BPI-R2 New Image Release : Ubuntu 16.04 V1.3 2018-3-30
Hi,I succeed to create wifi/AP,and it works fine,could you show me your log?
my hostapd.conf
I use my PC connect R2 AP to post these messages to you:
Hi, good news… I will send you my logs in about 10 hours, when i arriving home.
I have the same issue, i do have the ap0 device but when i launch hostapd, the wifi SSID does not appears, I try with multiple devices.
# bash -x ./wifi.sh
+ set +e
+ PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
+ DAEMON=/dev/null
+ NAME=wifi
+ DESC='Load MediaTek MT6625L firmware wifi & BT'
+ [[ -x /usr/bin/wmt_loader ]]
+ /usr/bin/wmt_loader
init combo device
Opened combo device
get device id : 30243
set device id : 30243
do module init: 30243
failed to init module
+ sleep 3
+ [[ -c /dev/stpwmt ]]
+ sleep 5
+ /usr/bin/stp_uart_launcher -p /etc/firmware
open device node succeed.(Node:/dev/stpwmt, fd:3)
chip id is 0x7623
chiId:0x7623, setting to property((null))
chiId:0x7623
run SOC chip flow
create pwr on thread ok
enter power on connsys flowpatch name pre-fix:ROMv2_lm_patch
fwVersion:0x8a00
/etc/firmware/ROMv2_lm_patch_1_0_hdr.bin
fw Ver in patch: 0x8a00
read patch info:0x22,0x00,0x06,0x00
gpatchnum = [2]
gdwonseq = [2]
/etc/firmware/ROMv2_lm_patch_1_1_hdr.bin
read patch info:0x21,0x00,0x0e,0xf0
gdwonseq = [1]
cmd(srh_patch) resp(ok)
+ [[ -c /dev/wmtWifi ]]
+ echo 0
+ sleep 5
+ echo A
+ sleep 2
+ ifconfig ap0
ap0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::8:22ff:feca:ecfd  prefixlen 64  scopeid 0x20<link>
        ether 02:08:22:ca:ec:fd  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 5  bytes 526 (526.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
+ [[ 0 != \0 ]]
+ echo 'Done, all good, ready to lauch hostapd'
Then i run hostapd
# hostapd -dd /etc/hostapd/hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd/hostapd.conf
ctrl_interface_group=0
rfkill: Cannot open RFKILL control device
nl80211: RFKILL status not available
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=1
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=6
nl80211: Disable use_monitor with device_ap_sme since no monitor mode support detected
nl80211: interface ap0 in phy phy1
nl80211: Set mode ifindex 10 iftype 3 (AP)
nl80211: Setup AP(ap0) - device_ap_sme=1 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0x570d20 (device SME)
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x570d20 match=
nl80211: Enable Probe Request reporting nl_preq=0x570d80
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x570d80 match=
nl80211: QCA vendor test command returned -95 (Operation not supported)
nl80211: Add own interface ifindex 8
nl80211: if_indices[16]: 8
nl80211: Add own interface ifindex 10
nl80211: if_indices[16]: 8 10
nl80211: Adding interface ap0 into bridge br0
phy: phy1
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=52 freq=5260 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=56 freq=5280 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=60 freq=5300 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=64 freq=5320 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=100 freq=5500 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=104 freq=5520 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=108 freq=5540 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=112 freq=5560 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=116 freq=5580 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=120 freq=5600 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=124 freq=5620 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=128 freq=5640 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=132 freq=5660 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=136 freq=5680 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=140 freq=5700 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=149 freq=5745 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=153 freq=5765 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=157 freq=5785 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=161 freq=5805 MHz max_tx_power=20 dBm
Allowed channel: mode=2 chan=165 freq=5825 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=12 freq=2467 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=13 freq=2472 MHz max_tx_power=20 dBm
hw vht capab: 0x0, conf vht capab: 0x0
Completing interface initialization
Mode: IEEE 802.11g  Channel: 6  Frequency: 2437 MHz
DFS 0 channels required radar detection
