BPI-R2 new image: BPI-R2 OpenWrt(LEDE) Souce code : 2018-05-09
(rr) #43
Hi Frank,
So I burned the image of ubuntu 16 from your images, than I copied the contents of BPI-BOOT the bananapi folder to the boot directory on disk and BPI-ROOT contents, the lib folder to the root directory overwriting the lib folder. But the bananapi will not boot, I get a blue screen and after a few seconds it turns black, saying no signal.
(Frank W.) #44
I guess you use hdmi? This is one of things only working on 4.4…but you can change network-settings like described on my wiki to login via ssh or use debug-uart (usb2serial).
(rr) #45
I’ll give that a try. Where is your wiki on setting up ssh?
#46
Hello, i get a “Bad Gateway” error for luci ???
(gary) #47
Hi Roman
Yes, the HDMI is not supported in openwrt yet. We can use the below three ways to login to R2 board if you use latest openwrt image:
  1. Serial port,
  2. ssh root@192.168.1.1 (from one of four lan ports), the 192.168.1.1 is the default gateway.
  3. web: http://192.168.1.1 (from one of four lan ports)
The Switch does works if you use ubuntu image, but HNAT doesn’t work, and we have no plan to support it.
(gary) #48
I also faced this problem one week ago, the reason is latest source code of luci doen’t stable yet, also I report issue to here: https://github.com/jow-/lucihttp/issues/1, but have no time to find the root cause yet.
The workaround is to use stable luci code, so please change the source of luci package in feeds.conf.default to below:
src-git luci https://github.com/openwrt/luci.git;lede-17.01
#49
Thank nicoo. I found some other interfaces. Do you know they can be used?
/proc/sys/net/ipv6/conf/all/temp_prefered_lft
/proc/sys/net/ipv6/conf/all/temp_valid_lft
/proc/sys/net/ipv6/conf/all/use_tempaddr
/proc/sys/net/ipv6/conf/br-lan/temp_prefered_lft
/proc/sys/net/ipv6/conf/br-lan/temp_valid_lft
/proc/sys/net/ipv6/conf/br-lan/use_tempaddr
/proc/sys/net/ipv6/conf/default/temp_prefered_lft
/proc/sys/net/ipv6/conf/default/temp_valid_lft
/proc/sys/net/ipv6/conf/default/use_tempaddr
/proc/sys/net/ipv6/conf/eth0/temp_prefered_lft
/proc/sys/net/ipv6/conf/eth0/temp_valid_lft
/proc/sys/net/ipv6/conf/eth0/use_tempaddr
/proc/sys/net/ipv6/conf/eth1/temp_prefered_lft
/proc/sys/net/ipv6/conf/eth1/temp_valid_lft
/proc/sys/net/ipv6/conf/eth1/use_tempaddr
/proc/sys/net/ipv6/conf/gre0/temp_prefered_lft
/proc/sys/net/ipv6/conf/gre0/temp_valid_lft
/proc/sys/net/ipv6/conf/gre0/use_tempaddr
/proc/sys/net/ipv6/conf/gretap0/temp_prefered_lft
/proc/sys/net/ipv6/conf/gretap0/temp_valid_lft
/proc/sys/net/ipv6/conf/gretap0/use_tempaddr
/proc/sys/net/ipv6/conf/lan0/temp_prefered_lft
/proc/sys/net/ipv6/conf/lan0/temp_valid_lft
/proc/sys/net/ipv6/conf/lan0/use_tempaddr
/proc/sys/net/ipv6/conf/lan1/temp_prefered_lft
/proc/sys/net/ipv6/conf/lan1/temp_valid_lft
/proc/sys/net/ipv6/conf/lan1/use_tempaddr
/proc/sys/net/ipv6/conf/lan2/temp_prefered_lft
/proc/sys/net/ipv6/conf/lan2/temp_valid_lft
/proc/sys/net/ipv6/conf/lan2/use_tempaddr
/proc/sys/net/ipv6/conf/lan3/temp_prefered_lft
/proc/sys/net/ipv6/conf/lan3/temp_valid_lft
/proc/sys/net/ipv6/conf/lan3/use_tempaddr
/proc/sys/net/ipv6/conf/lo/temp_prefered_lft
/proc/sys/net/ipv6/conf/lo/temp_valid_lft
/proc/sys/net/ipv6/conf/lo/use_tempaddr
/proc/sys/net/ipv6/conf/wan/temp_prefered_lft
/proc/sys/net/ipv6/conf/wan/temp_valid_lft
/proc/sys/net/ipv6/conf/wan/use_tempaddr
/sys/devices/virtual/thermal/thermal_zone0/trip_point_3_temp
/sys/devices/virtual/thermal/thermal_zone0/trip_point_2_temp
/sys/devices/virtual/thermal/thermal_zone0/trip_point_1_temp
/sys/devices/virtual/thermal/thermal_zone0/trip_point_0_temp
/sys/devices/virtual/thermal/thermal_zone0/temp
/sys/firmware/devicetree/base/thermal-zones/cpu_thermal/trips/cpu_passive/temperature
/sys/firmware/devicetree/base/thermal-zones/cpu_thermal/trips/cpu_active/temperature
/sys/firmware/devicetree/base/thermal-zones/cpu_thermal/trips/cpu_hot/temperature
/sys/firmware/devicetree/base/thermal-zones/cpu_thermal/trips/cpu_crit/temperature
(Frank W.) #50
Is ssh enqbled in ubuntu by default with permitrootlogin? Have it also fixed on lan-ports?
