BPI-R2 slow ethernet speed
(Thomas) #26
I do also have an issue with BPi-R2 and network speed.
If I make tests with iperf, everything is fine. If I connect the R2 behind my providers router and do measures with https://fast.com I reach around 200 Mbit/s (should be 400Mbit/s which I do get when connecting directly to my providers router, but okay). If I connect more devices to all four ports of the R2 the speed measured with https://fast.com drops below 1Mbit/s. If I do exactly the same with a BPi-R1 I do reach arround 200Mbit/s on https://fast.com, also if the other devices are connected. During the tests with R1 and R2; the other devices were an Odroid-C2 and a Raspberry PI Zero, both running shairport-sync playing multiroom audio from a MacBook Pro.
Kernel used:
  • R2: 4.14.88-bpi-r2-main (frank-w)
  • R1: 4.14.55-1-ARCH
both running archlinux and using arno-iptables-firewall and dnsmasq. All LAN Ports are in one bridge.
@frank-w do you use the R2 as router or are you only doing some tests with it?
(Frank W.) #27
I use r2 (1 of 2) as router but i have only a adsl2+ with 12mbit/s
(Frank W.) #28
tested again with 4.19 and my gmac-patches
from r2 speed is ~940Mbit/s, to r2 i have only ~700Mbit/s
now i tested with iperf3 from r2 (first normal, second with -R, output from my laptop/client):
wan (eth1):
[18:46:48]$ iperf3 -s
Server listening on 5201
Accepted connection from 192.168.0.19, port 49282
[  5] local 192.168.0.21 port 5201 connected to 192.168.0.19 port 49284
[ ID] Interval           Transfer     Bandwidth
[  5]   0.00-1.00   sec   107 MBytes   895 Mbits/sec
[  5]   1.00-2.00   sec   112 MBytes   939 Mbits/sec
[  5]   2.00-3.00   sec   112 MBytes   939 Mbits/sec
[  5]   3.00-4.00   sec   112 MBytes   939 Mbits/sec
[  5]   4.00-5.00   sec   112 MBytes   939 Mbits/sec
[  5]   5.00-6.00   sec   112 MBytes   939 Mbits/sec
[  5]   6.00-7.00   sec   112 MBytes   939 Mbits/sec
[  5]   7.00-8.00   sec   112 MBytes   939 Mbits/sec
[  5]   8.00-9.00   sec   112 MBytes   939 Mbits/sec
[  5]   9.00-10.00  sec   112 MBytes   939 Mbits/sec
[  5]  10.00-10.05  sec  5.32 MBytes   939 Mbits/sec
[  5]   0.00-10.05  sec  0.00 Bytes  0.00 bits/sec                  sender
[  5]   0.00-10.05  sec  1.09 GBytes   935 Mbits/sec                  receiver
Accepted connection from 192.168.0.19, port 49286
[  5] local 192.168.0.21 port 5201 connected to 192.168.0.19 port 49288
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  5]   0.00-1.00   sec   102 MBytes   851 Mbits/sec    0    576 KBytes
[  5]   1.00-2.00   sec   111 MBytes   934 Mbits/sec    0    576 KBytes
[  5]   2.00-3.00   sec   111 MBytes   933 Mbits/sec    0    576 KBytes
[  5]   3.00-4.00   sec  80.3 MBytes   674 Mbits/sec    0    771 KBytes
[  5]   4.00-5.00   sec  73.0 MBytes   613 Mbits/sec    0    771 KBytes
[  5]   5.00-6.00   sec  73.5 MBytes   617 Mbits/sec    0    771 KBytes
[  5]   6.00-7.00   sec  73.5 MBytes   617 Mbits/sec    0    771 KBytes
[  5]   7.00-8.00   sec  73.5 MBytes   617 Mbits/sec    0    771 KBytes
[  5]   8.00-9.00   sec  73.5 MBytes   617 Mbits/sec    0    771 KBytes
[  5]   9.00-10.00  sec  73.5 MBytes   616 Mbits/sec    0    771 KBytes
[  5]  10.00-10.04  sec  2.49 MBytes   523 Mbits/sec    0    771 KBytes
[  5]   0.00-10.04  sec   847 MBytes   708 Mbits/sec    0             sender
[  5]   0.00-10.04  sec  0.00 Bytes  0.00 bits/sec                  receiver
lan0 (eth0):
Accepted connection from 192.168.0.19, port 49290
