[BPI-R64] loading OpenWRT built files into the board
Here is the full bootlog before start kernel. Because the saved bootarg env disappear after reboot, so after uboot i save the bootarg env again, then start the kernel from flash.
F0: 102B 0000
F5: 480A 0031
F5: 480A 0031
F3: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0000 0041 [0000]
G0: 0190 0000
T0: 0000 039E [000F]
Jump to BL
UNIVPLL_CON0 = 0xFE000000!!!
mt_pll_init: Set pll frequency for 25M crystal
RAM_CONSOLE preloader last status: 0x0 0x0 0x0 0x0 0x0 0x0
[PMIC_WRAP]wrap_init pass,the return value=0.
[pmic_init] Preloader Start..................
[pmic_init] MT6380 CHIP Code, reg_val = 0, 1:E2  0:E3
[pmic_init] Done...................
Chip part number:7622A
MT7622 Version: 1.2.7, (iPA)
SSC OFF
mt_pll_post_init: mt_get_cpu_freq = 1350000Khz
mt_pll_post_init: mt_get_mem_freq = 1600000Khz
mt_pll_post_init: mt_get_bus_freq = 1119920Khz
[PLFM] Init I2C: OK(0)
[BLDR] Build Time: 20180622-162441
==== Dump RGU Reg ========
RGU MODE:     4D
RGU LENGTH:   FFE0
RGU STA:      0
RGU INTERVAL: FFF
RGU SWSYSRST: 8000
==== Dump RGU Reg End ====
RGU: g_rgu_satus:0
 mtk_wdt_mode_config  mode value=10, tmp:22000010
PL P ON
WDT does not trigger reboot
WDT NONRST=0x20000000
WDT IRQ_EN=0x340003
RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3)
[EMI] MDL number = 2
[EMI] DRAMC calibration start
[EMI] DRAMC calibration end
[EMI]rank0 size: 0x40000000
[MEM] complex R/W mem test pass
RAM_CONSOLE wdt status (0x0)=0x0
[mmc_init]: msdc0 start mmc_init_host() in PL...
[msdc_init]: msdc0 Host controller intialization start
[SD0] Pins mode(1), none(0), down(1), up(2), keep(3)
[SD0] Pins mode(2), none(0), down(1), up(2), keep(3)
[info][msdc_set_startbit 1127] read data start bit at rising edge
[info][msdc_config_clksrc] input clock is 400000kHz
[SD0] Bus Width: 1
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(0) DDR(0) DIV(385) DS(0) RS(0)
[msdc_init]: msdc0 Host controller intialization done
[mmc_init]: msdc0 start mmc_init_card() in PL...
[mmc_init_card]: start
[SD0] Bus Width: 8
[SD0] Switch to High-Speed mode!
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(2) DDR(1) DIV(192) DS(0) RS(0)
[SD0] Bus Width: 8
[SD0] Size: 7456 MB, Max.Speed: 52000 kHz, blklen(512), nblks(15269888), ro(0)
[mmc_init_mem_card 3140][SD0] Initialized, eMMC50
before host->cur_bus_clk(259740)
[SD0] SET_CLK(52000kHz): SCLK(50000kHz) MODE(2) DDR(1) DIV(1) DS(0) RS(0)
host->cur_bus_clk(50000000)
[mmc_init_card]: finish successfully
[PLFM] Init Boot Device: OK(0)
[GPT_PL]Parsing Primary GPT now...
[GPT_PL][0]name=tee1, part_id=8, start_sect=0x400, nr_sects=0x200
[GPT_PL][1]name=lk, part_id=8, start_sect=0x600, nr_sects=0x400
[GPT_PL][2]name=nvram, part_id=8, start_sect=0xA00, nr_sects=0x400
[GPT_PL][3]name=rf, part_id=8, start_sect=0xE00, nr_sects=0x200
[GPT_PL][4]name=boot, part_id=8, start_sect=0x1000, nr_sects=0x20000
[GPT_PL][5]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][6]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][7]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][8]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][9]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][10]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][11]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][12]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][13]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][14]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][15]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][16]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][17]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][18]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][19]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][20]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][21]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][22]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][23]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][24]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][25]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][26]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][27]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][28]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][29]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][30]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][31]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][32]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][33]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][34]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][35]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][36]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][37]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][38]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][39]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][40]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][41]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][42]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][43]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][44]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][45]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][46]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][47]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][48]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][49]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][50]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][51]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][52]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][53]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][54]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][55]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][56]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][57]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][58]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][59]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][60]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][61]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][62]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][63]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][64]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][65]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][66]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][67]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][68]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][69]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][70]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][71]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][72]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][73]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][74]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][75]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][76]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][77]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][78]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][79]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][80]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][81]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][82]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][83]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][84]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][85]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][86]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][87]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][88]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][89]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][90]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][91]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][92]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][93]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][94]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][95]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][96]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][97]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][98]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][99]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][100]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][101]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][102]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][103]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][104]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][105]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][106]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][107]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][108]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][109]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][110]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][111]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][112]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][113]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][114]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][115]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][116]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][117]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][118]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][119]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][120]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][121]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][122]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][123]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][124]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][125]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][126]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL][127]name=, part_id=8, start_sect=0x0, nr_sects=0x1
[GPT_PL]Success to find valid GPT.
[PART] blksz: 512B
[PART] [0x0000000000080000-0x00000000000BFFFF] "tee1" (512 blocks)
[PART] [0x00000000000C0000-0x000000000013FFFF] "lk" (1024 blocks)
[PART] [0x0000000000140000-0x00000000001BFFFF] "nvram" (1024 blocks)
[PART] [0x00000000001C0000-0x00000000001FFFFF] "rf" (512 blocks)
[PART] [0x0000000000200000-0x00000000041FFFFF] "boot" (131072 blocks)
[PART] [0x0000000000000000-0x00000000000001FF] "" (1 blocks)
Device APC domain init setup:
Domain Setup (0x0)
Domain Setup (0x0)
Device APC domain after setup:
Domain Setup (0x0)
Domain Setup (0x0)
[get_part] part->nr_sects=512, part->info->name=tee1
[get_part] part->nr_sects=1024, part->info->name=lk
[PART] Image with part header
[PART] name : U-Boot
[PART] addr : 41E00000h mode : -1
[PART] size : 246424
[PART] magic: 58881688h
[PART] load "lk" from 0x00000000000C0200 (dev) to 0x41E00000 (mem) [SUCCESS]
[PART] load speed: 10938KB/s, 246424 bytes, 22ms
load lk (ret=0)
[PART] name : atf
[PART] addr : FFFFFFFFh mode : -1
[PART] size : 62032
[PART] load "tee1" from 0x0000000000080200 (dev) to 0x43000DC0 (mem) [SUCCESS]
[PART] load speed: 6730KB/s, 62032 bytes, 9ms
load tee1 (ret=0)
[BLDR] bldr load tee part ret=0x0, addr=0x43001000
[get_part] part->nr_sects=1024, part->info->name=nvram
[get_part] part->nr_sects=512, part->info->name=rf
[get_part] part->nr_sects=131072, part->info->name=boot
[BLDR] part_load_raw_part ret=0x0
[BLDR] part_load_images ret=0x0
[BLDR] Others, jump to ATF
[BLDR] jump to 0x41E00000
[BLDR] <0x41E00000>=0xEA00000F
[BLDR] <0x41E00004>=0xE59FF014
U-Boot 2014.04-rc1 (May 09 2019 - 19:22:09)
auto detection g_total_rank_size = 0x3F000000
DRAM:  1008 MiB
dev_num = 0
***size=4096, offset=1310720, blk_start=2560, blk_cnt=8
In:    serial
Out:   serial
Err:   serial
dev_num = 0
Net:   mtk_eth
Uip activated
  *** U-Boot EMMC ***
     1. System Load Linux to SDRAM via TFTP.
     2. System Load Linux Kernel then write to Flash via TFTP.
     3. Boot system code via Flash.
     4. System Load U-Boot then write to Flash via TFTP.
     5. System Load U-Boot then write to Flash via Serial.
     6. System Load ATF then write to Flash via TFTP.
     7. System Load Preloader then write to Flash via TFTP.
     8. System Load ROM header then write to Flash via TFTP.
     9. System Load CTP then write to Flash via TFTP.
     a. System Load CTP then Boot to CTP (via Flash).
     b. System Load flashimage then write to Flash via TFTP.
     c. System Load partition table then write to Flash via TFTP.
     U-Boot console
  Press UP/DOWN to move or Press 1~9,a~c to choose, ENTER to select
MT7622> setenv bootargs 'console=ttyS0,115200n1 rootfstype=squashfs earlyprintk block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts=eMMC:768k(mbr)ro,512k(uboot),512k(Config),256k(Factory),64M(Kernel),2048M(usrdata)'
MT7622> saveenv
Saving Environment to MMC...
dev_num = 0
Writing to MMC(0)... offset=1310720
size=4096
mmc->write_bl_len=512
done
MT7622> printenv
arch=arm
atf_filename=trustzone.bin
baudrate=115200
board=mt7622_evb
board_name=mt7622_evb
boot0=download_setting kernel;tftpboot ${loadaddr} ${kernel_filename}; bootm
boot1=download_setting kernel;tftpboot ${loadaddr} ${kernel_filename};run boot_wr_img;run boot_rd_img;bootm
boot10=download_setting flashimage;tftpboot ${loadaddr} ${flashimage_filename};run wr_flashimage;invaild_env
boot11=download_setting gpt;tftpboot ${loadaddr} ${gpt_filename};run wr_gpt
boot2=run boot_rd_img;bootm
boot3=download_setting uboot;tftpboot ${loadaddr} ${uboot_filename};run wr_uboot;invaild_env
boot4=loadb;run wr_uboot;invaild_env
boot5=download_setting atf;tftpboot ${loadaddr} ${atf_filename};run wr_atf
boot6=download_setting preloader;tftpboot ${loadaddr} ${preloader_filename};run wr_pl
boot7=download_setting hdr;tftpboot ${loadaddr} ${hdr_filename};run wr_rom_hdr
boot8=download_setting ctp;tftpboot ${loadaddr} ${ctp_filename};run wr_ctp
boot9=run boot_rd_ctp;boot_to_ctp
boot_rd_ctp=mmc device 0;mmc read ${loadaddr} 0x1000 0xa000
boot_rd_img=mmc device 0;mmc read ${loadaddr} 0x1000 1;image_blks 512;mmc read ${loadaddr} 0x1000 ${img_blks}
boot_wr_img=filesize_check 0x1E00000;if test ${filesize_result} = good; then image_blks 512  ${filesize};mmc device 0;mmc write ${loadaddr} 0x1000 0x18000;fi
bootargs=console=ttyS0,115200n1 rootfstype=squashfs earlyprintk block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts=eMMC:768k(mbr)ro,512k(uboot),512k(Config),256k(Factory),64M(Kernel),2048M(usrdata)
bootcmd=No
bootdelay=3
bootfile=iverson_uImage
bootmenu_0=1. System Load Linux to SDRAM via TFTP.=run boot0
bootmenu_1=2. System Load Linux Kernel then write to Flash via TFTP.=run boot1
bootmenu_10=b. System Load flashimage then write to Flash via TFTP.=run boot10
bootmenu_11=c. System Load partition table then write to Flash via TFTP.=run boot11
bootmenu_2=3. Boot system code via Flash.=run boot2
bootmenu_3=4. System Load U-Boot then write to Flash via TFTP.=run boot3
bootmenu_4=5. System Load U-Boot then write to Flash via Serial.=run boot4
bootmenu_5=6. System Load ATF then write to Flash via TFTP.=run boot5
bootmenu_6=7. System Load Preloader then write to Flash via TFTP.=run boot6
bootmenu_7=8. System Load ROM header then write to Flash via TFTP.=run boot7
bootmenu_8=9. System Load CTP then write to Flash via TFTP.=run boot8
bootmenu_9=a. System Load CTP then Boot to CTP (via Flash).=run boot9
bootmenu_delay=30
cpu=armv7
ctp_filename=ctp.bin
ethact=mtk_eth
ethaddr=00:0C:E7:11:22:33
fdt_high=0x6c000000
flashimage_filename=flashimage.bin
gpt_filename=GPT_EMMC
hdr_filename=hdr.binary
invaild_env=no
ipaddr=10.10.10.254
kernel_filename=iverson_uImage
loadaddr=0x4007FF28
preloader_filename=preloader_fpga7622_64_ldvt.bin
serverip=10.10.10.3
soc=mt7622
stderr=serial
stdin=serial
stdout=serial
uboot_filename=u-boot-mtk.bin
vendor=mediatek
wr_atf=filesize_check 0x40000;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x400 0x200;fi
wr_ctp=filesize_check 0x1400000;if test ${filesize_result} = good; then ctp_check;if test ${ctp_result} = good; then mmc device 0;mmc write ${loadaddr} 0x1000 0xa000;reset; fi;fi
wr_flashimage=filesize_check 0x1400000;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x0 0xa000;fi
wr_gpt=filesize_check 0x4400;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x0 0x22;fi
wr_pl=filesize_check 0x40000;if test ${filesize_result} = good; then mmc device 0; mmc write ${loadaddr} 0x0 0x200 emmc_preloader;fi
wr_rom_hdr=filesize_check 0xA000;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x0 0x50;fi
wr_uboot=filesize_check 0x80000;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x600 0x400;fi
Environment size: 3903/4092 bytes
MT7622> bootmenu
  *** U-Boot EMMC ***
     U-Boot console
mmc0 is current device
mmc0 operation
dev_num = 0
MMC read: dev # 0, block # 4096, count 1 ... 1 blocks read: OK
[do_read_image_blks] This is a FIT image,img_size = 0x2af388
mmc0 operation
dev_num = 0
MMC read: dev # 0, block # 4096, count 5498 ... 5498 blocks read: OK
bootm flag=0, states=70f
## Loading kernel from FIT Image at 4007ff28 ...
   Using 'config@1' configuration
   Trying 'kernel@1' kernel subimage
     Description:  ARM64 OpenWrt Linux-4.19.72
     Type:         Kernel Image
     Compression:  lzma compressed
     Data Start:   0x40080010
     Data Size:    2789906 Bytes = 2.7 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x41080000
     Entry Point:  0x41080000
     Hash algo:    crc32
     Hash value:   5cfc30ab
     Hash algo:    sha1
     Hash value:   733f3a06467f3cbf46c6bbad37a314c6a3031ac9
## Loading fdt from FIT Image at 4007ff28 ...
   Trying 'fdt@1' fdt subimage
     Description:  ARM64 OpenWrt BPI-R64 device tree blob
     Compression:  uncompressed
     Data Start:   0x4032935c
     Data Size:    23070 Bytes = 22.5 KiB
     Hash algo:    crc32
     Hash value:   6f50902d
     Hash algo:    sha1
     Hash value:   a45cf7ff90b8c1baa5e7680293643f6d156ddda2
   Booting using the fdt blob at 0x4032935c
   Uncompressing Kernel Image ... OK
   Loading Device Tree to 6bff7000, end 6bfffa1d ... OK
Starting kernel ...
Here is the full log after kernel start.
[ATF][    68.917108]save kernel info
[ATF][    68.920045]Kernel_EL2
[ATF][    68.922715]Kernel is 64Bit
[ATF][    68.925803]pc=0x41080000, r0=0x6bff7000, r1=0x0
INFO:    BL3-1: Preparing for EL3 exit to normal world, Kernel
INFO:    BL3-1: Next image address = 0x41080000
INFO:    BL3-1: Next image spsr = 0x3c9
[ATF][    68.943500]el3_exit
[    0.000000] Linux version 4.19.72 (ubuntu@ip-172-31-2-8) (gcc version 7.4.0 (OpenWrt GCC 7.4.0 r0+11006-713561a10b)) #0 SMP Fri Sep 13 14:40:29 2019
[    0.000000] Machine model: Bananapi BPI-R64
[    0.000000] On node 0 totalpages: 262096
[    0.000000]   DMA32 zone: 4096 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 262096 pages, LIFO batch:63
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Trusted OS migration not required
[    0.000000] random: get_random_bytes called from start_kernel+0x84/0x3f8 with crng_init=0
[    0.000000] percpu: Embedded 21 pages/cpu s46872 r8192 d30952 u86016
[    0.000000] pcpu-alloc: s46872 r8192 d30952 u86016 alloc=21*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258000
[    0.000000] Kernel command line: console=ttyS0,115200n1 rootfstype=squashfs earlyprintk block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts=eMMC:768k(mbr)ro,512k(uboot),512k(Config),256k(Factory),64M(Kernel),2048M(usrdata)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Memory: 1021484K/1048384K available (5758K kernel code, 398K rwdata, 1604K rodata, 320K init, 301K bss, 26900K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu:     CONFIG_RCU_FANOUT set to non-default value of 32.
[    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[    0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[    0.000003] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[    0.000171] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[    0.000179] pid_max: default: 32768 minimum: 301
[    0.000253] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.000264] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.001087] ASID allocator initialised with 65536 entries
[    0.001141] rcu: Hierarchical SRCU implementation.
[    0.001493] smp: Bringing up secondary CPUs ...
[    0.001794] Detected VIPT I-cache on CPU1
[    0.001831] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.001891] smp: Brought up 1 node, 2 CPUs
[    0.001898] SMP: Total of 2 processors activated.
[    0.001903] CPU features: detected: 32-bit EL0 Support
[    0.001968] CPU: All CPU(s) started at EL2
[    0.001977] alternatives: patching kernel code
[    0.002345] devtmpfs: initialized
[    0.004995] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.005007] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.005090] pinctrl core: initialized pinctrl subsystem
[    0.005268] reg-dummy reg-dummy: no of_node; not parsing pinctrl DT
[    0.005640] NET: Registered protocol family 16
[    0.006125] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.006249] DMA: preallocated 256 KiB pool for atomic allocations
[    0.014813] mtk-pinctrl 10211000.pinctrl: try to register 103 pins ...
