[BPI-R64] mt7622 mac80211 WiFi driver
Interesting find, I guess this only affects mt7622 wmac but not mt7615?
@moore any info on this?
Right,this patch is only for mt7622,but i guess for mt7615 there should be a similar way as mt7622 uses mt7615 core
The four antennas on the board are all for MT7622 WiFi, could you explain more that what did you mean about ā€œhow does the board decides which device uses which antennaā€?
Iā€™ve tested the latest driver, and it can use rate MCS31 (4 antennas).
root@OpenWrt:/# iw phy | grep Antennas
        Available Antennas: TX 0xf RX 0xf
        Configured Antennas: TX 0xf RX 0xf
root@OpenWrt:/# iw dev wlan0 station dump
Station 2c:fd:a1:ce:5e:a9 (on wlan0)
        inactive time:  8 ms
        rx bytes:       12685717
        rx packets:     169384
        tx bytes:       812461366
        tx packets:     271666
        tx retries:     75596
        tx failed:      150
        rx drop misc:   1
        signal:         -43 [-43, -60, -44, -44] dBm
        signal avg:     -43 [-43, -59, -44, -44] dBm
        tx bitrate:     288.9 MBit/s MCS 31 short GI
        tx duration:    41637653 us
        rx bitrate:     288.9 MBit/s MCS 31 short GI
        rx duration:    1901454 us
Needs the MCS31 mode enabled? How?
is your latest branch fixed to use 4 antennas?
i donā€™t know if i need additional patches to enable all 4 antennasā€¦thats why i asked how to enable the mode to check
what he meant is to test the speed directly. If the speed of a single antenna is about 100Mbps, the speed of four antennas is more than 200Mbps.
there are two problems with MT7622 wifi, right? first is 6db, and second is antenna. isnā€™t it repair on your branch?
6db seems to depend on eeprom which cannot be loaded currently without mtd (my file-aproach was denied to be implemented). Antenna i donā€™t know how to check/set the mcs31 mode.
i can only fix if i know how to do it :slight_smile:
how can I judge that my board has successfully loaded eeprom? i have no errors in the startup log? but " txpower 6.00 dBm"
by default eeprom from card is loadedā€¦an this is stuck by 6dbmā€¦to use higher txpower vyou need to load other eeprom with the tx-bytes set to 21db
Txpower and the number of tx antenna are both load from eeprom. You can try to manually set ā€œtx_maskā€ variable in mt7615_eeprom_parse_hw_cap() to 4, to see if you can get 4 antennas working.
can you help me to add code for loading eeprom-file from rootfs? instead of mtd partition? imho this should be similar
i know it is loaded from mtd, i want to know how to check the load is successful, because my boot log has no eeprom errors.
does no error mean that the load was successful? but I deleted all mtd used to save eeprom. still no startup error. dd if=/dev/zero of=/dev/mmcblk1p4 dd if=/dev/zero of=/dev/mmcblk1p5
As i said,by default eeprom is read from card itself (imho called efuse). Additionaly mtd can be used. I guess read from mtd is done here (common code for all mt76 wireless devices):
https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/drivers/net/wireless/mediatek/mt76/eeprom.c?h=linux-5.9.y#n57
So you can add debug code here to check
your commands here on my r2 with mt7615
root@bpi-r2:~# iw phy | grep Antennas
root@bpi-r2:~# iw dev wlan0 station dump
first is same output as yours, last one is empty, i guess i need to be connected to a AP to see output, right? can i open an IP with mcs31 enabled?
have not tried yet the code-change in this file (tx_mask = 4):
https://elixir.bootlin.com/linux/latest/source/drivers/net/wireless/mediatek/mt76/mt7615/eeprom.c#L135
can you help me getting eeprom-data loaded from file?
ok!:orange_heart::heart_decoration:
Yes. MCS31 is already enabled in HT mode. For VHT mode, you can see up to 4 spatial streams and MCS9. If you have two mt7615 NICs, you can run each of them with AP and STA mode.
I will do it when I have time.
How do i set this without openwrt? I guess it needs to be set in hostapd setup anyhow
I think it is possible to add such code, otherwise loading a configuration file is too troublesome, I tested it and the loading is no problem, compatible with existing code.