[  5] local 192.168.0.21 port 5201 connected to 192.168.0.19 port 49292
[  5]   0.00-1.00   sec   107 MBytes   894 Mbits/sec
[  5]  10.00-10.05  sec  5.27 MBytes   935 Mbits/sec
Accepted connection from 192.168.0.19, port 49294
[  5] local 192.168.0.21 port 5201 connected to 192.168.0.19 port 49296
[  5]   0.00-1.00   sec   106 MBytes   887 Mbits/sec    0    143 KBytes
[  5]   1.00-2.00   sec  85.0 MBytes   713 Mbits/sec    0    583 KBytes
[  5]   2.00-3.00   sec  73.5 MBytes   617 Mbits/sec    0    583 KBytes
[  5]   3.00-4.00   sec  73.5 MBytes   617 Mbits/sec    0    583 KBytes
[  5]   4.00-5.00   sec  73.5 MBytes   617 Mbits/sec    0    583 KBytes
[  5]   5.00-6.00   sec  74.0 MBytes   621 Mbits/sec    0    583 KBytes
[  5]   6.00-7.00   sec  73.3 MBytes   614 Mbits/sec    0    583 KBytes
[  5]   7.00-8.00   sec  73.5 MBytes   617 Mbits/sec    0    583 KBytes
[  5]   8.00-9.00   sec  73.4 MBytes   616 Mbits/sec    0    583 KBytes
[  5]   9.00-10.00  sec  73.4 MBytes   615 Mbits/sec    0    583 KBytes
[  5]  10.00-10.05  sec  3.01 MBytes   537 Mbits/sec    0    583 KBytes
[  5]   0.00-10.05  sec   782 MBytes   653 Mbits/sec    0             sender
[  5]   0.00-10.05  sec  0.00 Bytes  0.00 bits/sec                  receiver
(Thomas) #29
Today I did more tests.
As long as I do only connect 1 device to the lan ports (no matter which one) I do get ~200MBit/s with https://fast.com
If I connect more devices to the other lan ports, even if these device do not do any network communication, the more devices I do connect; the data-rate goes down to 3 MBit/s or even only some kbit/s.
  1. So I tried to not use arno-iptables-firewall, but did only activate forward and a masquerade rule, nothing else: Same result
  2. Then I thought maybe the bridge is the problem, so I removed the bridge and configured every lan port with it’s own subnet: same result
Then I thought maybe the MAC Addresses cause an issue, so I tried 2 different things:
  1. Give the same mac address to eth1 and wan, like it is the default: Same result
  2. Give every interface (eth0,eth1,lan0-lan3,wan) a different MAC address: Same result
So I have no idea what is causing this. BPI-R2 is not usable as router for my personal setup.
EDIT: tested with kernel 4.14.92_main selfcompiled and from frank’s github releases
(Frank W.) #30
Important info that this issue only appears only if more than 1 lanport is connected as my tests are only over one lan/wan-port or from lan to wan.
On my main-router i also have only 1 lan connected because this lan is a trunk to managed switch there my other devices are connected
(Frank W.) #31
@Ryder.Lee / @moore / @linkerosa / @Jackzeng can bpi-r2 operate without dsa-driver in 4.14+ like it works in 4.4 (eth1 fixed to wan,eth0 to lan-ports)
(bluelightning32) #32
As I mentioned in the other thread, I’m getting slow speeds. I’ll put my network configuration details in here.
My main router is a Netgear WNDR3800 running OpenWRT. I was testing out the banana pi r2, hoping it could replace the netgear. The netgear has an internal IP address of 192.168.15.1. It connects to my ISP using PPPOE. I posted details of its configuration on the OpenWRT board.
One of the lan ports of my router is connected to a switch. I am running the test between 2 computers. One of the computers, mihoshi is connected to that switch, and has an IP of 192.168.15.2. Because my main internet connection goes through PPPoE, mihoshi’s MTU is 1492.