[    0.014825] pinctrl core: registered pin 0 (GPIO_A) on pinctrl_mt7622
[    0.014830] pinctrl core: registered pin 1 (I2S1_IN) on pinctrl_mt7622
[    0.014835] pinctrl core: registered pin 2 (I2S1_OUT) on pinctrl_mt7622
[    0.014839] pinctrl core: registered pin 3 (I2S_BCLK) on pinctrl_mt7622
[    0.014843] pinctrl core: registered pin 4 (I2S_WS) on pinctrl_mt7622
[    0.014847] pinctrl core: registered pin 5 (I2S_MCLK) on pinctrl_mt7622
[    0.014851] pinctrl core: registered pin 6 (TXD0) on pinctrl_mt7622
[    0.014855] pinctrl core: registered pin 7 (RXD0) on pinctrl_mt7622
[    0.014859] pinctrl core: registered pin 8 (SPI_WP) on pinctrl_mt7622
[    0.014863] pinctrl core: registered pin 9 (SPI_HOLD) on pinctrl_mt7622
[    0.014867] pinctrl core: registered pin 10 (SPI_CLK) on pinctrl_mt7622
[    0.014871] pinctrl core: registered pin 11 (SPI_MOSI) on pinctrl_mt7622
[    0.014875] pinctrl core: registered pin 12 (SPI_MISO) on pinctrl_mt7622
[    0.014880] pinctrl core: registered pin 13 (SPI_CS) on pinctrl_mt7622
[    0.014884] pinctrl core: registered pin 14 (I2C_SDA) on pinctrl_mt7622
[    0.014888] pinctrl core: registered pin 15 (I2C_SCL) on pinctrl_mt7622
[    0.014894] pinctrl core: registered pin 16 (I2S2_IN) on pinctrl_mt7622
[    0.014898] pinctrl core: registered pin 17 (I2S3_IN) on pinctrl_mt7622
[    0.014902] pinctrl core: registered pin 18 (I2S4_IN) on pinctrl_mt7622
[    0.014906] pinctrl core: registered pin 19 (I2S2_OUT) on pinctrl_mt7622
[    0.014910] pinctrl core: registered pin 20 (I2S3_OUT) on pinctrl_mt7622
[    0.014914] pinctrl core: registered pin 21 (I2S4_OUT) on pinctrl_mt7622
[    0.014918] pinctrl core: registered pin 22 (GPIO_B) on pinctrl_mt7622
[    0.014922] pinctrl core: registered pin 23 (MDC) on pinctrl_mt7622
[    0.014926] pinctrl core: registered pin 24 (MDIO) on pinctrl_mt7622
[    0.014930] pinctrl core: registered pin 25 (G2_TXD0) on pinctrl_mt7622
[    0.014934] pinctrl core: registered pin 26 (G2_TXD1) on pinctrl_mt7622
[    0.014938] pinctrl core: registered pin 27 (G2_TXD2) on pinctrl_mt7622
[    0.014942] pinctrl core: registered pin 28 (G2_TXD3) on pinctrl_mt7622
[    0.014946] pinctrl core: registered pin 29 (G2_TXEN) on pinctrl_mt7622
[    0.014950] pinctrl core: registered pin 30 (G2_TXC) on pinctrl_mt7622
[    0.014954] pinctrl core: registered pin 31 (G2_RXD0) on pinctrl_mt7622
[    0.014958] pinctrl core: registered pin 32 (G2_RXD1) on pinctrl_mt7622
[    0.014962] pinctrl core: registered pin 33 (G2_RXD2) on pinctrl_mt7622
[    0.014966] pinctrl core: registered pin 34 (G2_RXD3) on pinctrl_mt7622
[    0.014970] pinctrl core: registered pin 35 (G2_RXDV) on pinctrl_mt7622
[    0.014974] pinctrl core: registered pin 36 (G2_RXC) on pinctrl_mt7622
[    0.014978] pinctrl core: registered pin 37 (NCEB) on pinctrl_mt7622
[    0.014982] pinctrl core: registered pin 38 (NWEB) on pinctrl_mt7622
[    0.014986] pinctrl core: registered pin 39 (NREB) on pinctrl_mt7622
[    0.014990] pinctrl core: registered pin 40 (NDL4) on pinctrl_mt7622
[    0.014994] pinctrl core: registered pin 41 (NDL5) on pinctrl_mt7622
[    0.014998] pinctrl core: registered pin 42 (NDL6) on pinctrl_mt7622
[    0.015002] pinctrl core: registered pin 43 (NDL7) on pinctrl_mt7622
[    0.015006] pinctrl core: registered pin 44 (NRB) on pinctrl_mt7622
[    0.015010] pinctrl core: registered pin 45 (NCLE) on pinctrl_mt7622
[    0.015014] pinctrl core: registered pin 46 (NALE) on pinctrl_mt7622
[    0.015018] pinctrl core: registered pin 47 (NDL0) on pinctrl_mt7622
[    0.015024] pinctrl core: registered pin 48 (NDL1) on pinctrl_mt7622
[    0.015028] pinctrl core: registered pin 49 (NDL2) on pinctrl_mt7622
[    0.015032] pinctrl core: registered pin 50 (NDL3) on pinctrl_mt7622
[    0.015036] pinctrl core: registered pin 51 (MDI_TP_P0) on pinctrl_mt7622
[    0.015040] pinctrl core: registered pin 52 (MDI_TN_P0) on pinctrl_mt7622
[    0.015044] pinctrl core: registered pin 53 (MDI_RP_P0) on pinctrl_mt7622
[    0.015048] pinctrl core: registered pin 54 (MDI_RN_P0) on pinctrl_mt7622
[    0.015052] pinctrl core: registered pin 55 (MDI_TP_P1) on pinctrl_mt7622
[    0.015056] pinctrl core: registered pin 56 (MDI_TN_P1) on pinctrl_mt7622
[    0.015060] pinctrl core: registered pin 57 (MDI_RP_P1) on pinctrl_mt7622
[    0.015064] pinctrl core: registered pin 58 (MDI_RN_P1) on pinctrl_mt7622
[    0.015068] pinctrl core: registered pin 59 (MDI_RP_P2) on pinctrl_mt7622
[    0.015072] pinctrl core: registered pin 60 (MDI_RN_P2) on pinctrl_mt7622
[    0.015076] pinctrl core: registered pin 61 (MDI_TP_P2) on pinctrl_mt7622
[    0.015080] pinctrl core: registered pin 62 (MDI_TN_P2) on pinctrl_mt7622
[    0.015084] pinctrl core: registered pin 63 (MDI_TP_P3) on pinctrl_mt7622
[    0.015089] pinctrl core: registered pin 64 (MDI_TN_P3) on pinctrl_mt7622
[    0.015093] pinctrl core: registered pin 65 (MDI_RP_P3) on pinctrl_mt7622
[    0.015097] pinctrl core: registered pin 66 (MDI_RN_P3) on pinctrl_mt7622
[    0.015101] pinctrl core: registered pin 67 (MDI_RP_P4) on pinctrl_mt7622
[    0.015105] pinctrl core: registered pin 68 (MDI_RN_P4) on pinctrl_mt7622
[    0.015109] pinctrl core: registered pin 69 (MDI_TP_P4) on pinctrl_mt7622
[    0.015113] pinctrl core: registered pin 70 (MDI_TN_P4) on pinctrl_mt7622
[    0.015117] pinctrl core: registered pin 71 (PMIC_SCL) on pinctrl_mt7622
[    0.015121] pinctrl core: registered pin 72 (PMIC_SDA) on pinctrl_mt7622
[    0.015125] pinctrl core: registered pin 73 (SPIC1_CLK) on pinctrl_mt7622
[    0.015129] pinctrl core: registered pin 74 (SPIC1_MOSI) on pinctrl_mt7622
[    0.015133] pinctrl core: registered pin 75 (SPIC1_MISO) on pinctrl_mt7622
[    0.015137] pinctrl core: registered pin 76 (SPIC1_CS) on pinctrl_mt7622
[    0.015142] pinctrl core: registered pin 77 (GPIO_D) on pinctrl_mt7622
[    0.015146] pinctrl core: registered pin 78 (WATCHDOG) on pinctrl_mt7622
[    0.015150] pinctrl core: registered pin 79 (RTS3_N) on pinctrl_mt7622
[    0.015155] pinctrl core: registered pin 80 (CTS3_N) on pinctrl_mt7622
[    0.015159] pinctrl core: registered pin 81 (TXD3) on pinctrl_mt7622
[    0.015163] pinctrl core: registered pin 82 (RXD3) on pinctrl_mt7622
[    0.015167] pinctrl core: registered pin 83 (PERST0_N) on pinctrl_mt7622
[    0.015172] pinctrl core: registered pin 84 (PERST1_N) on pinctrl_mt7622
[    0.015176] pinctrl core: registered pin 85 (WLED_N) on pinctrl_mt7622
[    0.015180] pinctrl core: registered pin 86 (EPHY_LED0_N) on pinctrl_mt7622
[    0.015184] pinctrl core: registered pin 87 (AUXIN0) on pinctrl_mt7622
[    0.015187] pinctrl core: registered pin 88 (AUXIN1) on pinctrl_mt7622
[    0.015191] pinctrl core: registered pin 89 (AUXIN2) on pinctrl_mt7622
[    0.015196] pinctrl core: registered pin 90 (AUXIN3) on pinctrl_mt7622
[    0.015199] pinctrl core: registered pin 91 (TXD4) on pinctrl_mt7622
[    0.015204] pinctrl core: registered pin 92 (RXD4) on pinctrl_mt7622
[    0.015208] pinctrl core: registered pin 93 (RTS4_N) on pinctrl_mt7622
[    0.015212] pinctrl core: registered pin 94 (CTS4_N) on pinctrl_mt7622
[    0.015216] pinctrl core: registered pin 95 (PWM1) on pinctrl_mt7622
[    0.015220] pinctrl core: registered pin 96 (PWM2) on pinctrl_mt7622
[    0.015224] pinctrl core: registered pin 97 (PWM3) on pinctrl_mt7622
[    0.015228] pinctrl core: registered pin 98 (PWM4) on pinctrl_mt7622
[    0.015232] pinctrl core: registered pin 99 (PWM5) on pinctrl_mt7622
[    0.015236] pinctrl core: registered pin 100 (PWM6) on pinctrl_mt7622
[    0.015240] pinctrl core: registered pin 101 (PWM7) on pinctrl_mt7622
[    0.015244] pinctrl core: registered pin 102 (GPIO_E) on pinctrl_mt7622
[    0.015767] mtk-pinctrl 10211000.pinctrl: no hogs found
[    0.017212] gpiochip_find_base: found new base at 409
[    0.017231] gpio gpiochip0: (pinctrl_mt7622): created GPIO range 0->102 ==> 10211000.pinctrl PIN 0->102
[    0.017251] mtk-pinctrl 10211000.pinctrl: request pin 90 (AUXIN3) for pinctrl_mt7622:499
[    0.017263] gpio gpiochip0: Persistence not supported for GPIO 90
[    0.017273] GPIO line 499 (asm_sel) hogged as output/high
[    0.017413] gpio gpiochip0: (pinctrl_mt7622): added GPIO chardev (254:0)
[    0.017419] gpiochip_setup_dev: registered GPIOs 409 to 511 on device: gpiochip0 (pinctrl_mt7622)
[    0.026245] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-1p8v[0]'
[    0.026419] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-3p3v[0]'
[    0.026553] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-5v[0]'
[    0.026839] SCSI subsystem initialized
[    0.026975] libata version 3.00 loaded.
[    0.027112] usbcore: registered new interface driver usbfs
[    0.027139] usbcore: registered new interface driver hub
[    0.027172] usbcore: registered new device driver usb
[    0.027652] Bluetooth: Core ver 2.22
[    0.027681] NET: Registered protocol family 31
[    0.027685] Bluetooth: HCI device and connection manager initialized
[    0.027696] Bluetooth: HCI socket layer initialized
[    0.027703] Bluetooth: L2CAP socket layer initialized
[    0.027732] Bluetooth: SCO socket layer initialized
[    0.028182] clocksource: Switched to clocksource arch_sys_counter
[    0.029068] NET: Registered protocol family 2
[    0.029558] default registered
[    0.029564] default registered
[    0.029568] MPTCP: Stable release v0.95
[    0.029578] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes)
[    0.029596] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.029647] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[    0.029751] TCP: Hash tables configured (established 8192 bind 8192)
[    0.029844] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.029866] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.029959] NET: Registered protocol family 1
[    0.029978] PCI: CLS 0 bytes, default 64
[    0.030575] alarmtimer alarmtimer: no of_node; not parsing pinctrl DT
[    0.030779] No memory allocated for crashlog
[    0.030879] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.033774] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.033785] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.036278] io scheduler noop registered (default)
[    0.036682] mtk-tphy 1a0c4000.usb-phy: failed to get ref_clk(id-1)
[    0.036964] pinctrl core: add 1 pinctrl maps
[    0.036992] mtk-pinctrl 10211000.pinctrl: found group selector 70 for pwm_ch7_2
[    0.037003] mtk-pinctrl 10211000.pinctrl: request pin 101 (PWM7) for 11006000.pwm
[    0.037010] mtk-pinctrl 10211000.pinctrl: enable function pwm group pwm_ch7_2
[    0.037273] pinctrl core: add 3 pinctrl maps
[    0.037286] pinctrl core: add 3 pinctrl maps
[    0.037303] mtk-pinctrl 10211000.pinctrl: found group selector 44 for pcie0_pad_perst
[    0.037314] mtk-pinctrl 10211000.pinctrl: found group selector 40 for pcie0_1_waken
[    0.037324] mtk-pinctrl 10211000.pinctrl: found group selector 41 for pcie0_1_clkreq
[    0.037334] mtk-pinctrl 10211000.pinctrl: found group selector 45 for pcie1_pad_perst
[    0.037344] mtk-pinctrl 10211000.pinctrl: found group selector 42 for pcie1_0_waken
[    0.037354] mtk-pinctrl 10211000.pinctrl: found group selector 43 for pcie1_0_clkreq
[    0.037362] mtk-pinctrl 10211000.pinctrl: request pin 83 (PERST0_N) for 1a140000.pcie
[    0.037367] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_pad_perst
[    0.037375] mtk-pinctrl 10211000.pinctrl: request pin 79 (RTS3_N) for 1a140000.pcie
[    0.037380] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_waken
[    0.037387] mtk-pinctrl 10211000.pinctrl: request pin 80 (CTS3_N) for 1a140000.pcie
[    0.037392] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_clkreq
[    0.037399] mtk-pinctrl 10211000.pinctrl: request pin 84 (PERST1_N) for 1a140000.pcie
[    0.037405] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_pad_perst
[    0.037411] mtk-pinctrl 10211000.pinctrl: request pin 14 (I2C_SDA) for 1a140000.pcie
[    0.037417] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_waken
[    0.037423] mtk-pinctrl 10211000.pinctrl: request pin 15 (I2C_SCL) for 1a140000.pcie
[    0.037428] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_clkreq
[    0.039814] pinctrl core: add 1 pinctrl maps
[    0.039841] mtk-pinctrl 10211000.pinctrl: found group selector 47 for pmic_bus
[    0.039851] mtk-pinctrl 10211000.pinctrl: request pin 71 (PMIC_SCL) for 10001000.pwrap
[    0.039858] mtk-pinctrl 10211000.pinctrl: request pin 72 (PMIC_SDA) for 10001000.pwrap
[    0.039864] mtk-pinctrl 10211000.pinctrl: enable function pmic group pmic_bus
[    0.039978] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[    0.053932] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.056880] serial8250 serial8250: no of_node; not parsing pinctrl DT
[    0.056987] pinctrl core: add 1 pinctrl maps
[    0.057018] mtk-pinctrl 10211000.pinctrl: found group selector 89 for uart0_0_tx_rx
[    0.057027] mtk-pinctrl 10211000.pinctrl: request pin 6 (TXD0) for 11002000.serial
[    0.057034] mtk-pinctrl 10211000.pinctrl: request pin 7 (RXD0) for 11002000.serial
[    0.057041] mtk-pinctrl 10211000.pinctrl: enable function uart group uart0_0_tx_rx
[    0.057315] console [ttyS0] disabled
[    0.077674] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 1562500) is a ST16650V2
[    1.655142] console [ttyS0] enabled
[    1.659055] pinctrl core: add 1 pinctrl maps
[    1.663485] mtk-pinctrl 10211000.pinctrl: found group selector 96 for uart2_1_tx_rx
[    1.671393] mtk-pinctrl 10211000.pinctrl: request pin 51 (MDI_TP_P0) for 11004000.serial
[    1.679743] mtk-pinctrl 10211000.pinctrl: request pin 52 (MDI_TN_P0) for 11004000.serial
[    1.688086] mtk-pinctrl 10211000.pinctrl: enable function uart group uart2_1_tx_rx
[    1.716387] 11004000.serial: ttyS1 at MMIO 0x11004000 (irq = 117, base_baud = 1562500) is a ST16650V2
[    1.726462] 1100c000.serial: ttyS2 at MMIO 0x1100c000 (irq = 123, base_baud = 17499995) is a MediaTek BTIF
[    1.736535] serial serial0: tty port ttyS2 registered
[    1.742085] mtk_rng 1020f000.rng: registered RNG driver
[    1.742215] random: fast init done
[    1.747644] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.751128] random: crng init done
[    1.760076] loop: module loaded
[    1.764707] pinctrl core: add 1 pinctrl maps
[    1.769159] mtk-pinctrl 10211000.pinctrl: found group selector 75 for spic0_0
[    1.776520] mtk-pinctrl 10211000.pinctrl: request pin 63 (MDI_TP_P3) for 1100a000.spi
[    1.784602] mtk-pinctrl 10211000.pinctrl: request pin 64 (MDI_TN_P3) for 1100a000.spi
[    1.792681] mtk-pinctrl 10211000.pinctrl: request pin 65 (MDI_RP_P3) for 1100a000.spi
[    1.800760] mtk-pinctrl 10211000.pinctrl: request pin 66 (MDI_RN_P3) for 1100a000.spi
[    1.808839] mtk-pinctrl 10211000.pinctrl: enable function spi group spic0_0
[    1.816407] pinctrl core: add 1 pinctrl maps
[    1.820869] mtk-pinctrl 10211000.pinctrl: found group selector 77 for spic1_0
[    1.828237] mtk-pinctrl 10211000.pinctrl: request pin 67 (MDI_RP_P4) for 11016000.spi
[    1.836309] mtk-pinctrl 10211000.pinctrl: request pin 68 (MDI_RN_P4) for 11016000.spi
[    1.844388] mtk-pinctrl 10211000.pinctrl: request pin 69 (MDI_TP_P4) for 11016000.spi
[    1.852468] mtk-pinctrl 10211000.pinctrl: request pin 70 (MDI_TN_P4) for 11016000.spi
[    1.860546] mtk-pinctrl 10211000.pinctrl: enable function spi group spic1_0
[    1.868234] mdio_bus fixed-0: GPIO lookup for consumer reset
[    1.874067] mdio_bus fixed-0: using lookup tables for GPIO lookup
[    1.880368] mdio_bus fixed-0: No GPIO consumer reset found
[    1.886026] libphy: Fixed MDIO Bus: probed
[    1.890687] sean debug physpeed = 2500
[    1.917237] mdio_bus mdio-bus: GPIO lookup for consumer reset
[    1.923169] mdio_bus mdio-bus: using device tree for GPIO lookup
[    1.929371] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mdio-bus[0]'
[    1.939961] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ethernet@1b100000/mdio-bus[0]'
[    1.950458] mdio_bus mdio-bus: using lookup tables for GPIO lookup
[    1.956828] mdio_bus mdio-bus: No GPIO consumer reset found
[    1.962575] libphy: mdio: probed
[    1.965914] mtk_soc_eth 1b100000.ethernet: generated random MAC address 6a:39:c1:b0:f8:30
[    1.974358] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mac@0/fixed-link[0]'
[    1.985660] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mac@0[0]'
[    1.996050] mtk_soc_eth 1b100000.ethernet: path gmac1_sgmii in set_mux_gdm1_to_gmac1_esw updated = 1
[    2.005477] mtk_soc_eth 1b100000.ethernet: mux mux_gmac2_gmac0_to_gephy isn't present on the SoC
[    2.014541] mtk_soc_eth 1b100000.ethernet: mux mux_u3_gmac2_to_qphy isn't present on the SoC
[    2.023249] mtk_soc_eth 1b100000.ethernet: path gmac1_sgmii in set_mux_gmac1_gmac2_to_sgmii_rgmii updated = 1
[    2.033477] mtk_soc_eth 1b100000.ethernet: mux mux_gmac12_to_gephy_sgmii isn't present on the SoC
[    2.042676] mtk_soc_eth 1b100000.ethernet: connected mac 0 to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[    2.053635] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffff8009460000, irq 131
[    2.063076] mtk_soc_eth 1b100000.ethernet: generated random MAC address 36:13:53:58:d7:43
[    2.071522] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mac@1/fixed-link[0]'
[    2.082822] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mac@1[0]'
[    2.093205] mtk_soc_eth 1b100000.ethernet: path gmac2_rgmii in set_mux_gdm1_to_gmac1_esw updated = 0
[    2.102631] mtk_soc_eth 1b100000.ethernet: mux mux_gmac2_gmac0_to_gephy isn't present on the SoC
[    2.111695] mtk_soc_eth 1b100000.ethernet: mux mux_u3_gmac2_to_qphy isn't present on the SoC
[    2.120401] mtk_soc_eth 1b100000.ethernet: path gmac2_rgmii in set_mux_gmac1_gmac2_to_sgmii_rgmii updated = 0
[    2.130628] mtk_soc_eth 1b100000.ethernet: mux mux_gmac12_to_gephy_sgmii isn't present on the SoC
[    2.139816] mtk_soc_eth 1b100000.ethernet: connected mac 1 to PHY at fixed-0:01 [uid=00000000, driver=Generic PHY]
[    2.150734] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffff8009460000, irq 131
[    2.160157] netif_napi_add() called with weight 256 on device
[    2.166451] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.3
[    2.173225] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.2
[    2.180150] xhci-mtk 1a0c0000.usb: Dropping the link to regulator.2
[    2.186639] xhci-mtk 1a0c0000.usb: Dropping the link to regulator.3
[    2.193453] rtc_mt7622 10212800.rtc: rtc core: registered 10212800.rtc as rtc0
[    2.201235] pinctrl core: add 1 pinctrl maps
[    2.205663] mtk-pinctrl 10211000.pinctrl: found group selector 109 for watchdog
[    2.213220] mtk-pinctrl 10211000.pinctrl: request pin 78 (WATCHDOG) for 10212000.watchdog
[    2.221660] mtk-pinctrl 10211000.pinctrl: enable function watchdog group watchdog
[    2.229395] MTK_WDT_NONRST_REG(20000000)
[    2.233436] RGU get IRQ ID failed
[    2.236974] Bluetooth: HCI UART driver ver 2.3
[    2.241566] Bluetooth: HCI UART protocol H4 registered
[    2.246859] Bluetooth: HCI UART protocol BCSP registered
[    2.252352] Bluetooth: HCI UART protocol ATH3K registered
[    2.257969] Bluetooth: HCI UART protocol Broadcom registered
[    2.263825] Bluetooth: HCI UART protocol QCA registered
[    2.269348] mtk-cpufreq mtk-cpufreq: no of_node; not parsing pinctrl DT
[    2.269856] bluetooth hci0: Direct firmware load for mediatek/mt7622pr2h.bin failed with error -2
[    2.276260] cpu cpu0: Linked as a consumer to regulator.4
[    2.285333] bluetooth hci0: Falling back to syfs fallback for: mediatek/mt7622pr2h.bin
[    2.290956] cpu cpu0: Linked as a consumer to regulator.7
[    2.305274] generic pinconfig core: found bias-pull-up with value 1
[    2.311744] generic pinconfig core: found input-enable with value 1
[    2.318217] generic pinconfig core: found bias-pull-down with value 1
[    2.324860] pinctrl core: add 11 pinctrl maps
[    2.329369] generic pinconfig core: found bias-pull-up with value 1
[    2.335828] generic pinconfig core: found drive-strength with value 4
[    2.342470] generic pinconfig core: found input-enable with value 1
[    2.348941] generic pinconfig core: found bias-pull-down with value 1
[    2.355579] generic pinconfig core: found drive-strength with value 4
[    2.362225] pinctrl core: add 11 pinctrl maps
[    2.366723] mtk-pinctrl 10211000.pinctrl: found group selector 0 for emmc
[    2.373768] mtk-pinctrl 10211000.pinctrl: found group selector 0 for emmc
[    2.380810] mtk-pinctrl 10211000.pinctrl: request pin 40 (NDL4) for 11230000.mmc
[    2.388441] mtk-pinctrl 10211000.pinctrl: request pin 41 (NDL5) for 11230000.mmc
[    2.396066] mtk-pinctrl 10211000.pinctrl: request pin 42 (NDL6) for 11230000.mmc
[    2.403695] mtk-pinctrl 10211000.pinctrl: request pin 43 (NDL7) for 11230000.mmc
[    2.411325] mtk-pinctrl 10211000.pinctrl: request pin 44 (NRB) for 11230000.mmc
[    2.418865] mtk-pinctrl 10211000.pinctrl: request pin 45 (NCLE) for 11230000.mmc
[    2.426489] mtk-pinctrl 10211000.pinctrl: request pin 47 (NDL0) for 11230000.mmc
[    2.434118] mtk-pinctrl 10211000.pinctrl: request pin 48 (NDL1) for 11230000.mmc
[    2.441747] mtk-pinctrl 10211000.pinctrl: request pin 49 (NDL2) for 11230000.mmc
[    2.449376] mtk-pinctrl 10211000.pinctrl: request pin 50 (NDL3) for 11230000.mmc
[    2.457001] mtk-pinctrl 10211000.pinctrl: enable function emmc group emmc
[    2.464117] mtk-msdc 11230000.mmc: GPIO lookup for consumer wp
[    2.470134] mtk-msdc 11230000.mmc: using device tree for GPIO lookup
[    2.476692] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@11230000[0]'
[    2.485759] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@11230000[0]'
[    2.494733] mtk-msdc 11230000.mmc: using lookup tables for GPIO lookup
[    2.501467] mtk-msdc 11230000.mmc: No GPIO consumer wp found
[    2.507374] mtk-msdc 11230000.mmc: Linked as a consumer to regulator.2
[    2.514135] mtk-msdc 11230000.mmc: Linked as a consumer to regulator.1
[    2.520897] mtk-msdc 11230000.mmc: obtain a copy of previously claimed pinctrl
[    2.528609] mtk-pinctrl 10211000.pinctrl: request pin 40 (NDL4) for 11230000.mmc
[    2.536235] mtk-pinctrl 10211000.pinctrl: request pin 41 (NDL5) for 11230000.mmc
[    2.543866] mtk-pinctrl 10211000.pinctrl: request pin 42 (NDL6) for 11230000.mmc
[    2.551496] mtk-pinctrl 10211000.pinctrl: request pin 43 (NDL7) for 11230000.mmc
[    2.559124] mtk-pinctrl 10211000.pinctrl: request pin 44 (NRB) for 11230000.mmc
[    2.566659] mtk-pinctrl 10211000.pinctrl: request pin 45 (NCLE) for 11230000.mmc
[    2.574288] mtk-pinctrl 10211000.pinctrl: request pin 47 (NDL0) for 11230000.mmc
[    2.581918] mtk-pinctrl 10211000.pinctrl: request pin 48 (NDL1) for 11230000.mmc
[    2.589547] mtk-pinctrl 10211000.pinctrl: request pin 49 (NDL2) for 11230000.mmc
[    2.597170] mtk-pinctrl 10211000.pinctrl: request pin 50 (NDL3) for 11230000.mmc
[    2.604800] mtk-pinctrl 10211000.pinctrl: enable function emmc group emmc
[    2.637059] generic pinconfig core: found bias-pull-up with value 1
[    2.643532] generic pinconfig core: found drive-strength with value 8
[    2.650178] generic pinconfig core: found input-enable with value 1
[    2.656646] generic pinconfig core: found bias-pull-down with value 1
[    2.663290] generic pinconfig core: found drive-strength with value 12
[    2.670027] generic pinconfig core: found bias-pull-up with value 1
[    2.676489] pinctrl core: add 8 pinctrl maps
[    2.680906] generic pinconfig core: found bias-pull-up with value 1
[    2.687365] generic pinconfig core: found input-enable with value 1
[    2.693838] generic pinconfig core: found bias-pull-down with value 1
[    2.700485] pinctrl core: add 7 pinctrl maps
[    2.704904] mtk-pinctrl 10211000.pinctrl: found group selector 71 for sd_0
[    2.712025] mtk-pinctrl 10211000.pinctrl: found group selector 71 for sd_0
[    2.719135] mtk-pinctrl 10211000.pinctrl: request pin 16 (I2S2_IN) for 11240000.mmc
[    2.727027] mtk-pinctrl 10211000.pinctrl: request pin 17 (I2S3_IN) for 11240000.mmc
[    2.734927] mtk-pinctrl 10211000.pinctrl: request pin 18 (I2S4_IN) for 11240000.mmc
[    2.742825] mtk-pinctrl 10211000.pinctrl: request pin 19 (I2S2_OUT) for 11240000.mmc
[    2.750813] mtk-pinctrl 10211000.pinctrl: request pin 20 (I2S3_OUT) for 11240000.mmc
[    2.758804] mtk-pinctrl 10211000.pinctrl: request pin 21 (I2S4_OUT) for 11240000.mmc
[    2.766786] mtk-pinctrl 10211000.pinctrl: enable function sd group sd_0
[    2.773728] mtk-msdc 11240000.mmc: GPIO lookup for consumer cd
[    2.779745] mtk-msdc 11240000.mmc: using device tree for GPIO lookup
[    2.786307] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/mmc@11240000[0]' - status (0)
[    2.796094] mtk-pinctrl 10211000.pinctrl: request pin 81 (TXD3) for pinctrl_mt7622:490
[    2.804267] gpio gpiochip0: Persistence not supported for GPIO 81
[    2.810558] mtk-msdc 11240000.mmc: Got CD GPIO
[    2.815136] mtk-msdc 11240000.mmc: GPIO lookup for consumer wp
[    2.821153] mtk-msdc 11240000.mmc: using device tree for GPIO lookup
[    2.827706] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@11240000[0]'
[    2.836774] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@11240000[0]'
[    2.845748] mtk-msdc 11240000.mmc: using lookup tables for GPIO lookup
[    2.852481] mtk-msdc 11240000.mmc: No GPIO consumer wp found
[    2.858383] mtk-msdc 11240000.mmc: Linked as a consumer to regulator.2
[    2.865155] mtk-msdc 11240000.mmc: obtain a copy of previously claimed pinctrl
[    2.898802] NET: Registered protocol family 10
[    2.903936] Segment Routing with IPv6
[    2.907770] fullmesh registered
[    2.911019] ndiffports registered
[    2.914435] binder registered
[    2.917505] netlink registered
[    2.920654] roundrobin registered
[    2.924064] redundant registered
[    2.927385] blest registered
[    2.930354] NET: Registered protocol family 17
[    2.934952] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.948377] 8021q: 802.1Q VLAN Support v1.8
[    2.960785] pinctrl core: add 3 pinctrl maps
[    2.965201] pinctrl core: add 3 pinctrl maps
[    2.969645] mtk-pinctrl 10211000.pinctrl: found group selector 44 for pcie0_pad_perst
[    2.977723] mtk-pinctrl 10211000.pinctrl: found group selector 40 for pcie0_1_waken
[    2.985627] mtk-pinctrl 10211000.pinctrl: found group selector 41 for pcie0_1_clkreq
[    2.993620] mtk-pinctrl 10211000.pinctrl: found group selector 45 for pcie1_pad_perst
[    3.001702] mtk-pinctrl 10211000.pinctrl: found group selector 42 for pcie1_0_waken
[    3.009605] mtk-pinctrl 10211000.pinctrl: found group selector 43 for pcie1_0_clkreq
[    3.017591] mtk-pinctrl 10211000.pinctrl: request pin 83 (PERST0_N) for 1a140000.pcie
[    3.025671] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_pad_perst
[    3.033661] mtk-pinctrl 10211000.pinctrl: request pin 79 (RTS3_N) for 1a140000.pcie
[    3.041558] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_waken
[    3.049372] mtk-pinctrl 10211000.pinctrl: request pin 80 (CTS3_N) for 1a140000.pcie
[    3.057264] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_clkreq
[    3.065163] mtk-pinctrl 10211000.pinctrl: request pin 84 (PERST1_N) for 1a140000.pcie
[    3.073240] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_pad_perst
[    3.081228] mtk-pinctrl 10211000.pinctrl: request pin 14 (I2C_SDA) for 1a140000.pcie
[    3.089216] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_waken
[    3.097020] mtk-pinctrl 10211000.pinctrl: request pin 15 (I2C_SCL) for 1a140000.pcie
[    3.105008] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_clkreq
[    3.131749] mtk-msdc 11230000.mmc: phase: [map:1fffffff] [maxlen:29] [final:9]
[    3.140854] mtk-msdc 11230000.mmc: phase: [map:7ffffff] [maxlen:27] [final:9]
[    3.149011] mmc0: new HS200 MMC card at address 0001
[    3.213122] mtk-pcie 1a140000.pcie: Port0 link down
[    3.318206] mtk-pcie 1a140000.pcie: Port1 link down
[    3.323353] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
[    3.329735] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[    3.336732] pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
[    3.343827] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.349485] pci_bus 0000:00: scanning bus
[    3.354716] pci_bus 0000:00: fixups for bus
[    3.359031] pci_bus 0000:00: bus scan returning with max=00
[    3.364891] mtk_hsdma 1b007000.dma-controller: Using 3 as missing dma-requests property
[    3.373333] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[    3.381011] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/gsw@0[0]' - status (0)
[    3.390445] mtk-pinctrl 10211000.pinctrl: request pin 54 (MDI_RN_P0) for pinctrl_mt7622:463
[    3.968179] mt753x gsw@0: LAN/WAN VLAN setting=wllll
[    3.973770] mt753x gsw@0: Switch is MediaTek MT7531BE rev 0
[    6.648147] mt753x gsw@0: >>>>>>>>>>>>>>>>>>>>>>>>>>>>> START CALIBRATION:
[    6.657220] mt753x gsw@0: -------- gephy-calbration (port:0) --------
[    6.680342] CALDLY = 40
[    7.024521]  GE Rext AnaCal Saturation!
