[BPI-R64] Kernel-Development
@Ilya_Murav_jov
i have applied your patches to new branch 5.4-deb with changes for r2 (using uImage instead of uImage_nodt). have not tested much due to less time
https://github.com/frank-w/BPI-R2-4.14/tree/5.4-deb
Ok, wan works. About lanX, I couldn’t use them with dnsmasq to connect clients to the BPI, do you mean it is not ready now? My configs is:
sa@bpi-r64:~$ cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
  address 192.168.2.1/24
auto wan
iface wan inet dhcp
sa@bpi-r64:~$ cat /etc/dnsmasq.d/interfaces.conf
# netgear has them
min-port=4096
stop-dns-rebind
rebind-localhost-ok
dhcp-lease-max=255
dhcp-authoritative
interface=lan0
dhcp-range=tag:lan0,192.168.2.2,192.168.2.51,255.255.255.0,24h
#$ dnsmasq --help dhcp | grep router | head -1
#  3 router
dhcp-option=tag:lan0,option:router,192.168.2.1
Earlier I used eth0 in dnsmasq’ config and that worked, now I tried lanX instead and failed.
About internal Wifi, yes sometimes reloading works, but in most cases not
root@bpi-r64:~# modprobe -r mt7622 && modprobe mt7622
[40856.429436] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[40856.449097] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[40856.456377] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[40856.474745] cfg80211: failed to load regulatory.db
[40856.586232] mt7622_wmac 18000000.wmac: ASIC revision: 76220010
[40856.593122] mt7622_wmac 18000000.wmac: Invalid MAC address, using random address 56:06:94:79:d5:a9
[40856.604258] mt7622_wmac 18000000.wmac: MAC addr = 56:06:94:79:d5:a9
[40866.830724] mt7622_wmac 18000000.wmac: Message -16 (seq 1) timeout
[40866.837183] mt7622_wmac 18000000.wmac: Failed to get patch semaphore
[40866.844977] mt7622_wmac: probe of 18000000.wmac failed with error -11
The tag: looks wrong
Here is my config for r2…should work for r64 too
http://fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:network:start#dhcp
Have you set them up via interfaces/manual? For dhcp you should set fixed ip to lanport and run dnsmasq on this interface with same subnet and extending range
For wifi…if i understand you right it sounds like timing issue…maybe we can fix it with a delay before semaphore/firmware-load
My R64 after some time of working (1-2 days) throws the following, and after that I cannot use ethernet till I restart the system:
[251882.580012] ------------[ cut here ]------------
[251882.580298] NETDEV WATCHDOG: eth0 (mtk_soc_eth): transmit queue 0 timed out
[251882.580669] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:448 dev_watchdog+0x10c/0x164
[251882.580705] Modules linked in: wireguard ip6_udp_tunnel udp_tunnel ctr aes_generic ccm btmtkuart bluetooth ecdh_generic ecc zram mt7622 mt76 mac80211 libarc4 cfg80211 rfkill libaes nft_masq nft_chain_nat nfs
[251882.581184] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.24-bpi-r64-main #1
[251882.581217] Hardware name: Bananapi BPI-R64 (DT)
[251882.581298] pstate: 80000005 (Nzcv daif -PAN -UAO)
[251882.581351] pc : dev_watchdog+0x10c/0x164
[251882.581401] lr : dev_watchdog+0x10c/0x164
[251882.581431] sp : ffffffc010003d90
[251882.581464] x29: ffffffc010003d90 x28: 0000000000000002
[251882.581523] x27: ffffffc010003e50 x26: ffffffc01058cb70
[251882.581580] x25: 0000000000000000 x24: dead000000000122
[251882.581638] x23: ffffffc010003e50 x22: 0000000000000000
[251882.581695] x21: ffffff8003056fb8 x20: ffffff8003057000
[251882.581752] x19: ffffff80030573b8 x18: 000000000000000a
[251882.581808] x17: 00000000aae019fb x16: 00000000dba08a2f
[251882.581864] x15: 0000000000000000 x14: ffffffc0109e2221
[251882.581920] x13: 0000000000020000 x12: ffffffc010947000
[251882.581977] x11: ffffffc0109e1e43 x10: 0000000000000060
[251882.582033] x9 : 00000000000001b7 x8 : ffffff803fdb17e0
[251882.582090] x7 : ffffff803fdb17e0 x6 : 0000000000000001
[251882.582145] x5 : 0000000000000000 x4 : 0000000000000000
[251882.582200] x3 : 0000000000000040 x2 : ffffffc01093dcc0
[251882.582257] x1 : f17ec003da64a800 x0 : 0000000000000000
[251882.582310] Call trace:
[251882.582370]  dev_watchdog+0x10c/0x164
[251882.582430]  call_timer_fn.isra.31+0x20/0x74
[251882.582482]  __run_timers.part.32+0x1c8/0x1f4
[251882.582532]  run_timer_softirq+0x4c/0x88
[251882.582580]  __do_softirq+0x208/0x250
[251882.582626]  irq_exit+0x7c/0xc0
[251882.582685]  __handle_domain_irq+0x6c/0x98
[251882.582728]  gic_handle_irq+0x70/0xac
[251882.582773]  el1_irq+0xb8/0x180
[251882.582832]  arch_cpu_idle+0x1c/0x2c
[251882.582890]  default_idle_call+0x28/0x2c
[251882.582943]  do_idle+0xd8/0xf4
[251882.582995]  cpu_startup_entry+0x20/0x3c
[251882.583041]  rest_init+0xcc/0xd8
[251882.583088]  arch_call_rest_init+0xc/0x14
[251882.583132]  start_kernel+0x39c/0x3c8
[251882.583203] ---[ end trace d5ebce17defcc6a1 ]---
[251882.583372] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[251882.592130] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[251882.607139] ------------[ cut here ]------------
[251882.607184] refcount_t: underflow; use-after-free.
