Here is the bootlog, part2
[   16.004498] mount_root: loading kmods from internal overlay
[   16.016663] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[   16.024074] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[   16.111339] block: attempting to load /etc/config/fstab
[   16.116649] block: unable to load configuration (fstab: Entry not found)
[   16.123372] block: no usable configuration
[   16.127889] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
[   16.136236] urandom-seed: Seed file not found (/etc/urandom.seed)
[   16.170950] procd: - early -
[   16.173905] procd: - watchdog -
[   16.742387] procd: - watchdog -
[   16.745649] procd: - ubus -
[   16.878477] procd: - init -
[   16.978609] kmodloader: loading kernel modules from /etc/modules.d/*
[   16.988019] l2tp_core: L2TP core driver, V2.0
[   16.992815] l2tp_netlink: L2TP netlink interface
[   16.997879] gre: GRE over IPv4 demultiplexor driver
[   17.003264] ip_gre: GRE over IPv4 tunneling driver
[   17.009909] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   17.020406] cryptodev: driver 1.8 loaded.
[   17.026587] ip_tables: (C) 2000-2006 Netfilter Core Team
[   17.034639] mediatek_soc_hnat 1b100000.hnat: wan = eth1
[   17.040025] mediatek_soc_hnat 1b100000.hnat: ppd = eth0
[   17.045321] mediatek_soc_hnat 1b100000.hnat: gmac num = 2
[   17.051533] mediatek_soc_hnat 1b100000.hnat: FOE entry number = 16384
[   17.058772] mediatek_soc_hnat 1b100000.hnat: hwnat start
[   17.066645] ahci 1a200000.sata: couldn't get PHY in node sata: -517
[   17.123890] xt_time: kernel timezone is -0000
[   17.731310] register mt_drv
[   17.738569]
[   17.738569] == pAd = ffffff8009501000, size = 7221120, Status=0 ==
[   17.746264] AP Driver version-5.0.4.0
[   17.749988] read sub id = 1
[   17.752780] Use 1st iPAiLNA default bin.
[   17.756773] Use 1st /etc_ro/wlan/MT7622_EEPROM.bin default bin.
[   17.763274] <--mt7622_init()
[   17.767027] <-- RTMPAllocTxRxRingMemory, Status=0
[   17.772954] register mt_drv
[   17.773452] ahci 1a200000.sata: couldn't get PHY in node sata: -517
[   17.782256] add_oom_notifier()
[   17.789122] PPP generic driver version 2.4.2
[   17.794107] PPP MPPE Compression module registered
[   17.800220] NET: Registered protocol family 24
[   17.805581] PPTP driver version 0.8.5
[   17.811124] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[   17.817219] whnat_module_init(): module init and register callback for whnat
[   17.824390] create whnat_ctrl ok!!!
[   17.828031] wed_slot_map_get(): assign slot_id:0 for entry: 0!
[   17.833998] wed_slot_map_get(): assign slot_id:1 for entry: 1!
[   17.840031] whnat_hif_pcie_mirror_probe(): hif_cfg base addr=ffffff8009374400
[   17.848604] kmodloader: done loading kernel modules from /etc/modules.d/*
[   22.449246] device eth0 entered promiscuous mode
[   22.462379] br-lan: port 1(eth0) entered forwarding state
[   22.467894] br-lan: port 1(eth0) entered forwarding state
[   22.944785] ra0: ===> main_virtual_if_open
[   22.950135] load l1profile succeed!
[   22.954268] WHNAT=0
[   22.956415] whnat_driver_init(): chip not support wifi hardware nat feature
[   23.287841] APWdsInitialize():WdsEntry Number=4
[   23.293474] RtmpOSFileOpen(): Error 2 opening /etc/Wireless/RT2860/RT2860_5G.dat
[   23.300946] Open file "/etc/Wireless/RT2860/RT2860_5G.dat" failed!
