BPI M1 Plus wifi not working with android
(VIJAY ) #1
Hi All,
I tried Android LCD version image(BananaPi M1-M1P-R1 New Image : android and ubuntu sever Release 2018-07-28) with BPI M1 Plus. Display, touch and other built-in app working fine but wifi is not working. It showing “wifi is turning on” but nothing happens.
=============Configuration===================
[wifi_para]
wifi_used = 1
wifi_sdc_id = 3
wifi_usbc_id = 2
wifi_usbc_type = 1
wifi_mod_sel = 9
wifi_power = “”
; 1 - bcm40181 sdio wifi gpio config
;bcm40181_shdn = port:PH09<1><0>
;bcm40181_host_wake = port:PH10<0><0>
; 2 - bcm40183 sdio wifi gpio config
;bcm40183_wl_regon = port:PH09<1><0>
;bcm40183_wl_host_wake = port:PH10<0><0>
;bcm40183_bt_rst = port:PB05<1><0>
;bcm40183_bt_regon = port:PB05<1><0>
;bcm40183_bt_wake = port:PI20<1><0>
;bcm40183_bt_host_wake = port:PI21<0><0>
; 3 - rtl8723as sdio wifi + bt gpio config
;rtk_rtl8723as_wl_dis = port:PH09<1><0>
;rtk_rtl8723as_bt_dis = port:PB05<1><0>
;rtk_rtl8723as_wl_host_wake = port:PH10<0><0>
;rtk_rtl8723as_bt_host_wake = port:PI21<0><0>
; 4 - rtl8189es sdio wifi gpio config
;rtl8189es_shdn = port:PH09<1><0>
;rtl8189es_wakeup = port:PH10<1><1>
; 5 - rtl8192cu usb wifi
; 6 - rtl8188eu usb wifi
; 7 - ap6210 sdio wifi + bt gpio config
ap6xxx_wl_regon = port:PH22<1><0>
ap6xxx_wl_host_wake = port:PH15<0><0>
;ap6xxx_bt_regon =
;ap6xxx_bt_wake =
;ap6xxx_bt_host_wake =
==========Init.rc File==============
#2. broadcom wifi service
#2.1 broadcom wifi bcm40181 bcm40183 station and softap
 service wpa_supplicant /system/bin/wpa_supplicant \
-iwlan0 -Dnl80211 -c/data/misc/wifi/wpa_supplicant.conf \
-I/system/etc/wifi/wpa_supplicant_overlay.conf \
-O/data/misc/wifi/sockets \
-e/data/misc/wifi/entropy.bin -g@android:wpa_wlan0
#   we will start as root and wpa_supplicant will switch to user wifi
#   after setting up the capabilities required for WEXT
#   user wifi
#   group wifi inet keystore
class main
socket wpa_wlan0 dgram 660 wifi wifi
disabled
oneshot
#2.2 braodcom wifi sta p2p concurrent service
 service p2p_supplicant /system/bin/wpa_supplicant \
-O/data/misc/wifi/sockets -N \
-ip2p0 -Dnl80211 -c/data/misc/wifi/p2p_supplicant.conf \
-I/system/etc/wifi/p2p_supplicant_overlay.conf \
-puse_p2p_group_interface=1 -e/data/misc/wifi/entropy.bin \
#   user wifi
class main
disabled
oneshot
same configuration is working with Lemaker Banana Pro image (Android 4.2) Can anybody please suggest, what is going wrong?
Thanks in advance,
Regards, Vijay
