BPI M2M V1.1 is unable to boot
(Jagan Teki) #1
I have BPI M2M V1.1 A33 based board, which I can see any logs on the debug uart and no image on LCD7. I’m using the images from this link.
Note: the same board I have seen uart log with Mainline U-Boot.
Any help.
(ZB) #2
sorry, could you please provide me log info?
(Jagan Teki) #3
I couldn’t see any log on the console. attached is my setup.
(ZB) #4
Did you connect the right pins?
http://wiki.banana-pi.org/Banana_Pi_BPI-M2M#GPIO_PIN_define
(Jagan Teki) #5
Yes, you can see above diagram that I attached, Black - ground, Green - TX, Yellow - RX even I swap TX and RX.