[   23.308199] E2pAccessMode=2
[   23.311376] SSID[0]=MTK_AP1, EdcaIdx=0
[   23.315691] DBDC Mode=0, eDBDC_mode = 0
[   23.319883] BSS0 PhyMode=14
[   23.322773] wmode_band_equal(): Band Equal!
[   23.327780] BandSteering=0
[   23.330610] BndStrgBssIdx=
[   23.333518] [TxPower] BAND0: 100
[   23.337152] Power Boost (CCK, OFDM): RTMPSetProfileParameters[PowerUpCckOfdm] BAND1: (0)-(0)-(0)-(0)-(0)-(0)-(0)
[   23.347579] Power Boost (HT20): RTMPSetProfileParametersPower Boost (HT40): RTMPSetProfileParametersPower Boost (VHT20): RTMPSetProfileParametersPower Boost (VHT40): RTMPSetProfileParametersPower Boost (VHT80): RTMPSetProfileParametersPower Boost (VHT160): RTMPSetProfileParameters[CCKTxStream] BAND0: 4
[   23.375894] [PERCENTAGEenable] BAND0: 0
[   23.379928] [BFBACKOFFenable] BAND0: 0
[   23.383841] CalCacheApply = 0
[   23.387424] FragThreshold[0]=2346
[   23.393416] DfsZeroWait Support=0/0
[   23.397470] DfsZeroWaitCacTime=255/255
[   23.402062] read_etxbf: ETxBfEnCond = 1
[   23.405918] read_etxbf: BSSID[0]
[   23.409163] read_etxbf: MBSS[0] ETxBfEnCond = 1
[   23.436035] If/wds0 - PeerPhyOpMode=255
[   23.440413] APWdsInitialize():WdsEntry Number=4
[   23.444969] WDS-Enable mode=0
[   23.448035] AndesSendCmdMsg: Could not send in band command due to diablefRTMP_ADAPTER_MCU_SEND_IN_BAND_CMD
[   23.457793] AndesSendCmdMsg: Command type = ed, Extension command type = 48
[   23.466656] HT: WDEV[0] Ext Channel = ABOVE
[   23.471041] HT: greenap_cap = 1
[   23.474289] ChipI=7622, Value=0, pcie_aspm in profile=0
[   23.501759] ICapMode = 0
[   23.507951] WtcSetMaxStaNum: BssidNum:1, MaxStaNum:124 (WdsNum:4, ApcliNum:2, MaxNumChipRept:16), MinMcastWcid:125
[   23.518459] Fair Queueing Scheduler Initialization...
[   23.523687] Top Init Done!
[   23.526419] Use dev_alloc_skb
[   23.529801] RX[0] DESC ffffffc03b936000 size = 8192
[   23.534855] RX[1] DESC ffffffc03b938000 size = 8192
[   23.539840] cut_through_init(): ct sw token number = 4095
[   23.545413] cut_through_token_list_init(): TokenList inited done!id_head/tail=0/4096
[   23.553185] cut_through_token_list_init(): ffffffc03bb4d710,ffffffc03bb4d710
[   23.560401] cut_through_token_list_init(): TokenList inited done!id_head/tail=0/4096
[   23.568164] cut_through_token_list_init(): ffffffc03bb4d730,ffffffc03bb4d730
[   23.575292] whnat_ring_init(): cookie=ffffff8009501000
[   23.580447] whnat_ring_init(): whnat can't find for cookie:ffffff8009501000
[   23.587423] Hif Init Done!
