Hello, i compiled kernel 5.4.24 with DVB-S2 card support but i found out that kernel does not support docker.Can someone recommend me the best kernel for DVB-S2 card, docker, MT7530, raid support ?
It should support docker because previous versions did and i used same config…
Can you please tell me options you need to run your specific docker container and i can add them
Hi frank-w, i do not understand. I spent two days of installing, reinstalling docker and i always was unsuccessful. Now i installed once again and it was done. Thanks for your reply.
Docker has a script (pls do not ask me the name) to check which kernel options are missing… But goot to hear it is working now
Do yoú mean check-config ?
here is output
Generally Necessary:
- cgroup hierarchy: properly mounted [/sys/fs/cgroup]
- CONFIG_NAMESPACES: enabled
- CONFIG_NET_NS: enabled
- CONFIG_PID_NS: enabled
- CONFIG_IPC_NS: enabled
- CONFIG_UTS_NS: enabled
- CONFIG_CGROUPS: enabled
- CONFIG_CGROUP_CPUACCT: enabled
- CONFIG_CGROUP_DEVICE: enabled
- CONFIG_CGROUP_FREEZER: enabled
- CONFIG_CGROUP_SCHED: enabled
- CONFIG_CPUSETS: enabled
- CONFIG_MEMCG: enabled
- CONFIG_KEYS: enabled
- CONFIG_VETH: enabled (as module)
- CONFIG_BRIDGE: enabled
- CONFIG_BRIDGE_NETFILTER: enabled (as module)
- CONFIG_NF_NAT_IPV4: missing
- CONFIG_IP_NF_FILTER: enabled (as module)
- CONFIG_IP_NF_TARGET_MASQUERADE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_IPVS: enabled (as module)
- CONFIG_IP_NF_NAT: enabled (as module)
- CONFIG_NF_NAT: enabled (as module)
- CONFIG_NF_NAT_NEEDED: missing
- CONFIG_POSIX_MQUEUE: enabled
Optional Features:
- CONFIG_USER_NS: enabled
- CONFIG_SECCOMP: enabled
- CONFIG_CGROUP_PIDS: enabled
- CONFIG_MEMCG_SWAP: enabled
- CONFIG_MEMCG_SWAP_ENABLED: enabled (cgroup swap accounting is currently enabled)
- CONFIG_BLK_CGROUP: enabled
- CONFIG_BLK_DEV_THROTTLING: missing
- CONFIG_IOSCHED_CFQ: missing
- CONFIG_CFQ_GROUP_IOSCHED: missing
- CONFIG_CGROUP_PERF: enabled
- CONFIG_CGROUP_HUGETLB: missing
- CONFIG_NET_CLS_CGROUP: missing
- CONFIG_CGROUP_NET_PRIO: enabled
- CONFIG_CFS_BANDWIDTH: enabled
- CONFIG_FAIR_GROUP_SCHED: enabled
- CONFIG_RT_GROUP_SCHED: enabled
- CONFIG_IP_NF_TARGET_REDIRECT: missing
- CONFIG_IP_VS: enabled (as module)
- CONFIG_IP_VS_NFCT: missing
- CONFIG_IP_VS_PROTO_TCP: missing
- CONFIG_IP_VS_PROTO_UDP: missing
- CONFIG_IP_VS_RR: missing
- CONFIG_EXT4_FS: enabled
- CONFIG_EXT4_FS_POSIX_ACL: enabled
- CONFIG_EXT4_FS_SECURITY: enabled
- Network Drivers:
- “overlay”:
- CONFIG_VXLAN: missing
- CONFIG_BRIDGE_VLAN_FILTERING: enabled
Optional (for encrypted networks):
- CONFIG_CRYPTO: enabled
- CONFIG_CRYPTO_AEAD: enabled
- CONFIG_CRYPTO_GCM: enabled
- CONFIG_CRYPTO_SEQIV: enabled
- CONFIG_CRYPTO_GHASH: enabled
- CONFIG_XFRM: enabled
- CONFIG_XFRM_USER: missing
- CONFIG_XFRM_ALGO: enabled (as module)
- CONFIG_INET_ESP: missing
- CONFIG_INET_XFRM_MODE_TRANSPORT: missing
- “ipvlan”:
- CONFIG_IPVLAN: enabled (as module)
- “macvlan”:
- CONFIG_MACVLAN: enabled (as module)
- CONFIG_DUMMY: enabled (as module)
- “ftp,tftp client in container”:
- CONFIG_NF_NAT_FTP: enabled (as module)
- CONFIG_NF_CONNTRACK_FTP: enabled (as module)
- CONFIG_NF_NAT_TFTP: missing
- CONFIG_NF_CONNTRACK_TFTP: missing
- “overlay”:
- Storage Drivers:
- “aufs”:
- CONFIG_AUFS_FS: missing
- “btrfs”:
- CONFIG_BTRFS_FS: enabled (as module)
- CONFIG_BTRFS_FS_POSIX_ACL: missing
- “devicemapper”:
- CONFIG_BLK_DEV_DM: enabled
- CONFIG_DM_THIN_PROVISIONING: enabled (as module)
- “overlay”:
- CONFIG_OVERLAY_FS: enabled
- “zfs”:
- /dev/zfs: missing
- zfs command: missing
- zpool command: missing
- “aufs”:
Limits:
- /proc/sys/kernel/keys/root_maxkeys: 1000000
Right,here you can look which modules are needed for your setup…
Imho nf_nat should be enabled in last 5.4