Are you workin on integrating hdmi in 4.14?
@roman i hve no page for ssh yet…i mean configure network to get access to exing ssh-server. Network-config in 4.14 is different to 4.4 because of changed interface-names. But please make a new thread…this is for lede
(gary) #51
Vendor has submited patch of HDMI to kernel 4.16, but we don’t have time to port it to 4.14 and 4.9(openwrt).
#52
How can i compile as “hard-float” ? What i have to change during compile process ? Thanks a lot for all your help Guys
(gary) #53
Please make sure you’re using latest source code from https://github.com/garywangcn/bpi-r2_lede/tree/bpi-r2-on-lede-v1, and then ensure the option Advanced configuration options ->Target Options ->Use software floating point by default is NOT selected. And then compile whole project.
#54
Great Thanks @garywang So in this case i think, is a good choice to check the checkbox for all the userspace packages, right ?
(nicoo) #55
status (boolean) temporary IPv6 address. I didn’t check all your entries, I may know some of them but I mostly don’t know them… anyway you can forget all /proc/sys/net/ipv6/ entries. they are nothing related to temperature.
those inside /sy/device/virtual are parentless devices… I personally never have to deal with them, I don’t know much about them, excpet that they are used somehow for RAID… fyi, virtual devices can be elsewhere too…
/sys/firmware/devicetree/base/thermal-zones/cpu_thermal/ I don’t much about it, but seems interesting. I can’t turn on my BPI for now…
I need myself to monitor the temperature, I don’t know yet where are temperature sensors on the BPI, but I keep in mind to connect my own senor directly to the gpio. I don’t know if the gpio can be used with lede though…
hope this answer somehow
#56
didn’t work ,again Bad Gateway…
(gary) #57
It will take a huge time to validate all userspace packages, actually we’d like you are using the packages from the stable release, also please maintain yourself repository if you want to make a product based on R2 and Openwrt.
(gary) #58
can you please share us the list of installed packages? If you are still use latest luci code, maybe the workaround in https://github.com/jow-/lucihttp/issues/1 is required, please note that the workaround isn’t agreed by author yet.
#59
> base-files - 174-r4773-2cb61a83f4
> blkid - 2.30.1-2
> block-mount - 2017-07-31-8ab4fda6-1
> blockd - 2017-07-31-8ab4fda6-1
> busybox - 1.26.2-7
> chattr - 1.43.5-1
> curl - 7.54.1-1
> dnsmasq - 2.77-8
> dropbear - 2017.75-3
> e2fsprogs - 1.43.5-1
> fdisk - 2.30.1-2
> firewall - 2017-05-27-a4d98aea-1
> fstools - 2017-07-31-8ab4fda6-1
> fwtool - 1
> hostapd-common - 2016-12-19-ad02e79d-4
> ip-tiny - 4.11.0-1
> ip6tables - 1.6.1-1
> iptables - 1.6.1-1
> iptables-mod-ipsec - 1.6.1-1
> iwinfo - 2017-08-23-c1a03e82-1
> jshn - 2017-06-17-fd57eea9-1
> jsonfilter - 2016-07-02-dea067ad-1
> kernel - 4.9.44-1-06049d59456e793334a35db08d676f50
> kmod-crypto-aead - 4.9.44-1
> kmod-crypto-authenc - 4.9.44-1
> kmod-crypto-cbc - 4.9.44-1
> kmod-crypto-deflate - 4.9.44-1
> kmod-crypto-des - 4.9.44-1
> kmod-crypto-echainiv - 4.9.44-1
> kmod-crypto-hash - 4.9.44-1
> kmod-crypto-hmac - 4.9.44-1
> kmod-crypto-iv - 4.9.44-1
> kmod-crypto-manager - 4.9.44-1
> kmod-crypto-md5 - 4.9.44-1
> kmod-crypto-null - 4.9.44-1
> kmod-crypto-pcompress - 4.9.44-1
> kmod-crypto-rng - 4.9.44-1
> kmod-crypto-sha1 - 4.9.44-1
> kmod-crypto-sha256 - 4.9.44-1
> kmod-crypto-wq - 4.9.44-1
> kmod-fs-autofs4 - 4.9.44-1
> kmod-gpio-button-hotplug - 4.9.44-2
