hotplug exec instance, pid=774
[   11.481776] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/11002000.serial/tty/ttyS0","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"64","DEVNAME":"ttyS0","SEQNUM":"619"}}
[   11.498606] procd: Command: makedev
[   11.502142] procd:  /dev/ttyS0
[   11.505257] procd:  0660
[   11.507805] procd:  dialout
[   11.510604] procd: Message:
[   11.513411] procd:  ACTION=add
[   11.516477] procd:  DEVPATH=/devices/platform/11002000.serial/tty/ttyS0
[   11.523116] procd:  SUBSYSTEM=tty
[   11.526438] procd:  SYNTH_UUID=0
[   11.529690] procd:  MAJOR=4
[   11.532496] procd:  MINOR=64
[   11.535388] procd:  DEVNAME=ttyS0
[   11.538709] procd:  SEQNUM=619
[   11.542846] procd: Command: makedev
[   11.546366] procd:  /dev/ttyS0
[   11.549434] procd:  0600
[   11.551979] procd: Message:
[   11.554779] procd:  ACTION=add
[   11.557848] procd:  DEVPATH=/devices/platform/11002000.serial/tty/ttyS0
[   11.564474] procd:  SUBSYSTEM=tty
[   11.567802] procd:  SYNTH_UUID=0
[   11.571035] procd:  MAJOR=4
[   11.573842] procd:  MINOR=64
[   11.576735] procd:  DEVNAME=ttyS0
[   11.580062] procd:  SEQNUM=619
[   11.583209] procd: Command: exec
[   11.586443] procd:  /sbin/hotplug-call
[   11.590205] procd:  tty
[   11.592664] procd: Message:
[   11.595471] procd:  ACTION=add
[   11.598531] procd:  DEVPATH=/devices/platform/11002000.serial/tty/ttyS0
[   11.605158] procd:  SUBSYSTEM=tty
[   11.608484] procd:  SYNTH_UUID=0
[   11.611724] procd:  MAJOR=4
[   11.614524] procd:  MINOR=64
[   11.617418] procd:  DEVNAME=ttyS0
[   11.620744] procd:  SEQNUM=619
[   11.623837] procd: Finished hotplug exec instance, pid=774
[   11.629534] procd: Launched hotplug exec instance, pid=777
[   11.635170] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"5","MINOR":"0","DEVNAME":"tty","DEVMODE":"0666","SEQNUM":"620"}}
[   11.651454] procd: Command: makedev
[   11.654955] procd:  /dev/tty
[   11.657850] procd:  0666
[   11.660394] procd: Message:
[   11.663202] procd:  ACTION=add
[   11.666262] procd:  DEVPATH=/devices/virtual/tty/tty
[   11.671239] procd:  SUBSYSTEM=tty
[   11.674561] procd:  SYNTH_UUID=0
[   11.677801] procd:  MAJOR=5
[   11.680607] procd:  MINOR=0
[   11.683412] procd:  DEVNAME=tty
[   11.686560] procd:  DEVMODE=0666
[   11.689800] procd:  SEQNUM=620
[   11.692917] procd: Finished hotplug exec instance, pid=777
[   11.698464] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/11004000.serial/tty/ttyS1","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"65","DEVNAME":"ttyS1","SEQNUM":"621"}}
[   11.715149] procd: Command: makedev
[   11.718644] procd:  /dev/ttyS1
[   11.721730] procd:  0660
[   11.724275] procd:  dialout
[   11.727074] procd: Message:
[   11.729882] procd:  ACTION=add
[   11.732949] procd:  DEVPATH=/devices/platform/11004000.serial/tty/ttyS1
[   11.739575] procd:  SUBSYSTEM=tty
[   11.742895] procd:  SYNTH_UUID=0
[   11.746136] procd:  MAJOR=4
[   11.748941] procd:  MINOR=65
[   11.751838] procd:  DEVNAME=ttyS1
[   11.755166] procd:  SEQNUM=621
[   11.758295] procd: Command: makedev
[   11.761798] procd:  /dev/ttyS1
[   11.764864] procd:  0600
[   11.767409] procd: Message:
[   11.770209] procd:  ACTION=add
[   11.773277] procd:  DEVPATH=/devices/platform/11004000.serial/tty/ttyS1
[   11.779903] procd:  SUBSYSTEM=tty
[   11.783231] procd:  SYNTH_UUID=0
[   11.786463] procd:  MAJOR=4
[   11.789270] procd:  MINOR=65
[   11.792163] procd:  DEVNAME=ttyS1
[   11.795490] procd:  SEQNUM=621
[   11.798607] procd: Command: exec
[   11.801848] procd:  /sbin/hotplug-call
[   11.805609] procd:  tty
[   11.808067] procd: Message:
[   11.810867] procd:  ACTION=add
[   11.813954] procd:  DEVPATH=/devices/platform/11004000.serial/tty/ttyS1
[   11.820585] procd:  SUBSYSTEM=tty
[   11.823921] procd:  SYNTH_UUID=0
