BPI-R2 slow ethernet speed
I’ve got three R2 boards and I’m working with a number of your Kernel versions Frank - I’ll do some testing with the discussed setup this weekend - sorry I keep on disappearing! I know we need all hands on deck but I’ve had health issues - all resolved now :slight_smile:
I was recently digging through OpenWRT kernel patches for BPiR2 and stumbled upon this one:
Interesting lines are these:
+	if (!dsa_is_cpu_port(ds, 5)) {
+		val |= MHWTRAP_P5_DIS;
+		val |= MHWTRAP_P5_MAC_SEL;
+		val |= MHWTRAP_P5_RGMII_MODE;
What seems to be done here is the initialization of the port 5 of the switch to use RGMII mode no matter what is set in the DTS, but only in case this port was marked as a cpu port in DTS.
Right…port5 (eth1=wan) is rgmi only, i don’t know why it is only working if set to trgmii. Port6=eth0=lan supports trgmii. Imho trgmii was not setup the right way so it causes issues if adding the second gmac with another mode.
The code I cited means that the mode you set for port5 in DTS is essentially ignored andit hardcoded to always be rgmii. Probably there’s some other place where the value of the port mode from DTS is being used for something and that’s why we see differences (i.e. malformed packets) when set DTS port mode to rgmii.
You have 2 ends of gmac,switch and soc…imho this setting affects only switch-side. But the code you’ve found also sets switch-side…maybe it is overridden with dts-value? I meam that this code is only an initialization value
That’s it. :blush: We both do not know enough about the code in a whole to be sure. Then again when I seen the the patch above I thought that it might be a good explanation for the fact that we’ve got GMAC2 set to the mode it doesn’t support but still works. Might be a co-incidence though.
i looked again over the code-snippet above.
have you seen the “!” in the condition? so only if port 5 is no cpu-port (imho it can be used as external port) the lines below are used (trgmii-mode makes no sense for external port).
so it should be right and does not affect our trgmii-setting on r2 where p5 is a cpu-port if activated by 2nd-gmac-patches, else it not used and then it does not matter in which mode it is :slight_smile:
Maybe you want to try new phylink. Olser code was reported to have not this issue
Anyone here for trying actual phylink-code?
Can’t open link. GH said 404
it’s because 5.3-rc is released and we have updated phylink
Hi
I notice the same problem on 5.4.70 kernel. My configuration is:
  • provider speed - 1GbpsDL/300MbpsUL . Performance tested from laptop connected to provider’s box
  • lan ports bridged to br0, connected to internal gb network
  • R2 works on SSD disk. only MASQUERADE is used, All vlans removed from configuration
  • a simple. old linksys connected to provider’s box and internal network to verify connection
My tests shows:
  • download from internet to r2 using wan IP - 30MBps (wget over https)
  • download from internet to r2 using lan IP - 30MBps
  • download from internal net to r2 using lan IP - 30MBps (wget over http)
  • traffic between bridged ports 112MBps
  • speedtest from internal network using R2 - depends on restart, up to 100MbpsDL 200Mbps UL, sometimes 14MbpsDL /14 MbpsUL.
  • tcp download from the same https as test 1 and 2 to the internal serwer - 200kbps !!!
  • traffic using paraller linksys - always 200MbpsDl/230MbpsUL. no mater which server internal server or protocol
I’ve got stuck. I plan to switch to openwrt but fighting with compilation errors. Any hint ?
Thanks,
Do you use mainline kernel or from my repo (5.4-main)? Mainline is still missing pause option on gmac
Yes, it’s from your repo.
[core]
        repositoryformatversion = 0
        filemode = true
        bare = false
        logallrefupdates = true
[remote "origin"]
        url = https://github.com/frank-w/BPI-R2-4.14.git
        fetch = +refs/heads/*:refs/remotes/origin/*
[branch "5.4-main"]
        remote = origin
        merge = refs/heads/5.4-main
BR,
have you tried without bridging? have you took a look on cpu/interrupts while generating traffic?
watch "cat /proc/interrupts | grep eth"
Hi
the results are :
> cat /proc/interrupts ...  TorontoR2: Tue Oct 13 22:45:42 2020
> 240:     997594          0          0          0  MT_SYSIRQ 199 Level     1b1000
> 00.ethernet
> 241:     519358          0          0          0  MT_SYSIRQ 198 Level     1b1000
> 00.ethernet
even I’ve already added:
> post-up echo 2 > /sys/class/net/wan/queues/rx-0/rps_cpus
> post-up echo 3 > /sys/class/net/br0/queues/rx-0/rps_cpus
in /etc/network/interfaces
I also updated kernel yesterday from you repo, so test was done on updated kernel
BR, Marcin
For interrupts it is depending on how fast they counting…but i see you only use 1 cpu for both interrupts. You can try if it works better if you use 2
In my case it does not change anything…i got lags on streaming,but don’t know if they caused by r2 (maybe tv, isp or remote side)
Hello everyone!