// SPDX-License-Identifier: ISC
 * Copyright (C) 2016 Felix Fietkau <[email protected]>
#include <linux/of.h>
#include <linux/of_net.h>
#include <linux/mtd/mtd.h>
#include <linux/mtd/partitions.h>
#include <linux/etherdevice.h>
#include "mt76.h"
static int
mt76_get_of_file(struct mt76_dev *dev, int len)
#if defined(CONFIG_OF)
	struct device_node *np = dev->dev->of_node;
	const char *fname;
	struct file *fp;
	loff_t pos=0;
	char path[64]="/lib/firmware/";
	ssize_t ret;
	if (!np)
		return -ENOENT;
	ret = of_property_read_string(np, "mediatek,rf-conf", &fname);
	if (!np)
		return -EINVAL;
	if((strlen(path)+strlen(fname)) > sizeof(path)){
		dev_info(dev->dev,"Erro 'mediatek,rf-conf' too long\n");
		return -EINVAL;
	strcat(path,fname);
	dev_info(dev->dev,"Find 'mediatek,rf-conf' : %s\n",path);
	fp = filp_open(path, O_RDWR, 0);
	if (IS_ERR(fp)) {
		dev_info(dev->dev,"Open File Faile : %s\n",path);
		return -ENOENT;
	ret = kernel_read(fp, dev->eeprom.data, len, &pos);
	if(ret < len){
		dev_info(dev->dev,"Read File ERR, count %ld\n",ret);
		ret = -ENOENT;
	filp_close(fp, 0);
	of_node_put(np);
	dev_info(dev->dev,"Read File OK, count %ld\n",ret);
	return 0;
#else
	return -ENOENT;
#endif
static int
mt76_get_of_eeprom(struct mt76_dev *dev, int len)
#if defined(CONFIG_OF) && defined(CONFIG_MTD)
	struct mtd_info *mtd;
	const __be32 *list;
	const char *part;
	phandle phandle;
	int offset = 0;
	int size;
	size_t retlen;
	int ret;
	if (!np)
		return -ENOENT;
	list = of_get_property(np, "mediatek,mtd-eeprom", &size);
	if (!list)
		return -ENOENT;
	phandle = be32_to_cpup(list++);
	if (!phandle)
		return -ENOENT;
	np = of_find_node_by_phandle(phandle);
	if (!np)
		return -EINVAL;
	part = of_get_property(np, "label", NULL);
	if (!part)
		part = np->name;
	mtd = get_mtd_device_nm(part);
	if (IS_ERR(mtd)) {
		ret =  PTR_ERR(mtd);
		goto out_put_node;
	if (size <= sizeof(*list)) {
		ret = -EINVAL;
		goto out_put_node;
	offset = be32_to_cpup(list);
	ret = mtd_read(mtd, offset, len, &retlen, dev->eeprom.data);
	put_mtd_device(mtd);
	if (ret)
		goto out_put_node;
	if (retlen < len) {
		ret = -EINVAL;
		goto out_put_node;
out_put_node:
	of_node_put(np);
	return ret;
#else
	return -ENOENT;
#endif
void
mt76_eeprom_override(struct mt76_dev *dev)
#ifdef CONFIG_OF
	const u8 *mac;
	if (!np)
		return;
	mac = of_get_mac_address(np);
	if (!IS_ERR_OR_NULL(mac))
		memcpy(dev->macaddr, mac, ETH_ALEN);
#endif
	if (!is_valid_ether_addr(dev->macaddr)) {
		eth_random_addr(dev->macaddr);
		dev_info(dev->dev,
			 "Invalid MAC address, using random address %pM\n",
			 dev->macaddr);
EXPORT_SYMBOL_GPL(mt76_eeprom_override);
int
mt76_eeprom_init(struct mt76_dev *dev, int len)
	dev->eeprom.size = len;
	dev->eeprom.data = devm_kzalloc(dev->dev, len, GFP_KERNEL);
	if (!dev->eeprom.data)
		return -ENOMEM;
	return (!mt76_get_of_file(dev, len)) || (!mt76_get_of_eeprom(dev, len));//mtd priority mt76
EXPORT_SYMBOL_GPL(mt76_eeprom_init);
device treexx.dts
&wmac {
	mediatek,rf-conf = "mt7622_rf_conf.bin";
	status = "okay";
eeprom.bin copy to /lib/firmware/mt7622_rf_conf.bin
root@MT7622:~# dmesg | grep mt7622
[    1.237929] rtc_mt7622 10212800.rtc: registered as rtc0
[    2.171585] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01T00:00:01 UTC (946684801)
[    5.520073] mt7622_wmac 18000000.wmac: ASIC revision: 76220010
[    5.562880] mt7622_wmac 18000000.wmac: Find 'mediatek,rf-conf' : /lib/firmware/mt7622_rf_conf.bin
[    5.622651] mt7622_wmac 18000000.wmac: Read File OK, count 1024
[    5.666614] mt7622_wmac 18000000.wmac: MAC addr = 00:0c:43:26:60:00
[    5.721189] mt7622_wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20190801210351
[    5.856793] mt7622_wmac 18000000.wmac: Firmware init done
[    5.902582] mt7622_wmac 18000000.wmac: Driver own success
root@MT7622:~#
can it be added to your branch?