[   11.827162] procd:  MAJOR=4
[   11.829962] procd:  MINOR=65
[   11.832855] procd:  DEVNAME=ttyS1
[   11.836182] procd:  SEQNUM=621
[   11.839446] procd: Launched hotplug exec instance, pid=781
[   11.845071] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"179","MINOR":"0","DEVNAME":"mmcblk0","DEVTYPE":"disk","SEQNUM":"622"}}
[   11.865916] procd: Command: makedev
[   11.869428] procd:  /dev/mmcblk0
[   11.872667] procd:  0600
[   11.875212] procd: Message:
[   11.878012] procd:  ACTION=add
[   11.881080] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0
[   11.889875] procd:  SUBSYSTEM=block
[   11.893377] procd:  SYNTH_UUID=0
[   11.896617] procd:  MAJOR=179
[   11.899597] procd:  MINOR=0
[   11.902398] procd:  DEVNAME=mmcblk0
[   11.905899] procd:  DEVTYPE=disk
[   11.909139] procd:  SEQNUM=622
[   11.912330] procd: Command: exec
[   11.915572] procd:  /sbin/hotplug-call
[   11.919335] procd:  block
[   11.921959] procd: Message:
[   11.924767] procd:  ACTION=add
[   11.927835] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0
[   11.936632] procd:  SUBSYSTEM=block
[   11.940143] procd:  SYNTH_UUID=0
[   11.943398] procd:  MAJOR=179
[   11.946371] procd:  MINOR=0
[   11.949179] procd:  DEVNAME=mmcblk0
[   11.952679] procd:  DEVTYPE=disk
[   11.955920] procd:  SEQNUM=622
[   11.958999] procd: Finished hotplug exec instance, pid=781
[   11.964722] procd: Launched hotplug exec instance, pid=785
[   11.970349] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0boot0","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"179","MINOR":"8","DEVNAME":"mmcblk0boot0","DEVTYPE":"disk","SEQNUM":"623"}}
sh: write error:[   11.992739] procd: Command: makedev
[   11.997585] procd:  /dev/mmcblk0boot0
[   12.002622] procd:  0600
[   12.005173] procd: Message:
[   12.007980] procd:  ACTION=add
[   12.011042] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0boot0
[   12.020969] procd:  SUBSYSTEM=block
[   12.024470] procd:  SYNTH_UUID=0
[   12.027710] procd:  MAJOR=179
[   12.030683] procd:  MINOR=8
[   12.033489] procd:  DEVNAME=mmcblk0boot0
[   12.037424] procd:  DEVTYPE=disk
[   12.040664] procd:  SEQNUM=623
[   12.043843] procd: Command: exec
[   12.047078] procd:  /sbin/hotplug-call
[   12.050841] procd:  block
[   12.053483] procd: Message:
[   12.056303] procd:  ACTION=add
[   12.059371] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0boot0
[   12.069300] procd:  SUBSYSTEM=block
[   12.072801] procd:  SYNTH_UUID=0
[   12.076042] procd:  MAJOR=179
[   12.079015] procd:  MINOR=8
[   12.081822] procd:  DEVNAME=mmcblk0boot0
[   12.085758] procd:  DEVTYPE=disk
[   12.088998] procd:  SEQNUM=623
[   12.092083] procd: Finished hotplug exec instance, pid=785
[   12.097802] procd: Launched hotplug exec instance, pid=790
sh: write error:[   12.103465] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"179","MINOR":"1","DEVNAME":"mmcblk0p1","DEVTYPE":"partition","PARTN":"1","SEQNUM":"624"}}
[   12.128187] procd: Command: makedev
[   12.132898] procd:  /dev/mmcblk0p1
[   12.136410] procd:  0600
[   12.138951] procd: Message:
[   12.141760] procd:  ACTION=add
[   12.144827] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1
[   12.154491] procd:  SUBSYSTEM=block
[   12.157993] procd:  SYNTH_UUID=0
[   12.161234] procd:  MAJOR=179
[   12.164213] procd:  MINOR=1
[   12.167013] procd:  DEVNAME=mmcblk0p1
[   12.170693] procd:  DEVTYPE=partition
[   12.174367] procd:  PARTN=1
[   12.177174] procd:  SEQNUM=624
[   12.180353] procd: Command: exec
[   12.183596] procd:  /sbin/hotplug-call
[   12.187357] procd:  block
[   12.189981] procd: Message:
[   12.192788] procd:  ACTION=add
[   12.195855] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1
[   12.205519] procd:  SUBSYSTEM=block
[   12.209020] procd:  SYNTH_UUID=0
[   12.212260] procd:  MAJOR=179