nl80211: Set freq 2437 (ht_enabled=1, vht_enabled=0, bandwidth=20 MHz, cf1=2437 MHz, cf2=0 MHz)
  * freq=2437
  * vht_enabled=0
  * ht_enabled=1
  * sec_channel_offset=0
  * channel_type=1
RATE[0] rate=10 flags=0x1
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x1
RATE[3] rate=110 flags=0x1
RATE[4] rate=60 flags=0x0
RATE[5] rate=90 flags=0x0
RATE[6] rate=120 flags=0x0
RATE[7] rate=180 flags=0x0
RATE[8] rate=240 flags=0x0
RATE[9] rate=360 flags=0x0
RATE[10] rate=480 flags=0x0
RATE[11] rate=540 flags=0x0
hostapd_setup_bss(hapd=0x56e9a0 (ap0), first=1)
ap0: Flushing old station entries
nl80211: flush -> DEL_STATION ap0 (all)
ap0: Deauthenticate all stations
nl80211: sta_remove -> DEL_STATION ap0 ff:ff:ff:ff:ff:ff --> 0 (Success)
wpa_driver_nl80211_set_key: ifindex=10 (ap0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=10 (ap0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=10 (ap0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=10 (ap0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Using interface ap0 with hwaddr 02:08:22:ca:ec:fd and ssid "_test"
Deriving WPA PSK based on passphrase
SSID - hexdump_ascii(len=5):
     5f 4b 61 59 61                                    _test
PSK (ASCII passphrase) - hexdump_ascii(len=18): [REMOVED]
PSK (from passphrase) - hexdump(len=32): [REMOVED]
random: Cannot read from /dev/random: Resource temporarily unavailable
random: Got 0/20 bytes from /dev/random
random: Only 0/20 bytes of strong random data available from /dev/random
random: Not enough entropy pool available for secure operations
WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
Get randomness: len=32 entropy=0
GMK - hexdump(len=32): [REMOVED]
Key Counter - hexdump(len=32): [REMOVED]
WPA: Delay group state machine start until Beacon frames have been configured
nl80211: Set beacon (beacon_set=0)
nl80211: Beacon head - hexdump(len=56): 80 00 00 00 ff ff ff ff ff ff 02 08 22 ca ec fd 02 08 22 ca ec fd 00 00 00 00 00 00 00 00 00 00 64 00 11 04 00 05 5f 4b 61 59 61 01 08 82 84 8b 96 0c 12 18 24 03 01 06
nl80211: Beacon tail - hexdump(len=115): 2a 01 04 32 04 30 48 60 6c 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 2d 1a 0c 00 03 ff 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 3d 16 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 04 00 00 00 02 dd 18 00 50 f2 02 01 01 00 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
nl80211: ifindex=10
nl80211: beacon_int=100
nl80211: dtim_period=2
nl80211: ssid - hexdump_ascii(len=5):
  * beacon_int=100
nl80211: hidden SSID not in use
nl80211: privacy=1
nl80211: auth_algs=0x1
nl80211: wpa_version=0x2
nl80211: key_mgmt_suites=0x2
nl80211: pairwise_ciphers=0x18
nl80211: group_cipher=0x10
nl80211: SMPS mode - off
nl80211: beacon_ies - hexdump(len=6): 7f 04 00 00 00 02
nl80211: proberesp_ies - hexdump(len=6): 7f 04 00 00 00 02
nl80211: assocresp_ies - hexdump(len=6): 7f 04 00 00 00 02
WPA: Start group state machine to set initial keys
WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
Get randomness: len=16 entropy=0
GTK - hexdump(len=16): [REMOVED]
WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
wpa_driver_nl80211_set_key: ifindex=10 (ap0) alg=3 addr=0x521f2c key_idx=1 set_tx=1 seq_len=0 key_len=16
nl80211: KEY_DATA - hexdump(len=16): [REMOVED]
   broadcast key
nl80211: Set ap0 operstate 0->1 (UP)
netlink: Operstate: ifindex=10 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
Failed to set TX queue parameters for queue 0.
Failed to set TX queue parameters for queue 1.
Failed to set TX queue parameters for queue 2.
Failed to set TX queue parameters for queue 3.
ap0: interface state UNINITIALIZED->ENABLED
ap0: AP-ENABLED
ap0: Setup of interface done.
ctrl_iface not configured!
RTM_NEWLINK: ifi_index=10 ifname=ap0 operstate=6 linkmode=0 master=8 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
RTM_NEWLINK: ifi_index=10 ifname=ap0 master=8 operstate=6 ifi_family=7 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
nl80211: Add ifindex 8 for bridge br0
nl80211: ifindex 8 already in the list
RTM_NEWLINK: ifi_index=8 ifname=br0 operstate=6 linkmode=0 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
ap0: Event INTERFACE_STATUS (5) received
Unknown event 5
VLAN: RTM_NEWLINK: ifi_index=10 ifname=ap0 ifi_family=7 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
VLAN: vlan_newlink(ap0)
Seems like problem with random-device
Confirmed the issue was the entropy for WPA, as the system is doing nothing. I am still working to make all hardware.