[    7.028746] GE Rxet cal something wrong2
[    7.317988]  GE R50 AnaCal Saturation!
[    7.322125]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    7.603459]  GE R50 AnaCal Saturation!
[    7.607587]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    7.888968]  GE R50 AnaCal Saturation!
[    7.893096]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    8.174361]  GE R50 AnaCal Saturation!
[    8.178497]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    8.188711]  GE 1e_174(0x8080), 1e_175(0x8080)
[    8.284349]  GE Tx offset AnaCal Done! (pair-0)(6)(0x25) 0x1e_172=0x2520
[    8.356246]  GE Tx offset AnaCal Done! (pair-1)(6)(0x25) 0x1e_172=0x2525
[    8.387505]  GE Tx offset AnaCal Done! (pair-2)(1)(0x1) 0x1e_173=0x120
[    8.442970]  GE Tx offset AnaCal Done! (pair-3)(4)(0x23) 0x1e_173=0x123
[    8.621823]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x380e)
[    8.695557]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1414)
[    8.785549]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x1119)
[    8.855347]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x141c)
[    8.950586] PORT 0 RX_DC_OFFSET
[    8.970838] before pairA output = 1d
[    8.977650] after pairA output = 0
[    8.984211] before pairB output = e
[    8.990936] after pairB output = 1
[    8.997488] before pairC output = d
[    9.004218] after pairC output = 0
[    9.010773] before pairD output = 1e
[    9.017588] after pairD output = fe
[    9.021646] mt753x gsw@0: -------- gephy-calbration (port:1) --------
[    9.044767] CALDLY = 40
[    9.324485]  GE R50 AnaCal Saturation!
[    9.328621]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    9.609981]  GE R50 AnaCal Saturation!
[    9.614109]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    9.895454]  GE R50 AnaCal Saturation!
[    9.899590]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   10.180914]  GE R50 AnaCal Saturation!
[   10.185043]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   10.195263]  GE 1e_174(0x8080), 1e_175(0x8080)
[   10.299009]  GE Tx offset AnaCal Done! (pair-0)(7)(0x26) 0x1e_172=0x2620
[   10.370910]  GE Tx offset AnaCal Done! (pair-1)(6)(0x25) 0x1e_172=0x2625
[   10.459055]  GE Tx offset AnaCal Done! (pair-2)(8)(0x27) 0x1e_173=0x2720
[   10.522774]  GE Tx offset AnaCal Done! (pair-3)(5)(0x24) 0x1e_173=0x2724
[   10.711857]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x380e)
[   10.775486]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1616)
[   10.835151]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x1921)
[   10.884724]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x161e)
[   10.979990] PORT 1 RX_DC_OFFSET
[   11.000237] before pairA output = e
[   11.006961] after pairA output = ff
[   11.013612] before pairB output = f
[   11.020335] after pairB output = 1
[   11.026888] before pairC output = 1e
[   11.033707] after pairC output = fe
[   11.040353] before pairD output = f
[   11.047075] after pairD output = ff
[   11.051133] mt753x gsw@0: -------- gephy-calbration (port:2) --------
[   11.074250] CALDLY = 40
[   11.353942]  GE R50 AnaCal Saturation!
[   11.358071]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   11.639346]  GE R50 AnaCal Saturation!
[   11.643474]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   11.924884]  GE R50 AnaCal Saturation!
[   11.929021]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   12.210342]  GE R50 AnaCal Saturation!
[   12.214472]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   12.224694]  GE 1e_174(0x8080), 1e_175(0x8080)
[   12.312189]  GE Tx offset AnaCal Done! (pair-0)(5)(0x24) 0x1e_172=0x2420
[   12.367816]  GE Tx offset AnaCal Done! (pair-1)(4)(0x23) 0x1e_172=0x2423
[   12.423441]  GE Tx offset AnaCal Done! (pair-2)(4)(0x23) 0x1e_173=0x2320
[   12.495336]  GE Tx offset AnaCal Done! (pair-3)(6)(0x25) 0x1e_173=0x2325
[   12.613603]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x5816)
[   12.677243]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1515)
[   12.726807]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x1921)
[   12.786476]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x151d)
[   12.881715] PORT 2 RX_DC_OFFSET
[   12.901960] before pairA output = f
[   12.908686] after pairA output = 0
[   12.915241] before pairB output = d
[   12.921973] after pairB output = ff
[   12.928622] before pairC output = f
[   12.935347] after pairC output = 0
[   12.941907] before pairD output = f
[   12.948633] after pairD output = 1
[   12.952595] mt753x gsw@0: -------- gephy-calbration (port:3) --------
[   12.975718] CALDLY = 40
[   13.255433]  GE R50 AnaCal Saturation!
[   13.259570]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   13.540913]  GE R50 AnaCal Saturation!
[   13.545042]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   13.826377]  GE R50 AnaCal Saturation!
[   13.830512]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   14.111944]  GE R50 AnaCal Saturation!
[   14.116072]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   14.126289]  GE 1e_174(0x8080), 1e_175(0x8080)
[   14.205667]  GE Tx offset AnaCal Done! (pair-0)(4)(0x23) 0x1e_172=0x2320
[   14.269435]  GE Tx offset AnaCal Done! (pair-1)(5)(0x24) 0x1e_172=0x2324
[   14.325075]  GE Tx offset AnaCal Done! (pair-2)(4)(0x23) 0x1e_173=0x2320
[   14.405129]  GE Tx offset AnaCal Done! (pair-3)(7)(0x26) 0x1e_173=0x2326
[   14.523402]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x5816)
[   14.637589]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1111)
[   14.727670]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x131b)
[   14.807612]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x141c)
[   14.902937] PORT 3 RX_DC_OFFSET
[   14.923207] before pairA output = e
[   14.929936] after pairA output = 0
[   14.936489] before pairB output = 1e
[   14.943312] after pairB output = 0
[   14.949868] before pairC output = e
[   14.956592] after pairC output = 0
[   14.963155] before pairD output = 1d
[   14.969971] after pairD output = fe
[   14.974022] mt753x gsw@0: -------- gephy-calbration (port:4) --------
[   14.997155] CALDLY = 40
[   15.276953]  GE R50 AnaCal Saturation!
[   15.281089]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   15.562464]  GE R50 AnaCal Saturation!
[   15.566593]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   15.847922]  GE R50 AnaCal Saturation!
[   15.852059]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   16.133409]  GE R50 AnaCal Saturation!
[   16.137537]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   16.147756]  GE 1e_174(0x8080), 1e_175(0x8080)
[   16.219005]  GE Tx offset AnaCal Done! (pair-0)(3)(0x22) 0x1e_172=0x2220
[   16.290876]  GE Tx offset AnaCal Done! (pair-1)(6)(0x25) 0x1e_172=0x2225
[   16.379003]  GE Tx offset AnaCal Done! (pair-2)(8)(0x27) 0x1e_173=0x2720
[   16.426509]  GE Tx offset AnaCal Done! (pair-3)(3)(0x22) 0x1e_173=0x2722
[   16.595347]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x4411)
[   16.770256]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0xa0a)
[   16.890541]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x1018)
[   17.000759]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x1119)
[   17.096005] PORT 4 RX_DC_OFFSET
[   17.116281] before pairA output = 1e
[   17.123103] after pairA output = 0
[   17.129664] before pairB output = f
[   17.136386] after pairB output = 1
[   17.142948] before pairC output = f
[   17.149681] after pairC output = 0
[   17.156236] before pairD output = 1e
[   17.163056] after pairD output = ff
[   17.170534] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.3
[   17.177288] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.2
[   17.184187] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[   17.189597] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[   17.198901] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000210010
[   17.208259] xhci-mtk 1a0c0000.usb: irq 127, io mem 0x1a0c0000
[   17.214669] hub 1-0:1.0: USB hub found
[   17.218560] hub 1-0:1.0: 2 ports detected
[   17.222902] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[   17.228299] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[   17.235928] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[   17.242436] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   17.251069] hub 2-0:1.0: USB hub found
[   17.254945] hub 2-0:1.0: 1 port detected
[   17.259618] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01 10:10:50 UTC (946721450)
[   17.269633] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[   17.277347] Please append a correct "root=" boot option; here are the available partitions:
[   17.285993] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[   17.294514] SMP: stopping secondary CPUs
[   17.298554] Kernel Offset: disabled
[   17.302145] CPU features: 0x0,20002000
[   17.306003] Memory Limit: none
[   17.309148] Rebooting in 1 seconds..
@Ivan_Revyakin can you post yours too?
@bourne_hlm, looks like your Kernel still doesn’t know about MTD and MMC. @frank-w, the log from my Kernel at the List 1 below.
List 1 (Kernel log)
Starting kernel ...
[    0.000000] Memory: 1020304K/1048384K available (6718K kernel code, 416K rwdata, 1792K rodata, 320K init, 309K bss, 28080K reserved, 0K cma-reserved)
[    0.000178] pid_max: default: 32768 minimum: 301
[    0.000254] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.000265] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.001082] ASID allocator initialised with 65536 entries
[    0.001134] rcu: Hierarchical SRCU implementation.
[    0.001487] smp: Bringing up secondary CPUs ...
[    0.001793] Detected VIPT I-cache on CPU1
[    0.001890] smp: Brought up 1 node, 2 CPUs
[    0.001966] CPU: All CPU(s) started at EL2
[    0.001976] alternatives: patching kernel code
[    0.002333] devtmpfs: initialized
[    0.005022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.005035] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.005117] pinctrl core: initialized pinctrl subsystem
[    0.005298] reg-dummy reg-dummy: no of_node; not parsing pinctrl DT
[    0.005684] NET: Registered protocol family 16
[    0.006176] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.006302] DMA: preallocated 256 KiB pool for atomic allocations
[    0.014960] mtk-pinctrl 10211000.pinctrl: try to register 103 pins ...
[    0.014973] pinctrl core: registered pin 0 (GPIO_A) on pinctrl_mt7622
[    0.014978] pinctrl core: registered pin 1 (I2S1_IN) on pinctrl_mt7622
[    0.014983] pinctrl core: registered pin 2 (I2S1_OUT) on pinctrl_mt7622
[    0.014987] pinctrl core: registered pin 3 (I2S_BCLK) on pinctrl_mt7622
[    0.014991] pinctrl core: registered pin 4 (I2S_WS) on pinctrl_mt7622
[    0.014995] pinctrl core: registered pin 5 (I2S_MCLK) on pinctrl_mt7622
[    0.014999] pinctrl core: registered pin 6 (TXD0) on pinctrl_mt7622
[    0.015003] pinctrl core: registered pin 7 (RXD0) on pinctrl_mt7622
[    0.015007] pinctrl core: registered pin 8 (SPI_WP) on pinctrl_mt7622
[    0.015011] pinctrl core: registered pin 9 (SPI_HOLD) on pinctrl_mt7622
[    0.015015] pinctrl core: registered pin 10 (SPI_CLK) on pinctrl_mt7622
[    0.015019] pinctrl core: registered pin 11 (SPI_MOSI) on pinctrl_mt7622
[    0.015023] pinctrl core: registered pin 12 (SPI_MISO) on pinctrl_mt7622
[    0.015027] pinctrl core: registered pin 13 (SPI_CS) on pinctrl_mt7622
[    0.015033] pinctrl core: registered pin 14 (I2C_SDA) on pinctrl_mt7622
[    0.015037] pinctrl core: registered pin 15 (I2C_SCL) on pinctrl_mt7622
[    0.015041] pinctrl core: registered pin 16 (I2S2_IN) on pinctrl_mt7622
[    0.015045] pinctrl core: registered pin 17 (I2S3_IN) on pinctrl_mt7622
[    0.015049] pinctrl core: registered pin 18 (I2S4_IN) on pinctrl_mt7622
[    0.015053] pinctrl core: registered pin 19 (I2S2_OUT) on pinctrl_mt7622
[    0.015057] pinctrl core: registered pin 20 (I2S3_OUT) on pinctrl_mt7622
[    0.015061] pinctrl core: registered pin 21 (I2S4_OUT) on pinctrl_mt7622
[    0.015065] pinctrl core: registered pin 22 (GPIO_B) on pinctrl_mt7622
[    0.015069] pinctrl core: registered pin 23 (MDC) on pinctrl_mt7622
[    0.015073] pinctrl core: registered pin 24 (MDIO) on pinctrl_mt7622
[    0.015077] pinctrl core: registered pin 25 (G2_TXD0) on pinctrl_mt7622
[    0.015080] pinctrl core: registered pin 26 (G2_TXD1) on pinctrl_mt7622
[    0.015084] pinctrl core: registered pin 27 (G2_TXD2) on pinctrl_mt7622
[    0.015088] pinctrl core: registered pin 28 (G2_TXD3) on pinctrl_mt7622
[    0.015092] pinctrl core: registered pin 29 (G2_TXEN) on pinctrl_mt7622
[    0.015096] pinctrl core: registered pin 30 (G2_TXC) on pinctrl_mt7622
[    0.015100] pinctrl core: registered pin 31 (G2_RXD0) on pinctrl_mt7622
[    0.015104] pinctrl core: registered pin 32 (G2_RXD1) on pinctrl_mt7622
[    0.015108] pinctrl core: registered pin 33 (G2_RXD2) on pinctrl_mt7622
[    0.015112] pinctrl core: registered pin 34 (G2_RXD3) on pinctrl_mt7622
[    0.015116] pinctrl core: registered pin 35 (G2_RXDV) on pinctrl_mt7622
[    0.015120] pinctrl core: registered pin 36 (G2_RXC) on pinctrl_mt7622
[    0.015123] pinctrl core: registered pin 37 (NCEB) on pinctrl_mt7622
[    0.015127] pinctrl core: registered pin 38 (NWEB) on pinctrl_mt7622
[    0.015131] pinctrl core: registered pin 39 (NREB) on pinctrl_mt7622
[    0.015135] pinctrl core: registered pin 40 (NDL4) on pinctrl_mt7622
[    0.015139] pinctrl core: registered pin 41 (NDL5) on pinctrl_mt7622
[    0.015143] pinctrl core: registered pin 42 (NDL6) on pinctrl_mt7622
[    0.015147] pinctrl core: registered pin 43 (NDL7) on pinctrl_mt7622
[    0.015151] pinctrl core: registered pin 44 (NRB) on pinctrl_mt7622
[    0.015154] pinctrl core: registered pin 45 (NCLE) on pinctrl_mt7622
[    0.015161] pinctrl core: registered pin 46 (NALE) on pinctrl_mt7622
[    0.015165] pinctrl core: registered pin 47 (NDL0) on pinctrl_mt7622
[    0.015168] pinctrl core: registered pin 48 (NDL1) on pinctrl_mt7622
[    0.015172] pinctrl core: registered pin 49 (NDL2) on pinctrl_mt7622
[    0.015176] pinctrl core: registered pin 50 (NDL3) on pinctrl_mt7622
[    0.015180] pinctrl core: registered pin 51 (MDI_TP_P0) on pinctrl_mt7622
[    0.015184] pinctrl core: registered pin 52 (MDI_TN_P0) on pinctrl_mt7622
[    0.015188] pinctrl core: registered pin 53 (MDI_RP_P0) on pinctrl_mt7622
[    0.015192] pinctrl core: registered pin 54 (MDI_RN_P0) on pinctrl_mt7622
[    0.015196] pinctrl core: registered pin 55 (MDI_TP_P1) on pinctrl_mt7622
[    0.015200] pinctrl core: registered pin 56 (MDI_TN_P1) on pinctrl_mt7622
[    0.015204] pinctrl core: registered pin 57 (MDI_RP_P1) on pinctrl_mt7622
[    0.015208] pinctrl core: registered pin 58 (MDI_RN_P1) on pinctrl_mt7622
[    0.015212] pinctrl core: registered pin 59 (MDI_RP_P2) on pinctrl_mt7622
[    0.015216] pinctrl core: registered pin 60 (MDI_RN_P2) on pinctrl_mt7622
[    0.015220] pinctrl core: registered pin 61 (MDI_TP_P2) on pinctrl_mt7622
[    0.015224] pinctrl core: registered pin 62 (MDI_TN_P2) on pinctrl_mt7622
[    0.015228] pinctrl core: registered pin 63 (MDI_TP_P3) on pinctrl_mt7622
[    0.015232] pinctrl core: registered pin 64 (MDI_TN_P3) on pinctrl_mt7622
[    0.015236] pinctrl core: registered pin 65 (MDI_RP_P3) on pinctrl_mt7622
[    0.015240] pinctrl core: registered pin 66 (MDI_RN_P3) on pinctrl_mt7622
[    0.015244] pinctrl core: registered pin 67 (MDI_RP_P4) on pinctrl_mt7622
[    0.015248] pinctrl core: registered pin 68 (MDI_RN_P4) on pinctrl_mt7622
[    0.015252] pinctrl core: registered pin 69 (MDI_TP_P4) on pinctrl_mt7622
[    0.015256] pinctrl core: registered pin 70 (MDI_TN_P4) on pinctrl_mt7622
[    0.015260] pinctrl core: registered pin 71 (PMIC_SCL) on pinctrl_mt7622
[    0.015264] pinctrl core: registered pin 72 (PMIC_SDA) on pinctrl_mt7622
[    0.015268] pinctrl core: registered pin 73 (SPIC1_CLK) on pinctrl_mt7622
[    0.015272] pinctrl core: registered pin 74 (SPIC1_MOSI) on pinctrl_mt7622
[    0.015276] pinctrl core: registered pin 75 (SPIC1_MISO) on pinctrl_mt7622
[    0.015280] pinctrl core: registered pin 76 (SPIC1_CS) on pinctrl_mt7622
[    0.015284] pinctrl core: registered pin 77 (GPIO_D) on pinctrl_mt7622
[    0.015289] pinctrl core: registered pin 78 (WATCHDOG) on pinctrl_mt7622
[    0.015293] pinctrl core: registered pin 79 (RTS3_N) on pinctrl_mt7622
[    0.015297] pinctrl core: registered pin 80 (CTS3_N) on pinctrl_mt7622
[    0.015302] pinctrl core: registered pin 81 (TXD3) on pinctrl_mt7622
[    0.015305] pinctrl core: registered pin 82 (RXD3) on pinctrl_mt7622
[    0.015309] pinctrl core: registered pin 83 (PERST0_N) on pinctrl_mt7622
[    0.015313] pinctrl core: registered pin 84 (PERST1_N) on pinctrl_mt7622
[    0.015317] pinctrl core: registered pin 85 (WLED_N) on pinctrl_mt7622
[    0.015321] pinctrl core: registered pin 86 (EPHY_LED0_N) on pinctrl_mt7622
[    0.015325] pinctrl core: registered pin 87 (AUXIN0) on pinctrl_mt7622
[    0.015329] pinctrl core: registered pin 88 (AUXIN1) on pinctrl_mt7622
[    0.015333] pinctrl core: registered pin 89 (AUXIN2) on pinctrl_mt7622
[    0.015337] pinctrl core: registered pin 90 (AUXIN3) on pinctrl_mt7622
[    0.015341] pinctrl core: registered pin 91 (TXD4) on pinctrl_mt7622
[    0.015345] pinctrl core: registered pin 92 (RXD4) on pinctrl_mt7622
[    0.015348] pinctrl core: registered pin 93 (RTS4_N) on pinctrl_mt7622
[    0.015352] pinctrl core: registered pin 94 (CTS4_N) on pinctrl_mt7622
[    0.015356] pinctrl core: registered pin 95 (PWM1) on pinctrl_mt7622
[    0.015360] pinctrl core: registered pin 96 (PWM2) on pinctrl_mt7622
[    0.015364] pinctrl core: registered pin 97 (PWM3) on pinctrl_mt7622
[    0.015368] pinctrl core: registered pin 98 (PWM4) on pinctrl_mt7622
[    0.015372] pinctrl core: registered pin 99 (PWM5) on pinctrl_mt7622
[    0.015376] pinctrl core: registered pin 100 (PWM6) on pinctrl_mt7622
[    0.015380] pinctrl core: registered pin 101 (PWM7) on pinctrl_mt7622
[    0.015384] pinctrl core: registered pin 102 (GPIO_E) on pinctrl_mt7622
[    0.015908] mtk-pinctrl 10211000.pinctrl: no hogs found
[    0.017376] gpiochip_find_base: found new base at 409
[    0.017396] gpio gpiochip0: (pinctrl_mt7622): created GPIO range 0->102 ==> 10211000.pinctrl PIN 0->102
[    0.017416] mtk-pinctrl 10211000.pinctrl: request pin 90 (AUXIN3) for pinctrl_mt7622:499
[    0.017427] gpio gpiochip0: Persistence not supported for GPIO 90
[    0.017437] GPIO line 499 (asm_sel) hogged as output/high
[    0.017572] gpio gpiochip0: (pinctrl_mt7622): added GPIO chardev (254:0)
[    0.017578] gpiochip_setup_dev: registered GPIOs 409 to 511 on device: gpiochip0 (pinctrl_mt7622)
[    0.026603] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-1p8v[0]'
[    0.026784] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-3p3v[0]'
[    0.026905] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-5v[0]'
[    0.027196] SCSI subsystem initialized
[    0.027319] libata version 3.00 loaded.