[   12.215241] procd:  MINOR=1
[   12.218041] procd:  DEVNAME=mmcblk0p1
[   12.221715] procd:  DEVTYPE=partition
[   12.225389] procd:  PARTN=1
[   12.228194] procd:  SEQNUM=624
[   12.231278] procd: Finished hotplug exec instance, pid=790
[   12.237002] procd: Launched hotplug exec instance, pid=795
[   12.242628] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0boot1","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"179","MINOR":"16","DEVNAME":"mmcblk0boot1","DEVTYPE":"disk","SEQNUM":"625"}}
[   12.265139] procd: Command: makedev
[   12.268656] procd:  /dev/mmcblk0boot1
[   12.272332] procd:  0600
[   12.274872] procd: Message:
[   12.277679] procd:  ACTION=add
[   12.280746] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0boot1
[   12.290671] procd:  SUBSYSTEM=block
[   12.294173] procd:  SYNTH_UUID=0
[   12.297414] procd:  MAJOR=179
[   12.300393] procd:  MINOR=16
[   12.303287] procd:  DEVNAME=mmcblk0boot1
[   12.307222] procd:  DEVTYPE=disk
[   12.310455] procd:  SEQNUM=625
[   12.313609] procd: Command: exec
[   12.316851] procd:  /sbin/hotplug-call
[   12.320612] procd:  block
[   12.323244] procd: Message:
[   12.326045] procd:  ACTION=add
[   12.329112] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0boot1
[   12.339037] procd:  SUBSYSTEM=block
[   12.342538] procd:  SYNTH_UUID=0
[   12.345778] procd:  MAJOR=179
[   12.348757] procd:  MINOR=16
[   12.351651] procd:  DEVNAME=mmcblk0boot1
[   12.355586] procd:  DEVTYPE=disk
[   12.358820] procd:  SEQNUM=625
[   12.361905] procd: Finished hotplug exec instance, pid=795
[   12.367629] procd: Launched hotplug exec instance, pid=800
sh: write error:[   12.373266] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"179","MINOR":"2","DEVNAME":"mmcblk0p2","DEVTYPE":"partition","PARTN":"2","SEQNUM":"626"}}
[   12.397976] procd: Command: makedev
[   12.402699] procd:  /dev/mmcblk0p2
[   12.406150] procd:  0600
[   12.408695] procd: Message:
[   12.411502] procd:  ACTION=add
[   12.414563] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2
[   12.424228] procd:  SUBSYSTEM=block
[   12.427729] procd:  SYNTH_UUID=0
[   12.430962] procd:  MAJOR=179
[   12.433942] procd:  MINOR=2
[   12.436747] procd:  DEVNAME=mmcblk0p2
[   12.440421] procd:  DEVTYPE=partition
[   12.444096] procd:  PARTN=2
[   12.446896] procd:  SEQNUM=626
[   12.450050] procd: Command: exec
[   12.453292] procd:  /sbin/hotplug-call
[   12.457053] procd:  block
[   12.459683] procd: Message:
[   12.462483] procd:  ACTION=add
[   12.465551] procd:  DEVPATH=/devices/platform/11230000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2
[   12.475219] procd:  SUBSYSTEM=block
[   12.478713] procd:  SYNTH_UUID=0
[   12.481953] procd:  MAJOR=179
[   12.484933] procd:  MINOR=2
[   12.487740] procd:  DEVNAME=mmcblk0p2
[   12.491414] procd:  DEVTYPE=partition
[   12.495081] procd:  PARTN=2
[   12.497888] procd:  SEQNUM=626
[   12.500972] procd: Finished hotplug exec instance, pid=800
[   12.506688] procd: Launched hotplug exec instance, pid=805
[   12.512334] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/10212800.rtc/rtc/rtc0","SUBSYSTEM":"rtc","SYNTH_UUID":"0","MAJOR":"253","MINOR":"0","DEVNAME":"rtc0","SEQNUM":"627"}}
[   12.528805] procd: Command: makedev
[   12.532348] procd:  /dev/rtc0
[   12.535359] procd:  0600
[   12.537930] procd: Message:
[   12.540740] procd:  ACTION=add
[   12.543808] procd:  DEVPATH=/devices/platform/10212800.rtc/rtc/rtc0
[   12.550087] procd:  SUBSYSTEM=rtc
[   12.553415] procd:  SYNTH_UUID=0
[   12.556655] procd:  MAJOR=253
[   12.559635] procd:  MINOR=0
[   12.562436] procd:  DEVNAME=rtc0
[   12.565675] procd:  SEQNUM=627
[   12.568880] procd: Finished hotplug exec instance, pid=805
[   12.574435] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/10212000.watchdog/watchdog/watchdog0","SUBSYSTEM":"watchdog","SYNTH_UUID":"0","MAJOR":"251","MINOR":"0","DEVNAME":"watchdog0","SEQNUM":"628"}}