[   23.590144] ctl->txq = ffffff8009bdd738
[   23.593993] ctl->rxq = ffffff8009bdd750
[   23.597842] ctl->ackq = ffffff8009bdd768
[   23.601778] ctl->kickq = ffffff8009bdd780
[   23.605798] ctl->tx_doneq = ffffff8009bdd798
[   23.610082] ctl->rx_doneq = ffffff8009bdd7b0
[   23.614523] mt_rbus 0000:00:00.0: Direct firmware load for mt7622_patch_e2_hdr.bin failed with error -2
[   23.623939] Parsing patch header
[   23.627185]  Built date: 20190801210006a
[   23.631268]
[   23.632760]  Platform: ALPS
[   23.635640]  HW/SW version: 0x8a108a10
[   23.639463]  Patch version: 0x00000010
[   23.643284]  Target address: 0x9c000, length: 82080
[   23.648348] patch is not ready && get semaphore success
[   23.653653] EventGenericEventHandler: CMD Success
[   23.658922] MtCmdPatchFinishReq
[   23.673369] EventGenericEventHandler: CMD Success
[   23.678132] release patch semaphore
[   23.681648] WfMcuHwInit: Before NICLoadFirmware, check ICapMode = 0
[   23.687937] Parsing CPU 0 fw tailer
[   23.691445]  Chip ID: 0x06
[   23.694214]  Eco version: 0x00
[   23.697306]  Region number: 0x00
[   23.700558]  Format version: 0x00
[   23.703909]  Ram version: _reserved_
[   23.707632]  Built date: 20190801210351
[   23.711759]  Common crc: 0x0
[   23.714655] Parsing tailer region 0
[   23.718154]  Feature set: 0x01
[   23.721270]  Target address: 0xb7000, Download size: 249856
[   23.726856] Parsing tailer region 1
[   23.730354]  Feature set: 0x01
[   23.733470]  Target address: 0x203dc00, Download size: 46960
[   23.739184] EventGenericEventHandler: CMD Success
[   23.747994] EventGenericEventHandler: CMD Success
[   23.753116] MtCmdFwStartReq: override = 0x0, address = 0x0
[   23.800086] EventGenericEventHandler: CMD Success
[   23.804846] MCU Init Done!
[   23.807620] efuse_probe: efuse = 2
[   23.811049] RtmpChipOpsEepromHook::e2p_type=2, inf_Type=4
[   23.816489] RtmpEepromGetDefault::e2p_dafault=2
[   23.821063] RtmpChipOpsEepromHook: E2P type(2), E2pAccessMode = 2, E2P default = 2
[   23.828692] NVM is FLASH mode. dev_idx [0] FLASH OFFSET [0x0]
[   23.834876] RtmpOSFileOpen(): Error 2 opening /etc_ro/wlan/MT7615_EEPROM.bin
[   23.841982] --> Error opening file /etc_ro/wlan/MT7615_EEPROM.bin
[   23.848106] Load EEPROM Buffer from default BIN.
[   23.852846] Cal Free IC!!
[   23.856029] The EEPROM in Flash is wrong, use default
[   23.861133] NICReadEEPROMParameters: EEPROM 0x52 bb00
[   23.866903] NICReadEEPROMParameters: EEPROM 0x52 bb00
[   23.872709] mt7622_pa_lna_set(): read antCtrl = 0, polCtrl = 4, wifiStreams = 44
[   23.880149] mt7622_tssi_set(): nic_cfg1=20, mode=1
[   24.468914] br-lan: port 1(eth0) entered forwarding state
[   27.821297] Country Region from e2p = 0
[   27.825206] read sub id = 1
[   27.828032] RcRadioInit(): DbdcMode=0, ConcurrentBand=1
[   27.833287] RcRadioInit(): pRadioCtrl=ffffffc03bf451d8,Band=0,rfcap=1,channel=1,PhyMode=2 extCha=0xf
[   27.842442] MtSingleSkuLoadParam: RF_LOCKDOWN Feature OFF !!!
[   27.882419] MtBfBackOffLoadParam: RF_LOCKDOWN Feature OFF !!!
[   27.888359] EEPROM Init Done!