[    0.027455] usbcore: registered new interface driver usbfs
[    0.027486] usbcore: registered new interface driver hub
[    0.027523] usbcore: registered new device driver usb
[    0.028249] Bluetooth: Core ver 2.22
[    0.028281] NET: Registered protocol family 31
[    0.028285] Bluetooth: HCI device and connection manager initialized
[    0.028295] Bluetooth: HCI socket layer initialized
[    0.028301] Bluetooth: L2CAP socket layer initialized
[    0.028318] Bluetooth: SCO socket layer initialized
[    0.028654] clocksource: Switched to clocksource arch_sys_counter
[    0.029612] NET: Registered protocol family 2
[    0.030044] default registered
[    0.030051] default registered
[    0.030054] MPTCP: Stable release v0.95
[    0.030073] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes)
[    0.030093] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.030143] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[    0.030246] TCP: Hash tables configured (established 8192 bind 8192)
[    0.030339] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.030360] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.030458] NET: Registered protocol family 1
[    0.030478] PCI: CLS 0 bytes, default 64
[    0.031007] alarmtimer alarmtimer: no of_node; not parsing pinctrl DT
[    0.031215] No memory allocated for crashlog
[    0.031295] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.035536] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.035547] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.038338] io scheduler noop registered (default)
[    0.038769] mtk-tphy 1a0c4000.usb-phy: failed to get ref_clk(id-1)
[    0.039051] pinctrl core: add 1 pinctrl maps
[    0.039080] mtk-pinctrl 10211000.pinctrl: found group selector 70 for pwm_ch7_2
[    0.039090] mtk-pinctrl 10211000.pinctrl: request pin 101 (PWM7) for 11006000.pwm
[    0.039097] mtk-pinctrl 10211000.pinctrl: enable function pwm group pwm_ch7_2
[    0.039352] pinctrl core: add 3 pinctrl maps
[    0.039368] pinctrl core: add 3 pinctrl maps
[    0.039383] mtk-pinctrl 10211000.pinctrl: found group selector 44 for pcie0_pad_perst
[    0.039393] mtk-pinctrl 10211000.pinctrl: found group selector 40 for pcie0_1_waken
[    0.039403] mtk-pinctrl 10211000.pinctrl: found group selector 41 for pcie0_1_clkreq
[    0.039413] mtk-pinctrl 10211000.pinctrl: found group selector 45 for pcie1_pad_perst
[    0.039423] mtk-pinctrl 10211000.pinctrl: found group selector 42 for pcie1_0_waken
[    0.039433] mtk-pinctrl 10211000.pinctrl: found group selector 43 for pcie1_0_clkreq
[    0.039440] mtk-pinctrl 10211000.pinctrl: request pin 83 (PERST0_N) for 1a140000.pcie
[    0.039446] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_pad_perst
[    0.039453] mtk-pinctrl 10211000.pinctrl: request pin 79 (RTS3_N) for 1a140000.pcie
[    0.039458] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_waken
[    0.039465] mtk-pinctrl 10211000.pinctrl: request pin 80 (CTS3_N) for 1a140000.pcie
[    0.039470] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_clkreq
[    0.039477] mtk-pinctrl 10211000.pinctrl: request pin 84 (PERST1_N) for 1a140000.pcie
[    0.039482] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_pad_perst
[    0.039489] mtk-pinctrl 10211000.pinctrl: request pin 14 (I2C_SDA) for 1a140000.pcie
[    0.039494] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_waken
[    0.039500] mtk-pinctrl 10211000.pinctrl: request pin 15 (I2C_SCL) for 1a140000.pcie
[    0.039505] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_clkreq
[    0.041830] pinctrl core: add 1 pinctrl maps
[    0.041855] mtk-pinctrl 10211000.pinctrl: found group selector 47 for pmic_bus
[    0.041864] mtk-pinctrl 10211000.pinctrl: request pin 71 (PMIC_SCL) for 10001000.pwrap
[    0.041870] mtk-pinctrl 10211000.pinctrl: request pin 72 (PMIC_SDA) for 10001000.pwrap
[    0.041876] mtk-pinctrl 10211000.pinctrl: enable function pmic group pmic_bus
[    0.041991] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[    0.056067] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.058926] serial8250 serial8250: no of_node; not parsing pinctrl DT
[    0.059029] pinctrl core: add 1 pinctrl maps
[    0.059060] mtk-pinctrl 10211000.pinctrl: found group selector 89 for uart0_0_tx_rx
[    0.059070] mtk-pinctrl 10211000.pinctrl: request pin 6 (TXD0) for 11002000.serial
[    0.059077] mtk-pinctrl 10211000.pinctrl: request pin 7 (RXD0) for 11002000.serial
[    0.059083] mtk-pinctrl 10211000.pinctrl: enable function uart group uart0_0_tx_rx
[    0.059357] console [ttyS0] disabled
[    0.079743] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 1562500) is a ST16650V2
[    1.655436] console [ttyS0] enabled
[    1.659353] pinctrl core: add 1 pinctrl maps
[    1.663780] mtk-pinctrl 10211000.pinctrl: found group selector 96 for uart2_1_tx_rx
[    1.671687] mtk-pinctrl 10211000.pinctrl: request pin 51 (MDI_TP_P0) for 11004000.serial
[    1.680036] mtk-pinctrl 10211000.pinctrl: request pin 52 (MDI_TN_P0) for 11004000.serial
[    1.688377] mtk-pinctrl 10211000.pinctrl: enable function uart group uart2_1_tx_rx
[    1.716666] 11004000.serial: ttyS1 at MMIO 0x11004000 (irq = 117, base_baud = 1562500) is a ST16650V2
[    1.726720] 1100c000.serial: ttyS2 at MMIO 0x1100c000 (irq = 123, base_baud = 17499995) is a MediaTek BTIF
[    1.736778] serial serial0: tty port ttyS2 registered
[    1.742318] mtk_rng 1020f000.rng: registered RNG driver
[    1.742448] random: fast init done
[    1.751366] random: crng init done
[    1.755363] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.762418] pinctrl core: add 1 pinctrl maps
[    1.766846] mtk-pinctrl 10211000.pinctrl: found group selector 75 for spic0_0
[    1.774250] mtk-pinctrl 10211000.pinctrl: request pin 63 (MDI_TP_P3) for 1100a000.spi
[    1.782331] mtk-pinctrl 10211000.pinctrl: request pin 64 (MDI_TN_P3) for 1100a000.spi
[    1.790410] mtk-pinctrl 10211000.pinctrl: request pin 65 (MDI_RP_P3) for 1100a000.spi
[    1.798482] mtk-pinctrl 10211000.pinctrl: request pin 66 (MDI_RN_P3) for 1100a000.spi
[    1.806560] mtk-pinctrl 10211000.pinctrl: enable function spi group spic0_0
[    1.814063] pinctrl core: add 1 pinctrl maps
[    1.818478] mtk-pinctrl 10211000.pinctrl: found group selector 77 for spic1_0
[    1.825852] mtk-pinctrl 10211000.pinctrl: request pin 67 (MDI_RP_P4) for 11016000.spi
[    1.833933] mtk-pinctrl 10211000.pinctrl: request pin 68 (MDI_RN_P4) for 11016000.spi
[    1.842012] mtk-pinctrl 10211000.pinctrl: request pin 69 (MDI_TP_P4) for 11016000.spi
[    1.850090] mtk-pinctrl 10211000.pinctrl: request pin 70 (MDI_TN_P4) for 11016000.spi
[    1.858163] mtk-pinctrl 10211000.pinctrl: enable function spi group spic1_0
[    1.865870] mdio_bus fixed-0: GPIO lookup for consumer reset
[    1.871720] mdio_bus fixed-0: using lookup tables for GPIO lookup
[    1.878001] mdio_bus fixed-0: No GPIO consumer reset found
[    1.883666] libphy: Fixed MDIO Bus: probed
[    1.888315] sean debug physpeed = 2500
[    1.914892] mdio_bus mdio-bus: GPIO lookup for consumer reset
[    1.920823] mdio_bus mdio-bus: using device tree for GPIO lookup
[    1.927020] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mdio-bus[0]'
[    1.937613] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ethernet@1b100000/mdio-bus[0]'
[    1.948110] mdio_bus mdio-bus: using lookup tables for GPIO lookup
[    1.954486] mdio_bus mdio-bus: No GPIO consumer reset found
[    1.960234] libphy: mdio: probed
[    1.963573] mtk_soc_eth 1b100000.ethernet: generated random MAC address ae:8f:de:68:60:9c
[    1.972016] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mac@0/fixed-link[0]'
[    1.983325] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mac@0[0]'
[    1.993765] mtk_soc_eth 1b100000.ethernet: path gmac1_sgmii in set_mux_gdm1_to_gmac1_esw updated = 1
[    2.003192] mtk_soc_eth 1b100000.ethernet: mux mux_gmac2_gmac0_to_gephy isn't present on the SoC
[    2.012255] mtk_soc_eth 1b100000.ethernet: mux mux_u3_gmac2_to_qphy isn't present on the SoC
[    2.020961] mtk_soc_eth 1b100000.ethernet: path gmac1_sgmii in set_mux_gmac1_gmac2_to_sgmii_rgmii updated = 1
[    2.031189] mtk_soc_eth 1b100000.ethernet: mux mux_gmac12_to_gephy_sgmii isn't present on the SoC
[    2.040388] mtk_soc_eth 1b100000.ethernet: connected mac 0 to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[    2.051351] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffff8009540000, irq 131
[    2.060790] mtk_soc_eth 1b100000.ethernet: generated random MAC address 9a:87:80:92:18:78
[    2.069236] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mac@1/fixed-link[0]'
[    2.080537] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mac@1[0]'
[    2.090926] mtk_soc_eth 1b100000.ethernet: path gmac2_rgmii in set_mux_gdm1_to_gmac1_esw updated = 0
[    2.100352] mtk_soc_eth 1b100000.ethernet: mux mux_gmac2_gmac0_to_gephy isn't present on the SoC
[    2.109415] mtk_soc_eth 1b100000.ethernet: mux mux_u3_gmac2_to_qphy isn't present on the SoC
[    2.118116] mtk_soc_eth 1b100000.ethernet: path gmac2_rgmii in set_mux_gmac1_gmac2_to_sgmii_rgmii updated = 0
[    2.128344] mtk_soc_eth 1b100000.ethernet: mux mux_gmac12_to_gephy_sgmii isn't present on the SoC
[    2.137532] mtk_soc_eth 1b100000.ethernet: connected mac 1 to PHY at fixed-0:01 [uid=00000000, driver=Generic PHY]
[    2.148442] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffff8009540000, irq 131
[    2.157869] netif_napi_add() called with weight 256 on device
[    2.164188] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.3
[    2.170949] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.2
[    2.177867] xhci-mtk 1a0c0000.usb: Dropping the link to regulator.2
[    2.184392] xhci-mtk 1a0c0000.usb: Dropping the link to regulator.3
[    2.191165] rtc_mt7622 10212800.rtc: rtc core: registered 10212800.rtc as rtc0
[    2.198851] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[    2.208158] pinctrl core: add 1 pinctrl maps
[    2.212603] mtk-pinctrl 10211000.pinctrl: found group selector 109 for watchdog
[    2.220149] mtk-pinctrl 10211000.pinctrl: request pin 78 (WATCHDOG) for 10212000.watchdog
[    2.228580] mtk-pinctrl 10211000.pinctrl: enable function watchdog group watchdog
[    2.236320] MTK_WDT_NONRST_REG(20000000)
[    2.240367] RGU get IRQ ID failed
[    2.243921] Bluetooth: HCI UART driver ver 2.3
[    2.248500] Bluetooth: HCI UART protocol H4 registered
[    2.253805] Bluetooth: HCI UART protocol BCSP registered
[    2.259296] Bluetooth: HCI UART protocol ATH3K registered
[    2.264912] Bluetooth: HCI UART protocol Broadcom registered
[    2.270767] Bluetooth: HCI UART protocol QCA registered
[    2.276279] mtk-cpufreq mtk-cpufreq: no of_node; not parsing pinctrl DT
[    2.276745] bluetooth hci0: Direct firmware load for mediatek/mt7622pr2h.bin failed with error -2
[    2.283219] cpu cpu0: Linked as a consumer to regulator.4
[    2.292273] bluetooth hci0: Falling back to syfs fallback for: mediatek/mt7622pr2h.bin
[    2.297884] cpu cpu0: Linked as a consumer to regulator.7
[    2.312204] sdhci: Secure Digital Host Controller Interface driver
[    2.318574] sdhci: Copyright(c) Pierre Ossman
[    2.323157] generic pinconfig core: found bias-pull-up with value 1
[    2.329624] generic pinconfig core: found input-enable with value 1
[    2.336091] generic pinconfig core: found bias-pull-down with value 1
[    2.342739] pinctrl core: add 11 pinctrl maps
[    2.347240] generic pinconfig core: found bias-pull-up with value 1
[    2.353703] generic pinconfig core: found drive-strength with value 4
[    2.360344] generic pinconfig core: found input-enable with value 1
[    2.366810] generic pinconfig core: found bias-pull-down with value 1
[    2.373452] generic pinconfig core: found drive-strength with value 4
[    2.380098] pinctrl core: add 11 pinctrl maps
[    2.384598] mtk-pinctrl 10211000.pinctrl: found group selector 0 for emmc
[    2.391643] mtk-pinctrl 10211000.pinctrl: found group selector 0 for emmc
[    2.398685] mtk-pinctrl 10211000.pinctrl: request pin 40 (NDL4) for 11230000.mmc
[    2.406309] mtk-pinctrl 10211000.pinctrl: request pin 41 (NDL5) for 11230000.mmc
[    2.413938] mtk-pinctrl 10211000.pinctrl: request pin 42 (NDL6) for 11230000.mmc
[    2.421566] mtk-pinctrl 10211000.pinctrl: request pin 43 (NDL7) for 11230000.mmc
[    2.429195] mtk-pinctrl 10211000.pinctrl: request pin 44 (NRB) for 11230000.mmc
[    2.436728] mtk-pinctrl 10211000.pinctrl: request pin 45 (NCLE) for 11230000.mmc
[    2.444356] mtk-pinctrl 10211000.pinctrl: request pin 47 (NDL0) for 11230000.mmc
[    2.451985] mtk-pinctrl 10211000.pinctrl: request pin 48 (NDL1) for 11230000.mmc
[    2.459613] mtk-pinctrl 10211000.pinctrl: request pin 49 (NDL2) for 11230000.mmc
[    2.467238] mtk-pinctrl 10211000.pinctrl: request pin 50 (NDL3) for 11230000.mmc
[    2.474866] mtk-pinctrl 10211000.pinctrl: enable function emmc group emmc
[    2.481986] mtk-msdc 11230000.mmc: GPIO lookup for consumer wp
[    2.487997] mtk-msdc 11230000.mmc: using device tree for GPIO lookup
[    2.494560] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@11230000[0]'
[    2.503627] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@11230000[0]'
[    2.512600] mtk-msdc 11230000.mmc: using lookup tables for GPIO lookup
[    2.519332] mtk-msdc 11230000.mmc: No GPIO consumer wp found
[    2.525254] mtk-msdc 11230000.mmc: Linked as a consumer to regulator.2
[    2.532012] mtk-msdc 11230000.mmc: Linked as a consumer to regulator.1
[    2.538773] mtk-msdc 11230000.mmc: obtain a copy of previously claimed pinctrl
[    2.546472] mtk-pinctrl 10211000.pinctrl: request pin 40 (NDL4) for 11230000.mmc
[    2.554104] mtk-pinctrl 10211000.pinctrl: request pin 41 (NDL5) for 11230000.mmc
[    2.561733] mtk-pinctrl 10211000.pinctrl: request pin 42 (NDL6) for 11230000.mmc
[    2.569360] mtk-pinctrl 10211000.pinctrl: request pin 43 (NDL7) for 11230000.mmc
[    2.576984] mtk-pinctrl 10211000.pinctrl: request pin 44 (NRB) for 11230000.mmc
[    2.584522] mtk-pinctrl 10211000.pinctrl: request pin 45 (NCLE) for 11230000.mmc
[    2.592150] mtk-pinctrl 10211000.pinctrl: request pin 47 (NDL0) for 11230000.mmc
[    2.599778] mtk-pinctrl 10211000.pinctrl: request pin 48 (NDL1) for 11230000.mmc
[    2.607402] mtk-pinctrl 10211000.pinctrl: request pin 49 (NDL2) for 11230000.mmc
[    2.615030] mtk-pinctrl 10211000.pinctrl: request pin 50 (NDL3) for 11230000.mmc
[    2.622659] mtk-pinctrl 10211000.pinctrl: enable function emmc group emmc
[    2.654914] generic pinconfig core: found bias-pull-up with value 1
[    2.661385] generic pinconfig core: found drive-strength with value 8
[    2.668022] generic pinconfig core: found input-enable with value 1
[    2.674499] generic pinconfig core: found bias-pull-down with value 1
[    2.681142] generic pinconfig core: found drive-strength with value 12
[    2.687875] generic pinconfig core: found bias-pull-up with value 1
[    2.694343] pinctrl core: add 8 pinctrl maps
[    2.698760] generic pinconfig core: found bias-pull-up with value 1
[    2.705220] generic pinconfig core: found input-enable with value 1
[    2.711692] generic pinconfig core: found bias-pull-down with value 1
[    2.718332] pinctrl core: add 7 pinctrl maps
[    2.722756] mtk-pinctrl 10211000.pinctrl: found group selector 71 for sd_0
[    2.729880] mtk-pinctrl 10211000.pinctrl: found group selector 71 for sd_0
[    2.736979] mtk-pinctrl 10211000.pinctrl: request pin 16 (I2S2_IN) for 11240000.mmc
[    2.744878] mtk-pinctrl 10211000.pinctrl: request pin 17 (I2S3_IN) for 11240000.mmc
[    2.752775] mtk-pinctrl 10211000.pinctrl: request pin 18 (I2S4_IN) for 11240000.mmc
[    2.760673] mtk-pinctrl 10211000.pinctrl: request pin 19 (I2S2_OUT) for 11240000.mmc
[    2.768660] mtk-pinctrl 10211000.pinctrl: request pin 20 (I2S3_OUT) for 11240000.mmc
[    2.776643] mtk-pinctrl 10211000.pinctrl: request pin 21 (I2S4_OUT) for 11240000.mmc
[    2.784634] mtk-pinctrl 10211000.pinctrl: enable function sd group sd_0
[    2.791576] mtk-msdc 11240000.mmc: GPIO lookup for consumer cd
[    2.797586] mtk-msdc 11240000.mmc: using device tree for GPIO lookup
[    2.804155] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/mmc@11240000[0]' - status (0)
[    2.813941] mtk-pinctrl 10211000.pinctrl: request pin 81 (TXD3) for pinctrl_mt7622:490
[    2.822113] gpio gpiochip0: Persistence not supported for GPIO 81
[    2.828396] mtk-msdc 11240000.mmc: Got CD GPIO
[    2.832980] mtk-msdc 11240000.mmc: GPIO lookup for consumer wp
[    2.838995] mtk-msdc 11240000.mmc: using device tree for GPIO lookup
[    2.845548] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@11240000[0]'
[    2.854614] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@11240000[0]'
[    2.863588] mtk-msdc 11240000.mmc: using lookup tables for GPIO lookup
[    2.870321] mtk-msdc 11240000.mmc: No GPIO consumer wp found
[    2.876229] mtk-msdc 11240000.mmc: Linked as a consumer to regulator.2
[    2.883012] mtk-msdc 11240000.mmc: obtain a copy of previously claimed pinctrl
[    2.914787] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.922509] NET: Registered protocol family 10
[    2.927630] Segment Routing with IPv6
[    2.931475] fullmesh registered
[    2.934708] ndiffports registered
[    2.938138] binder registered
[    2.941217] netlink registered
[    2.944360] roundrobin registered
[    2.947770] redundant registered
[    2.951096] blest registered
[    2.954060] NET: Registered protocol family 17
[    2.958663] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.972092] 8021q: 802.1Q VLAN Support v1.8
[    2.985168] pinctrl core: add 3 pinctrl maps
[    2.989652] pinctrl core: add 3 pinctrl maps
[    2.994076] mtk-pinctrl 10211000.pinctrl: found group selector 44 for pcie0_pad_perst
[    3.002161] mtk-pinctrl 10211000.pinctrl: found group selector 40 for pcie0_1_waken
[    3.010065] mtk-pinctrl 10211000.pinctrl: found group selector 41 for pcie0_1_clkreq
[    3.018052] mtk-pinctrl 10211000.pinctrl: found group selector 45 for pcie1_pad_perst
[    3.026134] mtk-pinctrl 10211000.pinctrl: found group selector 42 for pcie1_0_waken
[    3.034037] mtk-pinctrl 10211000.pinctrl: found group selector 43 for pcie1_0_clkreq
[    3.042028] mtk-pinctrl 10211000.pinctrl: request pin 83 (PERST0_N) for 1a140000.pcie
[    3.050116] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_pad_perst
[    3.058102] mtk-pinctrl 10211000.pinctrl: request pin 79 (RTS3_N) for 1a140000.pcie
[    3.066000] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_waken
[    3.073810] mtk-pinctrl 10211000.pinctrl: request pin 80 (CTS3_N) for 1a140000.pcie
[    3.081707] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie0_1_clkreq
[    3.089605] mtk-pinctrl 10211000.pinctrl: request pin 84 (PERST1_N) for 1a140000.pcie
[    3.097677] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_pad_perst
[    3.105666] mtk-pinctrl 10211000.pinctrl: request pin 14 (I2C_SDA) for 1a140000.pcie
[    3.113654] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_waken
[    3.121463] mtk-pinctrl 10211000.pinctrl: request pin 15 (I2C_SCL) for 1a140000.pcie
[    3.129453] mtk-pinctrl 10211000.pinctrl: enable function pcie group pcie1_0_clkreq
[    3.144630] mtk-msdc 11230000.mmc: phase: [map:ffffffff] [maxlen:32] [final:10]
[    3.153827] mtk-msdc 11230000.mmc: phase: [map:1fffffff] [maxlen:29] [final:9]
[    3.162069] mmc0: new HS200 MMC card at address 0001
[    3.167299] mmcblk mmc0:0001: no of_node; not parsing pinctrl DT
[    3.174505] mmcblk0: mmc0:0001 008G30 7.28 GiB
[    3.180061] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
[    3.187027] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
[    3.193276] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB, chardev (250:0)
[    3.203089] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    3.210725] GPT:1 != 15269887
[    3.213777] GPT:Alternate GPT header not at the end of the disk.