[251882.607454] WARNING: CPU: 0 PID: 17464 at lib/refcount.c:190 refcount_sub_and_test_checked+0x90/0xcc
[251882.607483] Modules linked in: wireguard ip6_udp_tunnel udp_tunnel ctr aes_generic ccm btmtkuart bluetooth ecdh_generic ecc zram mt7622 mt76 mac80211 libarc4 cfg80211 rfkill libaes nft_masq nft_chain_nat nfs
[251882.607964] CPU: 0 PID: 17464 Comm: kworker/0:0 Tainted: G        W         5.4.24-bpi-r64-main #1
[251882.607997] Hardware name: Bananapi BPI-R64 (DT)
[251882.608069] Workqueue: events mtk_pending_work
[251882.608131] pstate: 80000005 (Nzcv daif -PAN -UAO)
[251882.608197] pc : refcount_sub_and_test_checked+0x90/0xcc
[251882.608259] lr : refcount_sub_and_test_checked+0x90/0xcc
[251882.608289] sp : ffffffc01698bcd0
[251882.608322] x29: ffffffc01698bcd0 x28: 0000000000000000
[251882.608380] x27: 0000000000000140 x26: 00000000ffffffff
[251882.608436] x25: 0000000000000000 x24: ffffff803e029a80
[251882.608493] x23: ffffff803e208000 x22: ffffff803e2087c0
[251882.608549] x21: 0000000000000001 x20: ffffff803e029a00
[251882.608605] x19: ffffffc010938000 x18: 0000000000000000
[251882.608660] x17: 0000000000000000 x16: 0000000000000000
[251882.608714] x15: 0000000000000000 x14: ffffffc010011000
[251882.608771] x13: 0000000000020000 x12: ffffffc010947000
[251882.608827] x11: ffffffc0109e1e41 x10: 0000000000000048
[251882.608882] x9 : 00000000000001e4 x8 : ffffffc0109e14a0
[251882.608938] x7 : ffffffc010938588 x6 : ffffff803fdb17d8
[251882.608992] x5 : 0000000000000006 x4 : 0000000000000001
[251882.609048] x3 : ffffff803fdb17d8 x2 : ffffff803d966600
[251882.609134] x1 : f17ec003da64a800 x0 : 0000000000000000
[251882.609187] Call trace:
[251882.609257]  refcount_sub_and_test_checked+0x90/0xcc
[251882.609318]  refcount_dec_and_test_checked+0x14/0x1c
[251882.609365]  mtk_stop+0x78/0x12c
[251882.609414]  mtk_pending_work+0xd8/0x250
[251882.609464]  process_one_work+0x16c/0x1d8
[251882.609508]  worker_thread+0x1d4/0x264
[251882.609562]  kthread+0xd0/0xe0
[251882.609616]  ret_from_fork+0x10/0x18
[251882.609655] ---[ end trace d5ebce17defcc6a2 ]---
[251882.640941] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[251882.641120] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[251882.641807] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[251882.641958] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[251978.579836] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[251978.582037] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[251978.582435] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[251978.616700] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[251978.616879] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[251978.617466] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[251978.617559] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[252068.691822] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252068.700096] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252068.701226] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252068.746232] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252068.746412] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252068.746991] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252068.747083] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[252159.571830] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252159.584304] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252159.584628] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252159.634317] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252159.634506] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252159.635064] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252159.635157] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[252250.451788] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252250.453015] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252250.453406] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252250.486435] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252250.486615] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252250.487228] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252250.487321] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[252346.451775] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252346.453921] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252346.454376] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252346.487521] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252346.489330] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252346.490026] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252346.490121] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[252442.451751] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252442.460138] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252442.461357] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252442.506162] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252442.506343] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252442.506960] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252442.507054] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[252533.587912] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252533.598484] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252533.598843] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252533.630353] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252533.630530] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252533.631080] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252533.631172] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[252623.699731] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252623.701565] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252623.701872] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252623.735333] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252623.735509] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252623.738056] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252623.738160] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
root@bananapir64:~#
root@bananapir64:~# [252778.579679] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252778.581785] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252778.587203] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252778.619884] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252778.620067] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252778.620602] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252778.620693] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[252938.579660] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[252938.580824] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[252938.581158] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[252938.614281] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[252938.614460] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[252938.614994] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[252938.615087] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
root@bananapir64:~#
root@bananapir64:~#
root@bananapir64:~# �з�ш
root@bananapir64:~# ping lenta.ru
^C
root@bananapir64:~# [253087.571640] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[253087.573068] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[253087.573385] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[253087.606326] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[253087.606512] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[253087.607032] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[253087.607124] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[253242.451614] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[253242.452843] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[253242.453159] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[253242.486184] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[253242.486365] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[253242.486917] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[253242.487010] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[253397.587583] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[253397.598019] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[253397.598380] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[253397.630202] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[253397.630379] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[253397.630936] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[253397.631030] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[253546.579549] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[253546.580730] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[253546.587190] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[253546.620911] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[253546.621092] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[253546.621635] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[253546.621727] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[253695.571534] mtk_soc_eth 1b100000.ethernet eth0: transmit timed out
[253695.572707] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[253695.573022] mtk_soc_eth 1b100000.ethernet eth1: Link is Down
[253695.621953] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[253695.622136] mtk_soc_eth 1b100000.ethernet eth1: configuring for fixed/rgmii link mode
[253695.622675] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[253695.622767] mtk_soc_eth 1b100000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
The kernel is 5.4 from @frank-w repo,
root@bananapir64:~# cat /etc/network/interfaces
auto lo
auto eth0
# need to up it AND before lanX/br0 => manual is just fine for it
iface eth0 inet manual
auto br0
iface br0 inet static
  bridge_ports lan1 lan2 lan3
  address 172.30.1.1/25
auto wan
iface wan inet dhcp
# router0 is renamed from lan0
auto router0
iface router0 inet manual
#auto wlan0
#iface wlan0 inet static
#  address 172.30.1.129/25
What does this error mean?