> kmod-ip6tables - 4.9.44-1
> kmod-ipsec - 4.9.44-1
> kmod-ipsec4 - 4.9.44-1
> kmod-ipsec6 - 4.9.44-1
> kmod-ipt-conntrack - 4.9.44-1
> kmod-ipt-core - 4.9.44-1
> kmod-ipt-ipsec - 4.9.44-1
> kmod-ipt-nat - 4.9.44-1
> kmod-iptunnel4 - 4.9.44-1
> kmod-iptunnel6 - 4.9.44-1
> kmod-leds-gpio - 4.9.44-1
> kmod-lib-crc-ccitt - 4.9.44-1
> kmod-lib-zlib-deflate - 4.9.44-1
> kmod-lib-zlib-inflate - 4.9.44-1
> kmod-nf-conntrack - 4.9.44-1
> kmod-nf-conntrack6 - 4.9.44-1
> kmod-nf-ipt - 4.9.44-1
> kmod-nf-ipt6 - 4.9.44-1
> kmod-nf-nat - 4.9.44-1
> kmod-ppp - 4.9.44-1
> kmod-pppoe - 4.9.44-1
> kmod-pppox - 4.9.44-1
> kmod-slhc - 4.9.44-1
> lede-keyring - 2017-01-20-a50b7529-1
> libblkid - 2.30.1-2
> libblobmsg-json - 2017-06-17-fd57eea9-1
> libbz2 - 1.0.6-3
> libc - 1.1.16-1
> libcurl - 7.54.1-1
> libext2fs - 1.43.5-1
> libfdisk - 2.30.1-2
> libgcc - 5.4.0-1
> libgmp - 6.1.2-1
> libip4tc - 1.6.1-1
> libip6tc - 1.6.1-1
> libiwinfo - 2017-08-23-c1a03e82-1
> libiwinfo-lua - 2017-08-23-c1a03e82-1
> libjson-c - 0.12.1-1
> libjson-script - 2017-06-17-fd57eea9-1
> liblua - 5.1.5-1
> liblucihttp - 2018-04-22-ccc685e5-1
> liblucihttp-lua - 2018-04-22-ccc685e5-1
> libmbedtls - 2.5.1-1
> libncurses - 6.0-1
> libnl-tiny - 0.1-5
> libopenssl - 1.0.2l-1
> libpthread - 1.1.16-1
> librt - 1.1.16-1
> libsmartcols - 2.30.1-2
> libubox - 2017-06-17-fd57eea9-1
> libubus - 2017-02-18-34c6e818-1
> libubus-lua - 2017-02-18-34c6e818-1
> libuci - 2017-04-12-c4df32b3-1
> libuci-lua - 2017-04-12-c4df32b3-1
> libuclient - 2016-12-09-52d955fd-1
> libustream-openssl - 2016-07-02-ec80adaa-2
> libuuid - 2.30.1-2
> libxtables - 1.6.1-1
> logd - 2017-03-03-21a4bd04-1
> lua - 5.1.5-1
> luci - git-18.138.35484-521554f-1
> luci-app-firewall - git-18.138.35484-521554f-1
> luci-base - git-18.138.35484-521554f-1
> luci-lib-ip - git-18.138.35484-521554f-1
> luci-lib-jsonc - git-18.138.35484-521554f-1
> luci-lib-nixio - git-18.138.35484-521554f-1
> luci-mod-admin-full - git-18.138.35484-521554f-1
> luci-proto-ipv6 - git-18.138.35484-521554f-1
> luci-proto-ppp - git-18.138.35484-521554f-1
> luci-theme-bootstrap - git-18.138.35484-521554f-1
> mtd - 21
> netifd - 2017-08-22-b5731bfb-1
> nstat - 4.11.0-1
> odhcp6c - 2017-03-22-0463b057-2
> odhcpd - 2017-08-16-94e65ee0-1
> openssl-util - 1.0.2l-1
> opkg - 2017-07-28-4bd8601e-1
> ppp - 2.4.7-12
> ppp-mod-pppoe - 2.4.7-12
> procd - 2017-08-22-54b46a35-1
> rpcd - 2016-12-03-0577cfc1-1
> rpcd-mod-rrdns - 20170710
> terminfo - 6.0-1
> trace-cmd - v2.6.1-1
> ubi-utils - 1.5.2-1
> ubox - 2017-03-03-21a4bd04-1
> ubusd - 2017-02-18-34c6e818-1
> uclient-fetch - 2016-12-09-52d955fd-1
> uhttpd - 2016-10-25-1628fa4b-2
> uhttpd-mod-ubus - 2016-10-25-1628fa4b-2
> usign - 2015-07-04-ef641914-1
> wmt - 4.9.44
> wpad-mini - 2016-12-19-ad02e79d-4
(gary) #60
You are still using latest luci code, you have two ways to let luci to work:
  1. Apply below patch to file build/target…/lucihttp-2018-04-22-ccc685e5/lib/lua.c, and then rebuild project. image
  2. Use the code from https://github.com/openwrt/luci.git;lede-17.01, the commands are: 1). change feeds.conf.default 2). scripts/feeds update -a 3). scripts/feeds install -a 4). make -j1 V=s
#61
so maybe my fault was not to enter the commands from step 2 to 3. I changed the feeds.conf.default but nothing was changed (without step 2,3) Thanks a lot @garywang I will give them a try
also i cannot find “build/target…/lucihttp-2018-04-22-ccc685e5/lib…”
#62
bpi-r2_lede/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_32/siit-1.2/siit.o’ failed
resolved with patch
