[BPI-R64] Kernel-Development
While working on wifi, i replaced firmware file,now bluetooth seems to work…
Got also wifi working:
All in my 5.4-r64-rc branch which will be soon renamed to main (maybe squashing build.sh commits)
If anyone wants to test…remember copying firmware-files to /lib/firmware/mediatek
kernel 5.4 is now finally released so i have updated my repo and added 5.4-r64-main and uploaded binary-kernels on my gdrive
https://drive.google.com/drive/folders/1SRUhYQqs5Jg_lKqgMfUlwSX4dG5T6qPZ
good news, on Patchwork/Mailinglist there was a DSA-driver for mt7531 released…i added it to this branch and made a quick test:
details
root@bpi-r64:~# uname -a
Linux bpi-r64 5.5.0-rc1-bpi-r64-netnext #9 SMP PREEMPT Tue Dec 10 11:59:07 CET 2019 aarch64 GNU/Linux
root@bpi-r64:~# ip a
    link/ether 12:9b:2c:56:cd:f0 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether b6:2e:63:86:9e:98 brd ff:ff:ff:ff:ff:ff
4: wan@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
5: lan0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.0.19/24 scope global lan0
6: lan1@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
7: lan2@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
8: lan3@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
root@bpi-r64:~# ping -c4 192.168.0.10
PING 192.168.0.10 (192.168.0.10) 56(84) bytes of data.
64 bytes from 192.168.0.10: icmp_seq=1 ttl=64 time=0.498 ms
64 bytes from 192.168.0.10: icmp_seq=2 ttl=64 time=0.371 ms
64 bytes from 192.168.0.10: icmp_seq=3 ttl=64 time=0.487 ms
64 bytes from 192.168.0.10: icmp_seq=4 ttl=64 time=0.458 ms
--- 192.168.0.10 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 81ms
rtt min/avg/max/mdev = 0.371/0.453/0.498/0.054 ms
root@bpi-r64:~#
root@bpi-r64:~# iperf3 -c 192.168.0.21
Connecting to host 192.168.0.21, port 5201
[  5] local 192.168.0.19 port 56412 connected to 192.168.0.21 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec   114 MBytes   957 Mbits/sec    0   1003 KBytes
[  5]   1.00-2.00   sec   113 MBytes   944 Mbits/sec    0   1.08 MBytes
[  5]   2.00-3.00   sec   112 MBytes   941 Mbits/sec    0   1.08 MBytes
[  5]   3.00-4.00   sec   112 MBytes   941 Mbits/sec    0   1.08 MBytes
[  5]   4.00-5.00   sec   112 MBytes   942 Mbits/sec    0   1.08 MBytes
[  5]   5.00-6.00   sec   112 MBytes   944 Mbits/sec    0   1.21 MBytes
[  5]   6.00-7.00   sec   112 MBytes   944 Mbits/sec    0   1.27 MBytes
[  5]   7.00-8.00   sec   112 MBytes   943 Mbits/sec    0   1.27 MBytes
[  5]   8.00-9.00   sec   111 MBytes   934 Mbits/sec    0   1.27 MBytes
[  5]   9.00-10.00  sec   112 MBytes   944 Mbits/sec    0   1.27 MBytes
[  5]   0.00-10.00  sec  1.10 GBytes   943 Mbits/sec    0             sender
[  5]   0.00-10.00  sec  1.10 GBytes   941 Mbits/sec                  receiver
iperf Done.
root@bpi-r64:~# iperf3 -c 192.168.0.21 -R
Reverse mode, remote host 192.168.0.21 is sending
[  5] local 192.168.0.19 port 56416 connected to 192.168.0.21 port 5201
[  5]   0.00-1.00   sec   112 MBytes   941 Mbits/sec
[  5]   1.00-2.00   sec   111 MBytes   932 Mbits/sec
[  5]   3.00-4.00   sec   112 MBytes   938 Mbits/sec
[  5]   4.00-5.00   sec   112 MBytes   941 Mbits/sec
[  5]   5.00-6.00   sec   112 MBytes   941 Mbits/sec
[  5]   6.00-7.00   sec   112 MBytes   938 Mbits/sec
[  5]   7.00-8.00   sec   112 MBytes   941 Mbits/sec
[  5]   8.00-9.00   sec   112 MBytes   937 Mbits/sec
[  5]   9.00-10.00  sec   112 MBytes   941 Mbits/sec
[  5]   0.00-10.00  sec  1.10 GBytes   942 Mbits/sec  617             sender
[  5]   0.00-10.00  sec  1.09 GBytes   939 Mbits/sec                  receiver
iperf Done.
root@bpi-r64:~#
have managed to backport to 5.4:
i added the timeout-loop (waiting for MT7531_SGMII_LINK_STATUS) from the other mt7531-phy-driver, but the driver seem to have same SGMII-timeout if loaded from local storage…
this loop seems to break functionality if sgmii is not initialized before (uboot tftp). I have reverted it and it works again. Retransmitts were caused by my local switch config (flowcontrol is disabled by default…after set to autonegotiate/on on both ports no retransmitts happen)
Hi Frank,
I tested your image with kernel 5.4+buster and wanted to get internet via Wifi (client mode!) for BPI-R64, but failed.