entropy_avail should be higher than 100
# cat /proc/sys/kernel/random/entropy_avail
3318
Install rng (Random Number Generator) to gain enough entropy for WPA,SSL,GPG key generation
apt-get install rng-tools
echo 'HRNGDEVICE=/dev/urandom' >> /etc/default/rng-tools
docker0   Link encap:Ethernet  HWaddr 02:42:71:11:c3:47
          inet addr:172.17.0.1  Bcast:172.17.255.255  Mask:255.255.0.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth0      Link encap:Ethernet  HWaddr ee:c8:85:f9:0a:59
          inet addr:192.168.1.8  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::ecc8:85ff:fef9:a59/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1139 errors:0 dropped:10 overruns:0 frame:0
          TX packets:734 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:153706 (153.7 KB)  TX bytes:105033 (105.0 KB)
          Interrupt:71
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:99 errors:0 dropped:0 overruns:0 frame:0
          TX packets:99 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:9877 (9.8 KB)  TX bytes:9877 (9.8 KB)
rfkill: initial event: idx=0 type=2 op=0 soft=0 hard=0
rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
rfkill: initial event: idx=2 type=1 op=0 soft=0 hard=0
rfkill: initial event: idx=3 type=2 op=0 soft=0 hard=0
Could not read interface ap0 flags: No such device
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=ap0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=0 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 0 iftype 2 (STATION)
nl80211: Failed to set interface 0 to mode 2: -19 (No such device)
nl80211 driver initialization failed.
hostapd_interface_deinit_free(0x7f6d3cd8)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0x7f6d3cd8)
ap0: interface state UNINITIALIZED->DISABLED
hostapd_bss_deinit: deinit bss ap0
ap0: AP-DISABLED
hostapd_cleanup(hapd=0x7f6d49a0 (ap0))
hostapd_free_hapd_data: Interface ap0 wasn't started
hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit
hostapd_interface_free(0x7f6d3cd8)
hostapd_interface_free: free hapd 0x7f6d49a0
hostapd_cleanup_iface(0x7f6d3cd8)
hostapd_cleanup_iface_partial(0x7f6d3cd8)
hostapd_cleanup_iface: free iface=0x7f6d3cd8
ifconfig -a
bond0     Link encap:Ethernet  HWaddr aa:46:01:b7:36:bb
          BROADCAST MASTER MULTICAST  MTU:1500  Metric:1
          RX packets:3508 errors:0 dropped:10 overruns:0 frame:0
          TX packets:1848 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:353407 (353.4 KB)  TX bytes:770480 (770.4 KB)
          Interrupt:71
eth1      Link encap:Ethernet  HWaddr 4e:06:78:74:1d:29
          Interrupt:71
          RX packets:103 errors:0 dropped:0 overruns:0 frame:0
          TX packets:103 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:10386 (10.3 KB)  TX bytes:10386 (10.3 KB)
sit0      Link encap:IPv6-in-IPv4
          NOARP  MTU:1480  Metric:1
tunl0     Link encap:IPIP Tunnel  HWaddr
163
init combo device
Opened combo device
@Jackzeng Any updates on this R2 stuck in booting progress issue?.
Hello, Do you mean you need to use Ctrl+D to skip when R2 stuck? if yes, that probably filesystem was broken, you could try to change filesystem to only read, after all you configurations configured.
@Jackzeng My usecase is, I dont want to use Ctl+D and the boot process should be auto error check & fix it like normal Ubuntu is doing. Because, there will be NO keyboard/monitor for end user to understand why the boot process struck. So it should be done automatically; Not by using any user’s input.
Maybe this can help: http://xmodulo.com/automatic-filesystem-checks-repair-linux.html
@garywang @jackzeng have you a clue,why entropy is so bad?
Are you running the haveged daemon?
I have no problems (no additional daemon,but lxc with 2 containers which maybe helping on creating entropy), but xbgmsharp has massive problems…also with rng-daemon
i saw that line on powerdown: “Stopped Load/Save Random Seed.” maybe this does not work for user @xbgmsharp
This is the same image but with all the packages updated to 12/05/2018, moreover I allowed myself to enable the ssh access also for the root as in the development phase in my opinion makes everything more flexible.
The available usernames are: pi, root. The passwords are respectively: bananapi, bananapi
https://mega.nz/#!VMw0QR5J!mCsgmRU7QGmpolaBkSxtQ8CfGRTcCRotaawtw_tS6b0
I would like to use the USBIP that is integrates in the Linux-Tools. has somebody an instruction for this?
Hi, just wanted to remark that the login credentials are a bit misleading. It might just be me, but upon downloading via Google drive root / bananapi didn’t work. Turns out the login is now pi / bananapi. Go figure ¯_(ツ)_/¯