[   12.592921] procd: Command: makedev
[   12.596425] procd:  /dev/watchdog0
[   12.599838] procd:  0600
[   12.602377] procd: Message:
[   12.605184] procd:  ACTION=add
[   12.608251] procd:  DEVPATH=/devices/platform/10212000.watchdog/watchdog/watchdog0
[   12.615832] procd:  SUBSYSTEM=watchdog
[   12.619593] procd:  SYNTH_UUID=0
[   12.622826] procd:  MAJOR=251
[   12.625807] procd:  MINOR=0
[   12.628612] procd:  DEVNAME=watchdog0
[   12.632287] procd:  SEQNUM=628
[   13.135925] procd: Coldplug complete
[   13.139520] procd: Change state 1 -> 2
[   13.143289] procd: - watchdog -
[   13.146441] procd: Ping
[   13.148905] procd: Opened watchdog with timeout 30s
[   13.153864] procd: - ubus -
[   13.156685] procd: Create service ubus
[   13.160462] procd: Start instance ubus::instance1
[   13.165387] procd: Started instance ubus::instance1[810]
[   13.169064] random: ubusd: uninitialized urandom read (4 bytes read)
[   13.170775] procd: running /etc/init.d/ubus running
[   13.182832] procd: glob failed on /etc/init.d/ubus
[   13.207701] random: ubusd: uninitialized urandom read (4 bytes read)
[   13.214158] random: ubusd: uninitialized urandom read (4 bytes read)
[   13.220748] procd: Connected to ubus, id=62f59590
[   13.225475] procd: Change state 2 -> 3
[   13.229238] procd: - init -
[   13.233103] procd: Parsing inittab - ::sysinit:/etc/init.d/rcS S boot
[   13.239586] procd: Parsing inittab - ::shutdown:/etc/init.d/rcS K shutdown
[   13.246496] procd: Parsing inittab - ::askconsole:/usr/libexec/login.sh
[   13.253407] procd: Launched new askconsole action, pid=811
[   13.258932] procd: running /etc/rc.d/S* boot
[   13.343319] urngd: v1.0.2 started.
[   13.354712] kmodloader: loading kernel modules from /etc/modules.d/*
[   13.368966] random: crng init done
[   13.372399] random: 7 urandom warning(s) missed due to ratelimiting
[   13.379692] tun: Universal TUN/TAP device driver, 1.6
[   13.395154] cryptodev: driver 1.10 loaded.
[   13.402474] i2c /dev entries driver
[   13.412462] hidraw: raw HID events driver (C) Jiri Kosina
[   13.420040] Mirror/redirect action on
[   13.427927] u32 classifier
[   13.430631]     input device check on
[   13.434315]     Actions configured
[   13.454973] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.460319] Bluetooth: BNEP filters: protocol multicast
[   13.465549] Bluetooth: BNEP socket layer initialized
[   13.472503] usbcore: registered new interface driver btusb
[   13.479006] usbcore: registered new interface driver cdc_wdm
[   13.485360] Loading modules backported from Linux version v5.4.27-0-g585e0cc08069
[   13.492855] Backport generated by backports.git v5.4.27-1-0-gf6e8852f
[   13.500608] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[   13.506573] Bluetooth: HIDP socket layer initialized
[   13.522485] Bluetooth: RFCOMM TTY layer initialized
[   13.527399] Bluetooth: RFCOMM socket layer initialized
[   13.532548] Bluetooth: RFCOMM ver 1.11
[   13.537939] usbcore: registered new interface driver ums-alauda
[   13.544402] usbcore: registered new interface driver ums-cypress
[   13.550778] usbcore: registered new interface driver ums-datafab
[   13.557101] usbcore: registered new interface driver ums-freecom
[   13.563426] usbcore: registered new interface driver ums-isd200
[   13.569660] usbcore: registered new interface driver ums-jumpshot
[   13.576044] usbcore: registered new interface driver ums-karma
[   13.582278] usbcore: registered new interface driver ums-sddr09
[   13.588538] usbcore: registered new interface driver ums-sddr55
[   13.594810] usbcore: registered new interface driver ums-usbat
[   13.604814] wireguard: WireGuard 1.0.20200506 loaded. See www.wireguard.com for information.
