[BPI-R2] Uboot - pcie/sata/ahci
Just created a new thread because the original Uboot-thread got to big…
currently working on https://github.com/frank-w/u-boot/commits/sata_test_ryder
last state: needs phy-driver ( Add latest U-boot support for BPI R2 & BPI R64 (not yet) )
added now a basic template…needs to be filled :slight_smile: : https://github.com/frank-w/u-boot/commit/ba0c145cc1d739c07ff440dc2b01d8387ab4e4a8
this is the one on linux: https://github.com/torvalds/linux/blob/master/drivers/phy/mediatek/phy-mtk-tphy.c
pcie-driver in uboot (current state): https://github.com/frank-w/u-boot/blob/sata_test_ryder/drivers/pci/pcie_mediatek.c
@ryder.lee first problem, how can i trigger the tphy-driver? it is compiled in, but not called on pci enum
phy drivers should be attached by OFW/FDT code.
PCI-E driver should find them by FDT xref from “phys” property.
arch/arm/dts/mt7623n-bananapi-bpi-r2.dtb: Warning (phys_property): /pcie-controller@1a140000: Missing property '#phy-cells' in node /pcie-phy@1a14a000 or bad phandle (referred from phys[1])
tried to add phys here in pcie-node (not the phy):
285         phys = <&pcie0_phy>,
286                <&pcie1_phy>;
ok, got it…had added phy-cells only to one phy :smiley:
seems to work so far:
DEBUG: probing TPHY mtk_phy_probe 32
have to go now…maybe you can try to get further? @ray
Me giving hints and writing mt7530 init for second port :slight_smile:
your phandle is wrong. I will take care of phy driver these days.
Have not uploaded last state (had to hurry)…it’s defined like above…with #PHY-CELLS=0 in both phy-nodes
have now pushed current state (where phy-probe gets called)
sent Patch-Series out: https://patchwork.ozlabs.org/project/uboot/list/?series=123226