Is it possible to fix that?
I dont have /dev/rfkill, by the way, maybe that is the root cause. The same command at my computer x86 works (I get connection via Wifi).
root@bpi-r64:~# wpa_supplicant -i wlan0 -c <(wpa_passphrase catbo passphrase)
Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
wlan0: SME: Trying to authenticate with cc:2d:21:14:60:81 (SSID='catbo' freq=2437 MHz)
nl80211: Failed to open /proc/sys/net/ipv6/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
nl80211: Failed to set IPv6 unicast in multicast filter
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="catbo" auth_failures=1 duration=10 reason=CONN_FAILED
^Cnl80211: Failed to open /proc/sys/net/ipv6/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
wlan0: CTRL-EVENT-TERMINATING
root@bpi-r64:~#
dmesg at the same time:
[104448.297511] wlan0: authenticate with cc:2d:21:14:60:81
[104448.349616] wlan0: send auth to cc:2d:21:14:60:81 (try 1/3)
[104448.361821] wlan0: send auth to cc:2d:21:14:60:81 (try 2/3)
[104448.373934] wlan0: send auth to cc:2d:21:14:60:81 (try 3/3)
[104448.386182] wlan0: authentication with cc:2d:21:14:60:81 timed out
[104452.541424] wlan0: authenticate with cc:2d:21:14:60:81
[104452.593539] wlan0: send auth to cc:2d:21:14:60:81 (try 1/3)
[104452.605874] wlan0: send auth to cc:2d:21:14:60:81 (try 2/3)
[104452.617989] wlan0: send auth to cc:2d:21:14:60:81 (try 3/3)
[104452.630210] wlan0: authentication with cc:2d:21:14:60:81 timed out
[104457.185530] wlan0: authenticate with cc:2d:21:14:60:81
[104457.237700] wlan0: send auth to cc:2d:21:14:60:81 (try 1/3)
[104457.249998] wlan0: send auth to cc:2d:21:14:60:81 (try 2/3)
[104457.262245] wlan0: send auth to cc:2d:21:14:60:81 (try 3/3)
[104457.274466] wlan0: authentication with cc:2d:21:14:60:81 timed out
[104462.333487] wlan0: authenticate with cc:2d:21:14:60:81
[104462.385575] wlan0: send auth to cc:2d:21:14:60:81 (try 1/3)
[104462.397729] wlan0: send auth to cc:2d:21:14:60:81 (try 2/3)
[104462.410166] wlan0: send auth to cc:2d:21:14:60:81 (try 3/3)
[104462.422325] wlan0: authentication with cc:2d:21:14:60:81 timed out
I have not tested client-mode.maybe it is not implemented. You should ask in mt7622 wifi thread
Have you tried searching in menuconfig of kernel for rfkill? Imho there is such option…maybe it’s required for client mode
Meanwhile I use your image with Debian. A little bit later I try to rebuild the thing
@Ilya_Murav_jov have added rfkill to 5.4-main…clientmode works in my quick test
@jasmin have you an idea hoe to define pwm-gpio’s? [BPI-R64] Kernel-Development or maybe how to get poweroff working?
Thanks, I’ll try.
Finally I managed to build and test 5.4-main branch, and with dkms built wireguard too.
sa@bpi-r64:~$ sudo ip link add dev wg0 type wireguard
sa@bpi-r64:~$ sudo wg
interface: wg0
Client tools I got from Debian testing, but wireguard.ko requires building. For convenience I used fpm to build linux-headers deb, and after recompling fixdep/modpost I got success, but it is long and errorprone.
After all I found another way to build:
ARCH=arm64 CROSS_COMPILE='ccache aarch64-linux-gnu-' make bindeb-pkg
and got almost at once
$ ls -1 *.deb
linux-headers-5.4.0-bpi-r64+_5.4.0-bpi-r64+-4_arm64.deb
linux-image-5.4.0-bpi-r64+_5.4.0-bpi-r64+-4_arm64.deb
linux-libc-dev_5.4.0-bpi-r64+-4_arm64.deb
At least linux-headers (the main target as it is needed for dkms) is usable. I think, after tweaking, it would be nice to put linux-headers.deb along other artifacts to https://github.com/frank-w/BPI-R2-4.14/releases with CI.
How did you create linux-headers deb from linux source of my repo? Imho version is wrong (should be 5.4.12+).