[   13.613267] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[   13.633098] xt_time: kernel timezone is -0000
[   13.638075] usbcore: registered new interface driver cdc_ether
[   13.735053] mt7615_init()-->
[   13.737959] __pci_register_driver--> mod_name=mt7615e
[   13.743169] mt7615e 0000:01:00.0: assign IRQ: got 139
[   13.748254] pci 0000:00:00.0: enabling device (0000 -> 0002)
[   13.753919] pci 0000:00:00.0: enabling bus mastering
[   13.758894] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[   13.764980] mt7615e 0000:01:00.0: enabling bus mastering
[   13.773705] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   13.781341] __pci_register_driver--> mod_name=mt7615e ret=0
[   13.801919] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   13.809590] <--mt7615_init() with ret=0
[   13.827235] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.835378] mt7622-wmac 18000000.wmac: <--mt7615_mcu_wait_response() with ret=2
[   13.842745] mt7622-wmac 18000000.wmac: Returning from mt7615_mcu_send_message pt2 ret=2
[   13.843448] PPP generic driver version 2.4.2
[   13.854304] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[   13.854304]
[   13.865514] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.865570] NET: Registered protocol family 24
[   13.880277] usbcore: registered new interface driver qmi_wwan
[   13.885385] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.894632] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.902804] mt7622-wmac 18000000.wmac: <--mt7615_mcu_wait_response() with ret=3
[   13.903046] kmodloader: done loading kernel modules from /etc/modules.d/*
[   13.910129] mt7622-wmac 18000000.wmac: Returning from mt7615_mcu_send_message pt2 ret=3
[   13.932913] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
[   13.941535] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
sh: write error: No such file or directory
[   13.954185] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   14.004856] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   14.013960] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   15.328597] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[   15.337359] mtk_soc_eth 1b100000.ethernet: 0x100 = 0xffff9070, 0x10c = 0x100808ff
[   15.344878] mtk_soc_eth 1b100000.ethernet: reset pse
[   15.429869] mtk_soc_eth 1b100000.ethernet: PPE started
[   15.435141] debugfs: Directory 'mtk_ppe' with parent '/' already present!
[   15.441951] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[   15.450455] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[   15.456699] br-lan: port 1(eth0) entered blocking state
[   15.464319] br-lan: port 1(eth0) entered disabled state
[   15.469806] device eth0 entered promiscuous mode
[   15.477689] br-lan: port 1(eth0) entered blocking state
[   15.482949] br-lan: port 1(eth0) entered forwarding state
[   15.496040] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[   15.504523] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[   15.514317] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
udhcpc: started, v1.31.1
udhcpc: sending discover
[   17.944775] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   17.952941] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   17.964896] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
udhcpc: no lease, failing
[   35.811134] mt7615e 0000:01:00.0: wait_event_timeout myret=0 state=0x1 empty=1
[   35.818366] mt7615e 0000:01:00.0: dev.init_name=(null) dev.id=0 driver_name=mt7615e Message -4294967280 (ffffffff00000010) (seq 1) timeout
[   35.830798] mt7615e 0000:01:00.0: Returning from mt7615_mcu_send_message pt2 ret=-110
[   35.838630] mt7615e 0000:01:00.0: Failed to get patch semaphore
BusyBox v1.31.1 () built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt SNAPSHOT, r13225-bc0288b768
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
root@OpenWrt:/# dmesg|grep max=
root@OpenWrt:/# lspci
01:00.0 Class 0002: 14c3:7615
00:00.0 Class 0604: 14c3:3258
root@OpenWrt:/# dmesg|grep mt7615
root@OpenWrt:/#
I too see that the mt7622 wifi firmware gets loaded and I can get full network functionality from it (802.11n). But mt7615 driver does not get to the point of loading firmware.
@Ryder.Lee, I do have
&wmac {
	status = "okay";
in the mt7622-bananapi-bpi-r64.dts file.
In mt7622.dtsi file, the btif node is:
btif: serial@1100c000 {
		compatible = "mediatek,mt7622-btif",
			     "mediatek,mtk-btif";
		reg = <0 0x1100c000 0 0x1000>;
		interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_LOW>;
		clocks = <&pericfg CLK_PERI_BTIF_PD>;
		clock-names = "main";
		reg-shift = <2>;
		reg-io-width = <4>;
		status = "disabled";
		bluetooth {
			compatible = "mediatek,mt7622-bluetooth";
			power-domains = <&scpsys MT7622_POWER_DOMAIN_WB>;
			clocks = <&clk25m>;
			clock-names = "ref";
status = “disabled”; – does this mean BTIF is already disabled?
BTIF is another problem to enable both BT and onbaord WiFi. I guess this is a board issue since I saw mcu timeout from your log.
btw I saw this patch has applied into openwrt trunk, so no need to apply extra patch for BT
I just clarified that you can run both MT7615 and MT7622 simultaneously. I didn’t see any problems to share the same driver here, but actually I used mt7622-rfb not bpi-r64.
