BPI-R2 new image: OpenWrt 18.06.2 source code fork
(Alexey Loukianov) #1
Last few months I’ve been working on getting BPi R2 upstream OpenWrt support into a better state. Finally the project is in good enough shape to be shared with wider public.
Welcome aboard:
To build use the standard OpenWrt build procedure:
$ git clone https://github.com/lexa2/openwrt.git
$ cd openwrt
$ git checkout v18.06.2-bpir2-rc1
$ { echo CONFIG_TARGET_mediatek=y; echo CONFIG_TARGET_mediatek_mt7623=y; echo CONFIG_TARGET_mediatek_mt7623_DEVICE_7623n-bananapi-bpi-r2=y; } > .config
$ { echo CONFIG_DEVEL=y; echo CONFIG_CCACHE=y; } >> .config
$ make defconfig
$ make menuconfig
$ make -j16
Important: make sure to disable generation of initramfs and squashfs images in menuconfig. It is located under “Target Images —>” menu. Only ext4-based images are supported at current state. I’m working on getting squashfs support into a better shape.
Note: boot and root partition sizes are defined under “Target Images —>” menu in menuconfig. Default sizes are 32Mb for boot and 256Mb for root. It is OK to resize any of these using partition management utilities after writing the image to the SD card.
Warning: Moving the start of the boot partition is forbidden and might lead to an unbootable image. Space from the start of SD card and up to the start of the boot partition is reserved for board boot purposes and should not be touched.
In case compilation fails with some error rerun make like this: make -j1 V=s. Details will be revealed showing what’s going on and what went wrong. Upon successful compilation resulting image will be available in bin/targets/mediatek/mt7623:
$ ls -1 bin/targets/mediatek/mt7623
config.seed
openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-ext4-sdcard.img.gz
openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-ext4-sysupgrade.tar.gz
openwrt-mediatek-mt7623-device-7623n-bananapi-bpi-r2.manifest
packages
sha256sums
Write the image to the SD card like this (assuming /dev/mmdblk1 is your SD card):
$ zcat openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-ext4-sdcard.img.gz | dd of=/dev/mmcblk1 bs=1M
$ sync
With luck your SD card should be ready to boot R2 into the OpenWrt 18.06.2.
P.S. Please do not report usage-related issues/quiestions to my github page - it is only for reporting code-related build system issues. Direct usage questions into this thread or better luck would be to post to OpenWrt users forum.
#2
I have a problem:
<ASSERT> mt_rtc_6323.c:line 106 0
[PLFM] preloader fatal error...
Something like this
(Alexey Loukianov) #3
Asserts are obviously different. Providing full bootlog will be a good idea :wink: . Also please provide (and compare to what I got) the output for the following commands:
$ cd /into/your/openwrt/buildroot/
$ sha1sum ./staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/bpi-r2-preloader.bin
51f2d73d6e1e47f9b961ec86b1cd624c8bc5e5d9 *./staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/bpi-r2-preloader.bin
$ SIZE=$(stat -c '%s' ./staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/bpi-r2-preloader.bin); zcat ./bin/targets/mediatek/mt7623/openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-ext4-sdcard.img.gz | dd bs=1 skip=2048 count=$SIZE 2>/dev/null| sha1sum
51f2d73d6e1e47f9b961ec86b1cd624c8bc5e5d9 *-
$ zcat ./bin/targets/mediatek/mt7623/openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-ext4-sdcard.img.gz | dd bs=1 count=20 2>/dev/null | md5sum
e1b8ea1c8320eb08f212c6576517d7c3 *-
$ zcat ./bin/targets/mediatek/mt7623/openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-ext4-sdcard.img.gz | dd bs=1 skip=512 count=48 2>/dev/null | md5sum
e03b8edee9ddcc97139f664b8bc4a3a8 *-
First two command calculate and compare sha1sum for preloader. Third and fourth generate checksums for required boot signatures (SDMMC_BOOT and BRLYT).
