[BPI-M3] New image: Android 5.1 (Version:V4) 2017-01-10
(BPI_Justin) #1
Android 5.1 2017-01-11 for BPI-M3
Release Note:
  1. WIFI can’t boot issue - Fixed
  2. Power consumption issue - Fixed
  3. Google service - Supported
  4. Android 5.0 - Optimized
HDMI-Version
Google Drive: https://drive.google.com/open?id=0B_YnvHgh2rwjMVFnQzRhTmM5Q0U
Baidu Cloud: https://pan.baidu.com/s/1sl6fXBv
MD5: 85915509ad849fc7fa28bcaf0528e877
LCD-Version
Google Drive: https://drive.google.com/open?id=0B_YnvHgh2rwjazUxenhSVnllaDQ
Baidu Cloud: https://pan.baidu.com/s/1jIK7wAq
MD5: feada8d6ee0ae29a30d1aa1b1be40472
Banana Pi M3 Android 5.1 Lollipop V4 (BPi-M3):
Banana Pi M3 - Reanálise da placa com Android 5.1!!!
[BPI-M3] New image: Android 5.1 (Version:V5) 2017-05-11
A little issue with Android 5.1 V4 and power down mode
(jdredd34) #2
Very good to see! Will be checking this out very shortly.
(jdredd34) #3
Loaded and running… just onboard WIFI not working :frowning: See’s my networks, just never connects. Worked well for a few days on last version and then quit working and never get to work again. Only can configure it and never establish a connection. SItting in same room as router.
(jdredd34) #4
Using ethernet it works well. Smoother… maybe a bit snappier maybe in some spots?
Still can’t get wifi to work.
Google App store worked. It had to download update to it but that wasn’t a big deal.
Installed a few apps that worked. Good old Netflix still a pain. Black screen with audio :cry:
My app worked still.
I have the old board with the USB power. Using usb brick 3amp to power this and it is been pretty happy.
#5
So, with which LCD screen is the “LCD-Version” supposed to work?
(bpi team) #6
we test this LCD screen https://bananapi.gitbooks.io/bpi-accessories/content/en/bpi70lcdtouchpanel.html
#7
@Justin: What about real FullHD (not upscaled from HD) screen resolution and BlueTooth (for music streaming)? Working or not? https://play.google.com/store/apps/details?id=com.nomone.resolution_changer update on FullHD: it’s hilarious, you can get FullHD (1920x1080) by an APK called NOMone Resolution Changer.
However font rendering is blurry then. Take care, do not fiddle around to much (trying randomly all the rez settings). Make backup, as it fucked up my system yesterday. System is back, and a setting that actually works with Nomone app: 1920x1080, 200dpi instead of the default 1280x720, 160dpi.
@Justin, NO ANSWER IS ALSO AN ANSWER FROM YOU BANANAPI SUCKERS. WHEN I SUM UP MY EXPERIENCE WITH YOU I NEVER WOULD RECOMMEND TO BUY ANY OF YOUR PAPERCLIP PRODUCTS AGAIN.
#8
Try change option router -> operating frequency ->“channel one”
#9
Still no source shared so we can make some changes? :frowning:
(Tonio Dev) #10
@BPI_Justin @sinovoip Wifi and Bluetooth does not work on this version. I could get the wifi to work on V3. I restarted several times but no luck. I have a 5V / 3A adapter and image is on EMMC. SD card slot empty.
Any idea ? Help please.