If your ISP has persistent ip - try to use SNAT --to-source in general it’s faster as it has less overhead.
in my case i have follofing speeds:
General ssl/tsl (ssh or https) - max ~100Mb/s (Megabit/s) - the bottleneck is ssl/tsl encryption - 100% 1 of cpu cores used (when r2 is client or server).
traffic between bridged ports - 860-960 Mbit’s not sure what it depens on.
it was tested on numerous of kernels 5.4, 5.5, 5.8, 5.9 amd 4.14 (long time ago :))
You can also try to use perf top to determine the bottleneck.
also you can try to spread interrupts over 2 CPUs
i dont remember exact command, but you can google smp_affinity also the commant shold seems like:
echo <cpu_mask> > /proc/irq/<irq_num>/smp_affinity i can find some details if needed
But i think you should start with perf top during the speed test. (installing perf may depend on your distro)
Thank you for your tests
See my linked thread here
Generally if client opens a https webpage through r2,r2 do only forward packets…it does not need to encrypt/decrypt.so only the routing/nat-part should be done on cpu.
@marcin please do not use MBps as it is not clear if you mean Megabit or Megabyte per second
I have strange Iperf results from local server to r2 (without NAT)
> Connecting to host server, port 5201
> [  4] local r2 port 49210 connected to server port 5201
> [ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
> [  4]   0.00-1.00   sec  11.8 MBytes  99.1 Mbits/sec  273   4.24 KBytes
> [  4]   1.00-2.00   sec  12.9 MBytes   108 Mbits/sec  263   2.83 KBytes
> [  4]   2.00-3.00   sec  8.45 MBytes  70.9 Mbits/sec  130   1.41 KBytes
> [  4]   3.00-4.00   sec  8.51 MBytes  71.4 Mbits/sec  183   5.66 KBytes
> [  4]   4.00-5.00   sec   954 KBytes  7.82 Mbits/sec   35   4.24 KBytes
> [  4]   5.00-6.00   sec  6.46 MBytes  54.2 Mbits/sec  154   12.7 KBytes
> [  4]   6.00-7.00   sec  2.42 MBytes  20.3 Mbits/sec   57   1.41 KBytes
> [  4]   7.00-8.00   sec  9.51 MBytes  79.7 Mbits/sec  148   7.07 KBytes
> [  4]   8.00-9.00   sec  16.5 MBytes   139 Mbits/sec  347   9.90 KBytes
> [  4]   9.00-10.00  sec  12.8 MBytes   107 Mbits/sec  300   2.83 KBytes
> [  4]   0.00-10.00  sec  90.3 MBytes  75.8 Mbits/sec  1890             sender
> [  4]   0.00-10.00  sec  90.0 MBytes  75.5 Mbits/sec                  receiver
> iperf Done.
> Connecting to host r2, port 5201
> [  5] local server port 53752 connected to r2 port 5201
> [ ID] Interval           Transfer     Bitrate         Retr  Cwnd
> [  5]   0.00-1.00   sec  86.9 MBytes   729 Mbits/sec   68    851 KBytes
> [  5]   1.00-2.00   sec  86.2 MBytes   724 Mbits/sec    0   1.02 MBytes
> [  5]   2.00-3.00   sec  85.0 MBytes   713 Mbits/sec    0   1.17 MBytes
> [  5]   3.00-4.00   sec  86.2 MBytes   724 Mbits/sec    0   1.29 MBytes
> [  5]   4.00-5.00   sec  87.5 MBytes   734 Mbits/sec    0   1.39 MBytes
> [  5]   5.00-6.00   sec  85.0 MBytes   713 Mbits/sec    5   1.03 MBytes
> [  5]   6.00-7.00   sec  66.2 MBytes   556 Mbits/sec  740    153 KBytes
> [  5]   7.00-8.00   sec  86.2 MBytes   724 Mbits/sec  109   1.20 MBytes
> [  5]   8.00-9.00   sec  85.0 MBytes   713 Mbits/sec    0   1.32 MBytes
> [  5]   9.00-10.00  sec  85.0 MBytes   713 Mbits/sec    0   1.41 MBytes
> [  5]   0.00-10.00  sec   839 MBytes   704 Mbits/sec  922             sender
> [  5]   0.00-10.00  sec   837 MBytes   702 Mbits/sec                  receiver
> iperf Done.
No problem between two local net hosts.
BTW: I use MB for megabytes, Mb for megabits
BR Marcin