[   27.891357] mt_mac_init()-->
[   27.894259] mt7622_init_mac_cr(): TMAC_TRCR0=0x82783c8c
[   27.899508] <--mt_mac_init()
[   27.920991] CmdRxHdrTransBLUpdateRsp::EventExtCmdResult.u4Status = 0x0
[   27.938055] CmdRxHdrTransBLUpdateRsp::EventExtCmdResult.u4Status = 0x0
[   27.955120] CmdRxHdrTransBLUpdateRsp::EventExtCmdResult.u4Status = 0x0
[   27.961653] MAC Init Done!
[   27.964367] MT7622BBPInit() todo
[   27.967610] PHY Init Done!
[   27.970977] MtCmdSetMacTxRx:(ret = 0)
[   27.974816] WifiFwdSet::disabled=0
[   27.978267] ap_ftkd> Initialize FT KDP Module...
[   27.982929] Main bssid = 00:00:00:00:00:00
[   27.987287] MtCmdSetMacTxRx:(ret = 0)
[   27.998330] MtCmdSetMacTxRx:(ret = 0)
[   28.002041] <==== mt_wifi_init, Status=0
[   28.005990] TxBfModuleEnCtrl:It's not DBDC mode
[   28.010586] MtCmdEDCCACtrl: BandIdx: 0, EDCCACtrl: 1
[   28.015613] MtCmdEDCCACtrl: BandIdx: 1, EDCCACtrl: 1
[   28.020722] The new WDS interface MAC = 00:00:00:00:00:00, MacTabMatchWCID = 0
[   28.028555] The new WDS interface MAC = 00:00:00:00:00:00, MacTabMatchWCID = 0
[   28.036648] The new WDS interface MAC = 00:00:00:00:00:00, MacTabMatchWCID = 0
[   28.044671] The new WDS interface MAC = 00:00:00:00:00:00, MacTabMatchWCID = 0
[   28.052668] Total allocated 4 WDS interfaces!
[   28.057859] WtcSetMaxStaNum: BssidNum:1, MaxStaNum:124 (WdsNum:4, ApcliNum:2, MaxNumChipRept:16), MinMcastWcid:125
[   28.096032] RedInit: set Driver/N9 RED Enable to 1.
[   28.101127] RedInit: RED Initiailize Done.
[   28.105353] cp_support_is_enabled: set Driver CP_SUPPORT to Mode 2.
[   28.111834] Number of Packet Allocated in open = 0
[   28.116902] Number of Packet Freed in open = 0
[   28.121517] RTMP_COM_IoctlHandle -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
[   28.127987] ap_inf_open --->
[   28.131156] wifi_sys_open(), wdev idx = 0
[   28.135385] wdev_attr_update(): wdevId0 = 00:0c:43:26:60:60
[   28.141455]  [RadarStateCheck] RD_NORMAL_MODE
[   28.147139] MtCmdChannelSwitch: control_chl = 6,control_ch2=0, central_chl = 8 DBDCIdx= 0, Band= 0
[   28.156297] BW = 1,TXStream = 4, RXStream = 4, scan(0)
[   28.207010] [DfsCacNormalStart] Normal start. Enable MAC TX
[   28.283719] Caller: wlan_operate_init+0xe8/0x118 [mt_wifi]
[   28.289436] phy_mode=14, ch=6, wdev_type=1
[   28.293838] ht_cap->HtCapInfo: ldpc=1,ch_width=1,gf=0,sgi20=1,sgi40=1,tx_stbc=1,rx_stbc=1,amsdu_size=0
[   28.303368] ht_cap->HtCapParm: mdpu_density=5, ampdu_factor=3
[   28.312110] AP inf up for ra_0(func_idx) OmacIdx=0
[   28.319697] mtd_isr::DriverOwn = TRUE
[   28.320511] AsicRadioOnOffCtrl(): DbdcIdx=0 RadioOn
[   28.328362] ApAutoChannelAtBootUp----------------->
[   28.333428] ApAutoChannelAtBootUp: AutoChannelBootup = 0
[   28.338835] ApAutoChannelAtBootUp<-----------------
[   28.343799]  ap_run_at_boot() : ACS is disable !!