   11.725429] mt7615e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20180518100604a
[   11.725429]
[   11.725460] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[   11.725460]
[   12.062099] mt7615e 0000:01:00.0: N9 Firmware Version: 2.0, Build Time: 20200131181812
[   12.069506] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
[   12.090294] mt7615e 0000:01:00.0: CR4 Firmware Version: _reserved_, Build Time: 20190121161307
[   15.553467] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[   15.614134] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[   15.622470] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[   15.626933] br-lan: port 1(eth0) entered blocking state
[   15.636314] br-lan: port 1(eth0) entered disabled state
[   15.641727] device eth0 entered promiscuous mode
[   15.647038] br-lan: port 1(eth0) entered blocking state
[   15.652297] br-lan: port 1(eth0) entered forwarding state
[   15.662663] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[   15.670581] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[   16.474019] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[   16.481306] jffs2_build_filesystem(): unlocking the mtd device...
[   16.481308] done.
[   16.489476] jffs2_build_filesystem(): erasing all blocks after the end marker...
[   18.535370] done.
[   18.544786] jffs2: notice: (2009) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   18.647845] overlayfs: upper fs does not support tmpfile.
[   18.653298] overlayfs: "xino" feature enabled using 32 upper inode bits.
  _______                     ________        __
 OpenWrt SNAPSHOT, r0-b052b62
root@OpenWrt:/#
I guess it’s just R64 board issue, so please ask BPI team @sinovoip for help.
Same issue with OpenWRT + 4.19. Not surprising, because I’m building openwrt from sources and it builds mt76 using latest source from github.
Can you tell which version of mt76 you’re using, or approximate build date, so I can find it in git?
can you provide mac80211 debug logs? did you guys have this fixup in your tree? i suspect this is root cause for your problems - “then clients stops connecting until reboot”.
thx for your solution!!!
i successfully boot BPI-R64 on kernel 5.4
but i found some iusse
1),the mpcie not work,and i think the official DTS file has null declaration
2), i try build-in wifi ,but i can’t successfully boot it
at lasted thx for your contribution
&btif {
        status = "okay";
Please check your dts file and set status = “disabled”;
have you applied mpcie-patches (splitting+irq-handling) for r64?
this is basicly for google-cards, but also pcie-related:
for bluetooth i have also this in my tree:
and just for explaination: the mt7622.dtsi defines nodes for SOC-level and will be overlayed by board-specific dts…like mt7622*-r64.dts, there are some nodes enabled and partially some additional content added (like pinctl-definitions)
Yes it was applied from beginning. I also try mt76 from yesterday but problem still exist
thx for your help
it works !!!
now, when i run on 40Mhz
it can’t seem to connect to the Internet
online network IMG_825555693350-1
local network
Please tell me how to activate SATA in this firmware?
I agree with @Kosyak. I get the same behavior with kernel 4.19.115: onboard wifi works, but pcie mt7615 fails to acquire the semaphore and thus does not reach up to loading firmware.
So I am continuing to stay with kernel 5.4 experiment.
@frank-w, I do see the mt7622 onboard wifi get and release the semaphore before mt7615 attempts to get it. Here is output of
dmesg|grep 76
(I added a debug message in mt7615/mcu.c mt7615_mcu_patch_sem_ctrl function)
[   13.094986] mt7615_init()-->
[   13.097893] __pci_register_driver--> mod_name=mt7615e
[   13.103101] mt7615e 0000:01:00.0: assign IRQ: got 139
[   13.118855] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[   13.124942] mt7615e 0000:01:00.0: enabling bus mastering
[   13.133763] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   13.141424] __pci_register_driver--> mod_name=mt7615e ret=0
[   13.169728] <--mt7615_init() with ret=0
[   13.187143] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.187639] PPP generic driver version 2.4.2
[   13.195270] mt7622-wmac 18000000.wmac: <--mt7615_mcu_wait_response() with ret=2
[   13.206831] mt7622-wmac 18000000.wmac: Returning from mt7615_mcu_send_message pt2 ret=2
[   13.214832] mt7622-wmac 18000000.wmac: PATCH_SEM_GET. ret = 2
[   13.219242] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[   13.235471] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.260705] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.268934] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.277098] mt7622-wmac 18000000.wmac: <--mt7615_mcu_wait_response() with ret=3
[   13.284430] mt7622-wmac 18000000.wmac: Returning from mt7615_mcu_send_message pt2 ret=3
[   13.292442] mt7622-wmac 18000000.wmac: PATCH_SEM_RELEASE. ret = 3
[   13.308442] mt7622-wmac 18000000.wmac: N9 Firmware Version: 2.0, Build Time: 20200131180931
[   13.316969] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.329096] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.379783] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   13.393093] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   14.876682] br-lan: port 1(eth0) entered forwarding state
[   17.212603] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   17.220777] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
[   17.232731] mt7622-wmac 18000000.wmac: mt7615_mcu_wait_response() -- got response in skb
root@OpenWrt:/# sl[   33.763050] mt7615e 0000:01:00.0: wait_event_timeout myret=0 state=0x1 empty=1
[   33.770287] mt7615e 0000:01:00.0: dev.init_name=(null) dev.id=0 driver_name=mt7615e Message -4294967280 (ffffffff00000010) (seq 1) t
[   33.782723] mt7615e 0000:01:00.0: Returning from mt7615_mcu_send_message pt2 ret=-110
[   33.790552] mt7615e 0000:01:00.0: PATCH_SEM_GET. ret = -110
[   33.796122] mt7615e 0000:01:00.0: Failed to get patch semaphore
How can I disable the mt7622 onboard wifi in the DTS? If the mt7615 gets working, I don’t see a need for the onboard wifi.
