BPI-R2-Kernel 4.18
Ok then we need vendor-support for this issue. @Ryder.Lee @garywang any ideas?
maybe you can try this patchset (4 patches): https://patchwork.kernel.org/patch/10500639/
Have you tried another drive/cable?
The patch does not work:
msze@dvig0472:~/BPI-R2-4.14$ patch -p1 < ./v3-1-4-PCI-mediatek-fixup-mtk_pcie_find_port-logical.patch
patching file drivers/pci/controller/pcie-mediatek.c
Hunk #1 FAILED at 337. 1 out of 1 hunk FAILED – saving rejects to file drivers/pci/controller/pcie-mediatek.c.rej
I will try another cable and couple of 2,5 inch drives this evening
I exchanged drive and cable and so far (copied only 6GB) so good. No errors. I will try this evening to copy something about 30-40GB.
If it success I will try to mkfs,ext4 on one 3TB drive and then check it again.
Sounds good…then change 1 back…maybe only the drive to figure out a cable problem. please tell me if it is working without the pcie-patch…
and please check if your sata-socket is soldered correctly like jofri wrote here: Searching testing people for hdmi + wifi in Kernel 4.16
You’re right my sata sockets (both) need resoldering. When I touch them the’re moving …
Have you resoldered sata sockets with success?
not yet. I’m waiting for Sinovoip decision … (my banana is still under warranty)