[    3.219975] GPT:1 != 15269887
[    3.223028] GPT: Use GNU Parted to correct GPT errors.
[    3.228341]  mmcblk0: p1 p2 p3 p4 p5
[    3.237579] mtk-pcie 1a140000.pcie: Port0 link down
[    3.342684] mtk-pcie 1a140000.pcie: Port1 link down
[    3.347849] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
[    3.354232] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[    3.361235] pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
[    3.368325] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.373984] pci_bus 0000:00: scanning bus
[    3.379224] pci_bus 0000:00: fixups for bus
[    3.383533] pci_bus 0000:00: bus scan returning with max=00
[    3.389435] mtk_hsdma 1b007000.dma-controller: Using 3 as missing dma-requests property
[    3.397863] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[    3.405548] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/gsw@0[0]' - status (0)
[    3.414981] mtk-pinctrl 10211000.pinctrl: request pin 54 (MDI_RN_P0) for pinctrl_mt7622:463
[    3.988657] mt753x gsw@0: LAN/WAN VLAN setting=wllll
[    3.994251] mt753x gsw@0: Switch is MediaTek MT7531BE rev 0
[    6.694478] mt753x gsw@0: >>>>>>>>>>>>>>>>>>>>>>>>>>>>> START CALIBRATION:
[    6.703580] mt753x gsw@0: -------- gephy-calbration (port:0) --------
[    6.726895] CALDLY = 40
[    7.074652]  GE Rext AnaCal Saturation!
[    7.078877] GE Rxet cal something wrong2
[    7.371105]  GE R50 AnaCal Saturation!
[    7.375234]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    7.658963]  GE R50 AnaCal Saturation!
[    7.663092]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    7.947226]  GE R50 AnaCal Saturation!
[    7.951364]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    8.235558]  GE R50 AnaCal Saturation!
[    8.239696]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    8.249966]  GE 1e_174(0x8080), 1e_175(0x8080)
[    8.321914]  GE Tx offset AnaCal Done! (pair-0)(3)(0x22) 0x1e_172=0x2220
[    8.378126]  GE Tx offset AnaCal Done! (pair-1)(4)(0x23) 0x1e_172=0x2223
[    8.426083]  GE Tx offset AnaCal Done! (pair-2)(3)(0x22) 0x1e_173=0x2220
[    8.482259]  GE Tx offset AnaCal Done! (pair-3)(4)(0x23) 0x1e_173=0x2223
[    8.591501]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x5415)
[    8.675763]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1313)
[    8.766667]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x1b23)
[    8.878011]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x1018)
[    8.974259] PORT 0 RX_DC_OFFSET
[    8.994698] before pairA output = 1d
[    9.001545] after pairA output = ff
[    9.008224] before pairB output = 1e
[    9.015081] after pairB output = 0
[    9.021679] before pairC output = f
[    9.028437] after pairC output = 0
[    9.035032] before pairD output = f
[    9.041796] after pairD output = 1
[    9.045763] mt753x gsw@0: -------- gephy-calbration (port:1) --------
[    9.069079] CALDLY = 40
[    9.351832]  GE R50 AnaCal Saturation!
[    9.355961]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    9.639719]  GE R50 AnaCal Saturation!
[    9.643847]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[    9.927532]  GE R50 AnaCal Saturation!
[    9.931668]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   10.215898]  GE R50 AnaCal Saturation!
[   10.220035]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   10.230302]  GE 1e_174(0x8080), 1e_175(0x8080)
[   10.335142]  GE Tx offset AnaCal Done! (pair-0)(7)(0x26) 0x1e_172=0x2620
[   10.366684]  GE Tx offset AnaCal Done! (pair-1)(1)(0x1) 0x1e_172=0x2601
[   10.398138]  GE Tx offset AnaCal Done! (pair-2)(1)(0x1) 0x1e_173=0x120
[   10.429476]  GE Tx offset AnaCal Done! (pair-3)(1)(0x1) 0x1e_173=0x101
[   10.589557]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x4411)
[   10.684428]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1313)
[   10.764629]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x1b23)
[   10.824875]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x1921)
[   10.921073] PORT 1 RX_DC_OFFSET
[   10.941503] before pairA output = f
[   10.948259] after pairA output = 1
[   10.954853] before pairB output = f
[   10.961612] after pairB output = 1
[   10.968198] before pairC output = 1e
[   10.975052] after pairC output = ff
[   10.981734] before pairD output = 1e
[   10.988579] after pairD output = 0
[   10.992554] mt753x gsw@0: -------- gephy-calbration (port:2) --------
[   11.015858] CALDLY = 40
[   11.298445]  GE R50 AnaCal Saturation!
[   11.302582]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   11.586793]  GE R50 AnaCal Saturation!
[   11.590929]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   11.874674]  GE R50 AnaCal Saturation!
[   11.878811]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   12.162951]  GE R50 AnaCal Saturation!
[   12.167080]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   12.177352]  GE 1e_174(0x8080), 1e_175(0x8080)
[   12.249295]  GE Tx offset AnaCal Done! (pair-0)(3)(0x22) 0x1e_172=0x2220
[   12.313657]  GE Tx offset AnaCal Done! (pair-1)(5)(0x24) 0x1e_172=0x2224
[   12.353387]  GE Tx offset AnaCal Done! (pair-2)(2)(0x2) 0x1e_173=0x220
[   12.384717]  GE Tx offset AnaCal Done! (pair-3)(1)(0x1) 0x1e_173=0x201
[   12.503988]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x681a)
[   12.629513]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1f1f)
[   12.699956]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x151d)
[   12.831263]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x2028)
[   12.927462] PORT 2 RX_DC_OFFSET
[   12.947908] before pairA output = 1e
[   12.954763] after pairA output = ff
[   12.961440] before pairB output = e
[   12.968196] after pairB output = 1
[   12.974789] before pairC output = 1e
[   12.981636] after pairC output = 0
[   12.988221] before pairD output = f
[   12.994987] after pairD output = 0
[   12.998955] mt753x gsw@0: -------- gephy-calbration (port:3) --------
[   13.022254] CALDLY = 40
[   13.304837]  GE R50 AnaCal Saturation!
[   13.308974]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   13.593215]  GE R50 AnaCal Saturation!
[   13.597344]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   13.881213]  GE R50 AnaCal Saturation!
[   13.885343]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   14.169616]  GE R50 AnaCal Saturation!
[   14.173745]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   14.184020]  GE 1e_174(0x8080), 1e_175(0x8080)
[   14.247761]  GE Tx offset AnaCal Done! (pair-0)(2)(0x2) 0x1e_172=0x220
[   14.287326]  GE Tx offset AnaCal Done! (pair-1)(2)(0x21) 0x1e_172=0x221
[   14.335187]  GE Tx offset AnaCal Done! (pair-2)(3)(0x22) 0x1e_173=0x2220
[   14.366711]  GE Tx offset AnaCal Done! (pair-3)(1)(0x1) 0x1e_173=0x2201
[   14.557615]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x3c0f)
[   14.662761]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0x1212)
[   14.722990]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0x161e)
[   14.824206]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0x1e26)
[   14.919942] PORT 3 RX_DC_OFFSET
[   14.940381] before pairA output = d
[   14.947138] after pairA output = 1
[   14.953733] before pairB output = f
[   14.960466] after pairB output = ff
[   14.967141] before pairC output = f
[   14.973906] after pairC output = 0
[   14.980496] before pairD output = 1e
[   14.987342] after pairD output = ff
[   14.991405] mt753x gsw@0: -------- gephy-calbration (port:4) --------
[   15.014704] CALDLY = 40
[   15.297462]  GE R50 AnaCal Saturation!
[   15.301599]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   15.585865]  GE R50 AnaCal Saturation!
[   15.590001]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   15.874205]  GE R50 AnaCal Saturation!
[   15.878334]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   16.162135]  GE R50 AnaCal Saturation!
[   16.166263]  GE R50 AnaCal Done! (32) (0x0)(0x80)
[   16.176546]  GE 1e_174(0x8080), 1e_175(0x8080)
[   16.256742]  GE Tx offset AnaCal Done! (pair-0)(4)(0x4) 0x1e_172=0x420
[   16.312716]  GE Tx offset AnaCal Done! (pair-1)(4)(0x23) 0x1e_172=0x423
[   16.360588]  GE Tx offset AnaCal Done! (pair-2)(3)(0x22) 0x1e_173=0x2220
[   16.408527]  GE Tx offset AnaCal Done! (pair-3)(3)(0x22) 0x1e_173=0x2222
[   16.548580]  GE Tx amp AnaCal Done! (pair-0)(1e_12 = 0x5014)
[   16.674174]  GE Tx amp AnaCal Done! (pair-1)(1e_17 = 0xf0f)
[   16.846740]  GE Tx amp AnaCal Done! (pair-2)(1e_19 = 0xb13)
[   16.977939]  GE Tx amp AnaCal Done! (pair-3)(1e_21 = 0xf17)
[   17.074056] PORT 4 RX_DC_OFFSET
[   17.094485] before pairA output = e
[   17.101244] after pairA output = 1
[   17.107833] before pairB output = 1e
[   17.114687] after pairB output = ff
[   17.121340] before pairC output = 1e
[   17.128185] after pairC output = ff
[   17.134868] before pairD output = f
[   17.141626] after pairD output = 1
[   17.149067] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.3
[   17.155823] xhci-mtk 1a0c0000.usb: Linked as a consumer to regulator.2
[   17.162723] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[   17.168124] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[   17.176591] mt753x gsw@0: Port 0 Link is Up - 100Mbps/Full
[   17.182346] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000210010
[   17.191707] xhci-mtk 1a0c0000.usb: irq 127, io mem 0x1a0c0000
[   17.198142] hub 1-0:1.0: USB hub found
[   17.202031] hub 1-0:1.0: 2 ports detected
[   17.206375] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[   17.211774] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[   17.219410] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[   17.225909] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   17.234536] hub 2-0:1.0: USB hub found
[   17.238411] hub 2-0:1.0: 1 port detected
[   17.242830] 6 cmdlinepart partitions found on MTD device eMMC
[   17.248763] Creating 6 MTD partitions on "eMMC":
[   17.253523] 0x000000000000-0x0000000c0000 : "mbr"
[   17.258801] 0x0000000c0000-0x000000140000 : "uboot"
[   17.264203] 0x000000140000-0x0000001c0000 : "Config"
[   17.269700] 0x0000001c0000-0x000000200000 : "Factory"
[   17.275263] 0x000000200000-0x000004200000 : "Kernel"
[   17.281868] 2 fit-fw partitions found on MTD device Kernel
[   17.287524] 0x000000200000-0x000000520000 : "kernel"
[   17.293036] 0x000000519c84-0x000004200000 : "rootfs"
[   17.298488] mtd: device 6 (rootfs) set to be root filesystem
[   17.304375] 1 squashfs-split partitions found on MTD device rootfs
[   17.310753] 0x000002520000-0x000004200000 : "rootfs_data"
[   17.316668] 0x000004200000-0x000084200000 : "usrdata"
[   17.322247] block2mtd: mtd0: [eMMC] erase_size = 64KiB [65536]
[   17.328448] rtc_mt7622 10212800.rtc: setting system clock to 2000-01-01 05:00:04 UTC (946702804)
[   17.341157] VFS: Mounted root (squashfs filesystem) readonly on device 31:6.
[   17.350108] devtmpfs: mounted
[   17.353310] Freeing unused kernel memory: 320K
[   17.388670] Run /sbin/init as init process
[   17.559865] init: Console is alive
[   18.547997] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[   18.581021] pps_core: LinuxPPS API ver. 1 registered
[   18.586143] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[   18.597571] PTP clock support registered
[   18.606380] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/factory[0]' - status (0)
[   18.616391] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/wps[0]' - status (0)
[   18.626010] mtk-pinctrl 10211000.pinctrl: request pin 0 (GPIO_A) for pinctrl_mt7622:409
[   18.634284] mtk-pinctrl 10211000.pinctrl: request pin 102 (GPIO_E) for pinctrl_mt7622:511
[   18.644143] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   18.651747] ehci-platform: EHCI generic platform driver
[   18.658885] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   18.665886] ohci-platform: OHCI generic platform driver
[   18.672707] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/green[0]' - status (0)
[   18.682063] mtk-pinctrl 10211000.pinctrl: request pin 89 (AUXIN2) for pinctrl_mt7622:498
[   18.690418] gpio gpiochip0: Persistence not supported for GPIO 89
[   18.696696] no flags found for gpios
[   18.700462] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/red[0]' - status (0)
[   18.709619] mtk-pinctrl 10211000.pinctrl: request pin 88 (AUXIN1) for pinctrl_mt7622:497
[   18.717962] gpio gpiochip0: Persistence not supported for GPIO 88
[   18.724246] no flags found for gpios
[   18.729527] usbcore: registered new interface driver usb-storage
[   18.735948] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[   18.747849] init: - preinit -
[   22.098746] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
mount: mounting /dev/mmcblk0p1 on /recovery failed: Resource bus[   22.147013] urandom-seed: Seed file not found (/etc/urandom.seed)
y
umount: can't unmount /recovery: Invalid argument
[   22.240834] jffs2reset: /dev/mtdblock7 is not mounted
[   22.246091] jffs2reset: /dev/mtdblock7 will be erased on next mount
[   22.256879] procd: - early -
Failed to connect to ubus
[   22.915776] procd: - ubus -
[   23.000891] procd: - init -
@bourne_hlm, the List 2 below contains all of my Kernel configuration. Maybe I missed something necessary in the previous output. BTW how to get only changes of .config from init state (from default)?