As I said it was not an easy way:
git checkout 5.4-r64-main
bash build.sh importconfig
bash build.sh build
bash build.sh cryptodev
bash build.sh pack
fpm -v 5.4.0-bpi-r64-r64-main -f --prefix=/ -a arm64 -p ../SD -s dir -t deb --name linux-headers-5.4.0-bpi-r64-r64-main --description "Header files related to Linux kernel version 5.4.0-bpi-r64-r64-main" \
./.config=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/.config \
./.missing-syscalls.d=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/.missing-syscalls.d \
./Kbuild=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/Kbuild \
./Kconfig=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/Kconfig \
./Makefile=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/Makefile \
./Module.symvers=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/Module.symvers \
./include=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/ \
./arch/arm64/include=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/arch/arm64/ \
./arch/arm64/Makefile=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/arch/arm64/ \
./arch/arm64/kernel/module.lds=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/arch/arm64/kernel/ \
./scripts=/usr/src/linux-headers-5.4.0-bpi-r64-r64-main/ \
dpkg-deb -I ../SD/linux-headers-5.4.0-bpi-r64-r64-main_5.4.0-bpi-r64-r64-main_arm64.deb
 new Debian package, version 2.0.
 size 8308784 bytes: control archive=158906 bytes.
Is your current source located at /usr/src/linux-headers-5.4.0-bpi-r64-r64-main?
I thinking about adding it to build.sh (deb function). But it needs to be universal (kernelversion,source directory).
Yep:
sa@bpi-r64:~$ ls -lah /lib/modules/`uname -r`/build
lrwxrwxrwx 1 root root 45 Jan 27 23:33 /lib/modules/5.4.0-bpi-r64-r64-main/build -> /usr/src/linux-headers-5.4.0-bpi-r64-r64-main
I would recommend to make use of
$ grep -RE module.lds scripts
scripts/package/builddeb:(cd $srctree; find arch/$SRCARCH -name module.lds -o -name Kbuild.platforms -o -name Platform) >> "$objtree/debian/hdrsrcfiles"
to build linux-headers etc. make bindeb-pkg is officially documented and use it.
I mean if it is source or target for deb creation…
afair buildeb does not work for crosscompile (binary package). can you give example for adding it to build.sh (function deb already contains versionstring)?
After some poking I got compatible linux-headers, I think:
$ bash build.sh build
$ cat include/config/kernel.release
$ LOCALVERSION=-r64-main ./scripts/setlocalversion .
-bpi-r64-r64-main
$ LOCALVERSION=-r64-main ARCH=arm64 CROSS_COMPILE='ccache aarch64-linux-gnu-' make bindeb-pkg
$ ls -lah ../*.deb
-rw-r--r-- 1 ilya ilya  11M фев  2 12:50 ../linux-headers-5.4.0-bpi-r64-r64-main_5.4.0-bpi-r64-r64-main-11_arm64.deb
-rw-r--r-- 1 ilya ilya 4,5M фев  2 12:50 ../linux-image-5.4.0-bpi-r64-r64-main_5.4.0-bpi-r64-r64-main-11_arm64.deb
-rw-r--r-- 1 ilya ilya 1,0M фев  2 12:50 ../linux-libc-dev_5.4.0-bpi-r64-r64-main-11_arm64.deb
imho it works, e.g. https://linux-sunxi.org/Mainline_Kernel_Howto#Specific_Debian_kernel_notes
Then, to make the kernel, use; substituting your cross compiler;:
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- deb-pkg
Note: if you want to build, but not start from scratch, the target bindeb-pkg does not do a clean first, whereas deb-pkg does.
I’ll later try to adapt to banana pi reality.
“works” is relative :wink: it does not create an uImage and path for kernel-image is not the one used by bpi-images (/boot/bananapi/bpi-r*/linux/).
  • for r2 you need 32bit uImage/kernel with appended dtb
  • for r64 you need 32bit uImage with 64bit kernel and with dtb in dtb-folder
if we solve this we can use
ARCH=arm CROSS_COMPILE='ccache arm-linux-gnueabihf-' LOCALVERSION=-main make bindeb-pkg #r2
ARCH=arm64 CROSS_COMPILE='ccache aarch64-linux-gnu-' LOCALVERSION=-r64-main make bindeb-pkg #r64
after importconfig
but for linux-headers i can add it to build.sh/travis, if i found out how to build/upload only the headers-deb
scripts/Makefile.package:
KBUILD_PKG_ROOTCMD ?="fakeroot -u"
deb-pkg:
        $(MAKE) clean
        $(CONFIG_SHELL) $(srctree)/scripts/package/mkdebian
        $(call cmd,src_tar,$(KDEB_SOURCENAME))
        origversion=$$(dpkg-parsechangelog -SVersion |sed 's/-[^-]*$$//');\
                mv $(KDEB_SOURCENAME).tar.gz ../$(KDEB_SOURCENAME)_$${origversion}.orig.tar.gz
        +dpkg-buildpackage -r$(KBUILD_PKG_ROOTCMD) -a$$(cat debian/arch) $(DPKG_FLAGS) -i.git -us -uc
bindeb-pkg:
        +dpkg-buildpackage -r$(KBUILD_PKG_ROOTCMD) -a$$(cat debian/arch) $(DPKG_FLAGS) -b -nc -uc
maybe we can set KBUILD_PKG_ROOTCMD or DPKG_FLAGS to create source-only or using script before to generate uImage…DPKG_FLAGS seem not to be set anywhere
btw. bindeb-pkg should build only binary package (not source), see help at the end of makefile…but in my test it also creates the source-deb, but deb-pkg makes clean before and seem to create a source tarball. filename ($kernel_headers_packagename) for source-deb is set in the mkdebian script, but i have not found where it was used to create the headers-file…i guess somewhere with the debian/control file, where also the others are listed.
