[BPI-M3] BPI RGB&1602 Module and how to use
OS: BPI-M3 Ubuntu15.10 (Kernel3.4) Version: 1.0 HDMI
Step 1: Download WiringPI
$ git clone https://github.com/BPI-SINOVOIP/BPI-WiringPi.git1 -b BPI_M3 $ cd BPI-WiringPi $ chmod +x ./build $ sudo ./build
Step 2 : Copy smaple code to 1602.c file
$ sudo vi 1602.c
Step 3 : Compile 1602.c
$ gcc -o 1602 1602.c -l wiringPi -lpthread -lwiringPiDev
Step 4: Run 1602
$ sudo ./1602
Video Demo:
Sample Code:
#include <stdio.h>
#include <wiringPi.h>
#include <pthread.h>
#include <mcp23017.h>
#include <lcd.h>
#include <time.h>
int page=3;
int select=1;
int display;
int color=0;
pthread_t id;
void show()
    time_t timep;
    struct tm *ptm;
    digitalWrite ( 113, LOW);
    digitalWrite ( 114, LOW);
    digitalWrite ( 115, LOW);
    lcdPosition(display,0,0);
    switch(page)
        case 0:
            if (select==1)
                lcdPrintf(display,">>1.System Time ");
                lcdPrintf(display,"  2.LED RGB ");
            else
                lcdPrintf(display,"  1.System Time ");
                lcdPrintf(display,">>2.LED RGB ");
            break;
        case 1:
            time(&timep);
            ptm=localtime(&timep);
            lcdPrintf(display,"   %04d/%02d/%02d   ",1900+ptm->tm_year, 1+ptm->tm_mon, ptm->tm_mday);
            lcdPrintf(display,"    %02d:%02d:%02d    ",ptm->tm_hour, ptm->tm_min, ptm->tm_sec);
            break;
        case 2:
            lcdPrintf(display," **LED RGB**");
            lcdPrintf(display,"     Color: %d   ",color);
            digitalWrite ( 113, color&0x01);
            digitalWrite ( 114, color&0x02);
            digitalWrite ( 115, color&0x04);
            color=(color+1)%8;
            delay(400);
            break;
        case 3:
              lcdPrintf(display,"RGB&1602 Module ");
              lcdPrintf(display,"for BPI-M3 ");
            break;
    delay(100);
void key(void)
    int i;
    while(1)
        for(i=108;i<113;i++)
            if (digitalRead(i)>0)
                switch(i)
                    case 108:
                        page=0;
                        break;
                    case 109:
                        select=select%2+1;
                        break;
                    case 110:
                        page=3;
                        break;
                    case 111:
                        page=select;
                        break;
                    case 112:
                        select=select%2+1;
                        break;
                delay(400);
        delay(100);
int main()
    wiringPiSetup();
    mcp23017Setup (100, 0x20);
    pthread_create(&id,NULL,(void *)key,NULL);
    digitalWrite(107,1);
    digitalWrite(101,0);
    display=lcdInit(2,16,4,100,102,103,104,105,106,0,0,0,0);
    lcdHome(display);
      for(int i=0;i<16;i++)
          pinMode(100+i,OUTPUT);
    while(1)
        show();
more information:
https://bananapi.gitbooks.io/bpi-accessories/content/lcd1602displaymodule.html
I have just bought the RGB&1602 module and tested the above c program on my BPI-M3 running on Ubuntu 16.04. It does not work, the LCD kept showing garbages and the RGB light keep changing colors. Is there any wrong there ?