List 2 (part 1) (Kernel .config)
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=70400
CONFIG_CLANG_VERSION=0
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
CONFIG_THREAD_INFO_IN_TASK=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_LOCALVERSION=""
CONFIG_BUILD_SALT=""
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_GENERIC_MSI_IRQ=y
CONFIG_GENERIC_MSI_IRQ_DOMAIN=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
CONFIG_NO_HZ_IDLE=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_PREEMPT_NONE=y
CONFIG_TICK_CPU_ACCOUNTING=y
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_SCHED_AVG_IRQ=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TREE_RCU=y
CONFIG_RCU_EXPERT=y
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
CONFIG_RCU_FANOUT=32
CONFIG_RCU_FANOUT_LEAF=16
CONFIG_BUILD_BIN2C=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
CONFIG_ARCH_SUPPORTS_NUMA_BALANCING=y
CONFIG_ARCH_SUPPORTS_INT128=y
CONFIG_CGROUPS=y
CONFIG_PAGE_COUNTER=y
CONFIG_MEMCG=y
CONFIG_MEMCG_KMEM=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_RT_GROUP_SCHED=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_SOCK_CGROUP_DATA=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
CONFIG_CRASHLOG=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE="/home/revyakin.data/Downloads/OPENWRT/openmptcprouter/bpi-r64/source/build_dir/target-aarch64_cortex-a53_musl/root-mediatek /home/revyakin.data/Downloads/OPENWRT/openmptcprouter/bpi-r64/source/target/linux/generic/image/initramfs-base-files.txt"
CONFIG_INITRAMFS_ROOT_UID=1000
CONFIG_INITRAMFS_ROOT_GID=1000
CONFIG_INITRAMFS_COMPRESSION_NONE=y
CONFIG_INITRAMFS_COMPRESSION=""
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_HAVE_UID16=y
CONFIG_SYSCTL_EXCEPTION_TRACE=y
CONFIG_KALLSYMS_UNCOMPRESSED=y
CONFIG_BPF=y
CONFIG_EXPERT=y
CONFIG_UID16=y
CONFIG_MULTIUSER=y
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_BASE_RELATIVE=y
CONFIG_BPF_SYSCALL=y
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_EMBEDDED=y
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_SLUB=y
CONFIG_SLAB_MERGE_DEFAULT=y
CONFIG_SLUB_CPU_PARTIAL=y
CONFIG_ARM64=y
CONFIG_64BIT=y
CONFIG_MMU=y
CONFIG_ARM64_PAGE_SHIFT=12
CONFIG_ARM64_CONT_SHIFT=4
CONFIG_ARCH_MMAP_RND_BITS_MIN=18
CONFIG_ARCH_MMAP_RND_BITS_MAX=24
CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MIN=11
CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MAX=16
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_ILLEGAL_POINTER_VALUE=0xdead000000000000
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_GENERIC_BUG=y
CONFIG_GENERIC_BUG_RELATIVE_POINTERS=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CSUM=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ZONE_DMA32=y
CONFIG_HAVE_GENERIC_GUP=y
CONFIG_SMP=y
CONFIG_KERNEL_MODE_NEON=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_PGTABLE_LEVELS=3
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_ARCH_PROC_KCORE_TEXT=y
CONFIG_ARCH_MEDIATEK=y
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
CONFIG_PCI_DOMAINS_GENERIC=y
CONFIG_PCI_SYSCALL=y
CONFIG_PCI_MSI=y
CONFIG_PCI_MSI_IRQ_DOMAIN=y
CONFIG_PCI_QUIRKS=y
CONFIG_PCI_DEBUG=y
CONFIG_PCIE_MEDIATEK=y
CONFIG_ARM64_4K_PAGES=y
CONFIG_ARM64_VA_BITS_39=y
CONFIG_ARM64_VA_BITS=39
CONFIG_ARM64_PA_BITS_48=y
CONFIG_ARM64_PA_BITS=48
CONFIG_SCHED_MC=y
CONFIG_NR_CPUS=2
CONFIG_HOLES_IN_ZONE=y
CONFIG_HZ_100=y
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y
CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_DEFAULT=y
CONFIG_ARCH_SELECT_MEMORY_MODEL=y
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_SYS_SUPPORTS_HUGETLBFS=y
CONFIG_ARCH_WANT_HUGE_PMD_SHARE=y
CONFIG_ARCH_HAS_CACHE_LINE_SIZE=y
CONFIG_SECCOMP=y
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_HARDEN_BRANCH_PREDICTOR=y
CONFIG_HARDEN_EL2_VECTORS=y
CONFIG_ARM64_SSBD=y
CONFIG_ARM64_HW_AFDBM=y
CONFIG_ARM64_PAN=y
CONFIG_ARM64_VHE=y
CONFIG_ARM64_UAO=y
CONFIG_ARM64_SVE=y
CONFIG_CMDLINE=""
CONFIG_COMPAT=y
CONFIG_SYSVIPC_COMPAT=y
CONFIG_PM=y
CONFIG_PM_CLK=y
CONFIG_PM_GENERIC_DOMAINS=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
CONFIG_PM_GENERIC_DOMAINS_OF=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_ARM_MEDIATEK_CPUFREQ=y
CONFIG_ARM_PSCI_FW=y
CONFIG_HAVE_ARM_SMCCC=y
CONFIG_JUMP_LABEL=y
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_HAVE_RCU_TABLE_FREE=y
CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y
CONFIG_HAVE_ALIGNED_STRUCT_PAGE=y
CONFIG_HAVE_CMPXCHG_LOCAL=y
CONFIG_HAVE_CMPXCHG_DOUBLE=y
CONFIG_ARCH_WANT_COMPAT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP_FILTER=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_STACKPROTECTOR=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_ARCH_TRANSPARENT_HUGEPAGE=y
CONFIG_HAVE_ARCH_HUGE_VMAP=y
CONFIG_MODULES_USE_ELF_RELA=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_ARCH_MMAP_RND_BITS=18
CONFIG_HAVE_ARCH_MMAP_RND_COMPAT_BITS=y
CONFIG_ARCH_MMAP_RND_COMPAT_BITS=11
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_COMPAT_OLD_SIGACTION=y
CONFIG_COMPAT_32BIT_TIME=y
CONFIG_HAVE_ARCH_VMAP_STACK=y
CONFIG_VMAP_STACK=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_REFCOUNT_FULL=y
CONFIG_HAVE_ARCH_PREL32_RELOCATIONS=y
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
CONFIG_PLUGIN_HOSTCC=""
CONFIG_HAVE_GCC_PLUGINS=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_STRIPPED=y
CONFIG_BLOCK=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_PARTITION_ADVANCED=y
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
CONFIG_BLOCK_COMPAT=y
CONFIG_BLK_MQ_PCI=y
CONFIG_IOSCHED_NOOP=y
CONFIG_DEFAULT_NOOP=y
CONFIG_DEFAULT_IOSCHED="noop"
CONFIG_PADATA=y
CONFIG_ASN1=m
CONFIG_ARCH_INLINE_SPIN_TRYLOCK=y
CONFIG_ARCH_INLINE_SPIN_TRYLOCK_BH=y
CONFIG_ARCH_INLINE_SPIN_LOCK=y
CONFIG_ARCH_INLINE_SPIN_LOCK_BH=y
CONFIG_ARCH_INLINE_SPIN_LOCK_IRQ=y
CONFIG_ARCH_INLINE_SPIN_LOCK_IRQSAVE=y
CONFIG_ARCH_INLINE_SPIN_UNLOCK=y
CONFIG_ARCH_INLINE_SPIN_UNLOCK_BH=y
CONFIG_ARCH_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_ARCH_INLINE_SPIN_UNLOCK_IRQRESTORE=y
CONFIG_ARCH_INLINE_READ_LOCK=y
CONFIG_ARCH_INLINE_READ_LOCK_BH=y
CONFIG_ARCH_INLINE_READ_LOCK_IRQ=y
CONFIG_ARCH_INLINE_READ_LOCK_IRQSAVE=y
CONFIG_ARCH_INLINE_READ_UNLOCK=y
CONFIG_ARCH_INLINE_READ_UNLOCK_BH=y
CONFIG_ARCH_INLINE_READ_UNLOCK_IRQ=y
CONFIG_ARCH_INLINE_READ_UNLOCK_IRQRESTORE=y
CONFIG_ARCH_INLINE_WRITE_LOCK=y
CONFIG_ARCH_INLINE_WRITE_LOCK_BH=y
CONFIG_ARCH_INLINE_WRITE_LOCK_IRQ=y
CONFIG_ARCH_INLINE_WRITE_LOCK_IRQSAVE=y
CONFIG_ARCH_INLINE_WRITE_UNLOCK=y
CONFIG_ARCH_INLINE_WRITE_UNLOCK_BH=y
CONFIG_ARCH_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_INLINE_WRITE_UNLOCK_IRQRESTORE=y
CONFIG_INLINE_SPIN_TRYLOCK=y
CONFIG_INLINE_SPIN_TRYLOCK_BH=y
CONFIG_INLINE_SPIN_LOCK=y
CONFIG_INLINE_SPIN_LOCK_BH=y
CONFIG_INLINE_SPIN_LOCK_IRQ=y
CONFIG_INLINE_SPIN_LOCK_IRQSAVE=y
CONFIG_INLINE_SPIN_UNLOCK_BH=y
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE=y
CONFIG_INLINE_READ_LOCK=y
CONFIG_INLINE_READ_LOCK_BH=y
CONFIG_INLINE_READ_LOCK_IRQ=y
CONFIG_INLINE_READ_LOCK_IRQSAVE=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_BH=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK_IRQRESTORE=y
CONFIG_INLINE_WRITE_LOCK=y
CONFIG_INLINE_WRITE_LOCK_BH=y
CONFIG_INLINE_WRITE_LOCK_IRQ=y
CONFIG_INLINE_WRITE_LOCK_IRQSAVE=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_BH=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_ARCH_USE_QUEUED_SPINLOCKS=y
CONFIG_QUEUED_SPINLOCKS=y
CONFIG_ARCH_USE_QUEUED_RWLOCKS=y
CONFIG_QUEUED_RWLOCKS=y
CONFIG_ARCH_HAS_SYSCALL_WRAPPER=y
CONFIG_FREEZER=y
CONFIG_BINFMT_ELF=y
CONFIG_COMPAT_BINFMT_ELF=y
CONFIG_ELFCORE=y
CONFIG_BINFMT_SCRIPT=y
CONFIG_COREDUMP=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_SPARSEMEM_MANUAL=y
CONFIG_SPARSEMEM=y
CONFIG_HAVE_MEMORY_PRESENT=y
CONFIG_SPARSEMEM_EXTREME=y
CONFIG_SPARSEMEM_VMEMMAP_ENABLE=y
CONFIG_SPARSEMEM_VMEMMAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_NO_BOOTMEM=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
CONFIG_PHYS_ADDR_T_64BIT=y
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_ARCH_SUPPORTS_MEMORY_FAILURE=y
CONFIG_ZSMALLOC=m
CONFIG_GENERIC_EARLY_IOREMAP=y
CONFIG_FRAME_VECTOR=y
CONFIG_ARCH_HAS_PTE_SPECIAL=y
CONFIG_NET=y
CONFIG_COMPAT_NETLINK_MESSAGES=y
CONFIG_NET_INGRESS=y
CONFIG_NET_EGRESS=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=m
CONFIG_XFRM_USER=m
CONFIG_XFRM_INTERFACE=m
CONFIG_XFRM_IPCOMP=m
CONFIG_NET_KEY=m
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_ROUTE_CLASSID=y
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE_DEMUX=m
CONFIG_NET_IP_TUNNEL=m
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE_COMMON=y
CONFIG_IP_MROUTE=y
CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
CONFIG_SYN_COOKIES=y
CONFIG_NET_IPVTI=m
CONFIG_NET_UDP_TUNNEL=m
CONFIG_NET_FOU=m
CONFIG_NET_FOU_IP_TUNNELS=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_XFRM_MODE_TRANSPORT=m
CONFIG_INET_XFRM_MODE_TUNNEL=m
CONFIG_INET_XFRM_MODE_BEET=m
CONFIG_TCP_CONG_ADVANCED=y
CONFIG_TCP_CONG_CUBIC=y
CONFIG_TCP_CONG_BBR=y
CONFIG_TCP_CONG_LIA=y
CONFIG_TCP_CONG_OLIA=y
CONFIG_TCP_CONG_WVEGAS=y
CONFIG_TCP_CONG_BALIA=y
CONFIG_TCP_CONG_MCTCPDESYNC=y
CONFIG_DEFAULT_OLIA=y
CONFIG_DEFAULT_TCP_CONG="olia"
CONFIG_IPV6=y
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
CONFIG_INET6_IPCOMP=m
CONFIG_INET6_XFRM_TUNNEL=m
CONFIG_INET6_TUNNEL=m
CONFIG_INET6_XFRM_MODE_TRANSPORT=m
CONFIG_INET6_XFRM_MODE_TUNNEL=m
CONFIG_INET6_XFRM_MODE_BEET=m
CONFIG_IPV6_VTI=m
CONFIG_IPV6_SIT=m
CONFIG_IPV6_SIT_6RD=y
CONFIG_IPV6_NDISC_NODETYPE=y
CONFIG_IPV6_TUNNEL=m
CONFIG_IPV6_GRE=m
CONFIG_IPV6_FOU=m
CONFIG_IPV6_FOU_TUNNEL=m
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_IPV6_SUBTREES=y
CONFIG_IPV6_MROUTE=y
CONFIG_MPTCP=y
CONFIG_MPTCP_PM_ADVANCED=y
CONFIG_MPTCP_FULLMESH=y
CONFIG_MPTCP_NDIFFPORTS=y
CONFIG_MPTCP_BINDER=y
CONFIG_MPTCP_NETLINK=y
CONFIG_DEFAULT_FULLMESH=y
CONFIG_DEFAULT_MPTCP_PM="fullmesh"
CONFIG_MPTCP_SCHED_ADVANCED=y
CONFIG_MPTCP_BLEST=y
CONFIG_MPTCP_ROUNDROBIN=y
CONFIG_MPTCP_REDUNDANT=y
CONFIG_DEFAULT_SCHEDULER=y
CONFIG_DEFAULT_MPTCP_SCHED="default"
CONFIG_NET_PTP_CLASSIFY=y
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=m
CONFIG_NETFILTER_INGRESS=y
CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_FAMILY_BRIDGE=y
CONFIG_NETFILTER_FAMILY_ARP=y
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_LOG_COMMON=m
CONFIG_NETFILTER_CONNCOUNT=m
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_CUSTOM=2
CONFIG_NF_CONNTRACK_ZONES=y
CONFIG_NF_CONNTRACK_PROCFS=y
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CONNTRACK_RTCACHE=m
CONFIG_NF_CONNTRACK_LABELS=y
CONFIG_NF_CT_PROTO_GRE=m
CONFIG_NF_CONNTRACK_AMANDA=m
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_H323=m
CONFIG_NF_CONNTRACK_IRC=m
CONFIG_NF_CONNTRACK_BROADCAST=m
CONFIG_NF_CONNTRACK_SNMP=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
CONFIG_NF_NAT=m
CONFIG_NF_NAT_NEEDED=y
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_SIP=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_REDIRECT=y
CONFIG_NF_TABLES=m
CONFIG_NF_TABLES_INET=y
CONFIG_NF_TABLES_NETDEV=y
CONFIG_NFT_NUMGEN=m
CONFIG_NFT_CT=m
CONFIG_NFT_FLOW_OFFLOAD=m
CONFIG_NFT_COUNTER=m
CONFIG_NFT_LOG=m
CONFIG_NFT_LIMIT=m
CONFIG_NFT_MASQ=m
CONFIG_NFT_REDIR=m
CONFIG_NFT_NAT=m
CONFIG_NFT_QUOTA=m
CONFIG_NFT_REJECT=m
CONFIG_NFT_REJECT_INET=m
CONFIG_NFT_HASH=m
CONFIG_NFT_FIB=m
CONFIG_NFT_FIB_INET=m
CONFIG_NF_DUP_NETDEV=m
CONFIG_NFT_DUP_NETDEV=m
CONFIG_NFT_FWD_NETDEV=m
CONFIG_NF_FLOW_TABLE_INET=m
CONFIG_NF_FLOW_TABLE=m
CONFIG_NF_FLOW_TABLE_HW=m
CONFIG_NETFILTER_XTABLES=m
CONFIG_NETFILTER_XT_MARK=m
CONFIG_NETFILTER_XT_CONNMARK=m
CONFIG_NETFILTER_XT_SET=m
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CT=m
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_HL=m
CONFIG_NETFILTER_XT_TARGET_LED=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_NAT=m
CONFIG_NETFILTER_XT_TARGET_NETMAP=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
CONFIG_NETFILTER_XT_TARGET_FLOWOFFLOAD=m
CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
CONFIG_NETFILTER_XT_TARGET_TEE=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_BPF=m
CONFIG_NETFILTER_XT_MATCH_CLUSTER=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLABEL=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ECN=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_HL=m
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_SOCKET=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
CONFIG_IP_SET=m
CONFIG_IP_SET_MAX=256
CONFIG_IP_SET_BITMAP_IP=m
CONFIG_IP_SET_BITMAP_IPMAC=m
CONFIG_IP_SET_BITMAP_PORT=m
CONFIG_IP_SET_HASH_IP=m
CONFIG_IP_SET_HASH_IPMARK=m
CONFIG_IP_SET_HASH_IPPORT=m
CONFIG_IP_SET_HASH_IPPORTIP=m
CONFIG_IP_SET_HASH_IPPORTNET=m
CONFIG_IP_SET_HASH_IPMAC=m
CONFIG_IP_SET_HASH_MAC=m
CONFIG_IP_SET_HASH_NETPORTNET=m
CONFIG_IP_SET_HASH_NET=m
CONFIG_IP_SET_HASH_NETNET=m
CONFIG_IP_SET_HASH_NETPORT=m
CONFIG_IP_SET_HASH_NETIFACE=m
CONFIG_IP_SET_LIST_SET=m
CONFIG_IP_VS=m
CONFIG_IP_VS_IPV6=y
CONFIG_IP_VS_TAB_BITS=12
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_AH_ESP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
CONFIG_IP_VS_PROTO_SCTP=y
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
CONFIG_IP_VS_FO=m
CONFIG_IP_VS_OVF=m
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
CONFIG_IP_VS_SH_TAB_BITS=8
CONFIG_IP_VS_MH_TAB_INDEX=10
CONFIG_IP_VS_FTP=m
CONFIG_IP_VS_NFCT=y
CONFIG_IP_VS_PE_SIP=m
CONFIG_NF_DEFRAG_IPV4=m
CONFIG_NF_SOCKET_IPV4=m
CONFIG_NF_TPROXY_IPV4=m
CONFIG_NF_TABLES_IPV4=y
CONFIG_NFT_CHAIN_ROUTE_IPV4=m
CONFIG_NFT_REJECT_IPV4=m
CONFIG_NFT_FIB_IPV4=m
CONFIG_NF_TABLES_ARP=y
CONFIG_NF_FLOW_TABLE_IPV4=m
CONFIG_NF_DUP_IPV4=m
CONFIG_NF_LOG_IPV4=m
CONFIG_NF_REJECT_IPV4=m
CONFIG_NF_NAT_IPV4=m
CONFIG_NF_NAT_MASQUERADE_IPV4=y
CONFIG_NFT_CHAIN_NAT_IPV4=m
CONFIG_NFT_MASQ_IPV4=m
CONFIG_NFT_REDIR_IPV4=m
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PROTO_GRE=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_RPFILTER=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_CLUSTERIP=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
CONFIG_NF_SOCKET_IPV6=m
CONFIG_NF_TPROXY_IPV6=m
CONFIG_NF_TABLES_IPV6=y
CONFIG_NFT_CHAIN_ROUTE_IPV6=m
CONFIG_NFT_CHAIN_NAT_IPV6=m
CONFIG_NFT_MASQ_IPV6=m
CONFIG_NFT_REDIR_IPV6=m
CONFIG_NFT_REJECT_IPV6=m
CONFIG_NFT_FIB_IPV6=m
CONFIG_NF_FLOW_TABLE_IPV6=m
CONFIG_NF_DUP_IPV6=m
CONFIG_NF_REJECT_IPV6=m
CONFIG_NF_LOG_IPV6=m
CONFIG_NF_NAT_IPV6=m
CONFIG_NF_NAT_MASQUERADE_IPV6=y
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_MH=m
CONFIG_IP6_NF_MATCH_RPFILTER=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_RAW=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_IP6_NF_TARGET_NPT=m
CONFIG_NF_DEFRAG_IPV6=m
CONFIG_NF_TABLES_BRIDGE=y
CONFIG_NFT_BRIDGE_REJECT=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_IP6=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
CONFIG_IP_SCTP=m
CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
CONFIG_SCTP_COOKIE_HMAC_MD5=y
CONFIG_ATM=m
CONFIG_ATM_CLIP=m
CONFIG_ATM_CLIP_NO_ICMP=y
CONFIG_ATM_BR2684=m
CONFIG_ATM_BR2684_IPFILTER=y
CONFIG_L2TP=m
CONFIG_L2TP_V3=y
CONFIG_L2TP_IP=m
CONFIG_L2TP_ETH=m
CONFIG_STP=y
CONFIG_BRIDGE=y
CONFIG_BRIDGE_IGMP_SNOOPING=y
CONFIG_BRIDGE_VLAN_FILTERING=y
CONFIG_HAVE_NET_DSA=y
CONFIG_VLAN_8021Q=y
CONFIG_LLC=y
CONFIG_6LOWPAN=m
CONFIG_IEEE802154=m
CONFIG_IEEE802154_SOCKET=m
CONFIG_IEEE802154_6LOWPAN=m
CONFIG_MAC802154=m
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_CODEL=m
CONFIG_NET_SCH_FQ_CODEL=y
CONFIG_NET_SCH_FQ=m
CONFIG_NET_SCH_PIE=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_FLOW=m
CONFIG_NET_CLS_CGROUP=y
CONFIG_NET_CLS_BPF=m
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_CLS_MATCHALL=m
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
CONFIG_NET_EMATCH_IPSET=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_CSUM=m
CONFIG_NET_ACT_VLAN=m
CONFIG_NET_ACT_BPF=m
CONFIG_NET_ACT_CONNMARK=m
CONFIG_NET_ACT_CTINFO=m
CONFIG_NET_CLS_IND=y
CONFIG_NET_SCH_FIFO=y
CONFIG_DNS_RESOLVER=m
CONFIG_OPENVSWITCH=m
CONFIG_OPENVSWITCH_GRE=m
CONFIG_OPENVSWITCH_VXLAN=m
CONFIG_OPENVSWITCH_GENEVE=m
CONFIG_MPLS=y
CONFIG_NET_MPLS_GSO=m
CONFIG_MPLS_ROUTING=m
CONFIG_MPLS_IPTUNNEL=m
CONFIG_NET_NSH=m
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_XPS=y
CONFIG_CGROUP_NET_CLASSID=y
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
CONFIG_BPF_JIT=y
CONFIG_BPF_STREAM_PARSER=y
CONFIG_NET_FLOW_LIMIT=y
CONFIG_NET_PKTGEN=m
CONFIG_HAMRADIO=y
CONFIG_AX25=m
CONFIG_MKISS=m
CONFIG_CAN=m
CONFIG_CAN_RAW=m
CONFIG_CAN_BCM=m
CONFIG_CAN_GW=m
CONFIG_CAN_VCAN=m
CONFIG_CAN_SLCAN=m
CONFIG_CAN_DEV=m
CONFIG_CAN_CALC_BITTIMING=y
CONFIG_CAN_C_CAN=m
CONFIG_CAN_C_CAN_PLATFORM=m
CONFIG_CAN_C_CAN_PCI=m
CONFIG_CAN_8DEV_USB=m
CONFIG_CAN_EMS_USB=m
CONFIG_CAN_ESD_USB2=m
CONFIG_CAN_KVASER_USB=m
CONFIG_CAN_PEAK_USB=m
CONFIG_BT=y
CONFIG_BT_BREDR=y
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=m
CONFIG_BT_HS=y
CONFIG_BT_LE=y
CONFIG_BT_6LOWPAN=m
CONFIG_BT_DEBUGFS=y
CONFIG_BT_INTEL=m
CONFIG_BT_BCM=y
CONFIG_BT_QCA=y
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_SERDEV=y
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_ATH3K=y
CONFIG_BT_HCIUART_BCM=y
CONFIG_BT_HCIUART_QCA=y
CONFIG_BT_HCIVHCI=y
CONFIG_BT_MRVL=m
CONFIG_BT_MRVL_SDIO=m
CONFIG_BT_ATH3K=m
CONFIG_BT_MTKUART=y
CONFIG_STREAM_PARSER=y
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
CONFIG_RFKILL=y
CONFIG_LWTUNNEL=y