some of the magic (including collecting files for headers-package) seems to be in this script: scripts/package/builddeb
imho adding mkimage and patchs for dtb should be added here. there is also a section about location for image…there is no arm/arm64-part…maybe we can add one using an ENV-Variable to set target-directory
diff --git a/scripts/package/builddeb b/scripts/package/builddeb
index c4c580f547ef..5ca7d49e1227 100755
--- a/scripts/package/builddeb
+++ b/scripts/package/builddeb
@@ -70,6 +70,9 @@ um)
 parisc|mips|powerpc)
        installed_image_path="boot/vmlinux-$version"
+arm|arm64)
+       installed_image_path="boot/$imagepath/uImage-$version"
        installed_image_path="boot/vmlinuz-$version"
 esac
but we need to build uImage before…but how
the build itself seems to be done in same file
cp "$($MAKE -s -f $srctree/Makefile image_name)" "$tmpdir/$installed_image_path"
we could call dtbs/mkimage after it or passing all options to the existing make
maybe it’s easier to unpack the deb after generation, remove the wrong vmlinux and adding missing files
@frank-w I’ve changed builddeb a little, so one may build linux-image, linux-headers and linux-libc-dev like so
bash build.sh build
bash build.sh pack
bash build.sh pack_debs
ls ../*.deb
../linux-headers-5.4.17-bpi-r64-main-packaged_5.4.17-bpi-r64-main-packaged-1_arm64.deb  ../linux-libc-dev_5.4.17-bpi-r64-main-packaged-1_arm64.deb
../linux-image-5.4.17-bpi-r64-main-packaged_5.4.17-bpi-r64-main-packaged-1_arm64.deb
I think it is a good idea add the command to https://github.com/frank-w/BPI-R2-4.14/releases
Meanwhile, I’ve tried the last commit 2e4b86dfcf329f94ac123175b3eed5231b77bbf6 for my BPI-R64 and it doesn’t work for me because DHCP/WAN=eth1 doesn’t work:
Was in 5.4-r64-main:
sa@bpi-r64:~$ ip addr
    link/ether 3e:af:11:8b:df:12 brd ff:ff:ff:ff:ff:ff
    inet 192.168.2.1/24 brd 192.168.2.255 scope global eth0
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 5e:7d:b9:2e:95:c4 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.47/24 brd 192.168.1.255 scope global dynamic eth1
       valid_lft 86387sec preferred_lft 86387sec
Now:
sa@bpi-r64:~$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether f6:34:86:70:68:93 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether 32:b0:c0:e3:0f:41 brd ff:ff:ff:ff:ff:ff
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
5: wan@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
6: lan0@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
7: lan1@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
8: lan2@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
9: lan3@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
Also wlan disappered.
sa@bpi-r64:~$ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Include files from /etc/network/interfaces.d:
auto lo
iface lo inet loopback
auto eth0
#allow-hotplug eth0
iface eth0 inet static
  address 192.168.2.1/24
  #gateway 192.168.1.10
auto eth1
#allow-hotplug eth1
iface eth1 inet dhcp
source-directory /etc/network/interfaces.d
Good boot: boot-5.4.0-bpi-r64-r64-main.log (32.5 KB)
Bad boot: boot-5.4.17-bpi-r64-main_new.log (14.9 KB)
Any clues?
In 5.4-main i merged dsa driver for r64 and did not merged openwrt phy driver for r64.
You can now work with wan instead of eth1,but need to set eth0 up before…config like for r2. Have you tried working on wan?
Eth is defined in dts only for soc-side (thats why it is visible in ip a),but switchside (port5) is not defined
Just try wan/lanX instead of ethX
For internal wifi…i see a semaphore error on boot,but if i unload module and load again it works in my quick tests…have not found cause of it…[BPI-R64] mt7622 mac80211 WiFi driver