The wan port of the Banana PI R2 is connected to the switch. The other computer, ryoko is connected to lan3 of the Banana Pi R2. The Banana Pi is performing a NAT translation between the two computers. I’ve set ryoko’s MTU to 1492 to match mihoshi’s.
Here’s how I’m measuring the speed:
$ ssh kyle@192.168.15.2 'cat /dev/zero' | pv >/dev/null
^C02GiB 0:01:29 [37.3MiB/s]
I think mihoshi and ryoko’s network settings are correct, because the gets about 90MiB/s when I use an expressobin instead of the banana pi.
Here is the configuration of my banana pi:
root@bpi-r2:~# uname -a
Linux bpi-r2 4.14.80-bpi-r2-main #177 SMP Sun Nov 11 10:03:58 CET 2018 armv7l GNU/Linux
root@bpi-r2:~# iptables-save
# Generated by iptables-save v1.6.0 on Sun Jan 20 09:26:23 2019
*filter
:INPUT ACCEPT [8827:730234]
:FORWARD ACCEPT [54709:25786012]
:OUTPUT ACCEPT [9931:1198866]
COMMIT
# Completed on Sun Jan 20 09:26:23 2019
*nat
:PREROUTING ACCEPT [6742:849916]
:INPUT ACCEPT [3444:241724]
:OUTPUT ACCEPT [2492:166578]
:POSTROUTING ACCEPT [11:1615]
-A POSTROUTING -o wan -j MASQUERADE
COMMIT
root@bpi-r2:~# ip a
    inet6 ::1/128 scope host
    link/ether 3e:8c:11:69:29:8e brd ff:ff:ff:ff:ff:ff
    inet6 fe80::3c8c:11ff:fe69:298e/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 52:b1:52:1b:25:98 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::50b1:52ff:fe1b:2598/64 scope link
4: wan@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 10000
    inet 192.168.15.140/24 brd 192.168.15.255 scope global wan
    inet6 2602:ae:1592:e100:50b1:52ff:fe1b:2598/64 scope global mngtmpaddr dynamic
5: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000
6: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000
7: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000
8: lan3@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
9: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.2.1/24 brd 192.168.2.255 scope global br0
root@bpi-r2:~# lsmod
Module                  Size  Used by
iptable_filter         16384  0
mtkhnat                24576  0
ipt_MASQUERADE         16384  1
nf_nat_masquerade_ipv4    16384  1 ipt_MASQUERADE
iptable_nat            16384  1
nf_conntrack_ipv4      16384  2
nf_defrag_ipv4         16384  1 nf_conntrack_ipv4
nf_nat_ipv4            16384  1 iptable_nat
nf_nat                 32768  2 nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_conntrack          126976  5 nf_conntrack_ipv4,ipt_MASQUERADE,nf_nat_masquerade_ipv4,nf_nat_ipv4,nf_nat
bridge                151552  0
mtk_thermal            16384  0
thermal_sys            61440  1 mtk_thermal
spi_mt65xx             20480  0
pwm_mediatek           16384  0
mt6577_auxadc          16384  0
nvmem_mtk_efuse        16384  0
mtk_pmic_keys          16384  0
rtc_mt6397             16384  1
ip_tables              24576  2 iptable_filter,iptable_nat
x_tables               28672  3 ip_tables,iptable_filter,ipt_MASQUERADE
ipv6                  409600  23 bridge
Since you said you had difficulty reproducing this, I ran a speed test to the internet from ryoko. Strangely, I am getting 355Mb/s download and 308Mb/s upload, which is much higher than I expected considering the problems talking to a much closer computer. When ryoko connects directly to the switch, it gets 553Mb/s download and 451Mb/s upload.