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
CONFIG_MAY_USE_DEVLINK=y
CONFIG_HAVE_EBPF_JIT=y
CONFIG_ARM_AMBA=y
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE=""
CONFIG_FW_LOADER_USER_HELPER=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
CONFIG_WANT_DEV_COREDUMP=y
CONFIG_ALLOW_DEV_COREDUMP=y
CONFIG_DEV_COREDUMP=y
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=m
CONFIG_REGMAP_SPI=m
CONFIG_REGMAP_MMIO=y
CONFIG_DMA_SHARED_BUFFER=m
CONFIG_GENERIC_ARCH_TOPOLOGY=y
CONFIG_MTD=y
CONFIG_MTD_ROOTFS_ROOT_DEV=y
CONFIG_MTD_SPLIT_FIRMWARE=y
CONFIG_MTD_SPLIT_FIRMWARE_NAME="Kernel"
CONFIG_MTD_SPLIT=y
CONFIG_MTD_SPLIT_SUPPORT=y
CONFIG_MTD_SPLIT_SQUASHFS_ROOT=y
CONFIG_MTD_SPLIT_UIMAGE_FW=y
CONFIG_MTD_SPLIT_FIT_FW=y
CONFIG_MTD_TESTS=m
CONFIG_MTD_CMDLINE_PARTS=y
CONFIG_MTD_OF_PARTS=y
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_OOPS=m
CONFIG_MTD_CFI=y
CONFIG_MTD_GEN_PROBE=y
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
CONFIG_MTD_CFI_UTIL=y
CONFIG_MTD_COMPLEX_MAPPINGS=y
CONFIG_MTD_PHYSMAP_OF=y
CONFIG_MTD_M25P80=y
CONFIG_MTD_MTDRAM=m
CONFIG_MTDRAM_TOTAL_SIZE=4096
CONFIG_MTDRAM_ERASE_SIZE=128
CONFIG_MTD_BLOCK2MTD=y
CONFIG_MTD_NAND_CORE=y
CONFIG_MTD_NAND_ECC=y
CONFIG_MTD_NAND=y
CONFIG_MTD_NAND_MTK=y
CONFIG_MTD_SPI_NAND=y
CONFIG_MTD_SPI_NOR=y
CONFIG_MTD_MT81xx_NOR=y
CONFIG_MTD_UBI=y
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
CONFIG_MTD_UBI_BLOCK=y
CONFIG_DTC=y
CONFIG_OF=y
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=y
CONFIG_OF_RESERVED_MEM=y
CONFIG_PARPORT=m
CONFIG_PARPORT_1284=y
CONFIG_BLK_DEV=y
CONFIG_CDROM=m
CONFIG_ZRAM=m
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
CONFIG_BLK_DEV_NBD=m
CONFIG_ATA_OVER_ETH=m
CONFIG_OWL_LOADER=m
CONFIG_EEPROM_AT24=m
CONFIG_EEPROM_AT25=m
CONFIG_EEPROM_93CX6=m
CONFIG_ECHO=m
CONFIG_MTK_PLATFORM=""
CONFIG_SCSI_MOD=y
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_PROC_FS=y
CONFIG_BLK_DEV_SD=y
CONFIG_CHR_DEV_ST=m
CONFIG_BLK_DEV_SR=m
CONFIG_CHR_DEV_SG=m
CONFIG_SCSI_LOWLEVEL=y
CONFIG_HAVE_PATA_PLATFORM=y
CONFIG_ATA=y
CONFIG_SATA_AHCI=m
CONFIG_SATA_MOBILE_LPM_POLICY=0
CONFIG_AHCI_MTK=y
CONFIG_SATA_SIL24=m
CONFIG_ATA_SFF=y
CONFIG_ATA_BMDMA=y
CONFIG_ATA_PIIX=m
CONFIG_SATA_MV=m
CONFIG_SATA_NV=m
CONFIG_SATA_SIL=m
CONFIG_SATA_VIA=m
CONFIG_PATA_ARTOP=m
CONFIG_PATA_PDC_OLD=m
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_MD_LINEAR=m
CONFIG_MD_RAID0=m
CONFIG_MD_RAID1=m
CONFIG_MD_RAID10=m
CONFIG_MD_RAID456=m
CONFIG_MD_MULTIPATH=m
CONFIG_BLK_DEV_DM_BUILTIN=y
CONFIG_BLK_DEV_DM=m
CONFIG_DM_CRYPT=m
CONFIG_DM_MIRROR=m
CONFIG_DM_RAID=m
CONFIG_FIREWIRE=m
CONFIG_FIREWIRE_OHCI=m
CONFIG_FIREWIRE_SBP2=m
CONFIG_FIREWIRE_NET=m
CONFIG_NETDEVICES=y
CONFIG_MII=m
CONFIG_NET_CORE=y
CONFIG_BONDING=m
CONFIG_DUMMY=m
CONFIG_IFB=m
CONFIG_MACVLAN=m
CONFIG_VXLAN=m
CONFIG_GENEVE=m
CONFIG_MACSEC=m
CONFIG_TUN=m
CONFIG_VETH=m
CONFIG_NLMON=m
CONFIG_ATM_DRIVERS=y
CONFIG_ATM_TCP=m
CONFIG_ATM_SOLOS=m
CONFIG_ETHERNET=y
CONFIG_MDIO=m
CONFIG_NET_VENDOR_3COM=y
CONFIG_VORTEX=m
CONFIG_NET_VENDOR_ADAPTEC=y
CONFIG_NET_VENDOR_AGERE=y
CONFIG_ET131X=m
CONFIG_NET_VENDOR_ALACRITECH=y
CONFIG_NET_VENDOR_ALTEON=y
CONFIG_NET_VENDOR_AMAZON=y
CONFIG_NET_VENDOR_AMD=y
CONFIG_PCNET32=m
CONFIG_NET_VENDOR_AQUANTIA=y
CONFIG_NET_VENDOR_ARC=y
CONFIG_NET_VENDOR_ATHEROS=y
CONFIG_ATL2=m
CONFIG_ATL1=m
CONFIG_ATL1E=m
CONFIG_ATL1C=m
CONFIG_ALX=m
CONFIG_NET_VENDOR_AURORA=y
CONFIG_NET_VENDOR_BROADCOM=y
CONFIG_B44=m
CONFIG_B44_PCI_AUTOSELECT=y
CONFIG_B44_PCICORE_AUTOSELECT=y
CONFIG_B44_PCI=y
CONFIG_BNX2=m
CONFIG_TIGON3=m
CONFIG_BNX2X=m
CONFIG_NET_VENDOR_BROCADE=y
CONFIG_NET_VENDOR_CADENCE=y
CONFIG_NET_VENDOR_CAVIUM=y
CONFIG_NET_VENDOR_CHELSIO=y
CONFIG_NET_VENDOR_CISCO=y
CONFIG_NET_VENDOR_CORTINA=y
CONFIG_NET_VENDOR_DEC=y
CONFIG_NET_TULIP=y
CONFIG_DE2104X=m
CONFIG_DE2104X_DSL=0
CONFIG_TULIP=m
CONFIG_TULIP_MWI=y
CONFIG_TULIP_MMIO=y
CONFIG_TULIP_NAPI=y
CONFIG_TULIP_NAPI_HW_MITIGATION=y
CONFIG_WINBOND_840=m
CONFIG_DM9102=m
CONFIG_ULI526X=m
CONFIG_NET_VENDOR_DLINK=y
CONFIG_NET_VENDOR_EMULEX=y
CONFIG_NET_VENDOR_EZCHIP=y
CONFIG_NET_VENDOR_HISILICON=y
CONFIG_NET_VENDOR_HP=y
CONFIG_NET_VENDOR_HUAWEI=y
CONFIG_NET_VENDOR_I825XX=y
CONFIG_NET_VENDOR_INTEL=y
CONFIG_E100=m
CONFIG_E1000=m
CONFIG_IGB=m
CONFIG_IGB_HWMON=y
CONFIG_IXGBE=m
CONFIG_IXGBE_HWMON=y
CONFIG_IXGBEVF=m
CONFIG_NET_VENDOR_MARVELL=y
CONFIG_SKGE=m
CONFIG_SKY2=m
CONFIG_NET_VENDOR_MEDIATEK=y
CONFIG_NET_MEDIATEK_SOC=y
CONFIG_NET_VENDOR_MELLANOX=y
CONFIG_NET_VENDOR_MICREL=y
CONFIG_NET_VENDOR_MICROCHIP=y
CONFIG_NET_VENDOR_MICROSEMI=y
CONFIG_NET_VENDOR_MYRI=y
CONFIG_NET_VENDOR_NATSEMI=y
CONFIG_NATSEMI=m
CONFIG_NET_VENDOR_NETERION=y
CONFIG_NET_VENDOR_NETRONOME=y
CONFIG_NET_VENDOR_NI=y
CONFIG_NET_VENDOR_8390=y
CONFIG_NE2K_PCI=m
CONFIG_NET_VENDOR_NVIDIA=y
CONFIG_FORCEDETH=m
CONFIG_NET_VENDOR_OKI=y
CONFIG_ETHOC=m
CONFIG_NET_VENDOR_PACKET_ENGINES=y
CONFIG_NET_VENDOR_QLOGIC=y
CONFIG_NET_VENDOR_QUALCOMM=y
CONFIG_NET_VENDOR_RDC=y
CONFIG_R6040=m
CONFIG_NET_VENDOR_REALTEK=y
CONFIG_8139CP=m
CONFIG_8139TOO=m
CONFIG_8139TOO_PIO=y
CONFIG_R8169=m
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
CONFIG_NET_VENDOR_SAMSUNG=y
CONFIG_NET_VENDOR_SEEQ=y
CONFIG_NET_VENDOR_SOLARFLARE=y
CONFIG_NET_VENDOR_SILAN=y
CONFIG_NET_VENDOR_SIS=y
CONFIG_SIS900=m
CONFIG_SIS190=m
CONFIG_NET_VENDOR_SMSC=y
CONFIG_NET_VENDOR_SOCIONEXT=y
CONFIG_NET_VENDOR_STMICRO=y
CONFIG_NET_VENDOR_SUN=y
CONFIG_NIU=m
CONFIG_NET_VENDOR_SYNOPSYS=y
CONFIG_NET_VENDOR_TEHUTI=y
CONFIG_NET_VENDOR_TI=y
CONFIG_NET_VENDOR_VIA=y
CONFIG_VIA_RHINE=m
CONFIG_VIA_RHINE_MMIO=y
CONFIG_VIA_VELOCITY=m
CONFIG_NET_VENDOR_WIZNET=y
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
CONFIG_MDIO_BITBANG=m
CONFIG_MDIO_GPIO=m
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
CONFIG_SWCONFIG=m
CONFIG_IP17XX_PHY=m
CONFIG_MVSW61XX_PHY=m
CONFIG_RTL8306_PHY=m
CONFIG_RTL8366_SMI=m
CONFIG_RTL8366S_PHY=m
CONFIG_RTL8366RB_PHY=m
CONFIG_RTL8367B_PHY=m
CONFIG_MT753X_GSW=y
CONFIG_BCM_NET_PHYLIB=m
CONFIG_BROADCOM_PHY=m
CONFIG_FIXED_PHY=y
CONFIG_ICPLUS_PHY=y
CONFIG_REALTEK_PHY=y
CONFIG_MICREL_KS8995MA=m
CONFIG_PPP=m
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOATM=m
CONFIG_PPPOE=m
CONFIG_PPTP=m
CONFIG_PPPOL2TP=m
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_SLIP=m
CONFIG_SLHC=m
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
CONFIG_SLIP_MODE_SLIP6=y
CONFIG_USB_NET_DRIVERS=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=m
CONFIG_USB_USBNET=m
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_CDC_EEM=m
CONFIG_USB_NET_CDC_NCM=m
CONFIG_USB_NET_HUAWEI_CDC_NCM=m
CONFIG_USB_NET_CDC_MBIM=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SR9700=m
CONFIG_USB_NET_SMSC95XX=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_USB_NET_RNDIS_HOST=m
CONFIG_USB_NET_CDC_SUBSET_ENABLE=m
CONFIG_USB_NET_CDC_SUBSET=m
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
CONFIG_USB_NET_KALMIA=m
CONFIG_USB_NET_QMI_WWAN=m
CONFIG_USB_HSO=m
CONFIG_USB_IPHETH=m
CONFIG_USB_SIERRA_NET=m
CONFIG_WLAN=y
CONFIG_IEEE802154_DRIVERS=m
CONFIG_IEEE802154_FAKELB=m
CONFIG_IEEE802154_AT86RF230=m
CONFIG_IEEE802154_MRF24J40=m
CONFIG_IEEE802154_CC2520=m
CONFIG_IEEE802154_ATUSB=m
CONFIG_VMXNET3=m
CONFIG_ISDN=y
CONFIG_ISDN_I4L=m
CONFIG_ISDN_PPP=y
CONFIG_ISDN_PPP_VJ=y
CONFIG_ISDN_MPP=y
CONFIG_IPPP_FILTER=y
CONFIG_ISDN_PPP_BSDCOMP=m
CONFIG_ISDN_AUDIO=y
CONFIG_ISDN_TTY_FAX=y
CONFIG_ISDN_DIVERSION=m
CONFIG_ISDN_CAPI=m
CONFIG_ISDN_CAPI_CAPI20=m
CONFIG_ISDN_CAPI_MIDDLEWARE=y
CONFIG_ISDN_DRV_GIGASET=m
CONFIG_GIGASET_I4L=y
CONFIG_GIGASET_BASE=m
CONFIG_GIGASET_M105=m
CONFIG_GIGASET_M101=m
CONFIG_MISDN=m
CONFIG_MISDN_DSP=m
CONFIG_MISDN_L1OIP=m
CONFIG_MISDN_HFCPCI=m
CONFIG_MISDN_HFCMULTI=m
CONFIG_INPUT=m
CONFIG_INPUT_POLLDEV=m
CONFIG_INPUT_MATRIXKMAP=m
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_EVDEV=m
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_GPIO=m
CONFIG_KEYBOARD_GPIO_POLLED=m
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=m
CONFIG_TOUCHSCREEN_ADS7846=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_GPIO_BEEPER=m
CONFIG_INPUT_YEALINK=m
CONFIG_INPUT_CM109=m
CONFIG_INPUT_UINPUT=m
CONFIG_INPUT_GPIO_ROTARY_ENCODER=m
CONFIG_TTY=y
CONFIG_UNIX98_PTYS=y
CONFIG_LDISC_AUTOLOAD=y
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_PCI=m
CONFIG_SERIAL_8250_EXAR=m
CONFIG_SERIAL_8250_NR_UARTS=16
CONFIG_SERIAL_8250_RUNTIME_UARTS=16
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_MANY_PORTS=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_FSL=y
CONFIG_SERIAL_8250_MT6577=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_DEV_BUS=y
CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
CONFIG_PRINTER=m
CONFIG_PPDEV=m
CONFIG_HW_RANDOM=y
CONFIG_HW_RANDOM_MTK=y
CONFIG_TCG_TPM=m
CONFIG_TCG_TIS_I2C_ATMEL=m
CONFIG_TCG_TIS_I2C_INFINEON=m
CONFIG_DEVPORT=y
CONFIG_I2C=m
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_CHARDEV=m
CONFIG_I2C_MUX=m
CONFIG_I2C_MUX_GPIO=m
CONFIG_I2C_MUX_PCA9541=m
CONFIG_I2C_MUX_PCA954x=m
CONFIG_I2C_SMBUS=m
CONFIG_I2C_ALGOBIT=m
CONFIG_I2C_ALGOPCF=m
CONFIG_I2C_ALGOPCA=m
CONFIG_I2C_GPIO=m
CONFIG_I2C_TINY_USB=m
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
CONFIG_SPI_MEM=y
CONFIG_SPI_BITBANG=m
CONFIG_SPI_GPIO=m
CONFIG_SPI_MT65XX=y
CONFIG_SPI_MTK_SNFI=y
CONFIG_SPI_SPIDEV=m
CONFIG_PPS=m
CONFIG_PPS_CLIENT_LDISC=m
CONFIG_PPS_CLIENT_GPIO=m
CONFIG_PTP_1588_CLOCK=m
CONFIG_PINCTRL=y
CONFIG_GENERIC_PINCTRL_GROUPS=y
CONFIG_PINMUX=y
CONFIG_GENERIC_PINMUX_FUNCTIONS=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
CONFIG_DEBUG_PINCTRL=y
CONFIG_PINCTRL_MCP23S08=m
CONFIG_PINCTRL_SINGLE=y
CONFIG_EINT_MTK=y
CONFIG_PINCTRL_MT7622=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
List 2 (part 2)
CONFIG_GPIOLIB_IRQCHIP=y
CONFIG_DEBUG_GPIO=y
CONFIG_GPIO_PCA953X=m
CONFIG_GPIO_PCF857X=m
CONFIG_GPIO_74X164=m
CONFIG_W1=m
CONFIG_W1_MASTER_DS2490=m
CONFIG_W1_MASTER_DS2482=m
CONFIG_W1_MASTER_GPIO=m
CONFIG_W1_SLAVE_THERM=m
CONFIG_W1_SLAVE_SMEM=m
CONFIG_W1_SLAVE_DS2413=m
CONFIG_W1_SLAVE_DS2431=m
CONFIG_W1_SLAVE_DS2433=m
CONFIG_POWER_RESET=y
CONFIG_POWER_RESET_SYSCON=y
CONFIG_POWER_SUPPLY=y
CONFIG_HWMON=m
CONFIG_HWMON_VID=m
CONFIG_SENSORS_ADT7X10=m
CONFIG_SENSORS_ADT7410=m
CONFIG_SENSORS_ADT7475=m
CONFIG_SENSORS_GPIO_FAN=m
CONFIG_SENSORS_IT87=m
CONFIG_SENSORS_LTC4151=m
CONFIG_SENSORS_ADCXX=m
CONFIG_SENSORS_LM63=m
CONFIG_SENSORS_LM75=m
CONFIG_SENSORS_LM77=m
CONFIG_SENSORS_LM85=m
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_LM92=m
CONFIG_SENSORS_LM95241=m
CONFIG_PMBUS=m
CONFIG_SENSORS_ZL6100=m
CONFIG_SENSORS_PWM_FAN=m
CONFIG_SENSORS_SHT21=m
CONFIG_SENSORS_SCH56XX_COMMON=m
CONFIG_SENSORS_SCH5627=m
CONFIG_SENSORS_ADS1015=m
CONFIG_SENSORS_INA209=m
CONFIG_SENSORS_INA2XX=m
CONFIG_SENSORS_TMP102=m
CONFIG_SENSORS_TMP103=m
CONFIG_SENSORS_TMP421=m
CONFIG_SENSORS_W83793=m
CONFIG_THERMAL=y
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_OF=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
CONFIG_THERMAL_GOV_FAIR_SHARE=y
CONFIG_THERMAL_GOV_STEP_WISE=y
CONFIG_THERMAL_GOV_BANG_BANG=y
CONFIG_THERMAL_GOV_USER_SPACE=y
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_CPU_THERMAL=y
CONFIG_CLOCK_THERMAL=y
CONFIG_THERMAL_EMULATION=y
CONFIG_MTK_THERMAL=y
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_SYSFS=y
CONFIG_SOFT_WATCHDOG=m
CONFIG_MEDIATEK_WATCHDOG=y
CONFIG_WATCHDOG_PRETIMEOUT_GOV=y
CONFIG_WATCHDOG_PRETIMEOUT_DEFAULT_GOV_PANIC=y
CONFIG_WATCHDOG_PRETIMEOUT_GOV_PANIC=y
CONFIG_SSB_POSSIBLE=y
CONFIG_SSB=m
CONFIG_SSB_SPROM=y
CONFIG_SSB_BLOCKIO=y
CONFIG_SSB_PCIHOST_POSSIBLE=y
CONFIG_SSB_PCIHOST=y
CONFIG_SSB_B43_PCI_BRIDGE=y
CONFIG_SSB_SDIOHOST_POSSIBLE=y
CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y
CONFIG_SSB_DRIVER_PCICORE=y
CONFIG_BCMA_POSSIBLE=y
CONFIG_BCMA=m
CONFIG_BCMA_BLOCKIO=y
CONFIG_BCMA_HOST_PCI_POSSIBLE=y
CONFIG_BCMA_HOST_PCI=y
CONFIG_BCMA_DRIVER_PCI=y
CONFIG_MFD_SYSCON=y
CONFIG_REGULATOR=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_MT6380=y
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_V4L2=m
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
CONFIG_USB_M5602=m
CONFIG_USB_STV06XX=m
CONFIG_USB_GL860=m
CONFIG_USB_GSPCA_CONEX=m
CONFIG_USB_GSPCA_ETOMS=m
CONFIG_USB_GSPCA_FINEPIX=m
CONFIG_USB_GSPCA_JEILINJ=m
CONFIG_USB_GSPCA_KONICA=m
CONFIG_USB_GSPCA_MARS=m
CONFIG_USB_GSPCA_MR97310A=m
CONFIG_USB_GSPCA_OV519=m
CONFIG_USB_GSPCA_OV534=m
CONFIG_USB_GSPCA_OV534_9=m
CONFIG_USB_GSPCA_PAC207=m
CONFIG_USB_GSPCA_PAC7311=m
CONFIG_USB_GSPCA_SE401=m
CONFIG_USB_GSPCA_SN9C20X=m
CONFIG_USB_GSPCA_SONIXB=m
CONFIG_USB_GSPCA_SONIXJ=m
CONFIG_USB_GSPCA_SPCA500=m
CONFIG_USB_GSPCA_SPCA501=m
CONFIG_USB_GSPCA_SPCA505=m
CONFIG_USB_GSPCA_SPCA506=m
CONFIG_USB_GSPCA_SPCA508=m
CONFIG_USB_GSPCA_SPCA561=m
CONFIG_USB_GSPCA_SQ905=m
CONFIG_USB_GSPCA_SQ905C=m
CONFIG_USB_GSPCA_STK014=m
CONFIG_USB_GSPCA_SUNPLUS=m
CONFIG_USB_GSPCA_T613=m
CONFIG_USB_GSPCA_TV8532=m
CONFIG_USB_GSPCA_VC032X=m
CONFIG_USB_GSPCA_ZC3XX=m
CONFIG_USB_PWC=m
CONFIG_VIDEO_CPIA2=m
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEOBUF2_CORE=m
CONFIG_VIDEOBUF2_V4L2=m
CONFIG_VIDEOBUF2_MEMOPS=m
CONFIG_VIDEOBUF2_VMALLOC=m
CONFIG_SOUND=m
CONFIG_SOUND_OSS_CORE=y
CONFIG_SOUND_OSS_CORE_PRECLAIM=y
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_SEQ_DEVICE=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_COMPRESS_OFFLOAD=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_PCM_TIMER=y
CONFIG_SND_DYNAMIC_MINORS=y
CONFIG_SND_MAX_CARDS=16
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
CONFIG_SND_VMASTER=y
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_SEQUENCER_OSS=m
CONFIG_SND_SEQ_MIDI_EVENT=m
CONFIG_SND_SEQ_MIDI=m
CONFIG_SND_SEQ_VIRMIDI=m
CONFIG_SND_MPU401_UART=m
CONFIG_SND_AC97_CODEC=m
CONFIG_SND_DRIVERS=y
CONFIG_SND_DUMMY=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_PCI=y
CONFIG_SND_ENS1371=m
CONFIG_SND_INTEL8X0=m
CONFIG_SND_VIA82XX=m
CONFIG_SND_HDA=m
CONFIG_SND_HDA_INTEL=m
CONFIG_SND_HDA_HWDEP=y
CONFIG_SND_HDA_CODEC_REALTEK=m
CONFIG_SND_HDA_CODEC_ANALOG=m
CONFIG_SND_HDA_CODEC_SIGMATEL=m
CONFIG_SND_HDA_CODEC_VIA=m
CONFIG_SND_HDA_CODEC_HDMI=m
CONFIG_SND_HDA_CODEC_CIRRUS=m
CONFIG_SND_HDA_CODEC_CONEXANT=m
CONFIG_SND_HDA_CODEC_CA0110=m
CONFIG_SND_HDA_CODEC_CA0132=m
CONFIG_SND_HDA_CODEC_CMEDIA=m
CONFIG_SND_HDA_CODEC_SI3054=m
CONFIG_SND_HDA_GENERIC=m
CONFIG_SND_HDA_POWER_SAVE_DEFAULT=0
CONFIG_SND_HDA_CORE=m
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_SOC=m
CONFIG_SND_SOC_AC97_BUS=y
CONFIG_SND_SOC_I2C_AND_SPI=m
CONFIG_SND_SOC_AC97_CODEC=m
CONFIG_AC97_BUS=m
CONFIG_HID=m
CONFIG_HID_BATTERY_STRENGTH=y
CONFIG_HIDRAW=y
CONFIG_HID_GENERIC=m
CONFIG_USB_HID=m
CONFIG_USB_HIDDEV=y
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
CONFIG_USB_PCI=y
CONFIG_USB_DEFAULT_PERSIST=y
CONFIG_USB_LEDS_TRIGGER_USBPORT=m
CONFIG_USB_MON=m
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_XHCI_PCI=y
CONFIG_USB_XHCI_PLATFORM=m
CONFIG_USB_XHCI_MTK=y
CONFIG_USB_EHCI_HCD=m
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_PCI=m
CONFIG_USB_EHCI_HCD_PLATFORM=m
CONFIG_USB_OHCI_HCD=m
CONFIG_USB_OHCI_HCD_PCI=m
CONFIG_USB_OHCI_HCD_PLATFORM=m
CONFIG_USB_UHCI_HCD=m
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_WDM=m
CONFIG_USB_STORAGE=m
CONFIG_USB_STORAGE_DATAFAB=m
CONFIG_USB_STORAGE_FREECOM=m
CONFIG_USB_STORAGE_ISD200=m
CONFIG_USB_STORAGE_USBAT=m
CONFIG_USB_STORAGE_SDDR09=m
CONFIG_USB_STORAGE_SDDR55=m
CONFIG_USB_STORAGE_JUMPSHOT=m
CONFIG_USB_STORAGE_ALAUDA=m
CONFIG_USB_STORAGE_KARMA=m
CONFIG_USB_STORAGE_CYPRESS_ATACB=m
CONFIG_USB_UAS=m
CONFIG_USBIP_CORE=m
CONFIG_USBIP_VHCI_HCD=m
CONFIG_USBIP_VHCI_HC_PORTS=8
CONFIG_USBIP_VHCI_NR_HCS=1
CONFIG_USBIP_HOST=m
CONFIG_USB_DWC3=m
CONFIG_USB_DWC3_HOST=y
CONFIG_USB_DWC2=m
CONFIG_USB_DWC2_HOST=y
CONFIG_USB_DWC2_PCI=m
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_SIMPLE=m
CONFIG_USB_SERIAL_ARK3116=m
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_CH341=m
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_CYPRESS_M8=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_IPW=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_MOS7720=m
CONFIG_USB_SERIAL_MOS7840=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_OTI6858=m
CONFIG_USB_SERIAL_QUALCOMM=m
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_TI=m
CONFIG_USB_SERIAL_WWAN=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_TEST=m
CONFIG_USB_EZUSB_FX2=m
CONFIG_USB_CHAOSKEY=m
CONFIG_USB_ATM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_CXACRU=m
CONFIG_USB_UEAGLEATM=m
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=m
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SPI=m
CONFIG_MMC_MTK=y
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_BRIGHTNESS_HW_CHANGED=y
CONFIG_LEDS_GPIO=m
CONFIG_LEDS_PCA963X=m
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_ONESHOT=m
CONFIG_LEDS_TRIGGER_HEARTBEAT=m
CONFIG_LEDS_TRIGGER_GPIO=m
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
CONFIG_LEDS_TRIGGER_TRANSIENT=m
CONFIG_LEDS_TRIGGER_NETDEV=y
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
CONFIG_RTC_DRV_DS1307=m
CONFIG_RTC_DRV_DS1374=m
CONFIG_RTC_DRV_DS1672=m
CONFIG_RTC_DRV_RS5C372=m
CONFIG_RTC_DRV_ISL1208=m
CONFIG_RTC_DRV_PCF8563=m
CONFIG_RTC_DRV_EM3027=m
CONFIG_RTC_DRV_PCF2123=m
CONFIG_RTC_I2C_AND_SPI=m
CONFIG_RTC_DRV_MT7622=y
CONFIG_DMADEVICES=y
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
CONFIG_MTK_HSDMA=y
CONFIG_DMATEST=y
CONFIG_DMA_ENGINE_RAID=y
CONFIG_VIRTIO_MENU=y
CONFIG_STAGING=y
CONFIG_R8712U=m
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
CONFIG_COMMON_CLK_MEDIATEK=y
CONFIG_COMMON_CLK_MT2712=y