The linux-5.4.40/arch/arm64/boot/dts/mediatek/mt7622.dtsi file contains this:
wmac: wmac@18000000 {
	compatible = "mediatek,mt7622-wmac";
	reg = <0 0x18000000 0 0x100000>;
	interrupts = <GIC_SPI 211 IRQ_TYPE_LEVEL_LOW>;
	mediatek,infracfg = <&infracfg>;
And in mt7622-bananapi-bpi-r64.dts, it is overlaid with
&wmac {
	status = "okay";
By removing the wmac status=“okay” overlay, will that disable only the on-board wifi, and still try to initialize the mt7615? Or is enabling the wmac necessary for mt7615?
just disable the wmac-node like the btif above :slight_smile:
I’ve recorded trace during connection attempts using trace-cmd record -e mt76 -e mac80211 https://drive.google.com/drive/folders/17kKnUi9nhBDna_mg0xK_CkPFoJjim6Nf?usp=sharing
latest mt76 driver, client MAC: 60:67:20:48:4b:f8, -good trace - successful connection after R64 startup, -bad - failed (with “authentication timed out”) connection after ~1 hour.
Hope this will help.
P.S. Also, got this when tried to unload mt7615e:
[ 4946.079825] ------------[ cut here ]------------
[ 4946.084457] Have pending ack frames!
[ 4946.088153] WARNING: CPU: 1 PID: 2494 at ieee80211_free_ack_frame+0x48/0x50 [mac80211]
[ 4946.096058] Modules linked in: pppoe ppp_async iptable_nat xt_state xt_nat xt_conntrack xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD pppox ppp_generic nf_nat nf_flow_table_hw nf_flow_table nf_conntrack_rtcache nf_conntrack ipt_REJECT xt_time xt_tcpudp xt_multiport xt_mark xt_mac xt_limit xt_comment xt_TCPMSS xt_LOG slhc nf_reject_ipv4 nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 iptable_mangle iptable_filter ip_tables crc_ccitt mt7615e(-) mt7615_common mt76 mac80211 cfg80211 compat nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 leds_gpio xhci_plat_hcd ohci_platform ohci_hcd fsl_mph_dr_of ehci_platform ehci_fsl ehci_hcd gpio_button_hotplug
[ 4946.157059] CPU: 1 PID: 2494 Comm: rmmod Not tainted 5.4.41 #0
[ 4946.162880] Hardware name: Bananapi BPI-R64 (DT)
[ 4946.167487] pstate: 40000005 (nZcv daif -PAN -UAO)
[ 4946.172290] pc : ieee80211_free_ack_frame+0x48/0x50 [mac80211]
[ 4946.178132] lr : ieee80211_free_ack_frame+0x48/0x50 [mac80211]
[ 4946.183953] sp : ffffffc0121c3be0
[ 4946.187257] x29: ffffffc0121c3be0 x28: ffffff803e350b40
[ 4946.192559] x27: 0000000000000000 x26: 0000000000000000
[ 4946.197861] x25: 0000000056000000 x24: ffffff803ce42590
[ 4946.203163] x23: ffffffc0087fb980 x22: 0000000000000000
[ 4946.208464] x21: 000000007fffffff x20: 0000000000000000
[ 4946.213765] x19: ffffff803bc3b900 x18: 0000000000000000
[ 4946.219067] x17: 0000000000000000 x16: 0000000000000000
[ 4946.224369] x15: 0000000000000000 x14: ffffffc010a1ac88
[ 4946.229671] x13: 0000000000000000 x12: ffffffc010a1a000
[ 4946.234972] x11: ffffffc010988000 x10: 0000000000000010
[ 4946.240275] x9 : 0000000000000000 x8 : 0000000000000000
[ 4946.245576] x7 : 000000000000000f x6 : 0000000000000001
[ 4946.250877] x5 : 0000000000000000 x4 : 0000000000000000
[ 4946.256179] x3 : 0000000000000000 x2 : ffffff803fdce3c0
[ 4946.261481] x1 : ffffffc02f462000 x0 : 0000000000000018
[ 4946.266783] Call trace:
[ 4946.269242]  ieee80211_free_ack_frame+0x48/0x50 [mac80211]
[ 4946.274720]  idr_for_each+0x54/0xd0
[ 4946.278219]  ieee80211_free_hw+0x34/0xa0 [mac80211]
[ 4946.283091]  mt76_free_device+0x1c/0x28 [mt76]
[ 4946.287528]  mt7615_unregister_device+0x134/0x160 [mt7615e]
[ 4946.293091]  mt7622_wmac_remove+0x10/0x20 [mt7615e]
[ 4946.297961]  platform_drv_remove+0x28/0x48
[ 4946.302047]  device_release_driver_internal+0xf0/0x1b0
[ 4946.307175]  driver_detach+0x60/0xd0
[ 4946.310740]  bus_remove_driver+0x54/0xa8
[ 4946.314652]  driver_unregister+0x2c/0x58
[ 4946.318565]  platform_driver_unregister+0x10/0x18
[ 4946.323260]  mt7615_exit+0x14/0xe90 [mt7615e]
[ 4946.327609]  __arm64_sys_delete_module+0x1b0/0x258
[ 4946.332393]  el0_svc_common.constprop.1+0x7c/0xe8
[ 4946.337088]  el0_svc_handler+0x20/0x80
[ 4946.340827]  el0_svc+0x8/0xc
[ 4946.343698] ---[ end trace 25d4dd28a41c1106 ]---
The unloaded problem should be fixed and we’re running 1h+ iperf now and mt7622 seems stable. Please update your mt76 driver to the latest one.
