BPI-M2 Zero runs as wifi accsess point?
Hello,
has anyone ever realized a WiFi accsess point with the M2 zero? I want to connect this accsess point to the mobile Internet of a USB Dongel.
With a RPI 3 I have already done this and now I want to do this with the BPI M2Zero. Does anyone have any experience with this?
Kind regards,
Christof
Using hostapd 99,9% probabli yes.
I try if you need.
I also tried on BPI-M2 Zero with hostapd.conf as:
ctrl_interface=/var/run/hostapd interface=wlan0 driver=nl80211 ssid=well-B5096728 hw_mode=g channel=2 wmm_enabled=0 macaddr_acl=0 auth_algs=1 wpa=2 wpa_passphrase=mypass wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP CCMP rsn_pairwise=CCMP
but no AP visible… Any help would be appreciated.
RZ
Have same problem, tried on raspbian(not visible), ubuntu(driver not working), armbian(not visible). Also we have wifi antena
