BPI -M2 Zero + Ultra Camera (OV5640) Modprobe: Fatal Module not found
HI
I am complete noob, I installed: 2017-12-04-Armbian_5.36_Bananapim2zero_Ubuntu_xenial_next_4.14.3_desktop_preview_build_by_bpi.img as my flash.
I am trying to install (.ov5640) ultra camera onto my Banana pi BPI_M2 zero. I run the sudo modprobe ov5640 command and then get
modprobe: FATAL: Module ov5640 not found in directory /lib/modules/4.14.3-sunxi
please could someone tell me what is wrong
CSI / VFE is not ready on kernel 4.14.x, you need to use kernel 3.4.x
Thank you for your reply. I installed kernel 3.4.x as suggested.
I then ran following commands;
sudo modprobe ov5640 sudo modprobe sun8i_csi0
The first command ran with no error but second command gives error: fatal: module not found in /lib/3…4.x-sun8i
I have also tried sudo modprobe sun8i_csi and sudo modprobe sun8i_csi
First thing to check is if your Image has support for Camera (OV5640), that means the script.bin has OV5640 setup in it. I believe the MATE Image with the right bpi-tools will load OV5640/CSI at the boot time.
There is no sun8i_csi module and a load of the following modules would suffice to have camera working IF script.bin has ov5640 configuration:
   ov5640
   vfe_v4l2
You can check that after loading the two modules:
dmesg|grep ov
dmesg|grep OV
dmesg|grep VFE
if you don’t see error then you have success and can use your camera
BPI-M2 ZERO - CSI camera
$ dmesg | grep OV [ 9.147594] [OV5640@lex]init_sensor - frame_rate: 0, max_win_size: 11 [ 9.252262] [OV5640@lex]CSI_SUBDEV_PWR_ON! [ 9.331910] [OV5640@lex]sensor_init 0x0 [ 9.380640] [OV5640@lex]CSI_SUBDEV_PWR_OFF!
Very nice!
Do you plan to make you hardware extension available? If you do, please, reverse the reversed CSI pin at the sensor end and we can have a professional solution (more camera lens) and by the photos seems you plan night vision?
