I am trying to use multiple BPI-R2 devices aggregated together in a long string (lan3 of one connected to wan of the next), and the linux software bridge between wan/lan3 seems to be incorrectly forwarding LLDP frames. I’ve also tried lan0/lan3 with the same effect.
I am changing mac addresses in software using the macchanger -e utility. I am not making the change in the kernel .dtb file, so they boot with the same mac addresses.
The following post online is a good outline explaining how LLDP frames are not supposed to be transmitted across 802.1D compliant software bridges, so that devices can find their direct/nearest neighbor:
In the article, they are trying to override this behavior–which makes sense for certain virtual environments. However I’m having the opposite problem, and want it to behave as specified in 802.1D.
I am using the frank-w 4.14.141-bpi-r2-main kernel.
Here is my netplan file:
network:
version: 2
renderer: networkd
ethernets:
eth0: { dhcp4: no }
eth1: { dhcp4: no }
wan: { dhcp4: no }
lan0: { dhcp4: no }
lan1: { dhcp4: no }
lan2: { dhcp4: no }
lan3: { dhcp4: no }
bridges:
br0:
interfaces: [ lan0, lan3 ]
addresses: [ 192.168.2.103/24 ]
gateway4: 192.168.2.1
If unfamiliar with netplan, here are other outputs:
ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether 00:02:02:e9:c2:34 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether 00:03:03:8e:07:15 brd ff:ff:ff:ff:ff:ff
4: wan@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
link/ether 00:03:03:88:dc:30 brd ff:ff:ff:ff:ff:ff
5: lan0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP mode DEFAULT group default qlen 1000
link/ether 00:02:02:9b:64:fd brd ff:ff:ff:ff:ff:ff
6: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
link/ether 00:02:02:76:5b:a2 brd ff:ff:ff:ff:ff:ff
7: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
link/ether 00:02:02:5c:dd:59 brd ff:ff:ff:ff:ff:ff
8: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
link/ether 00:02:02:8c:7d:df brd ff:ff:ff:ff:ff:ff
9: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
link/ether 8e:b9:7b:fd:dd:f9 brd ff:ff:ff:ff:ff:ff
ip addr
inet6 ::1/128 scope host
inet6 fe80::202:2ff:fee9:c234/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
inet6 fe80::203:3ff:fe8e:715/64 scope link
4: wan@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000
5: lan0@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
6: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
7: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
8: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN group default qlen 1000
9: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.2.103/24 brd 192.168.2.255 scope global br0
inet6 fe80::8cb9:7bff:fefd:ddf9/64 scope link
brctl show
bridge name bridge id STP enabled interfaces
br0 8000.8eb97bfdddf9 no lan0
lan3
wan