[   28.349294] [PMF]APPMFInit:: Security is not WPA2/WPA2PSK AES
[   28.355140] [PMF]APPMFInit:: apidx=0, MFPC=0, MFPR=0, SHA256=0
[   28.361067] wifi_sys_linkup(), wdev idx = 0
[   28.365342] wtc_acquire_groupkey_wcid: Found a non-occupied wtbl_idx:127 for WDEV_TYPE:1
[   28.365342]  LinkToOmacIdx = 0, LinkToWdevType = 1
[   28.378529] bssUpdateBmcMngRate (BSS_INFO_BROADCAST_INFO), CmdBssInfoBmcRate.u2BcTransmit= 0, CmdBssInfoBmcRate.u2McTransmit = 0
[   28.436137] UpdateBeaconHandler, BCN_UPDATE_INIT, OmacIdx = 0
[   28.442108] APStartUpForMbss: BssIndex = 0 channel = 6
[   28.447688] MtCmdTxPowerDropCtrl: ucPowerDrop: 100, BandIdx: 0
[   28.454351] TxCCKStreamCtrl: set wrong parameters
[   28.462075] Enable 20/40 BSSCoex Channel Scan(BssCoex=1)
[   28.540505] MtCmdSetMacTxRx:(ret = 0)
[   28.544260] MtCmdChannelSwitch: control_chl = 3,control_ch2=0, central_chl = 3 DBDCIdx= 0, Band= 0
[   28.553898] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   28.599064] AP OBSS SYNC - BBP R4 to 20MHz.l
[   28.928964] MtCmdChannelSwitch: control_chl = 4,control_ch2=0, central_chl = 4 DBDCIdx= 0, Band= 0
[   28.937986] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   28.971455] AP OBSS SYNC - BBP R4 to 20MHz.l
[   29.277018] MtCmdChannelSwitch: control_chl = 5,control_ch2=0, central_chl = 5 DBDCIdx= 0, Band= 0
[   29.286047] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   29.319257] AP OBSS SYNC - BBP R4 to 20MHz.l
[   29.672943] MtCmdChannelSwitch: control_chl = 6,control_ch2=0, central_chl = 6 DBDCIdx= 0, Band= 0
[   29.681989] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   29.717842] AP OBSS SYNC - BBP R4 to 20MHz.l
[   30.032947] MtCmdChannelSwitch: control_chl = 7,control_ch2=0, central_chl = 7 DBDCIdx= 0, Band= 0
[   30.042186] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   30.075650] AP OBSS SYNC - BBP R4 to 20MHz.l
[   30.388946] MtCmdChannelSwitch: control_chl = 8,control_ch2=0, central_chl = 8 DBDCIdx= 0, Band= 0
[   30.400084] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   30.436710] AP OBSS SYNC - BBP R4 to 20MHz.l
[   30.740926] MtCmdChannelSwitch: control_chl = 9,control_ch2=0, central_chl = 9 DBDCIdx= 0, Band= 0
[   30.749909] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   30.767190] AP OBSS SYNC - BBP R4 to 20MHz.l
[   31.068925] MtCmdChannelSwitch: control_chl = 10,control_ch2=0, central_chl = 10 DBDCIdx= 0, Band= 0
[   31.078082] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   31.095344] AP OBSS SYNC - BBP R4 to 20MHz.l
[   31.396912] MtCmdChannelSwitch: control_chl = 11,control_ch2=0, central_chl = 11 DBDCIdx= 0, Band= 0
[   31.406240] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   31.423494] AP OBSS SYNC - BBP R4 to 20MHz.l
[   31.724920] MtCmdChannelSwitch: control_chl = 12,control_ch2=0, central_chl = 12 DBDCIdx= 0, Band= 0
[   31.734073] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   31.751368] AP OBSS SYNC - BBP R4 to 20MHz.l
[   32.052913] MtCmdChannelSwitch: control_chl = 13,control_ch2=0, central_chl = 13 DBDCIdx= 0, Band= 0
[   32.062066] BW = 0,TXStream = 4, RXStream = 4, scan(1)
[   32.079339] AP OBSS SYNC - BBP R4 to 20MHz.l
[   32.380903] Channel[Idx=2, Ch=3].bEffectedChannel=0x0!