I kept btif and wmac nodes disabled by commenting out those nodes from the mt7622-bananapi-bpi-r64.dts like this:
/* &wmac{
       status = "okay";
/* &wmac{
       status = "okay";
Both are inherently disabled in the mt7622.dsi.
I can see that mt7622 onboard wifi driver does not get activated, nor does BT. However, I still see mt7615 failing to get the patch semaphore
root@OpenWrt:/# dmesg|grep 76
[    0.005119] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.005132] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.765276] usbcore: registered new interface driver usb-storage
[    0.771647] rtc_mt7622 10212800.rtc: registered as rtc0
[    0.820476] Bluetooth: HCI UART protocol QCA registered
[    2.040331] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280
[    7.452312] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01T00:00:06 UTC (946684806)
[   11.621803] mt7615_init()-->
[   11.624704] __pci_register_driver--> mod_name=mt7615e
[   11.629893] mt7615e 0000:01:00.0: assign IRQ: got 137
[   11.645618] mt7615e 0000:01:00.0: enabling device (0000 -> 0002)
[   11.651698] mt7615e 0000:01:00.0: enabling bus mastering
[   11.668114] __pci_register_driver--> mod_name=mt7615e ret=0
[   11.673905] <--mt7615_init() with ret=0
[   14.955763] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[   31.714857] mt7615e 0000:01:00.0: Message -4294967280 (seq 1) timeout
[   31.721307] mt7615e 0000:01:00.0: Returning from mt7615_mcu_send_message pt2 ret=-110
[   31.729139] mt7615e 0000:01:00.0: Failed to get patch semaphore
I am going to try the spit pcie-nodes and other patches mentioned by @frank-w in post #31 I think that might hold some promise, because, when I compared the bootlog from the LEDE version of @sinovoip (http://wiki.banana-pi.org/BPI-R64_%2B_MT7615_function_test), I see it accesses addresses 1a143000 and 1a145000.
grep mtk-pcie ~/tmp/bpi-official-mt7615test-bootlog.txt
[    0.143882] mtk-pcie 1a143000.pcie: pcie rc 0 linkup success
[    0.144030] mtk-pcie 1a143000.pcie: PCI host bridge to bus 0001:00
[    0.251632] mtk-pcie 1a145000.pcie: Port1 link down
[    0.251797] mtk-pcie 1a145000.pcie: PCI host bridge to bus 0002:100:
But in my openwrt with kernel 5.4.40, it accesses only 1a140000
grep mtk-pcie ~/tmp/openwrt-kern5.4.40-05182020-1500.bootlog.txt
[    0.909497] mtk-pcie 1a140000.pcie: host bridge /pcie@1a140000 ranges:
[    0.916049] mtk-pcie 1a140000.pcie: Parsing ranges property...
[    0.921885] mtk-pcie 1a140000.pcie:   MEM 0x20000000..0x2fffffff -> 0x20000000
[    0.929291] mtk-pcie mtk_pcie_startup_port_v2. training timeout set to 1000. portbase=10afd000
[    0.953216] mtk-pcie mtk_pcie_startup_port_v2. training timeout set to 1000. portbase=10b05000
[    1.961852] mtk-pcie mtk_pcie_startup_port_v2. poll timeout. err=-110
[    1.961860] mtk-pcie 1a140000.pcie: Port1 link down
[    1.973277] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
I see that @frank-w patch for the split pcie-nodes seems more aligned with the boot log of BPI mt7615 function test.