CONFIG_COMMON_CLK_MT7622=y
CONFIG_COMMON_CLK_MT7622_ETHSYS=y
CONFIG_COMMON_CLK_MT7622_HIFSYS=y
CONFIG_COMMON_CLK_MT7622_AUDSYS=y
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
CONFIG_MTK_TIMER=y
CONFIG_IOMMU_API=y
CONFIG_IOMMU_SUPPORT=y
CONFIG_IOMMU_IOVA=y
CONFIG_OF_IOMMU=y
CONFIG_IOMMU_DMA=y
CONFIG_MTK_INFRACFG=y
CONFIG_MTK_PMIC_WRAP=y
CONFIG_MTK_SCPSYS=y
CONFIG_EXTCON=y
CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
CONFIG_IIO_KFIFO_BUF=m
CONFIG_IIO_TRIGGERED_BUFFER=m
CONFIG_IIO_TRIGGER=y
CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
CONFIG_AD799X=m
CONFIG_MEDIATEK_MT6577_AUXADC=y
CONFIG_CCS811=m
CONFIG_IIO_MS_SENSORS_I2C=m
CONFIG_AM2315=m
CONFIG_DHT11=m
CONFIG_HTU21=m
CONFIG_SI7020=m
CONFIG_BH1750=m
CONFIG_TSL4531=m
CONFIG_SENSORS_HMC5843=m
CONFIG_SENSORS_HMC5843_I2C=m
CONFIG_BMP280=m
CONFIG_BMP280_I2C=m
CONFIG_BMP280_SPI=m
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
CONFIG_PWM_MEDIATEK=y
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
CONFIG_ARM_GIC_V2M=y
CONFIG_ARM_GIC_V3=y
CONFIG_ARM_GIC_V3_ITS=y
CONFIG_ARM_GIC_V3_ITS_PCI=y
CONFIG_PARTITION_PERCPU=y
CONFIG_RESET_CONTROLLER=y
CONFIG_GENERIC_PHY=y
CONFIG_PHY_MTK_TPHY=y
CONFIG_RAS=y
CONFIG_DAX=m
CONFIG_NVMEM=y
CONFIG_MTK_EFUSE=y
CONFIG_PM_OPP=y
CONFIG_DCACHE_WORD_ACCESS=y
CONFIG_FS_IOMAP=y
CONFIG_EXT4_FS=y
CONFIG_EXT4_USE_FOR_EXT2=y
CONFIG_JBD2=y
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=m
CONFIG_REISERFS_FS_XATTR=y
CONFIG_JFS_FS=m
CONFIG_XFS_FS=m
CONFIG_BTRFS_FS=m
CONFIG_F2FS_FS=y
CONFIG_F2FS_STAT_FS=y
CONFIG_F2FS_FS_XATTR=y
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
CONFIG_FILE_LOCKING=y
CONFIG_FS_ENCRYPTION=y
CONFIG_FSNOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_FANOTIFY=y
CONFIG_AUTOFS4_FS=m
CONFIG_AUTOFS_FS=m
CONFIG_FUSE_FS=m
CONFIG_OVERLAY_FS=y
CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
CONFIG_OVERLAY_FS_XINO_AUTO=y
CONFIG_FSCACHE=m
CONFIG_FSCACHE_STATS=y
CONFIG_CACHEFILES=m
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_UDF_FS=m
CONFIG_FAT_FS=m
CONFIG_MSDOS_FS=m
CONFIG_VFAT_FS=m
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
CONFIG_NTFS_FS=m
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_STRIPPED=y
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_XATTR=y
CONFIG_MEMFD_CREATE=y
CONFIG_CONFIGFS_FS=m
CONFIG_MISC_FILESYSTEMS=y
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
CONFIG_JFFS2_FS=y
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
CONFIG_JFFS2_SUMMARY=y
CONFIG_JFFS2_FS_XATTR=y
CONFIG_JFFS2_COMPRESSION_OPTIONS=y
CONFIG_JFFS2_LZMA=y
CONFIG_JFFS2_RTIME=y
CONFIG_JFFS2_CMODE_PRIORITY=y
CONFIG_UBIFS_FS=y
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_FORMAT4=y
CONFIG_CRAMFS=m
CONFIG_CRAMFS_BLOCKDEV=y
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_FILE_DIRECT=y
CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU=y
CONFIG_SQUASHFS_XZ=y
CONFIG_SQUASHFS_EMBEDDED=y
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
CONFIG_MINIX_FS=m
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=m
CONFIG_NFS_V3=m
CONFIG_NFS_V4=m
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFSD=m
CONFIG_NFSD_V3=y
CONFIG_NFSD_V4=y
CONFIG_GRACE_PERIOD=m
CONFIG_LOCKD=m
CONFIG_LOCKD_V4=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=m
CONFIG_SUNRPC_GSS=m
CONFIG_RPCSEC_GSS_KRB5=m
CONFIG_CIFS=m
CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=m
CONFIG_NLS_CODEPAGE_775=m
CONFIG_NLS_CODEPAGE_850=m
CONFIG_NLS_CODEPAGE_852=m
CONFIG_NLS_CODEPAGE_862=m
CONFIG_NLS_CODEPAGE_864=m
CONFIG_NLS_CODEPAGE_866=m
CONFIG_NLS_CODEPAGE_936=m
CONFIG_NLS_CODEPAGE_950=m
CONFIG_NLS_CODEPAGE_932=m
CONFIG_NLS_ISO8859_8=m
CONFIG_NLS_CODEPAGE_1250=m
CONFIG_NLS_CODEPAGE_1251=m
CONFIG_NLS_ISO8859_1=m
CONFIG_NLS_ISO8859_2=m
CONFIG_NLS_ISO8859_6=m
CONFIG_NLS_ISO8859_13=m
CONFIG_NLS_ISO8859_15=m
CONFIG_NLS_KOI8_R=m
CONFIG_NLS_UTF8=m
CONFIG_KEYS=y
CONFIG_KEYS_COMPAT=y
CONFIG_SECURITY_DMESG_RESTRICT=y
CONFIG_SECURITYFS=y
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
CONFIG_HARDENED_USERCOPY=y
CONFIG_FORTIFY_SOURCE=y
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_XOR_BLOCKS=m
CONFIG_ASYNC_CORE=m
CONFIG_ASYNC_MEMCPY=m
CONFIG_ASYNC_XOR=m
CONFIG_ASYNC_PQ=m
CONFIG_ASYNC_RAID6_RECOV=m
CONFIG_CRYPTO=y
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_AKCIPHER2=m
CONFIG_CRYPTO_AKCIPHER=m
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_KPP=y
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_RSA=m
CONFIG_CRYPTO_ECDH=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=m
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
CONFIG_CRYPTO_PCRYPT=y
CONFIG_CRYPTO_WORKQUEUE=y
CONFIG_CRYPTO_AUTHENC=m
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=m
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=m
CONFIG_CRYPTO_CBC=y
CONFIG_CRYPTO_CTR=y
CONFIG_CRYPTO_CTS=y
CONFIG_CRYPTO_ECB=y
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_XTS=y
CONFIG_CRYPTO_CMAC=y
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_XCBC=m
CONFIG_CRYPTO_CRC32C=y
CONFIG_CRYPTO_CRC32=y
CONFIG_CRYPTO_GHASH=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=m
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_RMD160=m
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_TGR192=m
CONFIG_CRYPTO_WP512=m
CONFIG_CRYPTO_AES=y
CONFIG_CRYPTO_ANUBIS=m
CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_BLOWFISH_COMMON=m
CONFIG_CRYPTO_CAMELLIA=m
CONFIG_CRYPTO_CAST_COMMON=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_FCRYPT=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_TWOFISH_COMMON=m
CONFIG_CRYPTO_DEFLATE=y
CONFIG_CRYPTO_LZO=y
CONFIG_CRYPTO_LZ4=m
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
CONFIG_CRYPTO_USER_API=m
CONFIG_CRYPTO_USER_API_HASH=m
CONFIG_CRYPTO_USER_API_SKCIPHER=m
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_USER_API_AEAD=m
CONFIG_CRYPTO_HASH_INFO=y
CONFIG_CRYPTO_HW=y
CONFIG_CRYPTO_DEV_CCP=y
CONFIG_CRYPTO_DEV_CCP_DD=m
CONFIG_CRYPTO_DEV_SP_CCP=y
CONFIG_CRYPTO_DEV_CCP_CRYPTO=m
CONFIG_RAID6_PQ=m
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_RATIONAL=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_ARCH_HAS_FAST_MULTIPLIER=y
CONFIG_CRC_CCITT=m
CONFIG_CRC16=y
CONFIG_CRC_ITU_T=m
CONFIG_CRC32=y
CONFIG_CRC32_SARWATE=y
CONFIG_CRC7=m
CONFIG_LIBCRC32C=m
CONFIG_CRC8=m
CONFIG_XXHASH=m
CONFIG_AUDIT_ARCH_COMPAT_GENERIC=y
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_COMPRESS=m
CONFIG_LZ4_DECOMPRESS=m
CONFIG_ZSTD_COMPRESS=m
CONFIG_ZSTD_DECOMPRESS=m
CONFIG_XZ_DEC=y
CONFIG_LZMA_COMPRESS=y
CONFIG_LZMA_DECOMPRESS=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_NEED_SG_DMA_LENGTH=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_DMA_ADDR_T_64BIT=y
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_DMA_DIRECT_OPS=y
CONFIG_SWIOTLB=y
CONFIG_SGL_ALLOC=y
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_GLOB=y
CONFIG_NLATTR=y
CONFIG_CLZ_TAB=y
CONFIG_CORDIC=m
CONFIG_MPILIB=m
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=m
CONFIG_SG_POOL=y
CONFIG_ARCH_HAS_SG_CHAIN=y
CONFIG_SBITMAP=y
CONFIG_PRINTK_TIME=y
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=15
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=7
CONFIG_FRAME_WARN=1024
CONFIG_STRIP_ASM_SYMS=y
CONFIG_DEBUG_FS=y
CONFIG_OPTIMIZE_INLINING=y
CONFIG_ARCH_WANT_FRAME_POINTERS=y
CONFIG_FRAME_POINTER=y
CONFIG_DEBUG_KERNEL=y
CONFIG_HAVE_DEBUG_KMEMLEAK=y
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
CONFIG_HAVE_ARCH_KASAN=y
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
CONFIG_PANIC_ON_OOPS=y
CONFIG_PANIC_ON_OOPS_VALUE=1
CONFIG_PANIC_TIMEOUT=1
CONFIG_LOCK_DEBUGGING_SUPPORT=y
CONFIG_HAVE_DEBUG_BUGVERBOSE=y
CONFIG_RCU_CPU_STALL_TIMEOUT=60
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACING_SUPPORT=y
CONFIG_RUNTIME_TESTING_MENU=y
CONFIG_TEST_BPF=m
CONFIG_HAVE_ARCH_KGDB=y
CONFIG_ARCH_HAS_UBSAN_SANITIZE_ALL=y
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
It seems my EMMC and GPT partition not detected correctly. Missing that log:
[    3.162069] mmc0: new HS200 MMC card at address 0001
[    3.167299] mmcblk mmc0:0001: no of_node; not parsing pinctrl DT
[    3.174505] mmcblk0: mmc0:0001 008G30 7.28 GiB
[    3.180061] mmcblk0boot0: mmc0:0001 008G30 partition 1 4.00 MiB
[    3.187027] mmcblk0boot1: mmc0:0001 008G30 partition 2 4.00 MiB
[    3.193276] mmcblk0rpmb: mmc0:0001 008G30 partition 3 4.00 MiB, chardev (250:0)
[    3.203089] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    3.210725] GPT:1 != 15269887
[    3.213777] GPT:Alternate GPT header not at the end of the disk.
[    3.219975] GPT:1 != 15269887
[    3.223028] GPT: Use GNU Parted to correct GPT errors.
[    3.228341]  mmcblk0: p1 p2 p3 p4 p5
Should I flash the emmc_singleimage.img first?
   1.First flash the emmc_singleimage.img.
    2.Then flash the preloader preloader_emmc.bin.
    3.Then flash the emmc_openmptcprouter.img.
Could you please provide the uboot log and printenv?
I will rebuild the omr by your kernel config, and try again.
Thank you for your help!
You could try gdisk to fix gpt-errors…maybe parted
Short answer: No. This img-file contains these parts:
  1. GPT
  2. ATF
  3. U-boot
  4. Kernel
  5. RootFS
Only 1-3 you need from the file emmc_singleimage.img and these parts fit just in 2048kB (2MB). But! GPT layout of emmc_singleimage.img has only 20M for a ‘boot’ partition:
Number  Start (sector)    End (sector)  Size       Code  Name
   1            1024            1535   256.0 KiB   8300  tee1
   2            1536            2559   512.0 KiB   8300  lk
   3            2560            3583   512.0 KiB   8300  nvram
   4            3584            4095   256.0 KiB   8300  rf
   5            4096           45055   20.0 MiB    8300  boot
The ‘boot’ partition of GPT in our case is a partition contains Firmware (OpenWRT Kernel + RootFS as squashfs) – 4-5 items of the img. So if the Firmware is more 20M (our case) you need to extend ‘boot’, for example, to 64M.
Sure. List 3 below.
BTW you can flash only Firmware part (*squashfs-sysupgrade.bin) via “2. System Load Linux Kernel then write to Flash via TFTP.” instead “b. System Load flashimage then write to Flash via TFTP.”. This case your U-boot env will not rewrite any time you flash new OpenWRT build.
List 3 (U-boot env)
MT7622> printenv
arch=arm
atf_filename=trustzone.bin
baudrate=115200
board=mt7622_evb
board_name=mt7622_evb
boot0=download_setting kernel;tftpboot ${loadaddr} ${kernel_filename}; bootm
boot1=download_setting kernel;tftpboot ${loadaddr} ${kernel_filename};run boot_wr_img
boot10=download_setting flashimage;tftpboot ${loadaddr} ${flashimage_filename};run wr_flashimage
boot11=download_setting gpt;tftpboot ${loadaddr} ${gpt_filename};run wr_gpt
boot2=run boot_rd_img;bootm
boot3=download_setting uboot;tftpboot ${loadaddr} ${uboot_filename};run wr_uboot;invaild_env
boot4=loadb;run wr_uboot;invaild_env
boot5=download_setting atf;tftpboot ${loadaddr} ${atf_filename};run wr_atf
boot6=download_setting preloader;tftpboot ${loadaddr} ${preloader_filename};run wr_pl
boot7=download_setting hdr;tftpboot ${loadaddr} ${hdr_filename};run wr_rom_hdr
boot8=download_setting ctp;tftpboot ${loadaddr} ${ctp_filename};run wr_ctp
boot9=run boot_rd_ctp;boot_to_ctp
boot_rd_ctp=mmc device 0;mmc read ${loadaddr} 0x1000 0xa000
boot_rd_img=mmc device 0;mmc read ${loadaddr} 0x1000 1;image_blks 512;mmc read ${loadaddr} 0x1000 ${img_blks}
boot_wr_img=filesize_check 0x5000000;if test ${filesize_result} = good; then image_blks 512  ${filesize};mmc device 0;mmc write ${loadaddr} 0x1000 0x18000;fi
bootargs=console=ttyS0,115200n1 rootfstype=squashfs earlyprintk block2mtd.block2mtd=/dev/mmcblk0,65536,eMMC,5 mtdparts=eMMC:768k(mbr)ro,512k(uboot),512k(Config),256k(Factory),64M(Kernel),2048M(usrdata)
bootcmd=No
bootdelay=3
bootfile=iverson_uImage
bootmenu_0=1. System Load Linux to SDRAM via TFTP.=run boot0
bootmenu_1=2. System Load Linux Kernel then write to Flash via TFTP.=run boot1
bootmenu_10=b. System Load flashimage then write to Flash via TFTP.=run boot10
bootmenu_11=c. System Load partition table then write to Flash via TFTP.=run boot11
bootmenu_2=3. Boot system code via Flash.=run boot2
bootmenu_3=4. System Load U-Boot then write to Flash via TFTP.=run boot3
bootmenu_4=5. System Load U-Boot then write to Flash via Serial.=run boot4
bootmenu_5=6. System Load ATF then write to Flash via TFTP.=run boot5
bootmenu_6=7. System Load Preloader then write to Flash via TFTP.=run boot6
bootmenu_7=8. System Load ROM header then write to Flash via TFTP.=run boot7
bootmenu_8=9. System Load CTP then write to Flash via TFTP.=run boot8
bootmenu_9=a. System Load CTP then Boot to CTP (via Flash).=run boot9
bootmenu_delay=30
cpu=armv7
ctp_filename=ctp.bin
ethact=mtk_eth
ethaddr=00:0C:E7:11:22:33
fdt_high=0x6c000000
flashimage_filename=flashimage.bin
gpt_filename=GPT_EMMC
hdr_filename=hdr.binary
invaild_env=no
ipaddr=192.168.100.1
kernel_filename=openwrt-mediatek-mt7622-BPI-R64-initramfs-kernel.bin
loadaddr=0x4007FF28
preloader_filename=preloader_fpga7622_64_ldvt.bin
serverip=192.168.100.2
soc=mt7622
stderr=serial
stdin=serial
stdout=serial
uboot_filename=u-boot-mtk.bin
vendor=mediatek
wr_atf=filesize_check 0x40000;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x400 0x200;fi
wr_ctp=filesize_check 0x1400000;if test ${filesize_result} = good; then ctp_check;if test ${ctp_result} = good; then mmc device 0;mmc write ${loadaddr} 0x1000 0xa000;reset; fi;fi
wr_flashimage=filesize_check 0x5000000;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x0 0x18000;fi
wr_gpt=filesize_check 0x4400;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x0 0x22;fi
wr_pl=filesize_check 0x40000;if test ${filesize_result} = good; then mmc device 0; mmc write ${loadaddr} 0x0 0x200 emmc_preloader;fi
wr_rom_hdr=filesize_check 0xA000;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x0 0x50;fi
wr_uboot=filesize_check 0x80000;if test ${filesize_result} = good; then mmc device 0;mmc write ${loadaddr} 0x600 0x400;fi
Environment size: 3912/4092 bytes
Does this mean you do not need head0/1 and sd-preloader? In my test i need these 3 to boot into uboot from emmc
Well… this list is my assumption. But I guess the header and the preloader you mean are contained iside other file – “preloader_emmc.bin”, and it’s flashed once, regardless of the main img.
Here is “preloader_emmc.bin” ( eMMC preloader):
As I understand if we look at the dev dir inside linux, “preloader_emmc.bin” is flashed to the “mmcblk0boot0”, and “emmc_singleimage.img” is flashed to the “mmcblk0”:
root@OpenWrt:/# ll /dev/mmcblk0*
brw-------    1 root     root      179,   0 Jan  1 23:33 /dev/mmcblk0
brw-------    1 root     root      179,   8 Jan  1 23:33 /dev/mmcblk0boot0
brw-------    1 root     root      179,  16 Jan  1 23:33 /dev/mmcblk0boot1
brw-------    1 root     root      179,   1 Jan  1 23:33 /dev/mmcblk0p1
brw-------    1 root     root      179,   2 Jan  1 23:33 /dev/mmcblk0p2
brw-------    1 root     root      179,   3 Jan  1 23:33 /dev/mmcblk0p3
brw-------    1 root     root      179,   4 Jan  1 23:33 /dev/mmcblk0p4
brw-------    1 root     root      179,   5 Jan  1 23:33 /dev/mmcblk0p5
crw-------    1 root     root      250,   0 Jan  1 23:33 /dev/mmcblk0rpmb
Then the other headers are maybe in the single image because they have to be on user-partition (mmcblkx) not boot0. Ok,just wondered about…back to topic :slight_smile:
Where is your kernel .config coming from? ./build_dir/target-aarch64_cortex-a53_musl/linux-mediatek_mt7622/linux-4.19.72/.config? Could you please share the original kernel .config? It seems your .config file is not complete, it’s very difficult to do merge.
Drop lines beginning with #,append to yours and use it with oldconfig (don’t know how thos can be done in openwrt). In worst case us the merged file as defconfig
Here you are (./build_dir/target-aarch64_cortex-a53_musl/linux-mediatek_mt7622/linux-4.19.72/.config). Is this file you need? I’m still not so familiar with it as I want…
I have made an experiment :slight_smile: . I erased step by step parts of img (dd if=/dev/zero … conv=notrunc) and wrote instead of them meaningful files. So that is I know about mmcblk0 (bs=1k):
start   size   partition (name)     Purpose
0         17                        GPT layout
18       495                        - nothing -
512      256   mmcblk0p1 (tee1)     ATF
768      512   mmcblk0p2 (lk)       U-boot
1280     512   mmcblk0p3 (nvram)    U-boot env
1792     256   mmcblk0p4 (rf)       - nothing -
2048   20480   mmcblk0p5 (boot)     Kernel + squashfs RootFS
I can build and load the omr image to R64 now. Must select three items in the kernel menuconfig:
"Device Drivers"-->"Memory Technology Device (MTD) support"-->"Command line partition table parsing"
"Device Drivers"-->"Memory Technology Device (MTD) support""Self-contained MTD device drivers"-->"MTD using block device"
"Device Drivers"-->"MMC/SD/SDIO card suport"->"MMC block device driver"
But it seems the Soc wifi not working, it work with the emmc_singleimage.img image.
I think you need to add MT7615 module:
From this:
The mt7615 wifi was imho dropped in hw rev 1.x due to heat and power consumption. Was not working before because driver has not supported it.
The mt7622 Soc included wifi chip is not mt7615e. My R64 board is V1.1, and the LEDE in emmc_singleimage.img image included the mt7622 onboard wifi driver.
