BPI-R2 Ethernet MAC address
(Frank W.) #9
Have you used a actual uboot?
There is a fix for eth in uboot from nov 30th:
#10
Probably not, I’ve been using the recent images of LEDE and Ubuntu, but haven’t paid attention to what version of u-boot is included. I haven’t tried building BPI-R2-bsp yet, I will soon.
(Frank W.) #11
You can download the actual uboot from my gdrive
https://drive.google.com/drive/mobile/folders/1WLWAR1FC-rF4n2SgFecBlU1ym_XKqAR_/15Y5Y3NAOwg_IMmN3k6hdb7pAQj9oTVTl?usp=sharing&sort=13&direction=a
You can update it using bpi-update or like this: http://www.fw-web.de/dokuwiki/doku.php?id=en/bpi-r2/uboot#update_uboot
(moore liu) #12
this patch fixed the uboot load code issue which cannot download image via tftp protocol sometimes.
(Frank W.) #13
if the problem exists in current uboot,are there fixes for this?
(moore liu) #14
it is not an issue since mac address is from dts not uboot, thanks.
(Frank W.) #15
How do i set mac in dts? Is’nt there an uboot-way?
(moore liu) #16
you can refer to below discussion, thanks. http://zedboard.com/content/passing-mac-address-kernel-device-tree-blob
(Frank W.) #17
in that thread there must be added a entry to ethernet@xxxxx
local-mac-address = [00 0a 35 00 00 01];
i’ve found in mt7623.dtsi only 1 ethernet-section, is that eth0 or eth1?
as i see in curent kernel there are lan and wan both mapped to eth0:
4: wan@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default0
5: lan0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP0
6: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state 0
is that right? i supposed wan is a separate nic (eth1) and the lan-ports on eth0
this is on 4.4.70 (without dsa):
5: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKN0
6: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qle0
it seems that both nics are in same controller:
root@bpi-r2:~# find /sys/devices/platform/ -name 'eth0'
/sys/devices/platform/1b100000.ethernet/net/eth0
root@bpi-r2:~# find /sys/devices/platform/ -name 'eth1'
/sys/devices/platform/1b100000.ethernet/net/eth1
found nothing how they separated and why here 2 devices created
Ethernet-dts-entry is different…
4.4.70:
eth: ethernet@1b100000 {
		compatible = "mediatek,mt7623-eth";
		reg = <0 0x1b100000 0 0x20000>;
		interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_LOW>,
			     <GIC_SPI 199 IRQ_TYPE_LEVEL_LOW>,
			     <GIC_SPI 198 IRQ_TYPE_LEVEL_LOW>;
		clocks = <&topckgen CLK_TOP_ETHIF_SEL>,
			 <&clk26m>,
			 <&clk26m>,
			 <&clk26m>,
			 <&apmixedsys CLK_APMIXED_TRGPLL>,
			 <&ethsys CLK_ETHSYS_ESW>,
			 <&ethsys CLK_ETHSYS_GP2>,
			 <&ethsys CLK_ETHSYS_GP1>,
			 <&clk26m>,
			 <&clk26m>,
			 <&clk26m>,
			 <&clk26m>,
			 <&clk26m>;
		clock-names = "ethif", "eth1pll", "eth2pll",
			      "sgmipll", "trgpll", "esw", "gp2",
			      "gp1", "gp0", "sgmii_tx250m",
			      "sgmii_rx250m", "sgmii_cdr_ref",
			      "sgmii_cdr_fb";
		power-domains = <&scpsys MT2701_POWER_DOMAIN_ETH>;
		resets = <&watchdog MT2701_TOPRGU_ETHDMA_RST>;
		reset-names = "eth";
		mediatek,ethsys = <&ethsys>;
            mediatek,pctl = <&syscfg_pctl_a>;
		mediatek,switch = <&gsw>;
		#reset-cells = <1>;
		#address-cells = <1>;
		#size-cells = <0>;
		status = "disabled";
	gsw: gswsys@1b100000 {
		compatible = "mediatek,mt7623-gsw",
			     "mediatek,mt2701-gsw";
4.14 (last part):
reset-names = "fe", "gmac", "ppe";
#size-cells = <0>;
as you see in 4.4.70 there is a additional line +section
This will raise the question about lan/wan-isolation again…
Looked in schematics,but it’s not clear…on last page i see in block-diagram,that lan+wan goes over the 7530 switch…on the page with the switch only lan-ports are listed (1-4)
(gary) #18
Hi
I’ve tried the command ifconfig ethx hw ether 00:11:22:33:44:55 on both lede and ubuntu, it works. Can you please have a try?
(Frank W.) #19
i can also change mac with ifconfig hw ether…so i’m doing it currently (/etc/network/interfaces): http://www.fw-web.de/dokuwiki/doku.php?id=en/bpi-r2/software
but if the right way to do it is in dts…i want to set both interfaces in uboot, because then i have not recompile kernel and its independend from runnnig system
(Frank W.) #20
the way with “hwaddress ether” does not work in debian 9 (stretch), here you can do that with
iface lan0 inet static
  address 192.168.0.10
  netmask 255.255.255.0
  gateway 192.168.0.5
#  pre-up ip link set $IFACE up
  pre-up ip link set $IFACE address 02:01:02:03:04:08 up
  post-down ip link set $IFACE down
in /etc/network/interfaces
#21
It actually work in LEDE. Can you try use same MAC in wan and the device under br-lan.
(gary) #22
Hi BoringCat
I don’t think we can use the same MAC address for both wan and br-lan, this may cause switch chip doesn’t work fine.
(Weiqi Chen) #23
$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether ae:fc:de:ad:be:ef brd ff:ff:ff:ff:ff:ff
3: wan@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
4: lan0@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
5: lan1@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
6: lan2@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
7: lan3@eth0: <BROADCAST,MULTICAST,M-DOWN> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
$ cat /etc/udev/rules.d/00-static-mac-address.rules
ACTION=="add", SUBSYSTEM=="net", KERNELS=="1b100000.ethernet", RUN+="/sbin/ip link set dev %k address ae:fc:de:ad:be:ef"
I hate this solution, But …
@frank-w
(Frank W.) #24
?? what do you want to say me? :thinking:
that all interfaces are the same mac? it’s because currently only 1 gmac is used between mt7530 (switch) and CPU
see thread about the second GMAC
(Weiqi Chen) #25
I @you because the your solution(BPI-R2 Ethernet MAC address) might not work well for the linux kernel from your github repos.
(Frank W.) #26
currently in debian stretch with my kernel i do it that way:
  gateway 192.168.0.5
but good to know that there is a udev-way to do that
(moore liu) #27
it is ok because lan and wan are different subnet and we only need to make sure the mac address is unique for one subnet.
#28
Yes it is. But just on “Network Layer”. Because all Ethernet port on R2 is actually a mt7530 switch. The switch works on “Data Link Layer”. So If there are two devices have same MAC. It’s chip will not work fine.
