BPI-M2 Berry and ResinOS or Minibian
I’m looking for a solution how to install on my BPI-M2 Berry one of the following systems: ResinOS or Minibian.
Maybe somebody can point out the starting point for to do it. I see a list of prepared images for BPI-M2 Berry (http://www.banana-pi.org/m2u-download.html) but what I need to do, if I want to use my board with some other OS?
Thanks.
Hello did anyone found a solution? Maybe telling what other board thats similar to the bpi m2u/berry that is compatible with resinOS/balenaOS
You can try Armbian : https://dl.armbian.com/bananapim2ultra/ I’m using Ubuntu with HDD plugged on the Sata port. SD-card is required for booting but Armbian in running on the HDD. I2C is not working. Forget I2S . Not wired !!