My guess would be that your host compiler for some reason (I believe I’ve seen a bug report some time ago about u-boot failing to boot when compiled with recent gcc; wasn’t able to quickly find it now) failed to generate a proper u-boot binary.
You can check if u-boot is a culprit by downloading this one I built moment ago:
7623n-bananapi-bpi-r2-uboot-mediatek.bin (290.2 KB)
Implant it into your SD card like this:
$ dd if=7623n-bananapi-bpi-r2-uboot-mediatek.bin of=<your SD card block device> bs=1024 seek=320 conv=notrunc
Another possibility is that the preloader image I use for OpenWRT is a bad one. It work for my boards but whatever. Vendor remains silent w.r.t. my requests on what preloader image should be used with OpenWrt:
Still hadn’t got any response. You can try your luck with other preloaders from here:
Download any file having BPI-R2 in the beginning of its name and 2k at any part of the name. Then extract preloader from it and implant into your SD card:
$ zcat <file you had downloaded named like BPI-R2*2k*.gz> | dd of=preloader.bin bs=1024 count=300
$ dd if=preloader.bin of=<your SD card block device> bs=1024 seek=2 conv=notrunc
Good luck with hunting it down, please report back your findings here.
#4
Full bootlog
[USBD] USB PRB0 LineState: 0
[USBD] USB cable/ No Cable inserted!
[PLFM] Keep stay in USB Mode
Platform initialization is ok
wait for frequency meter finish, CLK26CALI = 0x81
mt_pll_post_init: mt_get_cpu_freq = 1040000Khz
wait for frequency meter finish, CLK26CALI = 0x90
mt_pll_post_init: mt_get_bus_freq = 273000Khz
mt_pll_post_init: mt_get_mem_freq = 133250Khz
[PWRAP] pwrap_init_preloader
[PWRAP] pwrap_init
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=0,rdata=2D52
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=1,rdata=2D52
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=2,rdata=2D52
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=3,rdata=800
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=4 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=5 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=6 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=7 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=8 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=9 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=10 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=11,rdata=1001
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=12,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=13,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=14,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=15,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=16,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=17,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=18,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=19,rdata=2003
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=20,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=21,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=22,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=23,rdata=6A97
[PWRAP] _pwrap_init_reg_clock
[PMIC_WRAP]wrap_init pass,the return value=0.
[pmic6323_init] Preloader Start..................
[pmic6323_init] PMIC CHIP Code = 0x2023
INT_MISC_CON: 1  TOP_RST_MISC: 1
pl pmic powerkey Press
[pmic6323_init] powerKey = 1
[pmic6323_init] is USB in = 0xB004
[pmic6323_init] Reg[0x11A]=0x1B
pmic setup LED
[pmic6323_init] Done...................
mt7623 disable long press reset ->>>>>
mt7623 disable long press reset <<<<<-
mt7623 VPA supplied by 1.0V to MT7530 ->
mt7623 VPA supplied by 1.0V to MT7530 <-
mt7623 enables RG_VGP1_EN for LCM ->
mt7623 enables RG_VGP1_EN for LCM <-
MT7623 E2 setting =>
MT7623 E2 setting <=
[PLFM] Init I2C: OK(0)
[PLFM] Init PWRAP: OK(0)
[PLFM] Init PMIC: OK(0)
[PLFM] chip[CA00]
[BLDR] [Support SD/eMMC] Build Time: 20170114-170026
==== Dump RGU Reg ========
RGU MODE:     4D
RGU LENGTH:   FFE0
RGU STA:      0
RGU INTERVAL: FFF
RGU SWSYSRST: 0
==== Dump RGU Reg End ====
RGU: g_rgu_satus:0
 mtk_wdt_mode_config  mode value=10, tmp:22000010
PL P ON
WDT does not trigger reboot
RGU mtk_wdt_init:MTK_WDT_DEBUG_CTL(590200F3)
kpd read addr: 0x0040: data:0x4001
Enter mtk_kpd_gpio_set!
kpd debug column : 0, 0, 0, 0, 0, 0, 0, 0
kpd debug row : 0, 0, 0, 0, 0, 0, 0, 0
after set KP enable: KP_SEL = 0x0 !
