Example for blinking LED with PWM
1. We need a PWM driver in U-boot to control hardware.
submitted patch:
https://patchwork.ozlabs.org/patch/1242081/
https://patchwork.ozlabs.org/patch/1242083/
2. We need to enable PWM in dts and configure pinctrl
diff --git a/arch/arm/dts/mt7622-rfb.dts b/arch/arm/dts/mt7622-rfb.dts
index 05502bddec..165496e8d9 100644
--- a/arch/arm/dts/mt7622-rfb.dts
+++ b/arch/arm/dts/mt7622-rfb.dts
@@ -69,6 +69,13 @@
+ pwm_pins: pwm1 {
+ mux {
+ function = "pwm";
+ groups = "pwm_ch1_0" ;
watchdog_pins: watchdog-default {
mux {
function = "watchdog";
@@ -155,6 +162,12 @@
status = "okay";
+&pwm {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pwm_pins>;
+ status = "okay";
&mmc0 {
pinctrl-0 = <&mmc0_pins_default>;
In this example, we use bpir64 pin 11 (UART1-TXD/GPIO51/TXD2/PWM_CH1) as PWM channel 1 (pwm_id=0), and connect this pin to a LED.
3. We need an application to access u-boot PWM API as a u-boot command
pwm 0 config 1000000000 500000000
pwm 0 enable
LED on (0.5 seconds) --> LED off (0.5 seconds) --> LED on (0.5 seconds) --> …
diff --git a/cmd/pwm.c b/cmd/pwm.c
new file mode 100644
index 0000000000..efd2f4590d
--- /dev/null
+++ b/cmd/pwm.c
@@ -0,0 +1,52 @@
+// SPDX-License-Identifier: GPL-2.0+
+ * Copyright (C) 2020 MediaTek Inc.
+ * Author: Sam Shih <[email protected]>
+#include <common.h>
+#include <command.h>
+#include <dm.h>
+#include <pwm.h>
+#include <dm/uclass-internal.h>
+int do_pwm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
+ struct udevice *dev;
+ unsigned long pwm_id, period, duty;
+ if (uclass_get_device(UCLASS_PWM, 0, &dev)) {
+ printf("unable to find pwm driver\n");
+ return CMD_RET_FAILURE;
+ if (argc < 2)
+ return CMD_RET_USAGE;
+ pwm_id = simple_strtoul(argv[1], NULL, 0);
+ if (strncmp(argv[2], "config", 10) == 0) {
+ if (argc < 4)
+ period = simple_strtoul(argv[3], NULL, 0);
+ duty = simple_strtoul(argv[4], NULL, 0);
+ if (pwm_set_config(dev, pwm_id, period, duty)) {
+ printf("unable to config pwm driver\n");
+ else if (strncmp(argv[2], "enable", 10) == 0) {
+ pwm_set_enable(dev, pwm_id, true);
+ else if (strncmp(argv[2], "disable", 10) == 0) {
+ pwm_set_enable(dev, pwm_id, false);
+ return 0;
+U_BOOT_CMD(
+ pwm, 5, 1, do_pwm,
+ "manage PWMs\n",
+ "<pwm_id> [config|enable|disable]\n"
+ "config: <pwm_id> config <period_in_ns> <duty_in_ns>\n"
+ "enable: <pwm_id> enable\n"
+ "disable: <pwm_id> disable\n"