Hmm, something wrong with
$ grep -C3 "only shutdown DMA" ./drivers/net/ethernet/mediatek/mtk_eth_soc.c
        phylink_disconnect_phy(mac->phylink);
        /* only shutdown DMA if this is the last user */
        if (!refcount_dec_and_test(&eth->dma_refcnt)) <======
                return 0;
Afair 5.4 has no second gmac support…so no eth1.
Could you try if network is broken on 5.6-main? I have 3 patches merged that were missing while phylink conversion
Thanks, I’ll try.
By the way, what is gmac and why one doesn’t suffice?
Gmac is the ethernet-lane between soc and switch. There are 2,but gmac #0 on r64 works in sgmii-mode (2.5gbit/s) where the other supports only rgmii (1gbit/s). On r64 basicly 1 is enough for common uses…currently dsa-framework does not support more than 1. So i wonder why your output shows 2…i guess you use the older openwrt driver i had in my repo till 5.4 was released. This had not used dsa-framework and hardwired lan-ports to eth0 and wan to eth1
No, I don’t use touch eth1 myself
root@bananapir64:~# uname -a
Linux bananapir64 5.4.24-bpi-r64-main #1 SMP PREEMPT Thu Mar 5 23:05:33 MSK 2020 aarch64 GNU/Linux
root@bananapir64:~# ip link list eth1
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether 42:0a:f8:7c:c5:3d brd ff:ff:ff:ff:ff:ff
I’ll check it again.
Can you show uname -r? That should be 5.4-rcx
root@bananapir64:~# uname -r
5.4.24-bpi-r64-main
Most likely the kernel is from https://github.com/frank-w/BPI-R2-4.14/releases
mhm, ok, i see in r64 dts that second gmac is defined but not defined on switch-side (port 5), so it appears in “ip a” but it’s not usable
I am using 5.6-main now, it is ok (now, without wifi=mt7622.ko).
right, have not merged mt7622 wifi-driver to this tree due to missing freetime, but your watchdog-warning/crash was in ethernet-driver ( mtk_soc_eth)
if it is working you can try adding these 2 Patches to 5.4:
05f57ab128ce net: ethernet: mediatek: move mt7623 settings out off the mt7530
903987b837eb net: dsa: mt7530: move mt7623 settings out off the mt7530
currently try to add mt7622, changed Kconfig/Makefile to new folder containing driver, but still old folder is used :thinking:
edit: have found the problem…mt76_new/Kconfig still referred the Kconfig in mt76/* have fixed it and do a test-build and then upload. btw. have added the 2 Patches from rene in 5.4-main
You mean 5.6 I think… Ok, but i’ll wait one more day or two to see if it is working more stable than 5.4
no, 5.6-main already had these 2 Patches (git log is from this branch), had now added them to 5.4-main too
have now uploaded my work including newer mt76-driver with mt7622, but imho dts node have to be added
https://github.com/frank-w/BPI-R2-4.14/commit/142162b7482b26c62c9b4411e7ed014e4927378e
As offtop. Frank can you explain me. How to use this repository. This is not Linux OS, this is Linux core. If I want to use it, what I should to do? I am Windows user and for me only OS core is very unusual thing.
Have not tried with windows yet…you need to look what build.sh does for r64…
Basicly this:
ARCH=arm64 make mt7622_bpi-r64_defconfig
ARCH=arm64 make menuconfig
ARCH=arm64 make
mkimage -A armhf -O linux -T kernel -C none -a 40080000 -e 40080000 -n "Linux Kernel $kernver" -d arch/arm64/boot/Image ./uImage_nodt
cp arch/arm64/boot/dts/mediatek/mt7622-bananapi-bpi-r64.dtb bpi-r64.dtb
Maybe it’s easier to setup an ubuntu virtual machine in windows and work in this
I am don’t understan yet. If I run build.sh I am get image which I can use on Banaba PI. Or I get file witch I should add to another repository, for receive Linux OS image.
The repo is linux-kernel only (and some tools,firmware). You can use my debian/ubuntu-image as base and use build.sh to install the built kernel on sdcard
I am apologize.But what to do with Linux kernel? This is not Linux OS. How to use It?
