BPI-R2 Compile errror about flex-2.6.4
Hello,
my sourcecode is form: https://github.com/garywangcn/bpi-r2_lede/tree/bpi-r2-on-lede-v1
my host PC settings :
  • cat /proc/version
  • Linux version 4.15.0-42-generic (buildd@lgw01-amd64-023) (gcc version 7.3.0 (Ubuntu 7.3.0-16ubuntu3)) #45-Ubuntu SMP Thu Nov 15 19:32:57 UTC 2018
when I compile with: make V=s -j1, I hava a compiling error:
  • Makefile:1689: recipe for target ‘stage1scan.c’ failed
  • make[6]: *** [stage1scan.c] Segmentation fault (core dumped)
  • make[6]: Leaving directory '/home/****/bpi-r2_lede/build_dir/host/flex-2.6.4/src
  • Makefile:539: recipe for target ‘all’ failed
  • make[5]: *** [all] Error 2
  • make[5]: Leaving directory ‘/home/****/bpi-r2_lede/build_dir/host/flex-2.6.4/src’
  • Makefile:525: recipe for target ‘all-recursive’ failed
  • make[4]: *** [all-recursive] Error 1
  • make[4]: Leaving directory ‘/home/****/bpi-r2_lede/build_dir/host/flex-2.6.4’
  • Makefile:28: recipe for target ‘/home/****/bpi-r2_lede/build_dir/host/flex-2.6.4/.built’ failed
  • make[3]: *** [/home/****/bpi-r2_lede/build_dir/host/flex-2.6.4/.built] Error 2
  • make[3]: Leaving directory ‘/home/****/bpi-r2_lede/tools/flex’
  • tools/Makefile:148: recipe for target ‘tools/flex/compile’ failed
  • make[2]: *** [tools/flex/compile] Error 2
  • make[2]: Leaving directory ‘/home/****/bpi-r2_lede’
  • tools/Makefile:146: recipe for target ‘/home/****/bpi-r2_lede/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.tools_compile_yynyyyyynyyyyynyynnyyyynyyyyyyyyyyyyyyynyynynnyyynny’ failed
  • make[1]: *** [/home/****/bpi-r2_lede/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.tools_compile_yynyyyyynyyyyynyynnyyyynyyyyyyyyyyyyyyynyynynnyyynny] Error 2
  • make[1]: Leaving directory ‘/home/****/bpi-r2_lede’
  • /home/****/bpi-r2_lede/include/toplevel.mk:207: recipe for target ‘world’ failed
  • make: *** [world] Error 2
Is there someone has the same problem?
Hello,could you please show me the whole print log?
it is difficult to judge the error only by this part.
Hello Jack,the problem is closed now, I changed flex2.6.4 to flex2.6.3.
This still happens on a fresh setup
/usr/bin/env bash ../libtool  --tag=CC   --mode=link gcc  -O2 -I/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/host/include -I/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/host/usr/include   -L/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/host/lib -L/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/host/usr/lib  -o stage1flex stage1flex-scan.o stage1flex-buf.o stage1flex-ccl.o stage1flex-dfa.o stage1flex-ecs.o stage1flex-filter.o stage1flex-gen.o stage1flex-main.o stage1flex-misc.o stage1flex-nfa.o stage1flex-options.o stage1flex-parse.o stage1flex-regex.o stage1flex-scanflags.o stage1flex-scanopt.o stage1flex-skel.o stage1flex-sym.o stage1flex-tables.o stage1flex-tables_shared.o stage1flex-tblcmp.o stage1flex-yylex.o    -lm
OpenWrt-libtool: link: gcc -O2 -I/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/host/include -I/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/host/usr/include -o stage1flex stage1flex-scan.o stage1flex-buf.o stage1flex-ccl.o stage1flex-dfa.o stage1flex-ecs.o stage1flex-filter.o stage1flex-gen.o stage1flex-main.o stage1flex-misc.o stage1flex-nfa.o stage1flex-options.o stage1flex-parse.o stage1flex-regex.o stage1flex-scanflags.o stage1flex-scanopt.o stage1flex-skel.o stage1flex-sym.o stage1flex-tables.o stage1flex-tables_shared.o stage1flex-tblcmp.o stage1flex-yylex.o  -L/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/host/lib -L/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/host/usr/lib -lm
./stage1flex   -o stage1scan.c ./scan.l
Makefile:1689: recipe for target 'stage1scan.c' failed
make[6]: Leaving directory '/datadisk/Projekte/R2/bpi-r2_lede/build_dir/host/flex-2.6.4/src'
Makefile:539: recipe for target 'all' failed
make[5]: Leaving directory '/datadisk/Projekte/R2/bpi-r2_lede/build_dir/host/flex-2.6.4/src'
Makefile:525: recipe for target 'all-recursive' failed
make[4]: Leaving directory '/datadisk/Projekte/R2/bpi-r2_lede/build_dir/host/flex-2.6.4'
Makefile:28: recipe for target '/datadisk/Projekte/R2/bpi-r2_lede/build_dir/host/flex-2.6.4/.built' failed
make[3]: *** [/datadisk/Projekte/R2/bpi-r2_lede/build_dir/host/flex-2.6.4/.built] Error 2
make[3]: Leaving directory '/datadisk/Projekte/R2/bpi-r2_lede/tools/flex'
tools/Makefile:148: recipe for target 'tools/flex/compile' failed
make[2]: Leaving directory '/datadisk/Projekte/R2/bpi-r2_lede'
tools/Makefile:146: recipe for target '/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.tools_compile_yynyyyyynyyyyynyynnyyyynyyyyyyyyyyyyyyynyynynnyyynny' failed
make[1]: *** [/datadisk/Projekte/R2/bpi-r2_lede/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.tools_compile_yynyyyyynyyyyynyynnyyyynyyyyyyyyyyyyyyynyynynnyyynny] Error 2
make[1]: Leaving directory '/datadisk/Projekte/R2/bpi-r2_lede'
/datadisk/Projekte/R2/bpi-r2_lede/include/toplevel.mk:207: recipe for target 'world' failed
Try without optimization (-O0 instead of 2) and -Wall to show all warnings
Hi Roy1
I’ve same problem. Would you teach me how to change flex 2.6.4 to 2.6.3?
Thanks
This seems to be fixed up stream. I applied this patch and flex compiled successfully https://bugs.openwrt.org/index.php?do=details&task_id=1003