MTK_PMIC_RST_KEY is used for this project!
[RTC] get_frequency_meter: input=0x0, ouput=5
[RTC] get_frequency_meter: input=0x0, ouput=0
[RTC] get_frequency_meter: input=0x0, ouput=4173
[RTC] RTC 32K mode setting wrong. Enter first boot/recovery.
[RTC] bbpu = 0x40, con = 0x8000
rtc_first_boot_init
[RTC] rtc cbusy time out!!!!!
rtc_recovery_flow
[RTC] get_frequency_meter: input=0x0, ouput=4172
Checksums is similar:
D:\OpenWRT\openwrt>sha1sum ./staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/bpi-r2-preloader.bin
51f2d73d6e1e47f9b961ec86b1cd624c8bc5e5d9  ./staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/image/bpi-r2-pre
# dd if=openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-ext4-sdcard.img bs=1 count=20 2>/dev/null | md5sum
e1b8ea1c8320eb08f212c6576517d7c3  -
# dd if=openwrt-mediatek-mt7623-7623n-bananapi-bpi-r2-ext4-sdcard.img bs=1 skip=512 count=48 2>/dev/null | md5sum
e03b8edee9ddcc97139f664b8bc4a3a8  -
I compare uboot with image in hexedit.
they have no differences:
But i found diff SDMMC_BOOT and BRLYT in my old image and your
your on left
(Alexey Loukianov) #5
That’s normal - differences are in the parts that are not checked. IIRC SDMMC_BOOT signarure is 20 bytes long and BRLYT is believed to be 32 bytes long but I’m using 48 bytes from original upstream images just to be on a safe side.
Your bootlog show that everything is OK w.r.t. signatures as preloader was loaded and started but had problems dealing with onboard RTC and treated this problems as fatal.
Here is how this part of boot looks like on my board:
[RTC] get_frequency_meter: input=0x0, ouput=3968
[RTC] bbpu = 0xD, con = 0x426
[RTC] powerkey1 = 0xA357, powerkey2 = 0x67D2
Writeif_unlock
[RTC] RTC_SPAR0=0x40
rtc_2sec_reboot_check cali=1024
[RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0x40, spar1 = 0x800
[RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1
[RTC] bbpu = 0xD, con = 0x426, cali = 0x400
SW reset with bypass power key flag
[PLFM] WDT reboot bypass power key!
[RTC] rtc_bbpu_power_on done
So it brings us back to a question if the preloader I chose for use with OpenWrt is a proper one. Here are two other preloaders to try:
BPI-R2-EMMC-boot0-0K-0905.img (90.5 KB)
BPI-R2-720P-2k.img (92 KB)
Please try implanting each of this one by one into your SD card starting from offset 2048 (2k) and report back results. I suspect that BPI-R2-720P-2k.img might initialize onboard memory to 1333 instead of expected 1600.
#6
I think problem occurred due to the power supply. after additional connecting +5 to OTG port botting is normal:
root@OpenWrt:/# df -h
/dev/root               126.0M      8.9M    114.5M   7% /
tmpfs                  1011.9M     48.0K   1011.8M   0% /tmp
Compiled Image (link will be available 14 days)
(Frank W.) #7
sounds like a problem only appear on power-cycle…i’ve read about a similar problem on guthub, but did not found the issue yet…maybe trying the other preloader (1333 vs. 1600)
(Alexey Loukianov) #8
We had settled down that it was an insufficient power related problem for @Tohin case. PSU in this case was an old 1.5A 12V brick in unknown condition w.r.t. ripple e.t.c. Providing additional stable 5V supply on the OTG port fixed the issue immediately.
