BPI-M2 Ultra new image:ubuntu-16.04.1-mate-desktop-preview3-bpi-m2u-sd-emmc.img 2016-11-29
2016-11-29-ubuntu-16.04.1-mate-desktop-preview3-bpi-m2u-sd-emmc.img.zip
  1. based on ubuntu 16.04.1 LTS Mate Desktop
  2. BPI-M2U kernel 3.10.65
  3. username & password: pi/bananapi , root/bananapi
  4. support LCD 7"
  5. support HDMI 1080P & 480P & 720P (default)
  6. support GMAC
  7. support WIFI
  8. support BT (with bluetoothctl can setup)
  9. support SATA
  10. support eMMC (support boot from eMMC)
  11. support Battery
  12. support IR (getevent can test)
  13. support touch screen (can control desktop or getevent to test) 13 support power key (getevent can test)
  14. support OTG & adbd (default on)
  15. support CAMERA ov5640 (tinacameratest app support photo / video H.264 hw encode)
  16. support uEnv.txt to fatload uImage
  17. support bpi-bootsel to set LCD7 or HDMI (720P & 1080P & 480P)
  18. support bpi-copy to write SD/eMMC with img.zip file
  19. support video play 1080p with vdpau (mpv)
  20. support nodejs
  21. support node-red
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjUWZHd0k3SUl5Mmc/view?usp=sharing
baidu cloud: https://pan.baidu.com/s/1pK7nu3p
MD5: f75fc192b51a438f613445f7482268e7
FILESIZE: 2024712263 (~1931MB) UNPACK: 7456MB (eMMC size)
are there any updates to this? it doesnt work on my unit, the older version does but with glitches.
I am already using this image… just connect a USB Harddrive… setup samba share or nfs share… copy a big amount of data to/from the harddrive… you will see that the device will reconnect as read only on a different device path…
This board, as it is right now, is not usable as a storage server… please prepare a functional kernel… if a device tree for kernel 4.x would be available, I am pretty sure the community would help to fix the rest…
Oh no, I’ve just bought my Ultra and was about to put mate onto it. Realise this is a preview3, but didn’t expect the most simple of operations (copying) to be broke. Is an update/fix coming out soon for this? Who is working on the images? Is raspbian image more stable?
Any comment from the bpi team?
Have been using ubuntu mate for a few days now… seems to lock up or slow down at random. Using the mate desktop and firefox browser seems very laggy… few seconds between tabs… am sure my pi3 is quicker than this. Hope an update comes out soon.
UPDATE - just connected a USB key and it came on with one config under sudo fdisk -l, then a few minutes later it changed to dev/sda and i get this when i try and mount
Failed to mount ‘/dev/sda’: Invalid argument The device ‘/dev/sda’ doesn’t seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
not good.