(Frank W.) #33
netgear (mainrouter): 192.168.15.1 connected to wan, right?
bpi-r2: wan: 192.168.15.140/24, br0 (all lan-ports): 192.168.2.1/24, NAT on wan
mihoshi (client/ssh-target): 192.168.15.2 => seems to be wrong
ryoko (other client): x.x.x.x ?
your lans are bridged together to br0 with 192.168.2.1/24 so your mihoshi & ryoko should have 192.168.2.x/24
from which system do you make the ssh? i guess from r2 to your client…then bottleneck could be r2’s cpu
(bluelightning32) #34
Ryoko is using DHCP from the banana Pi. Currently it has address 192.168.2.135. The wan port of the banana pi connects to a switch. Mihoshi does not connect to the banana pi. It connects directly to the switch.
Ryoko and Mihoshi’s networks are not bridged through br0. It goes through NAT translation in the banana pi.
[kyle@ryoko ~]$ ifconfig
enp0s18f2u4: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:24:9b:06:06:9c  txqueuelen 1000  (Ethernet)
        RX packets 780962  bytes 985254421 (939.6 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 778884  bytes 704802735 (672.1 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enp4s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1492
        inet 192.168.2.135  netmask 255.255.255.0  broadcast 192.168.2.255
        inet6 fe80::7f9b:6f9d:729d:78c9  prefixlen 64  scopeid 0x20<link>
        ether bc:5f:f4:af:1b:83  txqueuelen 10000  (Ethernet)
        RX packets 850718674  bytes 1219355660935 (1.1 TiB)
        RX errors 4  dropped 60  overruns 0  frame 6
        TX packets 247260591  bytes 146336285643 (136.2 GiB)
        TX errors 2  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 104706516  bytes 220974209428 (205.7 GiB)
        TX packets 104706516  bytes 220974209428 (205.7 GiB)
[kyle@ryoko ~]$ ssh kyle@192.168.15.2 'dd if=/dev/zero of=/dev/stdout bs=$((1024 * 1024)) count=1000' >/dev/null
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 27.7315 s, 37.8 MB/s
[kyle@ryoko ~]$ dd if=/dev/zero of=/dev/stdout bs=$((1024 * 1024)) count=1000 | ssh kyle@192.168.15.2 'cat >/dev/null'
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 9.3078 s, 113 MB/s
(Frank W.) #35
interesting…that means that problem is not encryption, but generation of data via dd…but in both commands data is not generated on r2…
192.168.15.2 seems to have problens generating the data, or it is direction-related…ryoko to 192.168.15.2 seems to work well, the opposite direction is bad
(Johnny) #36
Create an NFS share, use FTP - you have to rule out encryption overhead. Given that multiple reports seem to indicate faster ‘in’ than ‘out’ - then to my eyes the biggest culprit here is those 4 configurable LAN ports - the way they are exposed as ‘virtual’ interfaces and their shared lane to the CPU.
Maybe it’s the actual hardware - it’s likely software - but clearly there’s some kind of round-robin algorithm on some level that is causing an N^2 decrease in performance in one direction. That means there’s SOMETHING - a process, some code - something that’s operating per port and causes a delay, per-port that is proportional to the total number of used ports.
for each port do
{PROBLEM IS HERE}
end
I’m working on the lima/mali stuff right now - I’ll try to fix this eventually. We’ll fix it like you optimize a game engine - we’ll profile every single call on the kernel side that is MTK specific and networking specific.
Run one interface - benchmark, run two - etc etc
See which calls are taking up a relatively larger amount of time as you transfer one way, the other, and with one, two, three etc connected machines.
That’ll track down this problem - we’ll see the culprit code or we’ll determine a hardware limitation - but we’ll find it.
EDIT : I’m not saying that’s easy - but presumably we can generate valgrind data - if we can’t? then we can just do our own timing routines and dump to a log - whatever. N^2 issues will stick out like a sore thumb during profiling.
(bluelightning32) #37
It’s not due to encryption. I’ve been trying out different routers. If I replace the banana pi with an espressobin, the same benchmarks between the two computers get 90MiB/s.
(bluelightning32) #38
I did some more tests. As far as I can tell, the router is slow with incompressible data, but that doesn’t make any sense. I’ve never heard of a NAT trying to do compression.