[   32.386063] Channel[Idx=3, Ch=4].bEffectedChannel=0x0!
[   32.391213] Channel[Idx=4, Ch=5].bEffectedChannel=0x0!
[   32.396360] Channel[Idx=5, Ch=6].bEffectedChannel=0x0!
[   32.401508] Channel[Idx=6, Ch=7].bEffectedChannel=0x0!
[   32.406824] Channel[Idx=7, Ch=8].bEffectedChannel=0x1!
[   32.411975] needFallBack=TRUE due to OS!
[   32.415909] Channel[Idx=8, Ch=9].bEffectedChannel=0x0!
[   32.421055] Channel[Idx=9, Ch=10].bEffectedChannel=0x0!
[   32.426292] Channel[Idx=10, Ch=11].bEffectedChannel=0x0!
[   32.431612] Channel[Idx=11, Ch=12].bEffectedChannel=0x2!
[   32.436933] needFallBack=TRUE due to OP/OT!
[   32.441123] Channel[Idx=12, Ch=13].bEffectedChannel=0x0!
[   32.446464] MtCmdChannelSwitch: control_chl = 6,control_ch2=0, central_chl = 8 DBDCIdx= 0, Band= 0
[   32.455429] BW = 1,TXStream = 4, RXStream = 4, scan(0)
[   32.488566] [DfsCacNormalStart] Normal start. Enable MAC TX
[   32.564991] [DfsCacNormalStart] Normal start. Enable MAC TX
[   32.574305] apidx 0 for WscUUIDInit
[   32.577835] Generate UUID for apidx(0)
[   32.581631] ap_inf_open <---
[   32.584541] mtk_ppe_dev_register_hook : ineterface ra0 register (1)
[   32.611599] device ra0 entered promiscuous mode
[   32.616297] br-lan: port 2(ra0) entered forwarding state
[   32.621639] br-lan: port 2(ra0) entered forwarding state
[   32.753730] Device Instance
[   32.756588]  WDEV 00:, Name:ra0, Wdev(list) Idx:0
[   32.761378]           Idx:7
[   32.763612] mtk_ppe_dev_register_hook : ra0 has been registered in wifi_hook_if table[1]
[   32.771881]
[   32.773411]
[   32.774916]
[   32.776418]
[   32.777946]
[   32.779451]
[   32.780962]
[   32.782472]
[   32.783968]
[   32.785480]
[   32.786976]
[   32.788469]
[   32.789974]
[   32.791467]
[   32.792970]
[   32.794463]
[   34.624891] br-lan: port 2(ra0) entered forwarding state
[   38.508633] jffs2: notice: (2306) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[   39.287031] S60samba (4143): drop_caches: 3
[   40.272094] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[   40.279062] jffs2_build_filesystem(): unlocking the mtd device... done.
[   40.285733] jffs2_build_filesystem(): erasing all blocks after the end marker... done.
[   41.593965] jffs2: notice: (4264) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
BusyBox v1.25.1 () built-in shell (ash)
     _________
    /        /\      _    ___ ___  ___
   /  LE    /  \    | |  | __|   \| __|
  /    DE  /    \   | |__| _|| |) | _|
 /________/  LE  \  |____|___|___/|___|                      lede-project.org
 \        \   DE /
  \    LE  \    /  -----------------------------------------------------------
   \  DE    \  /    Reboot (17.01-SNAPSHOT, r0-aec93540)
    \________\/    -----------------------------------------------------------
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