I get fast speeds sending all 0s:
[kyle@mihoshi ~]$ dd if=/dev/zero of=/dev/stdout bs=$((1024 * 1024)) count=1000 | socat -u STDIN TCP4-LISTEN:25566,reuseaddr
[kyle@ryoko ~]$ socat -u TCP4:192.168.15.2:25566 STDOUT | pv >/dev/null
1000MiB 0:00:10 [94.8MiB/s] [
I get fast speeds sending all 1s:
[kyle@mihoshi ~]$ dd if=/dev/zero of=/dev/stdout bs=$((1024 * 1024)) count=1000 | tr '\000' '\377'  | socat -u STDIN TCP4-LISTEN:25566,reuseaddr
1000MiB 0:00:10 [94.0MiB/s] [
However, sending a zip file (incompressible data) is slow:
[kyle@mihoshi ~]$ dd if=/backup/dimension_zero/auto_backup/2018-12-14-13-01-23.zip of=/dev/stdout bs=$((1024 * 1024)) count=1000 | socat -u STDIN TCP4-LISTEN:25566,reuseaddr
1000MiB 0:00:29 [33.9MiB/s]
This shows that reading the file is not slow (the OS already cached it before I ran this test or the previous test, and I reran the network test afterwards too and got the same number):
[kyle@mihoshi ~]$ dd if=/backup/dimension_zero/auto_backup/2018-12-14-13-01-23.zip of=/dev/stdout bs=$((1024 * 1024)) count=1000 | cat >/dev/null
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 0.359988 s, 2.9 GB/s
I tried having the router receive the data, which would skip the NAT part. It does better:
root@bpi-r2:~# socat -u TCP4:192.168.15.2:25566 STDOUT | pv >/dev/null
1000MiB 0:00:14 [68.5MiB/s] [
Probably the tcp buffers aren’t optimized well on the router yet (which makes no different for it’s ability to NAT). Increasing the socat transfer size worked around this. I went back and tried a larger transfer size on ryoko, and it made no difference.
root@bpi-r2:~# socat -b$((1024 * 1024)) -u TCP4:192.168.15.2:25566 STDOUT | pv >/dev/null
1000MiB 0:00:11 [87.3MiB/s] [
(bluelightning32) #39
I did a tcpdump on ryoko and mihoshi during the speed test. Some packets from mihoshi to ryoko are dropped. Ryoko sees this and reduces the TCP window size. Packets are periodically dropped during the rest of the connection as it tries to zero in on the max speed.
Interestingly the 4th through 8th packets or so are dropped. I would have expected the router to have a large enough buffer to hold those packets and drop later packets when the buffer overflows.
(Frank W.) #40
@Ryder.Lee have you an idea how to debug this?
(Johnny) #41
@bluelightning32 - thank you very much for the extensive test results. Unusual behavior! nothing obvious springs to mind, the relative performance is definitely indicative of something, it narrows down the possibilities for sure. It ‘feels’ like a bus contention issue or some kind of buffer-overflow problem as you suggest - but it’s nothing that I’ve personally encountered before with networking gear
#42
Glad see the damn breaking on this issue. I had to resort to other hardware to keep my project going but would circle back to the R2 if someone needs a solution tested here. bluelightning32’s results appear consistent with with problems/experiments I did.
#43
Any updates on this?
I’m observing a similar problem, but much worse than @bluelightning32. When downloading through the Masquerading of the BPI R2 I only get a few hundreds of kbit/s. This makes the R2 not usable as a router for me right now.
When downloading to the Pi itself or uploading through it the speed is ok, though. I can also confirm, that there is a difference between multiple kinds of data. With if=/dev/zero it is fast, but with if=/dev/urandom it is slow. Also just downloading files through it (e.g. debian dvd iso) is around the same few hundreds of kbit/s.
I’ve tried with the official (https://github.com/BPI-SINOVOIP/BPI-R2-bsp) and @frank-w s (https://github.com/frank-w/BPI-R2-4.14) kernel and also with hwnat(http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:hwnat) on.
I will be doing some more detailed tests later this week and will post the output as well as my configuration here.
(dorabmon) #44
disable eth0 tso with ethtool and see if it helps the issue as following commands
ethtool -K eth0 tso off
(Thomas) #45
nope, that does not help
